1.1k Posts 105 Posters 796.0k Views 98 Watching
    @gertsanders Cool. You might like this pattern also then:
    dbemowskD
    dbemowskD
    @neverdie That's cool. Kind of like an overlapping honeycomb design.
    • M mickecarlsson
      @sundberg84 how is the rev10 progress going? I am about to order a batch of EasyPCB but want the new bells and whistles :-)
      sundberg84S
      sundberg84S
      #546
      @mickecarlsson except I have not yet tested the new things on the back (signing and extra flash) the boards are working. I will try to test the last things before May is over and the publish.
      If you want to order I can offcourse email you the Gerber's but on your own risk.
      My first experience with the board is that it's performing better than Rev 9 with the new position if the hardware. Also the ground plane helps.
        GertSandersG
        GertSandersG
        GertSanders
        @neverdie that is a nice pattern. I found that these things need time to draw. If anyone has a DXF file, I would love to try it.
        • sundberg84S sundberg84
          mickecarlsson
          @sundberg84 thanks for the offer, I can wait for the final, no worries. Do you have a list of the new components added on the back?
          • dbemowskD dbemowsk
            #549
            @dbemowsk said in What did you build today (Pictures) ?:
            Bingo! Looks like that's exactly what it is. A small honeycomb superimposed on a bigger one.
            dbemowskD 1 Reply Last reply
              dbemowskD
              dbemowskD
              @neverdie I created that basic pattern in OpenSCAD.
              Here is the scad
               $fn = 6;
               fudge = 0.01;
               pi=3.1415926;
               large_diameter = 40;
               circumradius = large_diameter/2;
               inradius = circumradius/(2*tan(180/$fn))-1;
               height = 2;
               line_width = 1;
               rotate([0, 0, 0]) hollow_cylinder(large_diameter-line_width, height, line_width);
               for(i=[1:$fn]) {
                   rotate([0, 0, (360/$fn*i)+30]) translate([inradius, 0, 0]) rotate([0, 0, 30]) hollow_cylinder(circumradius, height, line_width);
               module hollow_cylinder(diameter=10, thickness=2, line_thickness=2) {
                   difference() {
                       cylinder(thickness, d=diameter);
                       translate([0, 0, -fudge/2]) cylinder(thickness+fudge, d=diameter-(line_thickness*2));
              • dbemowskD
                dbemowskD
                Expanding on that, I mapped it out further to give people an idea of how it's calculated.
                And the scad based on my previous post.
                 $fn = 6;
                 fudge = 0.01;
                 pi=3.1415926;
                 height = 2;
                 line_width = 1;
                 for(i=[1:$fn]) {
                    rotate([0, 0, (360/$fn*i)+30]) translate([inradius*2, 0, 0]) rotate([0, 0, 30]) honeycomb();
                 module honeycomb() {
                     for(i=[1:$fn]) {
                     difference() {
                • M mickecarlsson
                  sundberg84S
                  sundberg84S
                  #552
                  @mickecarlsson - sure.
                  Signing: atsha204a (sot-32-3), R4: 1k-100k resistor (0805), C5 0,1uF capacitor (0805)
                  Flash: R7: 56k-100k resistor (0805), C7; 0,1uF capacitor (0805), U5: AT25DF512C or equivalent SPI Serial Flash Memory (8-lead SOIC). I bought this from Germany (but not tested)
                  • sundberg84S
                    sundberg84S
                    #553
                    Yesterday I tested the new EasyPCB with RFM radio and hardware signing. Worked out as expected and I'm going to release all files soon.
                    I haven't tested the flash part yet but I'm hoping this is working as well.
                    This picture will be a part of a new video with me building my new RFM69 serial gateway using signing.
                    Anyone they can guess which issue I had when I took the photo?
                    Rev9 vs Rev10 (inkl signing) rfm gw
                      mickecarlsson
                      wrote on last edited by mickecarlsson
                      #554
                      @sundberg84 the RFM69 is soldered 180 degrees wrong on the new board :white_frowning_face:
                      • M mickecarlsson
                        sundberg84S
                        sundberg84S
                        #555
                        @mickecarlsson interesting thought but no because the radio on rev9 isn't soldered in the image (but wrong rotated as you noticed). The hardware on that image is working. I added a HW radio without noticing so with the old code I just got no reply/Nack. I had to add the HW define.
                        • vladimirV
                          vladimirV
                          vladimir
                          Today I finally finished my second RGB LED lighting in the room. Next is the LED illumination of the perimeter of the bed. Under the bed, I want to place a motion sensor so that it reacts when I get out of bed at night.
                          • sundberg84S
                            sundberg84S
                            #557
                            Redesigning my nodes in the RFM69 network to be signed using EasyPCB 10. Today it was my beer cooler node (because it's very important the beer temperature is secured). In the same time I'm implementing @gohan idea with two temp points (top and bottom).
                            • vladimirV vladimir
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @vladimir
                              you could use this under the bed:
                              https://www.aliexpress.com/item/Free-Shipping-5-Pieces-RCWL-0516-Microwave-Radar-Sensor-Module-Human-Body-Induction-Switch-Module/32773310756.html?spm=a2g0s.9042311.0.0.27424c4dQaNm0K
                              It works like an infrared sensor (same three pins), but it does not need a line of sight. It just reacts to movement as this results in a disturbance in the emitted radio signal. Works very well on my clock :-)
                              The "high" value when movement is detected is not a full 5V, so I test the Out pin as an analog pin. Anything above 2.5V is an activation due to movement.
                              vladimirV 1 Reply Last reply
                              • GertSandersG GertSanders
                                @vladimir
                                vladimirV
                                vladimirV
                                vladimir
                                @gertsanders many thanks!:raised_hands: This is very interesting, I did not previously hear about such a sensor.
                                I understand correctly that it can be placed in a wooden case and it can work through it? Since the tree does not reflect its waves.
                                If this is so, will not it respond to the movement of the bed frame or my movements when I'm on the bed?...:thinking_face:
                                  I tried some of those radar sensors and are very sensitive, they could detect even if you move in the bed. In addition I'd rather not sleep next to a 5 Ghz radar emitter 😅
                                    vladimirV
                                    vladimirV
                                    vladimir
                                    @gohan Is there a chance to wake up a little toasted?:sweat_smile:
                                      fortunately the power is low, but still in the wifi power range and it is transmitting 24/7
                                        #563
                                        @gohan Oh, pish posh. It's made in China and sold for peanuts! What could possibly go wrong?
                                          I think it would be faster to answer to "what could possibly not go wrong"
