  2. Announcements
  3. 2.0 Discussion: Units, sensor types and protocol
170 Posts 23 Posters 118.9k Views 7 Watching
  • Z Zeph
    If there is interest in using somewhat of a standard rather than rolling our own (and I think a case could be made either way), it would be worth reviewing the IoTDB effort which is also trying to describe the semantics of sensor/actuator control. For example:
    https://iotdb.org/pub/iot-attribute.html
    Thanks interesting reading.
    • daulagariD
      daulagariD
      daulagari
      Yes, indeed interesting reading also in the light of controllers.
      • L
        L
        lunarok
        Please to see this post. As our plugin for Jeedom is complet now, I have some feedback to share.
        First, is there a date and status of version 2 for now ?
        Here my thoughs :
        • about units, I agree with the fact that it's lightier to have the Arduino not taking care of it, but instead use some conversion on the controller side
        • about value types, it will be better to have really type and not a notion of unit sometime here too like for power get only consuption and not kwh, really going all the way and give the unit control to the controller
        • about value types and sensor types, after writing the plugin, still weird for me to have a sensor presentation giving some clue on what type it is, but need to wait for some value to be sure. I mean power sensor for exemple that can get some different type of values, this is not really clean I think. Or the weather sensor, in one case it will send a value type that is numeric, the other one is text (forecast)
        • will it not be better to have some mechanism when it's an actuator to deliver the type of message it is accepting ? for exemple a heater, there is the off/on but also a mode type. How is it possible to know that the sensor is accepting all or only on/off ?
        So, for me, something like after a presentation being able on the controller to say what type of data and what commands we can say, will be the best. And important too, what data it can be requesting. I mean, now with the scene_controller to extend functions, we need to get data from the automation software too. Imagine to display some informations from outside the mySensors network.
        Maybe by completing the sensor_type and merging with value_types, removing the unit notion inside the value. And so during presentation we know all about the data it can send. And in second step during presentation, declare the actuator commands.
        One other point important and asked by some users, is it possible to integrate some security in the protocol ? As soon you talk about actuator accepting command from anyone, that's unsecure. Key given during inclusion by gateway and use for encode the data ?
        Thanks for reading
        Cédric
        • AnticimexA
          AnticimexA
          Anticimex
          About security, I'm looking into that. I am working on a concept involving key exchange and signing using an external circuit.
          • L
            L
            lunarok
            Yes for security can be also a first presentation requiring a signing. Like what Puppet is doing, agents first present themself to the master, master is waiting for someone to accept a request, and after it gives the certificate to the client and then the client tell him verything about itself (facts in this view can be compared to the sketch and sensors presentation)
            But I don't know if it's easy with arduino this type of exchange.
            Other way can be a simple key we put in sketchs, and using the same on every of our home, and use it in the lib to encode the data.
            • AnticimexA
              AnticimexA
              Anticimex
              I am working on a security protocol, and have posted my take on things in the security thread. I will weigh in on this thread once I have verified my design, but so far, only two new message types should be needed, one to request security capabilities and once for capabilities and a nonce. I do not think software based security is a suitable solution due to memory constraints so I am going for a hardware based solution with a pre-shared key. I will publish more concrete examples once I have verified them.
              • L
                L
                lunarok
                Is there any move on the V2 ? Can we see the actual status and what it is going to look like ?
                Going to a V2 for the Jeedom controller, will like to see it coming with mySensors v2 changes.
                Precisly will like to have a status about :
                • reboot of node without needing a special bootloader (inside the lib will be the best)
                • sending libversion from presentation including for gateway (this is include for nodes, I don't know for gateway)
                • possible of sending V_type used during presentation, no need to wait to send data
                • possible of sending a short desc name for each sensors created (can be helpfull when you create many sensors with same type and the difference is not only the order)
                • possible to send the power source of node, I don't know inside battery or else. This will be very helpful with battery/plug or battery/solar source for exemple. So we can know how much the battery is full but also if the sensor is actually on battery.
                • getConfig to be used for any paramteres instead of units, like this the node can request parameters from the conrtoler (think about a global sketch for a switch that can talk to a relay node, by the controller side you set which node it's controling)
                Can we have a wiki page maybe with an actual status of where is the V2 ? And is there a dev version we can try ?
                hekH 1 Reply Last reply
                • L lunarok
                  There has been some delays due to workload. But i hope to finish it eventually. :)
                  Not sure it is possible to reboot an arduino without watchdog enabled (anyone knows any tricks?).
                  Yep, possible to get version from gateway today.
                  There will be a different setup.
                  Good idea! I'll take that into consideration.
                  Thats also a good idea. I'll have to think about how it could be incorporated.
                  Config/settings will be a bit different as well.
                  Hmm.. my github account (henrikekblad) will contain the source until I feel it's worth trying out by the community. But there is a part of it I'm waiting for a c++ guru at work helping out with (advanced c++ templating which is a bit over my level of c++ knowledge). Those will hopefully make callbacks (incoming messages) usage awesome.
                  The plan is the gateway will be able to accept/push json objects instead of the semicolon separated parameters, Much depends on how memory demanding it becomes.
                  axillentA 1 Reply Last reply
                    axillentA
                    axillentA
                    axillent
                    can we avoid float?
                    instead of float a multiplied integer can be used
                    for example 34.6 C temperature can be presented as 346 (no dot)
                    a single float operation increase HEX size significantly
                    @hek what about idea we discussed to have a network with multiple gateways?
                    what about adding support for the 2.0 for the nodes be able to have a different BASE address per each gateway?
                    this way the future network will allows to have 255 sensors per EACH gateway, not per NETWORK
                    sense and drive
                    • axillentA axillent
                      can we avoid float?
                      @axillent
                      Yes, configurable base address would be handy if we choose to create an ESP-gateway. It is already supported today but you have to hard code it into MyConfig.h. Would be neat to have this configurable over WiFi.
                      Using OTA transmitted floats is optional. I haven't looked so deeply on how/if this will be supported yet in the upcoming version.
                      • tekkaT
                        tekkaT
                        tekka
                        Any plans for encryption?
                        AnticimexA 1 Reply Last reply
                        • AnticimexA
                          AnticimexA
                          Anticimex
                          • daulagariD
                            daulagariD
                            daulagari
                            what benefit is there from encryption vs signing in the MySensors case?
                            If you have a lock or door sensor do you want others to know when it is opened or closed?
                            Signing is quite expensive if you look at additional payload size, you need a big counter to prevent replay and a big MAC to prevent attacks. I think that when encrypting things you can do it with the same additional payload and maybe even a less.
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              • daulagariD
                                daulagariD
                                daulagari
                                Yes, signing, when properly done, is for sure a good begin.
                                How many bytes are you using for the truncated MAC and nonce?
                                The AES block size is 128 bytes, so 16 bytes so I do not see why that would not fit.
                                Encryption is already some kind of authentication is a sense that if you can successfully decode the message you can be sure that the other side knows the shared secret, just like in the cause of your SHA25-HMAC.
                                • daulagariD
                                  daulagariD
                                  daulagari
                                  Would be good to move the last five message into a separate thread...
                                  • AnticimexA
                                    AnticimexA
                                    Anticimex
                                    • AnticimexA
                                      AnticimexA
                                      Anticimex
                                      • AnticimexA Anticimex
                                        [[topic:post-is-deleted]]
                                        I'm afraid I can only fork a topic int two threads. Haven't found a way to move posts to another thread/topic.
                                        • AnticimexA
                                          AnticimexA
                                          Anticimex
