1.1k Posts 105 Posters 796.0k Views 98 Watching
  • sundberg84S sundberg84
    @bjacobse it's the cheapest one on eBay with the software cheese on Linux. I think it's a replica on Andostar x500 so search Usb microscope Andostar and you will find.
    @sundberg84 very professional video with multiple camera angles. Great work!
      I've been busy this week building my first native android app in (nativescript-vue). It will control my new car charging station (HALO Wallbox). The charging port will automatically turn on when I'm closing in to our house and turn off off when leaving the area.
        @hek Is that to prevent others from using it?
          @NeverDie, yes, and to have a small project to learn app development.
          • GertSandersG
            GertSandersG
            GertSanders
            #539
            One of three ongoing projects:
            lasercut box
            atmega1284p based
            DS3231 rtc (very accurate and 2 alarms!)
            LDR
            20 by 4 LCD, two sizes of numbers, menu driven setup
            buzzer
            leds for moodlighting
            doppler for proximity detection
            encoder for scrolling through values (for setting time)
            buttons with LED feedback for interactivity
            mp3 player
            most interface objects MySensorised :-)
            This entry is to boost my energy, because we are still a long way from home (pcb is still not made, focus is now on prototype and software).
              #540
              I love the design of the air vent on the righthand side of your laesrcut box. Does that pattern have a name?
              GertSandersG 2 Replies Last reply
                GertSandersG
                GertSandersG
                GertSanders
                #541
                @neverdie nope, but it is inspired by oriental frames, I just made that based on what I saw on one of my cabinets (which I bought while living in Singapore).
                  GertSandersG
                  GertSandersG
                  GertSanders
                  @neverdie I will publish the project once it has advanced a bit more (still need to design the PCB for this box).
                    A temp-node on 2xAA. Also a sneak-peak on EasyPCB rev 10...
                    https://youtu.be/TxzvhG4uo9I
                    mickecarlsson
                    @sundberg84 how is the rev10 progress going? I am about to order a batch of EasyPCB but want the new bells and whistles :-)
                    • GertSandersG GertSanders
                      @gertsanders Cool. You might like this pattern also then:
                      dbemowskD GertSandersG 2 Replies Last reply
                        dbemowskD
                        dbemowskD
                        @neverdie That's cool. Kind of like an overlapping honeycomb design.
                        • M mickecarlsson
                          sundberg84S
                          sundberg84S
                          #546
                          @mickecarlsson except I have not yet tested the new things on the back (signing and extra flash) the boards are working. I will try to test the last things before May is over and the publish.
                          If you want to order I can offcourse email you the Gerber's but on your own risk.
                          My first experience with the board is that it's performing better than Rev 9 with the new position if the hardware. Also the ground plane helps.
                            GertSandersG
                            GertSandersG
                            GertSanders
                            @neverdie that is a nice pattern. I found that these things need time to draw. If anyone has a DXF file, I would love to try it.
                              mickecarlsson
                              @sundberg84 thanks for the offer, I can wait for the final, no worries. Do you have a list of the new components added on the back?
                              • dbemowskD dbemowsk
                                #549
                                @dbemowsk said in What did you build today (Pictures) ?:
                                Bingo! Looks like that's exactly what it is. A small honeycomb superimposed on a bigger one.
                                dbemowskD 1 Reply Last reply
                                  dbemowskD
                                  dbemowskD
                                  @neverdie I created that basic pattern in OpenSCAD.
                                  Here is the scad
                                   $fn = 6;
                                   fudge = 0.01;
                                   pi=3.1415926;
                                   large_diameter = 40;
                                   circumradius = large_diameter/2;
                                   inradius = circumradius/(2*tan(180/$fn))-1;
                                   height = 2;
                                   line_width = 1;
                                   rotate([0, 0, 0]) hollow_cylinder(large_diameter-line_width, height, line_width);
                                   for(i=[1:$fn]) {
                                       rotate([0, 0, (360/$fn*i)+30]) translate([inradius, 0, 0]) rotate([0, 0, 30]) hollow_cylinder(circumradius, height, line_width);
                                   module hollow_cylinder(diameter=10, thickness=2, line_thickness=2) {
                                       difference() {
                                           cylinder(thickness, d=diameter);
                                           translate([0, 0, -fudge/2]) cylinder(thickness+fudge, d=diameter-(line_thickness*2));
                                  • dbemowskD
                                    dbemowskD
                                    Expanding on that, I mapped it out further to give people an idea of how it's calculated.
                                    And the scad based on my previous post.
                                     $fn = 6;
                                     fudge = 0.01;
                                     pi=3.1415926;
                                     height = 2;
                                     line_width = 1;
                                     for(i=[1:$fn]) {
                                        rotate([0, 0, (360/$fn*i)+30]) translate([inradius*2, 0, 0]) rotate([0, 0, 30]) honeycomb();
                                     module honeycomb() {
                                         for(i=[1:$fn]) {
                                         difference() {
                                    • M mickecarlsson
                                      sundberg84S
                                      sundberg84S
                                      #552
                                      @mickecarlsson - sure.
                                      Signing: atsha204a (sot-32-3), R4: 1k-100k resistor (0805), C5 0,1uF capacitor (0805)
                                      Flash: R7: 56k-100k resistor (0805), C7; 0,1uF capacitor (0805), U5: AT25DF512C or equivalent SPI Serial Flash Memory (8-lead SOIC). I bought this from Germany (but not tested)
                                      • sundberg84S
                                        sundberg84S
                                        #553
                                        Yesterday I tested the new EasyPCB with RFM radio and hardware signing. Worked out as expected and I'm going to release all files soon.
                                        I haven't tested the flash part yet but I'm hoping this is working as well.
                                        This picture will be a part of a new video with me building my new RFM69 serial gateway using signing.
                                        Anyone they can guess which issue I had when I took the photo?
                                        Rev9 vs Rev10 (inkl signing) rfm gw
                                          mickecarlsson
                                          wrote on last edited by mickecarlsson
                                          #554
                                          @sundberg84 the RFM69 is soldered 180 degrees wrong on the new board :white_frowning_face:
