1.1k Posts 105 Posters 796.0k Views 98 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    #539
    One of three ongoing projects:
    lasercut box
    atmega1284p based
    DS3231 rtc (very accurate and 2 alarms!)
    LDR
    20 by 4 LCD, two sizes of numbers, menu driven setup
    buzzer
    leds for moodlighting
    doppler for proximity detection
    encoder for scrolling through values (for setting time)
    buttons with LED feedback for interactivity
    mp3 player
    most interface objects MySensorised :-)
    This entry is to boost my energy, because we are still a long way from home (pcb is still not made, focus is now on prototype and software).
      #540
      I love the design of the air vent on the righthand side of your laesrcut box. Does that pattern have a name?
      GertSandersG 2 Replies Last reply
        GertSandersG
        GertSandersG
        GertSanders
        #541
        @neverdie nope, but it is inspired by oriental frames, I just made that based on what I saw on one of my cabinets (which I bought while living in Singapore).
          GertSandersG
          GertSandersG
          GertSanders
          @neverdie I will publish the project once it has advanced a bit more (still need to design the PCB for this box).
          • sundberg84S sundberg84
            A temp-node on 2xAA. Also a sneak-peak on EasyPCB rev 10...
            https://youtu.be/TxzvhG4uo9I
            mickecarlsson
            @sundberg84 how is the rev10 progress going? I am about to order a batch of EasyPCB but want the new bells and whistles :-)
            • GertSandersG GertSanders
              @gertsanders Cool. You might like this pattern also then:
              dbemowskD GertSandersG 2 Replies Last reply
                dbemowskD
                dbemowskD
                @neverdie That's cool. Kind of like an overlapping honeycomb design.
                • M mickecarlsson
                  sundberg84S
                  sundberg84S
                  #546
                  @mickecarlsson except I have not yet tested the new things on the back (signing and extra flash) the boards are working. I will try to test the last things before May is over and the publish.
                  If you want to order I can offcourse email you the Gerber's but on your own risk.
                  My first experience with the board is that it's performing better than Rev 9 with the new position if the hardware. Also the ground plane helps.
                    GertSandersG
                    GertSandersG
                    GertSanders
                    @neverdie that is a nice pattern. I found that these things need time to draw. If anyone has a DXF file, I would love to try it.
                      mickecarlsson
                      @sundberg84 thanks for the offer, I can wait for the final, no worries. Do you have a list of the new components added on the back?
                      • dbemowskD dbemowsk
                        #549
                        @dbemowsk said in What did you build today (Pictures) ?:
                        Bingo! Looks like that's exactly what it is. A small honeycomb superimposed on a bigger one.
                        dbemowskD 1 Reply Last reply
                          dbemowskD
                          dbemowskD
                          @neverdie I created that basic pattern in OpenSCAD.
                          Here is the scad
                           $fn = 6;
                           fudge = 0.01;
                           pi=3.1415926;
                           large_diameter = 40;
                           circumradius = large_diameter/2;
                           inradius = circumradius/(2*tan(180/$fn))-1;
                           height = 2;
                           line_width = 1;
                           rotate([0, 0, 0]) hollow_cylinder(large_diameter-line_width, height, line_width);
                           for(i=[1:$fn]) {
                               rotate([0, 0, (360/$fn*i)+30]) translate([inradius, 0, 0]) rotate([0, 0, 30]) hollow_cylinder(circumradius, height, line_width);
                           module hollow_cylinder(diameter=10, thickness=2, line_thickness=2) {
                               difference() {
                                   cylinder(thickness, d=diameter);
                                   translate([0, 0, -fudge/2]) cylinder(thickness+fudge, d=diameter-(line_thickness*2));
                          • dbemowskD
                            dbemowskD
                            Expanding on that, I mapped it out further to give people an idea of how it's calculated.
                            And the scad based on my previous post.
                             $fn = 6;
                             fudge = 0.01;
                             pi=3.1415926;
                             height = 2;
                             line_width = 1;
                             for(i=[1:$fn]) {
                                rotate([0, 0, (360/$fn*i)+30]) translate([inradius*2, 0, 0]) rotate([0, 0, 30]) honeycomb();
                             module honeycomb() {
                                 for(i=[1:$fn]) {
                                 difference() {
                            • M mickecarlsson
                              sundberg84S
                              sundberg84S
                              #552
                              @mickecarlsson - sure.
                              Signing: atsha204a (sot-32-3), R4: 1k-100k resistor (0805), C5 0,1uF capacitor (0805)
                              Flash: R7: 56k-100k resistor (0805), C7; 0,1uF capacitor (0805), U5: AT25DF512C or equivalent SPI Serial Flash Memory (8-lead SOIC). I bought this from Germany (but not tested)
                              • sundberg84S
                                sundberg84S
                                #553
                                Yesterday I tested the new EasyPCB with RFM radio and hardware signing. Worked out as expected and I'm going to release all files soon.
                                I haven't tested the flash part yet but I'm hoping this is working as well.
                                This picture will be a part of a new video with me building my new RFM69 serial gateway using signing.
                                Anyone they can guess which issue I had when I took the photo?
                                Rev9 vs Rev10 (inkl signing) rfm gw
                                  mickecarlsson
                                  wrote on last edited by mickecarlsson
                                  #554
                                  @sundberg84 the RFM69 is soldered 180 degrees wrong on the new board :white_frowning_face:
                                  • M mickecarlsson
                                    sundberg84S
                                    sundberg84S
                                    #555
                                    @mickecarlsson interesting thought but no because the radio on rev9 isn't soldered in the image (but wrong rotated as you noticed). The hardware on that image is working. I added a HW radio without noticing so with the old code I just got no reply/Nack. I had to add the HW define.
                                    • vladimirV
                                      vladimirV
                                      vladimir
                                      Today I finally finished my second RGB LED lighting in the room. Next is the LED illumination of the perimeter of the bed. Under the bed, I want to place a motion sensor so that it reacts when I get out of bed at night.
                                      • sundberg84S
                                        sundberg84S
                                        #557
                                        Redesigning my nodes in the RFM69 network to be signed using EasyPCB 10. Today it was my beer cooler node (because it's very important the beer temperature is secured). In the same time I'm implementing @gohan idea with two temp points (top and bottom).
                                        • vladimirV vladimir
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @vladimir
                                          you could use this under the bed:
                                          https://www.aliexpress.com/item/Free-Shipping-5-Pieces-RCWL-0516-Microwave-Radar-Sensor-Module-Human-Body-Induction-Switch-Module/32773310756.html?spm=a2g0s.9042311.0.0.27424c4dQaNm0K
                                          It works like an infrared sensor (same three pins), but it does not need a line of sight. It just reacts to movement as this results in a disturbance in the emitted radio signal. Works very well on my clock :-)
                                          The "high" value when movement is detected is not a full 5V, so I test the Out pin as an analog pin. Anything above 2.5V is an activation due to movement.
                                          vladimirV 1 Reply Last reply
