  3. Sensor taking the status of a blinking led of an alarm system
19 Posts 6 Posters 8.2k Views 3 Watching
    Meister_Petz
    my alarmsystem does not tell anything else about the status then blinking an led.
    LED Blinking: Alarmsystem active (1 Sec. on, 1 Sec off,...)
    LED OFF: Alarmsystem deacticated
    I would like to read this blinking led with a light sensor and send the status "active" or "inactive" to my controller.
    Any idea how the code could look?
    many thanks
    Petz
      Meister_Petz
      Ok, I'm going to do it like this:
      Taking a Photoresistor and taking readings vor 10 sec. after that I sum up all readings. If light was blinking the sum is much higher than if not blinking and so I determine the status. Active - not Active. Done
      • T
        Tibus
        It depend if it's in battery or not. If not on battery you can save de "millis()" of each turn on and if the curent millis()-lastTurnOn >5000 your led do not turn on since 5seconds. Of you can also add an interrupt on the photoresistor, save the millis, go to sleep with the interrupt and à timer. Each interrupt will update the current millis and if you don't have a interrupt for 5secinds, the sleep timer will wake the arduino and the same calcul to know that the millis don't change since 5seconds.
        I don't know if it's clear ;D?
        • M Meister_Petz
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @Meister_Petz
          I would open the alarm interface and solder in a couple of small wires... you don't want any ambient light n the photocell and covering the led seems ugly...
          then use the method @Tibus mentioned... use an interrupt on CHANGE and a timer to transmit off status if the timer expires.
          It think it would be prettier and more reliable. If you are living with a spouse or significant other, you will see the benefits!
          PS you can power the whole thing from the alarm interface ... try checking the power voltage to the interface. all you need is at least 3V3 and a few caps. you may be able to fit the pro-mini and the radio inside the interface!
            Meister_Petz
            @Tibus
            being new at programmig for arduino, I'm not really sure how to put this into code :-(
            could you give me an code example how you do that?
            @BulldogLowell
            I agree! When the warranty runs out, I'll take the opening and soldering approach ;-) But even at the moment it's not that bad, because the Alarmterminal is hidden and for switching it on, I use my controller.
            Many thanks for your help!
            Petz
            • M Meister_Petz
              @Tibus
              @BulldogLowell
              Petz
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @Meister_Petz
              if you need it to run on battery, then you may not want to bother with sleep, since you are looking for the non-occurrence of something. ;)
              the interrupt method will wake the MCU every time the led flashes...
              you could start with code like this (untested):
              EDITED
              typedef enum{
                NOT_ARMED = 0, ARMED
              AlarmState;
              AlarmState state;
              AlarmState lastAlarmState;
              unsigned long lastFlashTime;
              #define DIGITAL_INPUT_SENSOR 3   // The digital input you attached your light sensor
                gw.begin();
                gw.sendSketchInfo("Motion Sensor", "1.0");
                delay(1000);
                gw.present(CHILD_ID, S_MOTION);
                delay(1000);
                // Read digital light sensor value
                if (digitalRead(DIGITAL_INPUT_SENSOR) == HIGH)
                  lastFlashTime = millis();
                  state = ARMED;
                  if (lastAlarmState == NOT_ARMED)
                    gw.send(msg.set(ARMED));  // Send tripped value to gw
                if (lastFlashTime - millis() > 5000UL && state == ARMED) // you may have to adjust... this is 5 seconds
                  state = NOT_ARMED;
                  if (lastAlarmState == ARMED)
                    gw.send(msg.set(NOT_ARMED));  // Send not tripped value to gw
                lastAlarmState = state;
                Meister_Petz
                Many Thanks for the code, I will start to play around asap ;-)
                • M Meister_Petz
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  @Meister_Petz
                  OK, just check the edit... so it is not banging away at your gateway!!!
                    Meister_Petz
                    wrote on last edited by Meister_Petz
                    btw, thats was my working apporach before:
                    is there a nice way to add code? Do I really have to add 4 spaces before every line?
                    • daulagariD
                      daulagariD
                      daulagari
                      Yes, that is the way to format code.
                      But ... knowing some tools there is no need to do it by hand. In vi/vim:
                      :%s/^/    /
                      hekH 1 Reply Last reply
                      • daulagariD daulagari
                        :%s/^/    /
                        wrote on last edited by hek
                        @daulagari
                        or just surround code-block with 3 backtick-characters. This character ----> `
                        #include <hehe.h>
                        printf();
                        • M Meister_Petz
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @Meister_Petz
                          or in your arduino editor, just grab all the code (CTRL+A) and then increase indent twice... on my mack it is (COMMAND+ ]) That moves all the code right four spaces... see below:
                            Meister_Petz
                            MANY THANKS!
                            That is what I did until now without Millis and interupts,...
                            In this code I determine blinks by the difference between 2 following readings. Is there a better way?
                            And I simplified the message sent to the gateway quite a bit. Do I produce any errors with this?
                              /* Small sketch to determine the State of a Olympia Protect Alarmsystem
                              0. When UNARMED   : LED off - DISPLAY off
                              1. When ARMED     : LED blinks
                              2. When ACTIVATING: LED blinks - DISPLAY blinks (check if before State was ARMED)
                              3. When TRIGGERED : LED blinks - DISPLAY blinks (check if before State was ARMED)
                              #define CHILD_ID 3
                              const int phCell1Pin = 0; // Photocell 1 on PIN 0 - Display
                              const int phCell2Pin = 1; // Photocell 2 on PIN 1 - LED
                              const int phCell1Sensitivity = 100; // sets the minimum difference between two readings to determine blinking of Display
                              const int phCell2Sensitivity = 100; // sets the minimum difference between two readings to determine blinking of LED
                              const int sleepTime = 7000; // 7 Sec. between Reading Cycles
                              int armingTime = 30; // Seconds set until arming is done
                              int DisplayState = 0;
                              int LEDState = 0;
                              int AlarmSystemState = 4; // (0 = Off, 1 = On, 2 = Activating, 3 = Triggered)
                              int AlarmSystemStateOld = 0;
                              int myRound1[10] = {0,0,0,0,0,0,0,0,0,0}; // Array to store Readings
                              int myRound2[10] = {0,0,0,0,0,0,0,0,0,0}; // Array to store Readings
                              int goSleep = 0;
                              int i = 0;
                              int i1 = 0;
                              int i2 = 0;
                              void setup(void) {
                                gw.begin();
                                gw.present(CHILD_ID, S_DOOR);
                              void loop(void) {
                                   if (i < 10){ // 10 Readings
                                     myRound1[i] = analogRead(phCell1Pin); // read Photosensor Display
                                     //Serial.print("Display PhCell:"); Serial.println(myRound1[i]);
                                     myRound2[i] = analogRead(phCell2Pin); // read Photosensor LED
                                     //Serial.print("LED     PhCell:"); Serial.println(myRound2[i]);
                                     if (i > 0){ // compare 2 following readings
                                       // Display
                                       if ((myRound1[i] - myRound1[i-1]) > phCell1Sensitivity){i1++;}
                                       if ((myRound1[i-1] - myRound1[i]) > phCell1Sensitivity){i1++;}
                                       // LED
                                       if ((myRound2[i] - myRound2[i-1]) > phCell2Sensitivity){i2++;}
                                       if ((myRound2[i-1] - myRound2[i]) > phCell2Sensitivity){i2++;}
                                     i++;
                                     // Display
                                     if (i1 > 2){ // if there are more than 3 Readings which are assumed blinks - set DisplayState to blink
                                       DisplayState = 1; //Serial.println("Display blinkt - State 1");
                                       DisplayState = 0; // Serial.println("Display dunkel - State 0");
                                     //LED
                                     if (i2 > 2){ // if there are more than 3 Readings which are assumed blinks - set LEDState to blink
                                       LEDState = 1; //Serial.println("LED blinkt - State 1");
                                       LEDState = 0; // Serial.println("LED dunkel - State 0");
                                     goSleep = 1; // now transmit if necessary and wait before starting again
                                     // Reset
                                     i = 0;
                                     i1 = 0;
                                     i2 = 0;
                                   // send to Sleep
                                   if (goSleep == 1){
                                     if (DisplayState == 0 && LEDState == 0){
                                       AlarmSystemState = 0; // OFF
                                     } else if (DisplayState == 0 && LEDState == 1){
                                       AlarmSystemState = 1; // ON
                                     } else if (DisplayState == 1 && LEDState == 1 && AlarmSystemStateOld == 0){
                                       AlarmSystemState = 2; // Actviating
                                       //delay(70000); // wait 70 Seconds until Activating is done
                                     } else if (DisplayState == 1 && LEDState == 1 && AlarmSystemStateOld == 1){
                                       AlarmSystemState = 3; // TRIGGERED
                                      AlarmSystemState = AlarmSystemStateOld;
                                     // Send State change to Gateway
                                     //Serial.print("AlarmSystemState Änderung:");Serial.println(AlarmSystemState);
                                     gw.send(msg.set(AlarmSystemState));
                                     if (AlarmSystemState == 2){ // Delay until Arming is done before next read
                                       armingTime = (armingTime * 1000)+1000;
                                       delay(armingTime);
                                     AlarmSystemStateOld = AlarmSystemState;
                                     delay(sleepTime);
                                     goSleep = 0;
                                     delay(575);
                            • T
                              Tibus
                              why not use sleep. Yes it will wake the MCU every time the led flashes but it 'll consume less power when it sleep. you can go from 7ma to 10ua when it sleep. Even for one seconds it's a benefit no?
                              • brettzky84B
                                brettzky84B
                                brettzky84
                                Why not measure when there is voltage to the led??? Much more reliable and simple
                                • T Tibus
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  @Tibus said:
                                  why not use sleep.
                                  you are correct, of course. I look at it as a two step approach:
                                  1. get it to work
                                  2. get it to work better than before
                                    Meister_Petz
                                    @Tibus
                                    I agree about sleeping. But for one thing I don't have the slightest clue how working with interupts works (yet) and the Arduino is hook on the power of the Alarmsystem ;-)
                                    BTW my Alarmsystem Powersupply produces 6V. Would it make more sense to use a 5V Step Down Regulator and give power to pin 27 (5V) than 6V to PIN 30 (VIN)?
                                    Many Thanks
                                    Petz
                                    • M Meister_Petz
                                      @Tibus
                                      Many Thanks
                                      Petz
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      @Meister_Petz
                                      Pro-Mini? I'd just take the 6V to the RAW pin.
                                      6V to Vin on a nano.
                                        Meister_Petz
                                        Nano - so VIN! Thanks!
