  3. FOTA wont work, Controller error NACK
20 Posts 3 Posters 3.2k Views 3 Watching
  • H
    H
    Harrdy
    On my "normal sketch", the node output is clean. Sometimes the node has to send a sensor value again because there is an error message nack at the node, but this is relatively rare.
    I try the pingping sketch to check the reply from gateway. In this situation i got a nack error @ node. No reply from gateway
     *  This is a simple sketch used to demonstrate and test node-to-node MySensors communication.
     *  To use this sketch, assemble MySensors nodes - they need nothing more than a radio
     *  1.  Flash each node with the same sketch, open the console and type either 0 or 1 to the respective nodes to set their ID
     *  2.  You only need to set the node id once, and restart the nodes
     *  3.  To being a ping-pong test, simply type T in the console for one of the nodes.
     *  2015-05-25 Bruce Lacey v1.0
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #include "MYSLog.h"
    #define VSN "v1.0"
    // Define two generic nodes with a single child
    #define YING 200
    #define YANG 201
    #define CHILD 1
    MyMessage mPing(CHILD, V_VAR1);   //Ping message
    MyMessage mPong(CHILD, V_VAR2);   //Pong message
    	present(CHILD, S_CUSTOM);  //
    	sendSketchInfo( nodeTypeAsCharRepresentation( getNodeId() ), VSN );
    	LOG(F("\n%sReady.\n"), nodeTypeAsCharRepresentation(getNodeId()));
    	// Interactive command and control
    	// Entering a number from 0 or 1 will write the node 200 (YING) or 201 (YANG) to EEPROM
    	// Entering T on either node will initiate a ping-pong test.
    	if (Serial.available()) {
    		byte inChar = Serial.read();
    		uint8_t node = getNodeId();
    		// Manual Test Mode
    		if (inChar == 'T' || inChar == 't') {
    			LOG(F("T received - starting test...\n"));
    			MyMessage msg = mPong;
    			msg.sender = (node == YING ? YANG : YING);
    			sendPingOrPongResponse( msg );
    		} else if (inChar == '0' or inChar == '1') {
    			byte nodeID = 200 + (inChar - '0');
    			setNodeId(nodeID);
    			LOG("Invalid input\n");
    	LOG(F("Received %s from %s\n"), msgTypeAsCharRepresentation((mysensor_data)message.type),
    	    nodeTypeAsCharRepresentation(message.sender));
    	delay(250);
    	sendPingOrPongResponse( message );
    void sendPingOrPongResponse( MyMessage msg )
    	MyMessage response = (msg.type == V_VAR1 ? mPong : mPing);
    	LOG(F("Sending %s to %s\n"), msgTypeAsCharRepresentation( (mysensor_data)response.type ),
    	    nodeTypeAsCharRepresentation(msg.sender));
    	// Set payload to current time in millis to ensure each message is unique
    	response.set( (uint32_t)millis() );
    	response.setDestination(msg.sender);
    	send(response);
    void setNodeId(byte nodeID)
    	LOG(F("Setting node id to: %i.\n***Please restart the node for changes to take effect.\n"), nodeID);
    	hwWriteConfig(EEPROM_NODE_ID_ADDRESS, (byte)nodeID);
    const char * msgTypeAsCharRepresentation( mysensor_data mType )
    	return mType == V_VAR1 ? "Ping" : "Pong";
    const char * nodeTypeAsCharRepresentation( uint8_t node )
    	return node == YING ? "Ying Node" : "Yang Node";
    I also try this.
     requestTime(receiveTime);
    void receiveTime(unsigned long time) {
      Serial.println(time);
    And here? the node prints the controller time. Without any error.
      No, I meant looking at the serial debug while it is doing the fota
      • H
        H
        Harrdy
        How can i do this? I have the ttl reader on the arduino during the start. but the console is empty. Only after the fota process is finished, i see the output of the mysensors sketches. While the gateway is flashing red, the console remains empty. It takes about 10-15 seconds
        tekkaT 1 Reply Last reply
          I think there is a define to enable it, but I don't remember well as I use the dual optiboot. Maybe @tekka could help
          • H Harrdy
            tekkaT
            tekkaT
            tekka
            @harrdy MYSBootloader does not have a serial console output. In order to get a better understanding of your setup: can you post the full debug logs (GW & node) starting from the node booting until sending sensor data + node sketch?
            • H
              H
              Harrdy
              wrote on last edited by Harrdy
              Re: [FOTA wont work](Controller error NACK)
              @tekka
              node log during start until send sensor data
               __  __       ____
              16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
              26 MCO:BGN:BFR
              28 TSM:INIT
              30 TSF:WUR:MS=0
              36 TSM:INIT:TSP OK
              38 TSF:SID:OK,ID=6
              40 TSM:FPAR
              77 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              2084 !TSM:FPAR:NO REPLY
              2086 TSM:FPAR
              2123 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              4130 !TSM:FPAR:NO REPLY
              4132 TSM:FPAR
              4169 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              4188 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              4194 TSF:MSG:FPAR OK,ID=0,D=1
              6176 TSM:FPAR:OK
              6176 TSM:ID
              6178 TSM:ID:OK
              6180 TSM:UPL
              6184 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              8192 TSM:UPL
              8198 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              10207 TSM:UPL
              10209 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              10901 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
              10907 TSF:MSG:BC
              11608 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
              12218 TSM:UPL
              12255 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
              12265 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              12271 TSF:MSG:PONG RECV,HP=1
              12273 TSM:UPL:OK
              12275 TSM:READY:ID=6,PAR=0,DIS=1
              12314 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
              14329 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=OK:2.3.0
              14372 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=NACK:0
              16386 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=16,sg=0,ft=1,st=OK:TestBoard BMP180
              16402 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
              16420 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=OK:
              16429 TSF:MSG:SEND,6-6-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
              16435 MCO:REG:REQ
              16474 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
              18489 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
              20496 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              22507 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              24516 MCO:BGN:STP
              25018 MCO:BGN:INIT OK,TSP=1
              Battery Voltage: 3.25 V
              Battery percent: 96 %
              25552 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:96
              Temperature = 24.80 *C
              Pressure = 1016.96 hPa
              Forecast = unknown
              25608 TSF:MSG:SEND,6-6-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:24.8
              25620 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:1017
              25630 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=5,pt=0,l=7,sg=0,ft=0,st=OK:unknown
              25638 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
              25645 TSF:TDI:TSL
              25647 MCO:SLP:WUP=-1
              25649 TSF:TRI:TSB
              Battery Voltage: 2.95 V
              Battery percent: 87 %
              26189 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=NACK:87
              Pressure = 1016.87 hPa
              Forecast = unknown
              26243 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=4,pt=7,l=5,sg=0,ft=1,st=OK:1017
              26251 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
              26257 TSF:TDI:TSL
              gateway log
              	Aug 14, 2018 10:57:44	Notice	Node	 Serial   0	Received	Internal	[Log message] 3637381 TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:89
              	Aug 14, 2018 10:57:44	Notice	Node	 Serial   5:TestBoard BH1750	Received	Internal	[Battery level] 89
              	Aug 14, 2018 10:57:44	Info	Sensor variable	 Serial   5:TestBoard BH1750   20:45857 TSF:MSG:READ,5-5-0,s=20,c=0,t=16,pt=0,l=0,sg=0:  Light level	Received	Set	[Light level] 199
              	Aug 14, 2018 10:57:44	Notice	Node	 Serial   0	Received	Internal	[Log message] 3637369 TSF:MSG:READ,5-5-0,s=20,c=1,t=23,pt=3,l=2,sg=0:199
              	Aug 14, 2018 10:57:36	Info	Sensor variable	 Serial   9:TestBoard BMP180   1:1939766 TSF:MSG:READ,9-9-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
              	Aug 14, 2018 10:57:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3629883 TSF:MSG:READ,9-9-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
              	Aug 14, 2018 10:57:21	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Forecast	Received	Set	[Forecast] unknown
              	Aug 14, 2018 10:57:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 3614796 TSF:MSG:READ,6-6-0,s=1,c=1,t=5,pt=0,l=7,sg=0:unknown
              	Aug 14, 2018 10:57:21	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
              	Aug 14, 2018 10:57:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 3614785 TSF:MSG:READ,6-6-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
              	Aug 14, 2018 10:57:21	Info	Sensor variable	 Serial   6:TestBoard BMP180   0:3605562 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 24.8
              	Aug 14, 2018 10:57:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 3614773 TSF:MSG:READ,6-6-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.8
              	Aug 14, 2018 10:57:21	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Battery level] 96
              	Aug 14, 2018 10:57:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 3614691 TSF:MSG:READ,6-6-0,s=255,c=3,t=0,pt=1,l=1,sg=0:96
              	Aug 14, 2018 10:57:18	Notice	Node	 Serial   0	Received	Internal	[Log message] 3611703 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
              	Aug 14, 2018 10:57:18	Notice	Node	 Serial   0	Received	Internal	[Log message] 3611661 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              	Aug 14, 2018 10:57:16	Notice	Node	 Serial   0	Received	Internal	[Log message] 3609686 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
              	Aug 14, 2018 10:57:16	Notice	Node	 Serial   0	Received	Internal	[Log message] 3609644 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              	Aug 14, 2018 10:57:14	Notice	Node	 Serial   0	Received	Internal	[Log message] 3607665 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
              	Aug 14, 2018 10:57:14	Notice	Node	 Serial   0	Received	Internal	[Log message] 3607623 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605614 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
              	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605572 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              	Aug 14, 2018 10:57:12	Notice	Sensor	 Serial   6:TestBoard BMP180   0:3605562 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:	Received	Presentation	[Temperature] 3605562 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
              	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605562 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
              	Aug 14, 2018 10:57:12	Notice	Sensor	 Serial   6:TestBoard BMP180   1:3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:	Received	Presentation	[Barometer] 3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
              	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
              	Aug 14, 2018 10:57:12	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch version] 1.2
              	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605530 TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
              	Aug 14, 2018 10:57:12	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch name] TestBoard BMP180
              	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605516 TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=16,sg=0:TestBoard BMP180
              	Aug 14, 2018 10:57:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 3603517 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
              	Aug 14, 2018 10:57:10	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Internal	[Config] M
              	Aug 14, 2018 10:57:10	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Config] 0
              	Aug 14, 2018 10:57:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 3603466 TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
              	Aug 14, 2018 10:57:10	Notice	Node	 Serial   6:TestBoard BMP180	Received	Presentation	[Node] 2.3.0
              	Aug 14, 2018 10:57:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 3603451 TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
              	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601444 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
              	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601401 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601386 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
              	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601347 TSF:MSG:PINGED,ID=6,HP=1
              	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601341 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              	Aug 14, 2018 10:57:07	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Discover response] 0
              	Aug 14, 2018 10:57:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 3600699 TSF:MSG:READ,6-6-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
              	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3600049 TSF:SAN:OK
              	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3600040 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
              	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3600003 TSM:READY:NWD REQ
              	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599915 TSF:MSG:READ,7-7-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
              	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599904 TSF:MSG:READ,7-7-0,s=0,c=1,t=0,pt=7,l=5,sg=0:23.0
              	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599368 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
              	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599328 TSF:MSG:PINGED,ID=6,HP=1
              	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599322 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              	Aug 14, 2018 10:57:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 3597344 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
              	Aug 14, 2018 10:57:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 3597305 TSF:MSG:PINGED,ID=6,HP=1
              	Aug 14, 2018 10:57:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 3597299 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              	Aug 14, 2018 10:57:02	Notice	Node	 Serial   0	Received	Internal	[Log message] 3595327 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
              	Aug 14, 2018 10:57:02	Notice	Node	 Serial   0	Received	Internal	[Log message] 3595287 TSF:MSG:PINGED,ID=6,HP=1
              	Aug 14, 2018 10:57:02	Notice	Node	 Serial   0	Received	Internal	[Log message] 3595281 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593279 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
              	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593241 TSF:MSG:GWL OK
              	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593238 TSF:CKU:OK,FCTRL
              	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593234 TSF:MSG:FPAR REQ,ID=6
              	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593231 TSF:MSG:BC
              	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593225 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              	Aug 14, 2018 10:56:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591251 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
              	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591188 TSF:MSG:GWL OK
              	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591185 TSF:CKU:OK,FCTRL
              	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591181 TSF:MSG:FPAR REQ,ID=6
              	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591178 TSF:MSG:BC
              	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591172 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              	Aug 14, 2018 10:56:56	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589200 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
              	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589139 TSF:MSG:GWL OK
              	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589136 TSF:CKU:OK
              	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589133 TSF:PNG:SEND,TO=0
              	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589129 TSF:MSG:FPAR REQ,ID=6
              	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589126 TSF:MSG:BC
              	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589120 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              	Aug 14, 2018 10:56:52	Notice	Node	 Serial   0	Received	Internal	[Log message] 3585674 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
              	Aug 14, 2018 10:56:52	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
              	Aug 14, 2018 10:56:52	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
              	Aug 14, 2018 10:56:52	Notice	Node	 Serial   0	Received	Internal	[Log message] 3585614 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
              	Aug 14, 2018 10:56:49	Notice	Node	 Serial   0	Received	Internal	[Log message] 3582587 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
              	Aug 14, 2018 10:56:49	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
              	Aug 14, 2018 10:56:49	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
              	Aug 14, 2018 10:56:49	Notice	Node	 Serial   0	Received	Internal	[Log message] 3582528 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
              	Aug 14, 2018 10:56:46	Notice	Node	 Serial   0	Received	Internal	[Log message] 3579492 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
              	Aug 14, 2018 10:56:46	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
              	Aug 14, 2018 10:56:46	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
              	Aug 14, 2018 10:56:46	Notice	Node	 Serial   0	Received	Internal	[Log message] 3579432 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
              	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576639 TSF:MSG:READ,1-1-0,s=255,c=3,t=0,pt=1,l=1,sg=0:91
              	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576627 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:60.8
              	Aug 14, 2018 10:56:43	Info	Sensor variable	 Serial   1:TemperatureAndHumidity   1:405720740 TSF:MSG:READ,1-1-0,s=1,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 22.8
              	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576616 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:22.8
              	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576399 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
              	Aug 14, 2018 10:56:43	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
              	Aug 14, 2018 10:56:43	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
              	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576339 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
              	Aug 14, 2018 10:56:39	Notice	Node	 Serial   0	Received	Internal	[Log message] 3572920 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
              	Aug 14, 2018 10:56:39	Notice	Node	 Serial   0	Received	Internal	[Log message] 3572877 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569977 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
              	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569800 TSF:MSG:GWL OK
              	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569796 TSF:CKU:OK,FCTRL
              	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569792 TSF:MSG:FPAR REQ,ID=6
              	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569789 TSF:MSG:BC
              	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569782 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
              	Aug 14, 2018 10:56:34	Notice	Node	 Serial   0	Received	Internal	[Log message] 3567338 TSF:MSG:READ,9-9-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
              	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566862 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
              	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566706 TSF:MSG:GWL OK
              	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566703 TSF:CKU:OK
              	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566700 TSF:PNG:SEND,TO=0
              	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566696 TSF:MSG:FPAR REQ,ID=6
              	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566693 TSF:MSG:BC
              	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566687 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
              its my ota file, the same thing that is already on the arduino. i only change the sketch name.
              node sketch was too long, i use github to host it
              https://github.com/Harrdy/MySensors-TestBoard/blob/master/MySensors-TestBoard.ino
              currently used gateway
              3.3v directly from arduino with 47uF cap
              currently used node
              • H Harrdy
                @tekka
                 __  __       ____
                26 MCO:BGN:BFR
                28 TSM:INIT
                30 TSF:WUR:MS=0
                36 TSM:INIT:TSP OK
                38 TSF:SID:OK,ID=6
                40 TSM:FPAR
                2086 TSM:FPAR
                4132 TSM:FPAR
                6176 TSM:FPAR:OK
                6176 TSM:ID
                6178 TSM:ID:OK
                6180 TSM:UPL
                8192 TSM:UPL
                10207 TSM:UPL
                10907 TSF:MSG:BC
                12218 TSM:UPL
                12273 TSM:UPL:OK
                16435 MCO:REG:REQ
                24516 MCO:BGN:STP
                Forecast = unknown
                25645 TSF:TDI:TSL
                25649 TSF:TRI:TSB
                Forecast = unknown
                26257 TSF:TDI:TSL
                gateway log
                currently used node
                tekkaT
                tekkaT
                tekka
                @harrdy Node RF24: There are lots of failed transmissions during startup which normally hints to a power issue (bad capacitor?), a defective radio or a signal interference. Can you exchange both components and give it another spin?
                • H
                  H
                  Harrdy
                  @tekka said in FOTA wont work, Controller error NACK:
                  I change both the cap against a new one (old 4,7uF 50v, new 10uF 16v) and change ne nrf against a brand new one
                  first node startup
                   __  __       ____
                  26 MCO:BGN:BFR
                  28 TSM:INIT
                  30 TSF:WUR:MS=0
                  36 TSM:INIT:TSP OK
                  38 TSF:SID:OK,ID=6
                  40 TSM:FPAR
                  2086 TSM:FPAR
                  4132 TSM:FPAR
                  6176 TSM:FPAR:OK
                  6176 TSM:ID
                  6178 TSM:ID:OK
                  6180 TSM:UPL
                  8192 TSM:UPL
                  10207 TSM:UPL
                  10907 TSF:MSG:BC
                  12218 TSM:UPL
                  12273 TSM:UPL:OK
                  16435 MCO:REG:REQ
                  24516 MCO:BGN:STP
                  Forecast = unknown
                  25645 TSF:TDI:TSL
                  second node startup
                   __  __       ____
                  26 MCO:BGN:BFR
                  28 TSM:INIT
                  30 TSF:WUR:MS=0
                  36 TSM:INIT:TSP OK
                  38 TSF:SID:OK,ID=6
                  40 TSM:FPAR
                  2086 TSM:FPAR
                  4132 TSM:FPAR
                  6176 !TSM:FPAR:NO REPLY
                  6178 TSM:FPAR
                  6215 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  8222 !TSM:FPAR:FAIL
                  8224 TSM:FAIL:CNT=1
                  8226 TSM:FAIL:DIS
                  8228 TSF:TDI:TSL
                  18229 TSM:FAIL:RE-INIT
                  18231 TSM:INIT
                  18237 TSM:INIT:TSP OK
                  18241 TSF:SID:OK,ID=6
                  18243 TSM:FPAR
                  18280 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  20289 !TSM:FPAR:NO REPLY
                  20291 TSM:FPAR
                  20328 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  22337 !TSM:FPAR:NO REPLY
                  22339 TSM:FPAR
                  22376 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  24385 !TSM:FPAR:NO REPLY
                  24387 TSM:FPAR
                  24424 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  26433 !TSM:FPAR:FAIL
                  26435 TSM:FAIL:CNT=2
                  26437 TSM:FAIL:DIS
                  26439 TSF:TDI:TSL
                  36442 TSM:FAIL:RE-INIT
                  36444 TSM:INIT
                  36450 TSM:INIT:TSP OK
                  36454 TSF:SID:OK,ID=6
                  36456 TSM:FPAR
                  36493 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  38502 !TSM:FPAR:NO REPLY
                  38504 TSM:FPAR
                  38541 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  40550 !TSM:FPAR:NO REPLY
                  40552 TSM:FPAR
                  40589 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  40929 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  40935 TSF:MSG:FPAR OK,ID=0,D=1
                  42598 TSM:FPAR:OK
                  42600 TSM:ID
                  42600 TSM:ID:OK
                  42602 TSM:UPL
                  42606 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  42622 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  42629 TSF:MSG:PONG RECV,HP=1
                  42631 TSM:UPL:OK
                  42633 TSM:READY:ID=6,PAR=0,DIS=1
                  42643 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  44660 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
                  44679 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                  44709 TSF:MSG:READ,0-0-6,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  44752 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=16,sg=0,ft=0,st=OK:TestBoard BMP180
                  44763 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                  44785 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=OK:
                  44795 TSF:MSG:SEND,6-6-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                  44802 MCO:REG:REQ
                  44838 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
                  46848 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                  46882 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  46888 MCO:PIM:NODE REG=1
                  46891 MCO:BGN:STP
                  47392 MCO:BGN:INIT OK,TSP=1
                  47908 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:96
                  Temperature = 25.00 *C
                  Pressure = 1017.10 hPa
                  Forecast = unknown
                  47964 TSF:MSG:SEND,6-6-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:25.0
                  47982 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:1017
                  47994 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=5,pt=0,l=7,sg=0,ft=0,st=OK:unknown
                  48003 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  48009 TSF:TDI:TSL
                  48011 MCO:SLP:WUP=-1
                  48013 TSF:TRI:TSB
                  48523 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:87
                  Pressure = 1017.06 hPa
                  1. node startup
                   __  __       ____
                  26 MCO:BGN:BFR
                  28 TSM:INIT
                  30 TSF:WUR:MS=0
                  36 TSM:INIT:TSP OK
                  38 TSF:SID:OK,ID=6
                  40 TSM:FPAR
                  288 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  294 TSF:MSG:FPAR OK,ID=0,D=1
                  2084 TSM:FPAR:OK
                  2084 TSM:ID
                  2086 TSM:ID:OK
                  2088 TSM:UPL
                  2093 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  2123 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  2129 TSF:MSG:PONG RECV,HP=1
                  2131 TSM:UPL:OK
                  2134 TSM:READY:ID=6,PAR=0,DIS=1
                  2138 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  4155 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
                  4165 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                  6150 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                  6156 TSF:MSG:BC
                  6176 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
                  6189 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=16,sg=0,ft=0,st=OK:TestBoard BMP180
                  6234 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                  6256 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=OK:
                  6264 TSF:MSG:SEND,6-6-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                  6270 MCO:REG:REQ
                  6275 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                  8318 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
                  10328 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                  10350 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  10356 MCO:PIM:NODE REG=1
                  10360 MCO:BGN:STP
                  10862 MCO:BGN:INIT OK,TSP=1
                  Battery Voltage: 3.34 V
                  Battery percent: 99 %
                  11368 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:99
                  Temperature = 24.90 *C
                  Forecast = unknown
                  11423 TSF:MSG:SEND,6-6-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:24.9
                  11431 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:1017
                  11444 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=5,pt=0,l=7,sg=0,ft=0,st=OK:unknown
                  11452 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  11458 TSF:TDI:TSL
                  11460 MCO:SLP:WUP=-1
                  11462 TSF:TRI:TSB
                  gateway during 3. startup
                  Aug 14, 2018 12:17:18	Notice	Node	 Serial   0	Received	Internal	[Log message] 8415023 TSF:MSG:READ,7-7-0,s=0,c=1,t=0,pt=7,l=5,sg=0:23.1
                  	Aug 14, 2018 12:17:18	Notice	Node	 Serial   7:TestBoard BMP180	Received	Internal	[Battery level] 96
                  	Aug 14, 2018 12:17:18	Notice	Node	 Serial   0	Received	Internal	[Log message] 8414968 TSF:MSG:READ,7-7-0,s=255,c=3,t=0,pt=1,l=1,sg=0:96
                  	Aug 14, 2018 12:17:11	Notice	Node	 Serial   1:TemperatureAndHumidity	Received	Internal	[Battery level] 91
                  	Aug 14, 2018 12:17:11	Notice	Node	 Serial   0	Received	Internal	[Log message] 8408024 TSF:MSG:READ,1-1-0,s=255,c=3,t=0,pt=1,l=1,sg=0:91
                  	Aug 14, 2018 12:17:11	Info	Sensor variable	 Serial   1:TemperatureAndHumidity   0:405720731 TSF:MSG:READ,1-1-0,s=0,c=0,t=7,pt=0,l=0,sg=0:  Humidity	Received	Set	[Humidity] 58.7
                  	Aug 14, 2018 12:17:11	Notice	Node	 Serial   0	Received	Internal	[Log message] 8408009 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:58.7
                  	Aug 14, 2018 12:17:11	Info	Sensor variable	 Serial   1:TemperatureAndHumidity   1:405720740 TSF:MSG:READ,1-1-0,s=1,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 23.5
                  	Aug 14, 2018 12:17:11	Notice	Node	 Serial   0	Received	Internal	[Log message] 8407990 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:23.5
                  	Aug 14, 2018 12:17:09	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Forecast	Received	Set	[Forecast] unknown
                  	Aug 14, 2018 12:17:09	Notice	Node	 Serial   0	Received	Internal	[Log message] 8405341 TSF:MSG:READ,6-6-0,s=1,c=1,t=5,pt=0,l=7,sg=0:unknown
                  	Aug 14, 2018 12:17:09	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                  	Aug 14, 2018 12:17:09	Notice	Node	 Serial   0	Received	Internal	[Log message] 8405331 TSF:MSG:READ,6-6-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                  	Aug 14, 2018 12:17:09	Info	Sensor variable	 Serial   6:TestBoard BMP180   0:8400145 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 24.9
                  	Aug 14, 2018 12:17:09	Notice	Node	 Serial   0	Received	Internal	[Log message] 8405321 TSF:MSG:READ,6-6-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.9
                  	Aug 14, 2018 12:17:09	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Battery level] 99
                  	Aug 14, 2018 12:17:09	Notice	Node	 Serial   0	Received	Internal	[Log message] 8405268 TSF:MSG:READ,6-6-0,s=255,c=3,t=0,pt=1,l=1,sg=0:99
                  	Aug 14, 2018 12:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 8404247 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                  	Aug 14, 2018 12:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 8404224 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  	Aug 14, 2018 12:17:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 8402214 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  	Aug 14, 2018 12:17:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 8402172 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  	Aug 14, 2018 12:17:06	Notice	Node	 Serial   4:TestBoard DS18B20	Received	Internal	[Battery level] 87
                  	Aug 14, 2018 12:17:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 8402153 TSF:MSG:READ,4-4-0,s=255,c=3,t=0,pt=1,l=1,sg=0:87
                  	Aug 14, 2018 12:17:06	Info	Sensor variable	 Serial   4:TestBoard DS18B20   4:2254193 TSF:MSG:READ,4-4-0,s=4,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 21.7
                  	Aug 14, 2018 12:17:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 8402139 TSF:MSG:READ,4-4-0,s=4,c=1,t=0,pt=7,l=5,sg=0:21.7
                  	Aug 14, 2018 12:17:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400197 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  	Aug 14, 2018 12:17:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400155 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  	Aug 14, 2018 12:17:04	Notice	Sensor	 Serial   6:TestBoard BMP180   0:8400145 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:	Received	Presentation	[Temperature] 8400145 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                  	Aug 14, 2018 12:17:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400145 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                  	Aug 14, 2018 12:17:04	Notice	Sensor	 Serial   6:TestBoard BMP180   1:8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:	Received	Presentation	[Barometer] 8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                  	Aug 14, 2018 12:17:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                  	Aug 14, 2018 12:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch version] 1.2
                  	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400079 TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
                  	Aug 14, 2018 12:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch name] TestBoard BMP180
                  	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400066 TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=16,sg=0:TestBoard BMP180
                  	Aug 14, 2018 12:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Discover response] 0
                  	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400054 TSF:MSG:READ,6-6-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                  	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400045 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                  	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400007 TSM:READY:NWD REQ
                  	Aug 14, 2018 12:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 8398089 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                  	Aug 14, 2018 12:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Internal	[Config] M
                  	Aug 14, 2018 12:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Config] 0
                  	Aug 14, 2018 12:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 8398036 TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  	Aug 14, 2018 12:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Received	Presentation	[Node] 2.3.0
                  	Aug 14, 2018 12:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 8398020 TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
                  	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8396046 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                  	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8396004 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8395988 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                  	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8395963 TSF:MSG:PINGED,ID=6,HP=1
                  	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8395957 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  	Aug 14, 2018 12:16:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 8394148 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393918 TSF:MSG:GWL OK
                  	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393915 TSF:CKU:OK,FCTRL
                  	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393911 TSF:MSG:FPAR REQ,ID=6
                  	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393908 TSF:MSG:BC
                  	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393902 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  	Aug 14, 2018 12:16:52	Notice	Node	 Serial   0	Received	Internal	[Log message] 8388131 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                  	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387324 TSF:MSG:GWL OK
                  	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387321 TSF:CKU:OK
                  	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387317 TSF:PNG:SEND,TO=0
                  	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387314 TSF:MSG:FPAR REQ,ID=6
                  	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387311 TSF:MSG:BC
                  	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387305 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                  i'm not sure, is this a node or a gateway issue? i test many times with the node id 6, but all other nodes have the same error at fota. but i use the same components on all nodes, newbie pcb, 4,7uF cap, nrf24l01+, 3.3v booster and 2xAA
                  and sometimes, randomly, 1-2 per hour, the gateway flashs red without fota process.
                  i already try to change the gateway nrf24l01 pa against a normal one. i think, the red flashes were less. But fota did not work either. But with a normal nrf24l01 i have not received any data from far away nodes
                  YouTube - Gateway flashes
                  • H Harrdy
                    first node startup
                     __  __       ____
                    26 MCO:BGN:BFR
                    28 TSM:INIT
                    30 TSF:WUR:MS=0
                    36 TSM:INIT:TSP OK
                    38 TSF:SID:OK,ID=6
                    40 TSM:FPAR
                    2086 TSM:FPAR
                    4132 TSM:FPAR
                    6176 TSM:FPAR:OK
                    6176 TSM:ID
                    6178 TSM:ID:OK
                    6180 TSM:UPL
                    8192 TSM:UPL
                    10207 TSM:UPL
                    10907 TSF:MSG:BC
                    12218 TSM:UPL
                    12273 TSM:UPL:OK
                    16435 MCO:REG:REQ
                    24516 MCO:BGN:STP
                    Forecast = unknown
                    25645 TSF:TDI:TSL
                    second node startup
                     __  __       ____
                    26 MCO:BGN:BFR
                    28 TSM:INIT
                    30 TSF:WUR:MS=0
                    36 TSM:INIT:TSP OK
                    38 TSF:SID:OK,ID=6
                    40 TSM:FPAR
                    2086 TSM:FPAR
                    4132 TSM:FPAR
                    6178 TSM:FPAR
                    8222 !TSM:FPAR:FAIL
                    8224 TSM:FAIL:CNT=1
                    8226 TSM:FAIL:DIS
                    8228 TSF:TDI:TSL
                    18231 TSM:INIT
                    18243 TSM:FPAR
                    20291 TSM:FPAR
                    22339 TSM:FPAR
                    24387 TSM:FPAR
                    26437 TSM:FAIL:DIS
                    26439 TSF:TDI:TSL
                    36444 TSM:INIT
                    36456 TSM:FPAR
                    38504 TSM:FPAR
                    40552 TSM:FPAR
                    42598 TSM:FPAR:OK
                    42600 TSM:ID
                    42600 TSM:ID:OK
                    42602 TSM:UPL
                    42631 TSM:UPL:OK
                    44802 MCO:REG:REQ
                    46891 MCO:BGN:STP
                    Forecast = unknown
                    48009 TSF:TDI:TSL
                    48013 TSF:TRI:TSB
                    1. node startup
                     __  __       ____
                    26 MCO:BGN:BFR
                    28 TSM:INIT
                    30 TSF:WUR:MS=0
                    36 TSM:INIT:TSP OK
                    38 TSF:SID:OK,ID=6
                    40 TSM:FPAR
                    2084 TSM:FPAR:OK
                    2084 TSM:ID
                    2086 TSM:ID:OK
                    2088 TSM:UPL
                    2131 TSM:UPL:OK
                    6156 TSF:MSG:BC
                    6270 MCO:REG:REQ
                    10360 MCO:BGN:STP
                    Forecast = unknown
                    11458 TSF:TDI:TSL
                    11462 TSF:TRI:TSB
                    tekkaT
                    tekkaT
                    tekka
                    wrote on last edited by tekka
                    @harrdy ok, the caps are a bit small, do you have larger ones (10 or 100uF)? GW: exchange the capacitor on the GW radio (>=100uF) and/or power supply (eventually the USB port is too weak?)
                    • H
                      H
                      Harrdy
                      yes, i have a full box of caps in all sizes. i swap the gw cap from 10uF to 100uF and change the large (2meter) usb cable against a short one (1meter). the usb cable is attached to a supermicro x86 board (usb 2.0 port). this can deliver 500mA @ 5v
                      	Aug 14, 2018 13:17:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 542441 TSF:MSG:READ,9-9-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                      	Aug 14, 2018 13:17:13	Info	Sensor variable	 Serial   9:TestBoard BMP180   1:1939766 TSF:MSG:READ,9-9-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                      	Aug 14, 2018 13:17:13	Info	Sensor variable	 Serial   9:TestBoard BMP180   0:1939775 TSF:MSG:READ,9-9-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 23.4
                      	Aug 14, 2018 13:17:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 542432 TSF:MSG:READ,9-9-0,s=0,c=1,t=0,pt=7,l=5,sg=0:23.4
                      	Aug 14, 2018 13:17:13	Notice	Node	 Serial   9:TestBoard BMP180	Received	Internal	[Battery level] 94
                      	Aug 14, 2018 13:17:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 542377 TSF:MSG:READ,9-9-0,s=255,c=3,t=0,pt=1,l=1,sg=0:94
                      	Aug 14, 2018 13:17:08	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Forecast	Received	Set	[Forecast] unknown
                      	Aug 14, 2018 13:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 537254 TSF:MSG:READ,6-6-0,s=1,c=1,t=5,pt=0,l=7,sg=0:unknown
                      	Aug 14, 2018 13:17:08	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                      	Aug 14, 2018 13:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 537240 TSF:MSG:READ,6-6-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                      	Aug 14, 2018 13:17:08	Info	Sensor variable	 Serial   6:TestBoard BMP180   0:532055 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 24.4
                      	Aug 14, 2018 13:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 537228 TSF:MSG:READ,6-6-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.4
                      	Aug 14, 2018 13:17:08	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Battery level] 96
                      	Aug 14, 2018 13:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 537170 TSF:MSG:READ,6-6-0,s=255,c=3,t=0,pt=1,l=1,sg=0:96
                      	Aug 14, 2018 13:17:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 536145 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                      	Aug 14, 2018 13:17:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 536108 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      	Aug 14, 2018 13:17:05	Notice	Node	 Serial   0	Received	Internal	[Log message] 534134 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      	Aug 14, 2018 13:17:05	Notice	Node	 Serial   0	Received	Internal	[Log message] 534092 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532113 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532072 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      	Aug 14, 2018 13:17:03	Notice	Sensor	 Serial   6:TestBoard BMP180   0:532055 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:	Received	Presentation	[Temperature] 532055 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                      	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532055 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                      	Aug 14, 2018 13:17:03	Notice	Sensor	 Serial   6:TestBoard BMP180   1:532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:	Received	Presentation	[Barometer] 532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                      	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                      	Aug 14, 2018 13:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch version] 1.2
                      	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532023 TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
                      	Aug 14, 2018 13:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch name] TestBoard BMP180
                      	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532012 TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=16,sg=0:TestBoard BMP180
                      	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 530048 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                      	Aug 14, 2018 13:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Internal	[Config] M
                      	Aug 14, 2018 13:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Config] 0
                      	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529998 TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                      	Aug 14, 2018 13:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Received	Presentation	[Node] 2.3.0
                      	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529988 TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
                      	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529974 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529937 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529925 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                      	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529895 TSF:MSG:PINGED,ID=6,HP=1
                      	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529889 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 528380 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527849 TSF:MSG:GWL OK
                      	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527846 TSF:CKU:OK,FCTRL
                      	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527842 TSF:MSG:FPAR REQ,ID=6
                      	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527840 TSF:MSG:BC
                      	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527834 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      	Aug 14, 2018 13:16:57	Info	Sensor variable	 Serial   7:TestBoard BMP180   1:38654387 TSF:MSG:READ,7-7-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                      	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 526502 TSF:MSG:READ,7-7-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                      	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 526326 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525798 TSF:MSG:GWL OK
                      	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525796 TSF:CKU:OK
                      	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525792 TSF:PNG:SEND,TO=0
                      	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525789 TSF:MSG:FPAR REQ,ID=6
                      	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525786 TSF:MSG:BC
                      	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525779 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      	Aug 14, 2018 13:16:53	Notice	Node	 Serial   0	Received	Internal	[Log message] 522332 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                      	Aug 14, 2018 13:16:53	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                      	Aug 14, 2018 13:16:53	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:16:53	Notice	Node	 Serial   0	Received	Internal	[Log message] 522274 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:16:50	Notice	Node	 Serial   0	Received	Internal	[Log message] 519248 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                      	Aug 14, 2018 13:16:50	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                      	Aug 14, 2018 13:16:50	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:16:50	Notice	Node	 Serial   0	Received	Internal	[Log message] 519189 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:16:47	Notice	Node	 Serial   0	Received	Internal	[Log message] 516157 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                      	Aug 14, 2018 13:16:47	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                      	Aug 14, 2018 13:16:47	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:16:47	Notice	Node	 Serial   0	Received	Internal	[Log message] 516098 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:16:44	Notice	Node	 Serial   0	Received	Internal	[Log message] 513064 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                      	Aug 14, 2018 13:16:44	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                      	Aug 14, 2018 13:16:44	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:16:44	Notice	Node	 Serial   0	Received	Internal	[Log message] 513005 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:16:40	Notice	Node	 Serial   0	Received	Internal	[Log message] 509591 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                      	Aug 14, 2018 13:16:40	Notice	Node	 Serial   0	Received	Internal	[Log message] 509548 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      	Aug 14, 2018 13:16:38	Notice	Node	 Serial   0	Received	Internal	[Log message] 507119 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                      	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506473 TSF:MSG:GWL OK
                      	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506469 TSF:CKU:OK,FCTRL
                      	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506466 TSF:MSG:FPAR REQ,ID=6
                      	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506463 TSF:MSG:BC
                      	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506457 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                      nothing has changed
                      • H
                        H
                        Harrdy
                        i also have some 5v to 3.3v DC-DC StepDown breakouts. So i change the gw nrf24 powering source from directly to 3.3v arduino to this breakout.
                        The breakout is powering from 5v arduino.
                        https://www.ebay.de/itm/5Stks-800MA-5V-to-3-3V-DC-DC-Step-Down-Power-Supply-Buck-Module-AMS1117-LDO-MT/273132979923?hash=item3f97fe86d3:g:6GUAAOSwVzRavJuB
                        Unfortunately, this had no success
                        Bus 003 Device 045: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
                        Device Descriptor:
                          bLength                18
                          bDescriptorType         1
                          bcdUSB               1.10
                          bDeviceClass          255 Vendor Specific Class
                          bDeviceSubClass         0
                          bDeviceProtocol         0
                          bMaxPacketSize0         8
                          idVendor           0x1a86 QinHeng Electronics
                          idProduct          0x7523 HL-340 USB-Serial adapter
                          bcdDevice            2.54
                          iManufacturer           0
                          iProduct                2 USB2.0-Serial
                          iSerial                 0
                          bNumConfigurations      1
                          Configuration Descriptor:
                            bLength                 9
                            bDescriptorType         2
                            wTotalLength           39
                            bNumInterfaces          1
                            bConfigurationValue     1
                            iConfiguration          0
                            bmAttributes         0x80
                              (Bus Powered)
                            MaxPower               96mA
                            Interface Descriptor:
                              bLength                 9
                              bDescriptorType         4
                              bInterfaceNumber        0
                              bAlternateSetting       0
                              bNumEndpoints           3
                              bInterfaceClass       255 Vendor Specific Class
                              bInterfaceSubClass      1
                              bInterfaceProtocol      2
                              iInterface              0
                              Endpoint Descriptor:
                                bLength                 7
                                bDescriptorType         5
                                bEndpointAddress     0x82  EP 2 IN
                                bmAttributes            2
                                  Transfer Type            Bulk
                                  Synch Type               None
                                  Usage Type               Data
                                wMaxPacketSize     0x0020  1x 32 bytes
                                bInterval               0
                                bLength                 7
                                bDescriptorType         5
                                bEndpointAddress     0x02  EP 2 OUT
                                bmAttributes            2
                                  Transfer Type            Bulk
                                  Synch Type               None
                                  Usage Type               Data
                                bInterval               0
                                bLength                 7
                                bDescriptorType         5
                                bEndpointAddress     0x81  EP 1 IN
                                bmAttributes            3
                                  Transfer Type            Interrupt
                                  Synch Type               None
                                  Usage Type               Data
                                wMaxPacketSize     0x0008  1x 8 bytes
                                bInterval               1
                        Device Status:     0x0000
                          (Bus Powered)
                        probably a issue with the arduino nano clone?
                        • H
                          H
                          Harrdy
                          i have another original arduino uno. so, i build a second gateway with it.
                          nrf24l01+pa directly connected to 3.3v with wires. (100uF between vcc and gnd)
                          Aug 14, 2018 13:48:50	Notice	Node	 Serial   0	Received	Internal	[Log message] 72726 TSF:MSG:READ,7-7-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                          	Aug 14, 2018 13:48:50	Info	Sensor variable	 Serial   7:TestBoard BMP180   1:38654387 TSF:MSG:READ,7-7-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                          	Aug 14, 2018 13:48:37	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Forecast	Received	Set	[Forecast] unknown
                          	Aug 14, 2018 13:48:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 60128 TSF:MSG:READ,6-6-0,s=1,c=1,t=5,pt=0,l=7,sg=0:unknown
                          	Aug 14, 2018 13:48:37	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                          	Aug 14, 2018 13:48:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 60115 TSF:MSG:READ,6-6-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                          	Aug 14, 2018 13:48:37	Info	Sensor variable	 Serial   6:TestBoard BMP180   0:52960 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 24.6
                          	Aug 14, 2018 13:48:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 60103 TSF:MSG:READ,6-6-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.6
                          	Aug 14, 2018 13:48:37	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Battery level] 99
                          	Aug 14, 2018 13:48:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 60050 TSF:MSG:READ,6-6-0,s=255,c=3,t=0,pt=1,l=1,sg=0:99
                          	Aug 14, 2018 13:48:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 59038 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                          	Aug 14, 2018 13:48:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 59019 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          	Aug 14, 2018 13:48:34	Notice	Node	 Serial   0	Received	Internal	[Log message] 57044 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          	Aug 14, 2018 13:48:34	Notice	Node	 Serial   0	Received	Internal	[Log message] 57004 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          	Aug 14, 2018 13:48:32	Notice	Node	 Serial   0	Received	Internal	[Log message] 55029 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          	Aug 14, 2018 13:48:32	Notice	Node	 Serial   0	Received	Internal	[Log message] 54987 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 53012 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52970 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          	Aug 14, 2018 13:48:30	Notice	Sensor	 Serial   6:TestBoard BMP180   0:52960 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:	Received	Presentation	[Temperature] 52960 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                          	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52960 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                          	Aug 14, 2018 13:48:30	Notice	Sensor	 Serial   6:TestBoard BMP180   1:52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:	Received	Presentation	[Barometer] 52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                          	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                          	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch version] 1.2
                          	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52912 TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
                          	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch name] TestBoard BMP180
                          	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52896 TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=16,sg=0:TestBoard BMP180
                          	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52888 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                          	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Internal	[Config] M
                          	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Config] 0
                          	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52838 TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                          	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Received	Presentation	[Node] 2.3.0
                          	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52822 TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
                          	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50811 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                          	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50769 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50754 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                          	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50746 TSF:MSG:PINGED,ID=6,HP=1
                          	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50740 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                          	Aug 14, 2018 13:48:28	Info	Sensor variable	 Serial   9:TestBoard BMP180   1:1939766 TSF:MSG:READ,9-9-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                          	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50475 TSF:MSG:READ,9-9-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                          	Aug 14, 2018 13:48:28	Notice	Node	 Serial   9:TestBoard BMP180	Received	Internal	[Battery level] 94
                          	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50420 TSF:MSG:READ,9-9-0,s=255,c=3,t=0,pt=1,l=1,sg=0:94
                          	Aug 14, 2018 13:48:26	Notice	Node	 Serial   0	Received	Internal	[Log message] 48758 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          	Aug 14, 2018 13:48:26	Notice	Node	 Serial   0	Received	Internal	[Log message] 48718 TSF:MSG:PINGED,ID=6,HP=1
                          	Aug 14, 2018 13:48:26	Notice	Node	 Serial   0	Received	Internal	[Log message] 48713 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                          	Aug 14, 2018 13:48:24	Notice	Node	 Serial   0	Received	Internal	[Log message] 46737 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          	Aug 14, 2018 13:48:24	Notice	Node	 Serial   0	Received	Internal	[Log message] 46698 TSF:MSG:PINGED,ID=6,HP=1
                          	Aug 14, 2018 13:48:24	Notice	Node	 Serial   0	Received	Internal	[Log message] 46692 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                          	Aug 14, 2018 13:48:23	Notice	Node	 Serial   0	Received	Internal	[Log message] 45289 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44651 TSF:MSG:GWL OK
                          	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44648 TSF:CKU:OK,FCTRL
                          	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44645 TSF:MSG:FPAR REQ,ID=6
                          	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44642 TSF:MSG:BC
                          	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44636 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          	Aug 14, 2018 13:48:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 43259 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                          	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42601 TSF:MSG:GWL OK
                          	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42598 TSF:CKU:OK
                          	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42595 TSF:PNG:SEND,TO=0
                          	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42592 TSF:MSG:FPAR REQ,ID=6
                          	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42589 TSF:MSG:BC
                          	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42583 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          	Aug 14, 2018 13:48:16	Notice	Node	 Serial   0	Received	Internal	[Log message] 39150 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                          	Aug 14, 2018 13:48:16	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                          	Aug 14, 2018 13:48:16	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:48:16	Notice	Node	 Serial   0	Received	Internal	[Log message] 39076 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:48:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 36052 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                          	Aug 14, 2018 13:48:13	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                          	Aug 14, 2018 13:48:13	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:48:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 35986 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:48:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 32973 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                          	Aug 14, 2018 13:48:10	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                          	Aug 14, 2018 13:48:10	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:48:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 32902 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:48:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 29905 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                          	Aug 14, 2018 13:48:07	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                          	Aug 14, 2018 13:48:07	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:48:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 29818 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                          	Aug 14, 2018 13:48:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 26406 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                          	Aug 14, 2018 13:48:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 26364 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 24090 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                          	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23288 TSF:MSG:GWL OK
                          	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23285 TSF:CKU:OK,FCTRL
                          	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23281 TSF:MSG:FPAR REQ,ID=6
                          	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23279 TSF:MSG:BC
                          	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23273 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                          	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20989 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                          	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20202 TSF:MSG:GWL OK
                          	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20199 TSF:CKU:OK
                          	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20196 TSF:PNG:SEND,TO=0
                          	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20193 TSF:MSG:FPAR REQ,ID=6
                          	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20190 TSF:MSG:BC
                          	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20184 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                          	Aug 14, 2018 13:47:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 17587 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                          	Aug 14, 2018 13:47:55	Notice	Gateway	 Serial	Sent	Internal	[Discover]
                          	Aug 14, 2018 13:47:48	Info	Sensor variable	 Serial   7:TestBoard BMP180   1:38654387 TSF:MSG:READ,7-7-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                          	Aug 14, 2018 13:47:48	Notice	Node	 Serial   0	Received	Internal	[Log message] 11030 TSF:MSG:READ,7-7-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                          	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 34 MCO:BGN:INIT OK,TSP=1
                          	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 28 MCO:BGN:STP
                          	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Presentation	[Repeater node] 2.3.0
                          	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[GatewayTable ready] Gateway startup complete.
                          	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 23 MCO:REG:NOT NEEDED
                          	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 17 TSM:INIT:GW MODE
                          	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 20 TSM:READY:ID=0,PAR=0,DIS=0
                          	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 14 TSM:INIT:TSP OK
                          	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 6 TSF:WUR:MS=0
                          unfortunately somehow makes no difference
                          I think I let the fun with FOTA first and reburn the stock arduino bootloader. The normal sensor transmission works so apparently without problems
                          tekkaT 1 Reply Last reply
                            Try using nrf24 normal module, not PA, on gateway and see if you get better results
                            • H Harrdy
                              tekkaT
                              tekkaT
                              tekka
                              @harrdy Maybe node & GW are too close - try moving them further away. Also, what RF24_PA_LEVEL setting are you using on your GW?
                              • H
                                H
                                Harrdy
                                wrote on last edited by Harrdy
                                i also try different distances, from few cm to a few meters. All nodes were flashed with RF24_PA_LEVEL HIGH. On the gw i try LOW and HIGH
                                My idea was still to get the Sensebender Gateway to exclude the gateway as a source of error. But I'm not sure if the Sensebender gw supports the nrf24l01+pa. Or i buy another finish builded gateway based on esp8266 (like MDMSGate) or something else ...
                                  Try low power on both radio and put them 3 meters away. Those unshielded pa modules are a pain with higher power settings
                                  • H
                                    H
                                    Harrdy
                                    Your right, it was a power supply issue. I made few changes.
                                    • first step, change back from uno to nano.
                                    • second step, move from nano shield to breadboard
                                    • third step, add a powersupply breadboard shield
                                    • fourth step, add 0.1uF & 100uF cap between gnd and 3.3v
                                    after this, all red flashes are gone (PA LEVEL High). all "NACK" messages have disappeared and never come back until now.
                                    edit: ok, too happy ... wrong wired leds, connected to 3-5 instead of 4-6. red flashes are still alive and my arrest because of the disappeared nack messages? a filter in mycontroller ... :/
                                    i also tried both radios @low with 3 meters distance. same result.
                                      Try a normal radio on gateway instead of the PA lna
