1.1k Posts 105 Posters 796.0k Views 98 Watching
    I've been busy this week building my first native android app in (nativescript-vue). It will control my new car charging station (HALO Wallbox). The charging port will automatically turn on when I'm closing in to our house and turn off off when leaving the area.
    @hek Is that to prevent others from using it?
      @NeverDie, yes, and to have a small project to learn app development.
      • GertSandersG
        GertSandersG
        GertSanders
        #539
        One of three ongoing projects:
        lasercut box
        atmega1284p based
        DS3231 rtc (very accurate and 2 alarms!)
        LDR
        20 by 4 LCD, two sizes of numbers, menu driven setup
        buzzer
        leds for moodlighting
        doppler for proximity detection
        encoder for scrolling through values (for setting time)
        buttons with LED feedback for interactivity
        mp3 player
        most interface objects MySensorised :-)
        This entry is to boost my energy, because we are still a long way from home (pcb is still not made, focus is now on prototype and software).
          #540
          I love the design of the air vent on the righthand side of your laesrcut box. Does that pattern have a name?
          GertSandersG 2 Replies Last reply
            GertSandersG
            GertSandersG
            GertSanders
            #541
            @neverdie nope, but it is inspired by oriental frames, I just made that based on what I saw on one of my cabinets (which I bought while living in Singapore).
              GertSandersG
              GertSandersG
              GertSanders
              @neverdie I will publish the project once it has advanced a bit more (still need to design the PCB for this box).
              • sundberg84S sundberg84
                A temp-node on 2xAA. Also a sneak-peak on EasyPCB rev 10...
                https://youtu.be/TxzvhG4uo9I
                mickecarlsson
                @sundberg84 how is the rev10 progress going? I am about to order a batch of EasyPCB but want the new bells and whistles :-)
                • GertSandersG GertSanders
                  @gertsanders Cool. You might like this pattern also then:
                  dbemowskD GertSandersG 2 Replies Last reply
                    dbemowskD
                    dbemowskD
                    @neverdie That's cool. Kind of like an overlapping honeycomb design.
                    • M mickecarlsson
                      sundberg84S
                      sundberg84S
                      #546
                      @mickecarlsson except I have not yet tested the new things on the back (signing and extra flash) the boards are working. I will try to test the last things before May is over and the publish.
                      If you want to order I can offcourse email you the Gerber's but on your own risk.
                      My first experience with the board is that it's performing better than Rev 9 with the new position if the hardware. Also the ground plane helps.
                        GertSandersG
                        GertSandersG
                        GertSanders
                        @neverdie that is a nice pattern. I found that these things need time to draw. If anyone has a DXF file, I would love to try it.
                          mickecarlsson
                          @sundberg84 thanks for the offer, I can wait for the final, no worries. Do you have a list of the new components added on the back?
                          • dbemowskD dbemowsk
                            #549
                            @dbemowsk said in What did you build today (Pictures) ?:
                            Bingo! Looks like that's exactly what it is. A small honeycomb superimposed on a bigger one.
                            dbemowskD 1 Reply Last reply
                              dbemowskD
                              dbemowskD
                              @neverdie I created that basic pattern in OpenSCAD.
                              Here is the scad
                               $fn = 6;
                               fudge = 0.01;
                               pi=3.1415926;
                               large_diameter = 40;
                               circumradius = large_diameter/2;
                               inradius = circumradius/(2*tan(180/$fn))-1;
                               height = 2;
                               line_width = 1;
                               rotate([0, 0, 0]) hollow_cylinder(large_diameter-line_width, height, line_width);
                               for(i=[1:$fn]) {
                                   rotate([0, 0, (360/$fn*i)+30]) translate([inradius, 0, 0]) rotate([0, 0, 30]) hollow_cylinder(circumradius, height, line_width);
                               module hollow_cylinder(diameter=10, thickness=2, line_thickness=2) {
                                   difference() {
                                       cylinder(thickness, d=diameter);
                                       translate([0, 0, -fudge/2]) cylinder(thickness+fudge, d=diameter-(line_thickness*2));
                              • dbemowskD
                                dbemowskD
                                Expanding on that, I mapped it out further to give people an idea of how it's calculated.
                                And the scad based on my previous post.
                                 $fn = 6;
                                 fudge = 0.01;
                                 pi=3.1415926;
                                 height = 2;
                                 line_width = 1;
                                 for(i=[1:$fn]) {
                                    rotate([0, 0, (360/$fn*i)+30]) translate([inradius*2, 0, 0]) rotate([0, 0, 30]) honeycomb();
                                 module honeycomb() {
                                     for(i=[1:$fn]) {
                                     difference() {
                                • M mickecarlsson
                                  sundberg84S
                                  sundberg84S
                                  #552
                                  @mickecarlsson - sure.
                                  Signing: atsha204a (sot-32-3), R4: 1k-100k resistor (0805), C5 0,1uF capacitor (0805)
                                  Flash: R7: 56k-100k resistor (0805), C7; 0,1uF capacitor (0805), U5: AT25DF512C or equivalent SPI Serial Flash Memory (8-lead SOIC). I bought this from Germany (but not tested)
                                  • sundberg84S
                                    sundberg84S
                                    #553
                                    Yesterday I tested the new EasyPCB with RFM radio and hardware signing. Worked out as expected and I'm going to release all files soon.
                                    I haven't tested the flash part yet but I'm hoping this is working as well.
                                    This picture will be a part of a new video with me building my new RFM69 serial gateway using signing.
                                    Anyone they can guess which issue I had when I took the photo?
                                    Rev9 vs Rev10 (inkl signing) rfm gw
                                      mickecarlsson
                                      wrote on last edited by mickecarlsson
                                      #554
                                      @sundberg84 the RFM69 is soldered 180 degrees wrong on the new board :white_frowning_face:
                                      • M mickecarlsson
                                        sundberg84S
                                        sundberg84S
                                        #555
                                        @mickecarlsson interesting thought but no because the radio on rev9 isn't soldered in the image (but wrong rotated as you noticed). The hardware on that image is working. I added a HW radio without noticing so with the old code I just got no reply/Nack. I had to add the HW define.
                                        • vladimirV
                                          vladimirV
                                          vladimir
                                          Today I finally finished my second RGB LED lighting in the room. Next is the LED illumination of the perimeter of the bed. Under the bed, I want to place a motion sensor so that it reacts when I get out of bed at night.
