  3. Anyone tried the Creality CR-10 3D printer?
104 Posts 12 Posters 33.1k Views 10 Watching
  • P pjr
    @dbemowsk There is one example: Anet A2 dual Z single motor
    mbj
    @pjr I guess the trick is to find a closed loop belt of suitable length and also make a screw design which can move enough sideways to tighten the belt.
    dbemowskD 1 Reply Last reply
    • M mbj
      dbemowskD
      dbemowskD
      @mbj It would have to tighten and also not cause any binding of the Z axis during travel. I have see belt tensioner springs that snap on to the belt, but with this needing to be continual rotation, that wouldn't work.
      gohanG 1 Reply Last reply
      • dbemowskD dbemowsk
        @dbemowsk I think that if pretty much nobody is doing that kind of setup, I guess the technical complications kind of outweight the benefits of using a single motor for Z axis, don't they?
        • E
          E
          executivul
          Tevo Black Widow uses a single z stepper with 2 screws.
          • P
            P
            pjr
            @dbemowsk there is the same with tensioning with motor: Tevo Tarantula Single Motor Dual Z Axis
              #75
              I'm in the middle of putting the Prusa IS3 MK3 together, and it is a lot of assembly. If it's true that the CR-10 can be put together in half an hour, then that's really quite impressive.
              dbemowskD gohanG 2 Replies Last reply
                dbemowskD
                dbemowskD
                @neverdie If it is anything like my Anet A8, mine took quite a few hours to put together. It looks like the MK3 has an all or at least mostly metal frame which is nice. The frame on min is laser cut acrylic and one of the big things with that is that the acrylic comes with a protective paper coating which needed to be peeled off prior to assembly. That part took over an hour in itself and was a pain.
                  @neverdie the frame comes assembled is 2 pieces plus the control unit, so it is a matter of a few bolts and connecting the wires, nothing more.
                    #78
                    Attached is a photo of the benchy that was printed in PLA from a file that came 0_1524851107876_benchy.jpg
                    on the Prusa I3 MK3 SD Card. Not perfect, but I guess about par for a hobbyist 3D printer.
                      Nice, a little stringing that you can solve with minor tweaks. What happened to the chimney?
                        #80
                        @gohan said in Anyone tried the Creality CR-10 3D printer?:
                        Heck if I know. This is only the second object I've ever printed. However, if I had to guess, I'd guess that it's an artifact of the way it was sliced.
                        Presently I'm printing the Andreas Spiess power meter case: https://www.thingiverse.com/thing:2789890/#files
                        Just for the box itself, not even including the lid, the estimated print time is over 5 hours! So maybe when the megavolcano hot end comes out, I'll look into getting one.
                          What layer hight did you use?
                            dbemowskD
                            dbemowskD
                            @gohan Sound like it was a gcode file on the SD card, so my guess is that he didn't slice it and may not know.
                            • dbemowskD
                              dbemowskD
                              A note though if you are looking at choosing a slicer. For most of the time that I owned my 3D printer I was using Cura as my slicer. I have recently done some things using Slic3r and I find that it has a lot more options and does an overall better job at slicing. I also recommend a rapberry pi running octoprint.
                                @dbemowsk Presently using https://prusacontrol.org/ , which is a simplified version aimed at fresh noobs like me. I used it to generate the gcode for the Andreas Spiess power meter case (referenced above).,
                                  #85
                                  Are any of the available printer filaments odor free? The free roll of Prusa PLA that came with my kit doesn't smell very good when printing with it.
                                  I just now ordered: https://www.amazon.com/gp/product/B00MB3CV6K/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
                                  which claims to be "odor free." Well, here's hoping it is. ;)
                                  dbemowskD NeverDieN 2 Replies Last reply
                                    dbemowskD
                                    dbemowskD
                                    @neverdie said in Anyone tried the Creality CR-10 3D printer?:
                                    I myself have not tried any that are completely odor free. I haven't had too much trouble with the PLA that I have used, and I have tried a number of different brands. ABS smells a lot worse than PLA.
                                      @dbemowsk I was referring to the box he was printing, maybe a thicker layer would cut the print time since he doesn't need to have fine details on the box
                                        dbemowskD
                                        dbemowskD
                                        @gohan I see. I thought you were referring to his benchy.
                                        • E
                                          E
                                          executivul
                                          PLA smells like hot popcorn/cooking oil, it's corn based afterall
                                          ABS smells bad and it's a little toxic
                                          PETG is almost odourless, very resistent, easy to print, doesn't warp or shrink when cooling
                                          Best slicer: Simplify3D
