  2. Announcements
  3. 2.0 Discussion: Units, sensor types and protocol
170 Posts 23 Posters 118.9k Views 7 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    I am working on a security protocol, and have posted my take on things in the security thread. I will weigh in on this thread once I have verified my design, but so far, only two new message types should be needed, one to request security capabilities and once for capabilities and a nonce. I do not think software based security is a suitable solution due to memory constraints so I am going for a hardware based solution with a pre-shared key. I will publish more concrete examples once I have verified them.
    • L
      L
      lunarok
      Is there any move on the V2 ? Can we see the actual status and what it is going to look like ?
      Going to a V2 for the Jeedom controller, will like to see it coming with mySensors v2 changes.
      Precisly will like to have a status about :
      • reboot of node without needing a special bootloader (inside the lib will be the best)
      • sending libversion from presentation including for gateway (this is include for nodes, I don't know for gateway)
      • possible of sending V_type used during presentation, no need to wait to send data
      • possible of sending a short desc name for each sensors created (can be helpfull when you create many sensors with same type and the difference is not only the order)
      • possible to send the power source of node, I don't know inside battery or else. This will be very helpful with battery/plug or battery/solar source for exemple. So we can know how much the battery is full but also if the sensor is actually on battery.
      • getConfig to be used for any paramteres instead of units, like this the node can request parameters from the conrtoler (think about a global sketch for a switch that can talk to a relay node, by the controller side you set which node it's controling)
      Can we have a wiki page maybe with an actual status of where is the V2 ? And is there a dev version we can try ?
      hekH 1 Reply Last reply
      • L lunarok
        There has been some delays due to workload. But i hope to finish it eventually. :)
        Not sure it is possible to reboot an arduino without watchdog enabled (anyone knows any tricks?).
        Yep, possible to get version from gateway today.
        There will be a different setup.
        Good idea! I'll take that into consideration.
        Thats also a good idea. I'll have to think about how it could be incorporated.
        Config/settings will be a bit different as well.
        Hmm.. my github account (henrikekblad) will contain the source until I feel it's worth trying out by the community. But there is a part of it I'm waiting for a c++ guru at work helping out with (advanced c++ templating which is a bit over my level of c++ knowledge). Those will hopefully make callbacks (incoming messages) usage awesome.
        The plan is the gateway will be able to accept/push json objects instead of the semicolon separated parameters, Much depends on how memory demanding it becomes.
        axillentA 1 Reply Last reply
          axillentA
          axillentA
          axillent
          can we avoid float?
          instead of float a multiplied integer can be used
          for example 34.6 C temperature can be presented as 346 (no dot)
          a single float operation increase HEX size significantly
          @hek what about idea we discussed to have a network with multiple gateways?
          what about adding support for the 2.0 for the nodes be able to have a different BASE address per each gateway?
          this way the future network will allows to have 255 sensors per EACH gateway, not per NETWORK
          sense and drive
          • axillentA axillent
            can we avoid float?
            @axillent
            Yes, configurable base address would be handy if we choose to create an ESP-gateway. It is already supported today but you have to hard code it into MyConfig.h. Would be neat to have this configurable over WiFi.
            Using OTA transmitted floats is optional. I haven't looked so deeply on how/if this will be supported yet in the upcoming version.
            • tekkaT
              tekkaT
              tekka
              Any plans for encryption?
              AnticimexA 1 Reply Last reply
              • AnticimexA
                AnticimexA
                Anticimex
                • daulagariD
                  daulagariD
                  daulagari
                  what benefit is there from encryption vs signing in the MySensors case?
                  If you have a lock or door sensor do you want others to know when it is opened or closed?
                  Signing is quite expensive if you look at additional payload size, you need a big counter to prevent replay and a big MAC to prevent attacks. I think that when encrypting things you can do it with the same additional payload and maybe even a less.
                  • AnticimexA
                    AnticimexA
                    Anticimex
                    • daulagariD
                      daulagariD
                      daulagari
                      Yes, signing, when properly done, is for sure a good begin.
                      How many bytes are you using for the truncated MAC and nonce?
                      The AES block size is 128 bytes, so 16 bytes so I do not see why that would not fit.
                      Encryption is already some kind of authentication is a sense that if you can successfully decode the message you can be sure that the other side knows the shared secret, just like in the cause of your SHA25-HMAC.
                      • daulagariD
                        daulagariD
                        daulagari
                        Would be good to move the last five message into a separate thread...
                        • AnticimexA
                          AnticimexA
                          Anticimex
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            • AnticimexA Anticimex
                              [[topic:post-is-deleted]]
                              I'm afraid I can only fork a topic int two threads. Haven't found a way to move posts to another thread/topic.
                              • AnticimexA
                                AnticimexA
                                Anticimex
                                • tekkaT tekka
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @tekka Please see the discussion on security.
                                  • L
                                    L
                                    lunarok
                                    A new wish. Possible to have the network gateway listening for nodes also on the ethernet network. Looking for ethernet nodes inside the electric panel. No RF, no security break :)
                                    • axillentA
                                      axillentA
                                      axillent
                                      A support for multi-gateway setup is needed. Currently it is required to hardcode radio-channel or base-address for different segments-different gateways
                                      sense and drive
                                        marceloaqno
                                        Code Contributor
                                        There is a solution for multi-gateway that I'm working to port it to the development branch which could use the same radio channel and also to have sensors at gateway node.
                                        • M marceloaqno
                                          axillentA
                                          axillentA
                                          axillent
                                          @celonunes what kind of a solution it will be?
                                          will it be possible to route messages between nodes managed by different gateways?
                                          sense and drive
