  3. FOTA wont work, Controller error NACK
20 Posts 3 Posters 3.2k Views 3 Watching
  • H
    H
    Harrdy
    How can i do this? I have the ttl reader on the arduino during the start. but the console is empty. Only after the fota process is finished, i see the output of the mysensors sketches. While the gateway is flashing red, the console remains empty. It takes about 10-15 seconds
    tekkaT 1 Reply Last reply
      I think there is a define to enable it, but I don't remember well as I use the dual optiboot. Maybe @tekka could help
      • H Harrdy
        tekkaT
        tekkaT
        tekka
        @harrdy MYSBootloader does not have a serial console output. In order to get a better understanding of your setup: can you post the full debug logs (GW & node) starting from the node booting until sending sensor data + node sketch?
        • H
          H
          Harrdy
          wrote on last edited by Harrdy
          Re: [FOTA wont work](Controller error NACK)
          @tekka
          node log during start until send sensor data
           __  __       ____
          16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
          26 MCO:BGN:BFR
          28 TSM:INIT
          30 TSF:WUR:MS=0
          36 TSM:INIT:TSP OK
          38 TSF:SID:OK,ID=6
          40 TSM:FPAR
          77 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          2084 !TSM:FPAR:NO REPLY
          2086 TSM:FPAR
          2123 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          4130 !TSM:FPAR:NO REPLY
          4132 TSM:FPAR
          4169 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          4188 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          4194 TSF:MSG:FPAR OK,ID=0,D=1
          6176 TSM:FPAR:OK
          6176 TSM:ID
          6178 TSM:ID:OK
          6180 TSM:UPL
          6184 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
          8192 TSM:UPL
          8198 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
          10207 TSM:UPL
          10209 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
          10901 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
          10907 TSF:MSG:BC
          11608 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
          12218 TSM:UPL
          12255 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
          12265 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
          12271 TSF:MSG:PONG RECV,HP=1
          12273 TSM:UPL:OK
          12275 TSM:READY:ID=6,PAR=0,DIS=1
          12314 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
          14329 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=OK:2.3.0
          14372 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=NACK:0
          16386 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=16,sg=0,ft=1,st=OK:TestBoard BMP180
          16402 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
          16420 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=OK:
          16429 TSF:MSG:SEND,6-6-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
          16435 MCO:REG:REQ
          16474 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
          18489 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
          20496 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
          22507 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
          24516 MCO:BGN:STP
          25018 MCO:BGN:INIT OK,TSP=1
          Battery Voltage: 3.25 V
          Battery percent: 96 %
          25552 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:96
          Temperature = 24.80 *C
          Pressure = 1016.96 hPa
          Forecast = unknown
          25608 TSF:MSG:SEND,6-6-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:24.8
          25620 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:1017
          25630 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=5,pt=0,l=7,sg=0,ft=0,st=OK:unknown
          25638 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
          25645 TSF:TDI:TSL
          25647 MCO:SLP:WUP=-1
          25649 TSF:TRI:TSB
          Battery Voltage: 2.95 V
          Battery percent: 87 %
          26189 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=NACK:87
          Pressure = 1016.87 hPa
          Forecast = unknown
          26243 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=4,pt=7,l=5,sg=0,ft=1,st=OK:1017
          26251 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
          26257 TSF:TDI:TSL
          gateway log
          	Aug 14, 2018 10:57:44	Notice	Node	 Serial   0	Received	Internal	[Log message] 3637381 TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:89
          	Aug 14, 2018 10:57:44	Notice	Node	 Serial   5:TestBoard BH1750	Received	Internal	[Battery level] 89
          	Aug 14, 2018 10:57:44	Info	Sensor variable	 Serial   5:TestBoard BH1750   20:45857 TSF:MSG:READ,5-5-0,s=20,c=0,t=16,pt=0,l=0,sg=0:  Light level	Received	Set	[Light level] 199
          	Aug 14, 2018 10:57:44	Notice	Node	 Serial   0	Received	Internal	[Log message] 3637369 TSF:MSG:READ,5-5-0,s=20,c=1,t=23,pt=3,l=2,sg=0:199
          	Aug 14, 2018 10:57:36	Info	Sensor variable	 Serial   9:TestBoard BMP180   1:1939766 TSF:MSG:READ,9-9-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
          	Aug 14, 2018 10:57:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3629883 TSF:MSG:READ,9-9-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
          	Aug 14, 2018 10:57:21	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Forecast	Received	Set	[Forecast] unknown
          	Aug 14, 2018 10:57:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 3614796 TSF:MSG:READ,6-6-0,s=1,c=1,t=5,pt=0,l=7,sg=0:unknown
          	Aug 14, 2018 10:57:21	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
          	Aug 14, 2018 10:57:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 3614785 TSF:MSG:READ,6-6-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
          	Aug 14, 2018 10:57:21	Info	Sensor variable	 Serial   6:TestBoard BMP180   0:3605562 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 24.8
          	Aug 14, 2018 10:57:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 3614773 TSF:MSG:READ,6-6-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.8
          	Aug 14, 2018 10:57:21	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Battery level] 96
          	Aug 14, 2018 10:57:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 3614691 TSF:MSG:READ,6-6-0,s=255,c=3,t=0,pt=1,l=1,sg=0:96
          	Aug 14, 2018 10:57:18	Notice	Node	 Serial   0	Received	Internal	[Log message] 3611703 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
          	Aug 14, 2018 10:57:18	Notice	Node	 Serial   0	Received	Internal	[Log message] 3611661 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
          	Aug 14, 2018 10:57:16	Notice	Node	 Serial   0	Received	Internal	[Log message] 3609686 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
          	Aug 14, 2018 10:57:16	Notice	Node	 Serial   0	Received	Internal	[Log message] 3609644 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
          	Aug 14, 2018 10:57:14	Notice	Node	 Serial   0	Received	Internal	[Log message] 3607665 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
          	Aug 14, 2018 10:57:14	Notice	Node	 Serial   0	Received	Internal	[Log message] 3607623 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
          	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605614 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
          	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605572 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
          	Aug 14, 2018 10:57:12	Notice	Sensor	 Serial   6:TestBoard BMP180   0:3605562 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:	Received	Presentation	[Temperature] 3605562 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
          	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605562 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
          	Aug 14, 2018 10:57:12	Notice	Sensor	 Serial   6:TestBoard BMP180   1:3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:	Received	Presentation	[Barometer] 3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
          	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605553 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
          	Aug 14, 2018 10:57:12	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch version] 1.2
          	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605530 TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
          	Aug 14, 2018 10:57:12	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch name] TestBoard BMP180
          	Aug 14, 2018 10:57:12	Notice	Node	 Serial   0	Received	Internal	[Log message] 3605516 TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=16,sg=0:TestBoard BMP180
          	Aug 14, 2018 10:57:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 3603517 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
          	Aug 14, 2018 10:57:10	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Internal	[Config] M
          	Aug 14, 2018 10:57:10	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Config] 0
          	Aug 14, 2018 10:57:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 3603466 TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
          	Aug 14, 2018 10:57:10	Notice	Node	 Serial   6:TestBoard BMP180	Received	Presentation	[Node] 2.3.0
          	Aug 14, 2018 10:57:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 3603451 TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
          	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601444 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
          	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601401 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601386 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
          	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601347 TSF:MSG:PINGED,ID=6,HP=1
          	Aug 14, 2018 10:57:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 3601341 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
          	Aug 14, 2018 10:57:07	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Discover response] 0
          	Aug 14, 2018 10:57:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 3600699 TSF:MSG:READ,6-6-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
          	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3600049 TSF:SAN:OK
          	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3600040 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
          	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3600003 TSM:READY:NWD REQ
          	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599915 TSF:MSG:READ,7-7-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
          	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599904 TSF:MSG:READ,7-7-0,s=0,c=1,t=0,pt=7,l=5,sg=0:23.0
          	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599368 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
          	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599328 TSF:MSG:PINGED,ID=6,HP=1
          	Aug 14, 2018 10:57:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 3599322 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
          	Aug 14, 2018 10:57:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 3597344 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
          	Aug 14, 2018 10:57:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 3597305 TSF:MSG:PINGED,ID=6,HP=1
          	Aug 14, 2018 10:57:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 3597299 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
          	Aug 14, 2018 10:57:02	Notice	Node	 Serial   0	Received	Internal	[Log message] 3595327 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
          	Aug 14, 2018 10:57:02	Notice	Node	 Serial   0	Received	Internal	[Log message] 3595287 TSF:MSG:PINGED,ID=6,HP=1
          	Aug 14, 2018 10:57:02	Notice	Node	 Serial   0	Received	Internal	[Log message] 3595281 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
          	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593279 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
          	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593241 TSF:MSG:GWL OK
          	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593238 TSF:CKU:OK,FCTRL
          	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593234 TSF:MSG:FPAR REQ,ID=6
          	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593231 TSF:MSG:BC
          	Aug 14, 2018 10:57:00	Notice	Node	 Serial   0	Received	Internal	[Log message] 3593225 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
          	Aug 14, 2018 10:56:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591251 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
          	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591188 TSF:MSG:GWL OK
          	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591185 TSF:CKU:OK,FCTRL
          	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591181 TSF:MSG:FPAR REQ,ID=6
          	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591178 TSF:MSG:BC
          	Aug 14, 2018 10:56:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 3591172 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
          	Aug 14, 2018 10:56:56	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589200 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
          	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589139 TSF:MSG:GWL OK
          	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589136 TSF:CKU:OK
          	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589133 TSF:PNG:SEND,TO=0
          	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589129 TSF:MSG:FPAR REQ,ID=6
          	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589126 TSF:MSG:BC
          	Aug 14, 2018 10:56:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 3589120 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
          	Aug 14, 2018 10:56:52	Notice	Node	 Serial   0	Received	Internal	[Log message] 3585674 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
          	Aug 14, 2018 10:56:52	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
          	Aug 14, 2018 10:56:52	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
          	Aug 14, 2018 10:56:52	Notice	Node	 Serial   0	Received	Internal	[Log message] 3585614 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
          	Aug 14, 2018 10:56:49	Notice	Node	 Serial   0	Received	Internal	[Log message] 3582587 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
          	Aug 14, 2018 10:56:49	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
          	Aug 14, 2018 10:56:49	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
          	Aug 14, 2018 10:56:49	Notice	Node	 Serial   0	Received	Internal	[Log message] 3582528 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
          	Aug 14, 2018 10:56:46	Notice	Node	 Serial   0	Received	Internal	[Log message] 3579492 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
          	Aug 14, 2018 10:56:46	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
          	Aug 14, 2018 10:56:46	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
          	Aug 14, 2018 10:56:46	Notice	Node	 Serial   0	Received	Internal	[Log message] 3579432 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
          	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576639 TSF:MSG:READ,1-1-0,s=255,c=3,t=0,pt=1,l=1,sg=0:91
          	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576627 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:60.8
          	Aug 14, 2018 10:56:43	Info	Sensor variable	 Serial   1:TemperatureAndHumidity   1:405720740 TSF:MSG:READ,1-1-0,s=1,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 22.8
          	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576616 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:22.8
          	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576399 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
          	Aug 14, 2018 10:56:43	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
          	Aug 14, 2018 10:56:43	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
          	Aug 14, 2018 10:56:43	Notice	Node	 Serial   0	Received	Internal	[Log message] 3576339 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
          	Aug 14, 2018 10:56:39	Notice	Node	 Serial   0	Received	Internal	[Log message] 3572920 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
          	Aug 14, 2018 10:56:39	Notice	Node	 Serial   0	Received	Internal	[Log message] 3572877 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569977 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
          	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569800 TSF:MSG:GWL OK
          	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569796 TSF:CKU:OK,FCTRL
          	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569792 TSF:MSG:FPAR REQ,ID=6
          	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569789 TSF:MSG:BC
          	Aug 14, 2018 10:56:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 3569782 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
          	Aug 14, 2018 10:56:34	Notice	Node	 Serial   0	Received	Internal	[Log message] 3567338 TSF:MSG:READ,9-9-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
          	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566862 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
          	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566706 TSF:MSG:GWL OK
          	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566703 TSF:CKU:OK
          	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566700 TSF:PNG:SEND,TO=0
          	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566696 TSF:MSG:FPAR REQ,ID=6
          	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566693 TSF:MSG:BC
          	Aug 14, 2018 10:56:33	Notice	Node	 Serial   0	Received	Internal	[Log message] 3566687 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
          its my ota file, the same thing that is already on the arduino. i only change the sketch name.
          node sketch was too long, i use github to host it
          https://github.com/Harrdy/MySensors-TestBoard/blob/master/MySensors-TestBoard.ino
          currently used gateway
          3.3v directly from arduino with 47uF cap
          currently used node
          • H Harrdy
            @tekka
             __  __       ____
            26 MCO:BGN:BFR
            28 TSM:INIT
            30 TSF:WUR:MS=0
            36 TSM:INIT:TSP OK
            38 TSF:SID:OK,ID=6
            40 TSM:FPAR
            2086 TSM:FPAR
            4132 TSM:FPAR
            6176 TSM:FPAR:OK
            6176 TSM:ID
            6178 TSM:ID:OK
            6180 TSM:UPL
            8192 TSM:UPL
            10207 TSM:UPL
            10907 TSF:MSG:BC
            12218 TSM:UPL
            12273 TSM:UPL:OK
            16435 MCO:REG:REQ
            24516 MCO:BGN:STP
            Forecast = unknown
            25645 TSF:TDI:TSL
            25649 TSF:TRI:TSB
            Forecast = unknown
            26257 TSF:TDI:TSL
            gateway log
            currently used node
            tekkaT
            tekkaT
            tekka
            @harrdy Node RF24: There are lots of failed transmissions during startup which normally hints to a power issue (bad capacitor?), a defective radio or a signal interference. Can you exchange both components and give it another spin?
            • H
              H
              Harrdy
              @tekka said in FOTA wont work, Controller error NACK:
              I change both the cap against a new one (old 4,7uF 50v, new 10uF 16v) and change ne nrf against a brand new one
              first node startup
               __  __       ____
              26 MCO:BGN:BFR
              28 TSM:INIT
              30 TSF:WUR:MS=0
              36 TSM:INIT:TSP OK
              38 TSF:SID:OK,ID=6
              40 TSM:FPAR
              2086 TSM:FPAR
              4132 TSM:FPAR
              6176 TSM:FPAR:OK
              6176 TSM:ID
              6178 TSM:ID:OK
              6180 TSM:UPL
              8192 TSM:UPL
              10207 TSM:UPL
              10907 TSF:MSG:BC
              12218 TSM:UPL
              12273 TSM:UPL:OK
              16435 MCO:REG:REQ
              24516 MCO:BGN:STP
              Forecast = unknown
              25645 TSF:TDI:TSL
              second node startup
               __  __       ____
              26 MCO:BGN:BFR
              28 TSM:INIT
              30 TSF:WUR:MS=0
              36 TSM:INIT:TSP OK
              38 TSF:SID:OK,ID=6
              40 TSM:FPAR
              2086 TSM:FPAR
              4132 TSM:FPAR
              6176 !TSM:FPAR:NO REPLY
              6178 TSM:FPAR
              6215 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              8222 !TSM:FPAR:FAIL
              8224 TSM:FAIL:CNT=1
              8226 TSM:FAIL:DIS
              8228 TSF:TDI:TSL
              18229 TSM:FAIL:RE-INIT
              18231 TSM:INIT
              18237 TSM:INIT:TSP OK
              18241 TSF:SID:OK,ID=6
              18243 TSM:FPAR
              18280 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              20289 !TSM:FPAR:NO REPLY
              20291 TSM:FPAR
              20328 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              22337 !TSM:FPAR:NO REPLY
              22339 TSM:FPAR
              22376 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              24385 !TSM:FPAR:NO REPLY
              24387 TSM:FPAR
              24424 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              26433 !TSM:FPAR:FAIL
              26435 TSM:FAIL:CNT=2
              26437 TSM:FAIL:DIS
              26439 TSF:TDI:TSL
              36442 TSM:FAIL:RE-INIT
              36444 TSM:INIT
              36450 TSM:INIT:TSP OK
              36454 TSF:SID:OK,ID=6
              36456 TSM:FPAR
              36493 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              38502 !TSM:FPAR:NO REPLY
              38504 TSM:FPAR
              38541 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              40550 !TSM:FPAR:NO REPLY
              40552 TSM:FPAR
              40589 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              40929 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              40935 TSF:MSG:FPAR OK,ID=0,D=1
              42598 TSM:FPAR:OK
              42600 TSM:ID
              42600 TSM:ID:OK
              42602 TSM:UPL
              42606 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              42622 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              42629 TSF:MSG:PONG RECV,HP=1
              42631 TSM:UPL:OK
              42633 TSM:READY:ID=6,PAR=0,DIS=1
              42643 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              44660 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
              44679 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              44709 TSF:MSG:READ,0-0-6,s=255,c=3,t=6,pt=0,l=1,sg=0:M
              44752 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=16,sg=0,ft=0,st=OK:TestBoard BMP180
              44763 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
              44785 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=OK:
              44795 TSF:MSG:SEND,6-6-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
              44802 MCO:REG:REQ
              44838 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
              46848 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
              46882 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              46888 MCO:PIM:NODE REG=1
              46891 MCO:BGN:STP
              47392 MCO:BGN:INIT OK,TSP=1
              47908 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:96
              Temperature = 25.00 *C
              Pressure = 1017.10 hPa
              Forecast = unknown
              47964 TSF:MSG:SEND,6-6-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:25.0
              47982 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:1017
              47994 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=5,pt=0,l=7,sg=0,ft=0,st=OK:unknown
              48003 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
              48009 TSF:TDI:TSL
              48011 MCO:SLP:WUP=-1
              48013 TSF:TRI:TSB
              48523 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:87
              Pressure = 1017.06 hPa
              1. node startup
               __  __       ____
              26 MCO:BGN:BFR
              28 TSM:INIT
              30 TSF:WUR:MS=0
              36 TSM:INIT:TSP OK
              38 TSF:SID:OK,ID=6
              40 TSM:FPAR
              288 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              294 TSF:MSG:FPAR OK,ID=0,D=1
              2084 TSM:FPAR:OK
              2084 TSM:ID
              2086 TSM:ID:OK
              2088 TSM:UPL
              2093 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2123 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2129 TSF:MSG:PONG RECV,HP=1
              2131 TSM:UPL:OK
              2134 TSM:READY:ID=6,PAR=0,DIS=1
              2138 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              4155 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
              4165 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              6150 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
              6156 TSF:MSG:BC
              6176 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
              6189 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=16,sg=0,ft=0,st=OK:TestBoard BMP180
              6234 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
              6256 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=OK:
              6264 TSF:MSG:SEND,6-6-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
              6270 MCO:REG:REQ
              6275 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              8318 !TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
              10328 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
              10350 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              10356 MCO:PIM:NODE REG=1
              10360 MCO:BGN:STP
              10862 MCO:BGN:INIT OK,TSP=1
              Battery Voltage: 3.34 V
              Battery percent: 99 %
              11368 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:99
              Temperature = 24.90 *C
              Forecast = unknown
              11423 TSF:MSG:SEND,6-6-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:24.9
              11431 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:1017
              11444 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=5,pt=0,l=7,sg=0,ft=0,st=OK:unknown
              11452 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
              11458 TSF:TDI:TSL
              11460 MCO:SLP:WUP=-1
              11462 TSF:TRI:TSB
              gateway during 3. startup
              Aug 14, 2018 12:17:18	Notice	Node	 Serial   0	Received	Internal	[Log message] 8415023 TSF:MSG:READ,7-7-0,s=0,c=1,t=0,pt=7,l=5,sg=0:23.1
              	Aug 14, 2018 12:17:18	Notice	Node	 Serial   7:TestBoard BMP180	Received	Internal	[Battery level] 96
              	Aug 14, 2018 12:17:18	Notice	Node	 Serial   0	Received	Internal	[Log message] 8414968 TSF:MSG:READ,7-7-0,s=255,c=3,t=0,pt=1,l=1,sg=0:96
              	Aug 14, 2018 12:17:11	Notice	Node	 Serial   1:TemperatureAndHumidity	Received	Internal	[Battery level] 91
              	Aug 14, 2018 12:17:11	Notice	Node	 Serial   0	Received	Internal	[Log message] 8408024 TSF:MSG:READ,1-1-0,s=255,c=3,t=0,pt=1,l=1,sg=0:91
              	Aug 14, 2018 12:17:11	Info	Sensor variable	 Serial   1:TemperatureAndHumidity   0:405720731 TSF:MSG:READ,1-1-0,s=0,c=0,t=7,pt=0,l=0,sg=0:  Humidity	Received	Set	[Humidity] 58.7
              	Aug 14, 2018 12:17:11	Notice	Node	 Serial   0	Received	Internal	[Log message] 8408009 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:58.7
              	Aug 14, 2018 12:17:11	Info	Sensor variable	 Serial   1:TemperatureAndHumidity   1:405720740 TSF:MSG:READ,1-1-0,s=1,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 23.5
              	Aug 14, 2018 12:17:11	Notice	Node	 Serial   0	Received	Internal	[Log message] 8407990 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:23.5
              	Aug 14, 2018 12:17:09	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Forecast	Received	Set	[Forecast] unknown
              	Aug 14, 2018 12:17:09	Notice	Node	 Serial   0	Received	Internal	[Log message] 8405341 TSF:MSG:READ,6-6-0,s=1,c=1,t=5,pt=0,l=7,sg=0:unknown
              	Aug 14, 2018 12:17:09	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
              	Aug 14, 2018 12:17:09	Notice	Node	 Serial   0	Received	Internal	[Log message] 8405331 TSF:MSG:READ,6-6-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
              	Aug 14, 2018 12:17:09	Info	Sensor variable	 Serial   6:TestBoard BMP180   0:8400145 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 24.9
              	Aug 14, 2018 12:17:09	Notice	Node	 Serial   0	Received	Internal	[Log message] 8405321 TSF:MSG:READ,6-6-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.9
              	Aug 14, 2018 12:17:09	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Battery level] 99
              	Aug 14, 2018 12:17:09	Notice	Node	 Serial   0	Received	Internal	[Log message] 8405268 TSF:MSG:READ,6-6-0,s=255,c=3,t=0,pt=1,l=1,sg=0:99
              	Aug 14, 2018 12:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 8404247 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
              	Aug 14, 2018 12:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 8404224 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              	Aug 14, 2018 12:17:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 8402214 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
              	Aug 14, 2018 12:17:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 8402172 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              	Aug 14, 2018 12:17:06	Notice	Node	 Serial   4:TestBoard DS18B20	Received	Internal	[Battery level] 87
              	Aug 14, 2018 12:17:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 8402153 TSF:MSG:READ,4-4-0,s=255,c=3,t=0,pt=1,l=1,sg=0:87
              	Aug 14, 2018 12:17:06	Info	Sensor variable	 Serial   4:TestBoard DS18B20   4:2254193 TSF:MSG:READ,4-4-0,s=4,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 21.7
              	Aug 14, 2018 12:17:06	Notice	Node	 Serial   0	Received	Internal	[Log message] 8402139 TSF:MSG:READ,4-4-0,s=4,c=1,t=0,pt=7,l=5,sg=0:21.7
              	Aug 14, 2018 12:17:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400197 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
              	Aug 14, 2018 12:17:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400155 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              	Aug 14, 2018 12:17:04	Notice	Sensor	 Serial   6:TestBoard BMP180   0:8400145 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:	Received	Presentation	[Temperature] 8400145 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
              	Aug 14, 2018 12:17:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400145 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
              	Aug 14, 2018 12:17:04	Notice	Sensor	 Serial   6:TestBoard BMP180   1:8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:	Received	Presentation	[Barometer] 8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
              	Aug 14, 2018 12:17:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400132 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
              	Aug 14, 2018 12:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch version] 1.2
              	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400079 TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
              	Aug 14, 2018 12:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch name] TestBoard BMP180
              	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400066 TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=16,sg=0:TestBoard BMP180
              	Aug 14, 2018 12:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Discover response] 0
              	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400054 TSF:MSG:READ,6-6-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
              	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400045 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
              	Aug 14, 2018 12:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 8400007 TSM:READY:NWD REQ
              	Aug 14, 2018 12:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 8398089 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
              	Aug 14, 2018 12:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Internal	[Config] M
              	Aug 14, 2018 12:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Config] 0
              	Aug 14, 2018 12:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 8398036 TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
              	Aug 14, 2018 12:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Received	Presentation	[Node] 2.3.0
              	Aug 14, 2018 12:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 8398020 TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
              	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8396046 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
              	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8396004 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8395988 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
              	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8395963 TSF:MSG:PINGED,ID=6,HP=1
              	Aug 14, 2018 12:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 8395957 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              	Aug 14, 2018 12:16:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 8394148 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
              	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393918 TSF:MSG:GWL OK
              	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393915 TSF:CKU:OK,FCTRL
              	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393911 TSF:MSG:FPAR REQ,ID=6
              	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393908 TSF:MSG:BC
              	Aug 14, 2018 12:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 8393902 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              	Aug 14, 2018 12:16:52	Notice	Node	 Serial   0	Received	Internal	[Log message] 8388131 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
              	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387324 TSF:MSG:GWL OK
              	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387321 TSF:CKU:OK
              	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387317 TSF:PNG:SEND,TO=0
              	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387314 TSF:MSG:FPAR REQ,ID=6
              	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387311 TSF:MSG:BC
              	Aug 14, 2018 12:16:51	Notice	Node	 Serial   0	Received	Internal	[Log message] 8387305 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
              i'm not sure, is this a node or a gateway issue? i test many times with the node id 6, but all other nodes have the same error at fota. but i use the same components on all nodes, newbie pcb, 4,7uF cap, nrf24l01+, 3.3v booster and 2xAA
              and sometimes, randomly, 1-2 per hour, the gateway flashs red without fota process.
              i already try to change the gateway nrf24l01 pa against a normal one. i think, the red flashes were less. But fota did not work either. But with a normal nrf24l01 i have not received any data from far away nodes
              YouTube - Gateway flashes
              • H Harrdy
                first node startup
                 __  __       ____
                26 MCO:BGN:BFR
                28 TSM:INIT
                30 TSF:WUR:MS=0
                36 TSM:INIT:TSP OK
                38 TSF:SID:OK,ID=6
                40 TSM:FPAR
                2086 TSM:FPAR
                4132 TSM:FPAR
                6176 TSM:FPAR:OK
                6176 TSM:ID
                6178 TSM:ID:OK
                6180 TSM:UPL
                8192 TSM:UPL
                10207 TSM:UPL
                10907 TSF:MSG:BC
                12218 TSM:UPL
                12273 TSM:UPL:OK
                16435 MCO:REG:REQ
                24516 MCO:BGN:STP
                Forecast = unknown
                25645 TSF:TDI:TSL
                second node startup
                 __  __       ____
                26 MCO:BGN:BFR
                28 TSM:INIT
                30 TSF:WUR:MS=0
                36 TSM:INIT:TSP OK
                38 TSF:SID:OK,ID=6
                40 TSM:FPAR
                2086 TSM:FPAR
                4132 TSM:FPAR
                6178 TSM:FPAR
                8222 !TSM:FPAR:FAIL
                8224 TSM:FAIL:CNT=1
                8226 TSM:FAIL:DIS
                8228 TSF:TDI:TSL
                18231 TSM:INIT
                18243 TSM:FPAR
                20291 TSM:FPAR
                22339 TSM:FPAR
                24387 TSM:FPAR
                26437 TSM:FAIL:DIS
                26439 TSF:TDI:TSL
                36444 TSM:INIT
                36456 TSM:FPAR
                38504 TSM:FPAR
                40552 TSM:FPAR
                42598 TSM:FPAR:OK
                42600 TSM:ID
                42600 TSM:ID:OK
                42602 TSM:UPL
                42631 TSM:UPL:OK
                44802 MCO:REG:REQ
                46891 MCO:BGN:STP
                Forecast = unknown
                48009 TSF:TDI:TSL
                48013 TSF:TRI:TSB
                1. node startup
                 __  __       ____
                26 MCO:BGN:BFR
                28 TSM:INIT
                30 TSF:WUR:MS=0
                36 TSM:INIT:TSP OK
                38 TSF:SID:OK,ID=6
                40 TSM:FPAR
                2084 TSM:FPAR:OK
                2084 TSM:ID
                2086 TSM:ID:OK
                2088 TSM:UPL
                2131 TSM:UPL:OK
                6156 TSF:MSG:BC
                6270 MCO:REG:REQ
                10360 MCO:BGN:STP
                Forecast = unknown
                11458 TSF:TDI:TSL
                11462 TSF:TRI:TSB
                tekkaT
                tekkaT
                tekka
                wrote on last edited by tekka
                @harrdy ok, the caps are a bit small, do you have larger ones (10 or 100uF)? GW: exchange the capacitor on the GW radio (>=100uF) and/or power supply (eventually the USB port is too weak?)
                • H
                  H
                  Harrdy
                  yes, i have a full box of caps in all sizes. i swap the gw cap from 10uF to 100uF and change the large (2meter) usb cable against a short one (1meter). the usb cable is attached to a supermicro x86 board (usb 2.0 port). this can deliver 500mA @ 5v
                  	Aug 14, 2018 13:17:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 542441 TSF:MSG:READ,9-9-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                  	Aug 14, 2018 13:17:13	Info	Sensor variable	 Serial   9:TestBoard BMP180   1:1939766 TSF:MSG:READ,9-9-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                  	Aug 14, 2018 13:17:13	Info	Sensor variable	 Serial   9:TestBoard BMP180   0:1939775 TSF:MSG:READ,9-9-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 23.4
                  	Aug 14, 2018 13:17:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 542432 TSF:MSG:READ,9-9-0,s=0,c=1,t=0,pt=7,l=5,sg=0:23.4
                  	Aug 14, 2018 13:17:13	Notice	Node	 Serial   9:TestBoard BMP180	Received	Internal	[Battery level] 94
                  	Aug 14, 2018 13:17:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 542377 TSF:MSG:READ,9-9-0,s=255,c=3,t=0,pt=1,l=1,sg=0:94
                  	Aug 14, 2018 13:17:08	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Forecast	Received	Set	[Forecast] unknown
                  	Aug 14, 2018 13:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 537254 TSF:MSG:READ,6-6-0,s=1,c=1,t=5,pt=0,l=7,sg=0:unknown
                  	Aug 14, 2018 13:17:08	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                  	Aug 14, 2018 13:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 537240 TSF:MSG:READ,6-6-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                  	Aug 14, 2018 13:17:08	Info	Sensor variable	 Serial   6:TestBoard BMP180   0:532055 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 24.4
                  	Aug 14, 2018 13:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 537228 TSF:MSG:READ,6-6-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.4
                  	Aug 14, 2018 13:17:08	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Battery level] 96
                  	Aug 14, 2018 13:17:08	Notice	Node	 Serial   0	Received	Internal	[Log message] 537170 TSF:MSG:READ,6-6-0,s=255,c=3,t=0,pt=1,l=1,sg=0:96
                  	Aug 14, 2018 13:17:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 536145 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                  	Aug 14, 2018 13:17:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 536108 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  	Aug 14, 2018 13:17:05	Notice	Node	 Serial   0	Received	Internal	[Log message] 534134 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  	Aug 14, 2018 13:17:05	Notice	Node	 Serial   0	Received	Internal	[Log message] 534092 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532113 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532072 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  	Aug 14, 2018 13:17:03	Notice	Sensor	 Serial   6:TestBoard BMP180   0:532055 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:	Received	Presentation	[Temperature] 532055 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                  	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532055 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                  	Aug 14, 2018 13:17:03	Notice	Sensor	 Serial   6:TestBoard BMP180   1:532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:	Received	Presentation	[Barometer] 532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                  	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532045 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                  	Aug 14, 2018 13:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch version] 1.2
                  	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532023 TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
                  	Aug 14, 2018 13:17:03	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch name] TestBoard BMP180
                  	Aug 14, 2018 13:17:03	Notice	Node	 Serial   0	Received	Internal	[Log message] 532012 TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=16,sg=0:TestBoard BMP180
                  	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 530048 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                  	Aug 14, 2018 13:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Internal	[Config] M
                  	Aug 14, 2018 13:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Config] 0
                  	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529998 TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  	Aug 14, 2018 13:17:01	Notice	Node	 Serial   6:TestBoard BMP180	Received	Presentation	[Node] 2.3.0
                  	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529988 TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
                  	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529974 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529937 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529925 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                  	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529895 TSF:MSG:PINGED,ID=6,HP=1
                  	Aug 14, 2018 13:17:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 529889 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 528380 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                  	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527849 TSF:MSG:GWL OK
                  	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527846 TSF:CKU:OK,FCTRL
                  	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527842 TSF:MSG:FPAR REQ,ID=6
                  	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527840 TSF:MSG:BC
                  	Aug 14, 2018 13:16:59	Notice	Node	 Serial   0	Received	Internal	[Log message] 527834 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  	Aug 14, 2018 13:16:57	Info	Sensor variable	 Serial   7:TestBoard BMP180   1:38654387 TSF:MSG:READ,7-7-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                  	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 526502 TSF:MSG:READ,7-7-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                  	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 526326 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                  	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525798 TSF:MSG:GWL OK
                  	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525796 TSF:CKU:OK
                  	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525792 TSF:PNG:SEND,TO=0
                  	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525789 TSF:MSG:FPAR REQ,ID=6
                  	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525786 TSF:MSG:BC
                  	Aug 14, 2018 13:16:57	Notice	Node	 Serial   0	Received	Internal	[Log message] 525779 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  	Aug 14, 2018 13:16:53	Notice	Node	 Serial   0	Received	Internal	[Log message] 522332 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                  	Aug 14, 2018 13:16:53	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                  	Aug 14, 2018 13:16:53	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                  	Aug 14, 2018 13:16:53	Notice	Node	 Serial   0	Received	Internal	[Log message] 522274 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                  	Aug 14, 2018 13:16:50	Notice	Node	 Serial   0	Received	Internal	[Log message] 519248 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                  	Aug 14, 2018 13:16:50	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                  	Aug 14, 2018 13:16:50	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                  	Aug 14, 2018 13:16:50	Notice	Node	 Serial   0	Received	Internal	[Log message] 519189 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                  	Aug 14, 2018 13:16:47	Notice	Node	 Serial   0	Received	Internal	[Log message] 516157 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                  	Aug 14, 2018 13:16:47	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                  	Aug 14, 2018 13:16:47	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                  	Aug 14, 2018 13:16:47	Notice	Node	 Serial   0	Received	Internal	[Log message] 516098 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                  	Aug 14, 2018 13:16:44	Notice	Node	 Serial   0	Received	Internal	[Log message] 513064 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                  	Aug 14, 2018 13:16:44	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                  	Aug 14, 2018 13:16:44	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                  	Aug 14, 2018 13:16:44	Notice	Node	 Serial   0	Received	Internal	[Log message] 513005 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                  	Aug 14, 2018 13:16:40	Notice	Node	 Serial   0	Received	Internal	[Log message] 509591 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                  	Aug 14, 2018 13:16:40	Notice	Node	 Serial   0	Received	Internal	[Log message] 509548 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  	Aug 14, 2018 13:16:38	Notice	Node	 Serial   0	Received	Internal	[Log message] 507119 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506473 TSF:MSG:GWL OK
                  	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506469 TSF:CKU:OK,FCTRL
                  	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506466 TSF:MSG:FPAR REQ,ID=6
                  	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506463 TSF:MSG:BC
                  	Aug 14, 2018 13:16:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 506457 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                  nothing has changed
                  • H
                    H
                    Harrdy
                    i also have some 5v to 3.3v DC-DC StepDown breakouts. So i change the gw nrf24 powering source from directly to 3.3v arduino to this breakout.
                    The breakout is powering from 5v arduino.
                    https://www.ebay.de/itm/5Stks-800MA-5V-to-3-3V-DC-DC-Step-Down-Power-Supply-Buck-Module-AMS1117-LDO-MT/273132979923?hash=item3f97fe86d3:g:6GUAAOSwVzRavJuB
                    Unfortunately, this had no success
                    Bus 003 Device 045: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
                    Device Descriptor:
                      bLength                18
                      bDescriptorType         1
                      bcdUSB               1.10
                      bDeviceClass          255 Vendor Specific Class
                      bDeviceSubClass         0
                      bDeviceProtocol         0
                      bMaxPacketSize0         8
                      idVendor           0x1a86 QinHeng Electronics
                      idProduct          0x7523 HL-340 USB-Serial adapter
                      bcdDevice            2.54
                      iManufacturer           0
                      iProduct                2 USB2.0-Serial
                      iSerial                 0
                      bNumConfigurations      1
                      Configuration Descriptor:
                        bLength                 9
                        bDescriptorType         2
                        wTotalLength           39
                        bNumInterfaces          1
                        bConfigurationValue     1
                        iConfiguration          0
                        bmAttributes         0x80
                          (Bus Powered)
                        MaxPower               96mA
                        Interface Descriptor:
                          bLength                 9
                          bDescriptorType         4
                          bInterfaceNumber        0
                          bAlternateSetting       0
                          bNumEndpoints           3
                          bInterfaceClass       255 Vendor Specific Class
                          bInterfaceSubClass      1
                          bInterfaceProtocol      2
                          iInterface              0
                          Endpoint Descriptor:
                            bLength                 7
                            bDescriptorType         5
                            bEndpointAddress     0x82  EP 2 IN
                            bmAttributes            2
                              Transfer Type            Bulk
                              Synch Type               None
                              Usage Type               Data
                            wMaxPacketSize     0x0020  1x 32 bytes
                            bInterval               0
                            bLength                 7
                            bDescriptorType         5
                            bEndpointAddress     0x02  EP 2 OUT
                            bmAttributes            2
                              Transfer Type            Bulk
                              Synch Type               None
                              Usage Type               Data
                            bInterval               0
                            bLength                 7
                            bDescriptorType         5
                            bEndpointAddress     0x81  EP 1 IN
                            bmAttributes            3
                              Transfer Type            Interrupt
                              Synch Type               None
                              Usage Type               Data
                            wMaxPacketSize     0x0008  1x 8 bytes
                            bInterval               1
                    Device Status:     0x0000
                      (Bus Powered)
                    probably a issue with the arduino nano clone?
                    • H
                      H
                      Harrdy
                      i have another original arduino uno. so, i build a second gateway with it.
                      nrf24l01+pa directly connected to 3.3v with wires. (100uF between vcc and gnd)
                      Aug 14, 2018 13:48:50	Notice	Node	 Serial   0	Received	Internal	[Log message] 72726 TSF:MSG:READ,7-7-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                      	Aug 14, 2018 13:48:50	Info	Sensor variable	 Serial   7:TestBoard BMP180   1:38654387 TSF:MSG:READ,7-7-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                      	Aug 14, 2018 13:48:37	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Forecast	Received	Set	[Forecast] unknown
                      	Aug 14, 2018 13:48:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 60128 TSF:MSG:READ,6-6-0,s=1,c=1,t=5,pt=0,l=7,sg=0:unknown
                      	Aug 14, 2018 13:48:37	Info	Sensor variable	 Serial   6:TestBoard BMP180   1:52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                      	Aug 14, 2018 13:48:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 60115 TSF:MSG:READ,6-6-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                      	Aug 14, 2018 13:48:37	Info	Sensor variable	 Serial   6:TestBoard BMP180   0:52960 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:  Temperature	Received	Set	[Temperature] 24.6
                      	Aug 14, 2018 13:48:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 60103 TSF:MSG:READ,6-6-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.6
                      	Aug 14, 2018 13:48:37	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Battery level] 99
                      	Aug 14, 2018 13:48:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 60050 TSF:MSG:READ,6-6-0,s=255,c=3,t=0,pt=1,l=1,sg=0:99
                      	Aug 14, 2018 13:48:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 59038 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                      	Aug 14, 2018 13:48:36	Notice	Node	 Serial   0	Received	Internal	[Log message] 59019 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      	Aug 14, 2018 13:48:34	Notice	Node	 Serial   0	Received	Internal	[Log message] 57044 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      	Aug 14, 2018 13:48:34	Notice	Node	 Serial   0	Received	Internal	[Log message] 57004 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      	Aug 14, 2018 13:48:32	Notice	Node	 Serial   0	Received	Internal	[Log message] 55029 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      	Aug 14, 2018 13:48:32	Notice	Node	 Serial   0	Received	Internal	[Log message] 54987 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 53012 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52970 TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      	Aug 14, 2018 13:48:30	Notice	Sensor	 Serial   6:TestBoard BMP180   0:52960 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:	Received	Presentation	[Temperature] 52960 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                      	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52960 TSF:MSG:READ,6-6-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
                      	Aug 14, 2018 13:48:30	Notice	Sensor	 Serial   6:TestBoard BMP180   1:52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:	Received	Presentation	[Barometer] 52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                      	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52946 TSF:MSG:READ,6-6-0,s=1,c=0,t=8,pt=0,l=0,sg=0:
                      	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch version] 1.2
                      	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52912 TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
                      	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Sketch name] TestBoard BMP180
                      	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52896 TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=16,sg=0:TestBoard BMP180
                      	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52888 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                      	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Internal	[Config] M
                      	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Received	Internal	[Config] 0
                      	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52838 TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                      	Aug 14, 2018 13:48:30	Notice	Node	 Serial   6:TestBoard BMP180	Received	Presentation	[Node] 2.3.0
                      	Aug 14, 2018 13:48:30	Notice	Node	 Serial   0	Received	Internal	[Log message] 52822 TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
                      	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50811 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                      	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50769 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50754 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                      	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50746 TSF:MSG:PINGED,ID=6,HP=1
                      	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50740 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      	Aug 14, 2018 13:48:28	Info	Sensor variable	 Serial   9:TestBoard BMP180   1:1939766 TSF:MSG:READ,9-9-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                      	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50475 TSF:MSG:READ,9-9-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                      	Aug 14, 2018 13:48:28	Notice	Node	 Serial   9:TestBoard BMP180	Received	Internal	[Battery level] 94
                      	Aug 14, 2018 13:48:28	Notice	Node	 Serial   0	Received	Internal	[Log message] 50420 TSF:MSG:READ,9-9-0,s=255,c=3,t=0,pt=1,l=1,sg=0:94
                      	Aug 14, 2018 13:48:26	Notice	Node	 Serial   0	Received	Internal	[Log message] 48758 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      	Aug 14, 2018 13:48:26	Notice	Node	 Serial   0	Received	Internal	[Log message] 48718 TSF:MSG:PINGED,ID=6,HP=1
                      	Aug 14, 2018 13:48:26	Notice	Node	 Serial   0	Received	Internal	[Log message] 48713 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      	Aug 14, 2018 13:48:24	Notice	Node	 Serial   0	Received	Internal	[Log message] 46737 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      	Aug 14, 2018 13:48:24	Notice	Node	 Serial   0	Received	Internal	[Log message] 46698 TSF:MSG:PINGED,ID=6,HP=1
                      	Aug 14, 2018 13:48:24	Notice	Node	 Serial   0	Received	Internal	[Log message] 46692 TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      	Aug 14, 2018 13:48:23	Notice	Node	 Serial   0	Received	Internal	[Log message] 45289 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                      	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44651 TSF:MSG:GWL OK
                      	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44648 TSF:CKU:OK,FCTRL
                      	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44645 TSF:MSG:FPAR REQ,ID=6
                      	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44642 TSF:MSG:BC
                      	Aug 14, 2018 13:48:22	Notice	Node	 Serial   0	Received	Internal	[Log message] 44636 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      	Aug 14, 2018 13:48:21	Notice	Node	 Serial   0	Received	Internal	[Log message] 43259 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42601 TSF:MSG:GWL OK
                      	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42598 TSF:CKU:OK
                      	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42595 TSF:PNG:SEND,TO=0
                      	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42592 TSF:MSG:FPAR REQ,ID=6
                      	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42589 TSF:MSG:BC
                      	Aug 14, 2018 13:48:20	Notice	Node	 Serial   0	Received	Internal	[Log message] 42583 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      	Aug 14, 2018 13:48:16	Notice	Node	 Serial   0	Received	Internal	[Log message] 39150 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                      	Aug 14, 2018 13:48:16	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                      	Aug 14, 2018 13:48:16	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:48:16	Notice	Node	 Serial   0	Received	Internal	[Log message] 39076 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:48:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 36052 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                      	Aug 14, 2018 13:48:13	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                      	Aug 14, 2018 13:48:13	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:48:13	Notice	Node	 Serial   0	Received	Internal	[Log message] 35986 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:48:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 32973 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                      	Aug 14, 2018 13:48:10	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                      	Aug 14, 2018 13:48:10	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:48:10	Notice	Node	 Serial   0	Received	Internal	[Log message] 32902 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:48:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 29905 !TSF:MSG:SEND,0-0-6-6,s=255,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=NACK:0A000300D80499FB
                      	Aug 14, 2018 13:48:07	Notice	Node	 Serial   6:TestBoard BMP180	Sent	Stream	[Firmware config response] 0A000300D80499FB
                      	Aug 14, 2018 13:48:07	Notice	Node	 Serial   6:TestBoard BMP180	Received	Stream	[Firmware config request] FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:48:07	Notice	Node	 Serial   0	Received	Internal	[Log message] 29818 TSF:MSG:READ,6-6-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFD80476B30103
                      	Aug 14, 2018 13:48:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 26406 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                      	Aug 14, 2018 13:48:04	Notice	Node	 Serial   0	Received	Internal	[Log message] 26364 TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 24090 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23288 TSF:MSG:GWL OK
                      	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23285 TSF:CKU:OK,FCTRL
                      	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23281 TSF:MSG:FPAR REQ,ID=6
                      	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23279 TSF:MSG:BC
                      	Aug 14, 2018 13:48:01	Notice	Node	 Serial   0	Received	Internal	[Log message] 23273 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                      	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20989 !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20202 TSF:MSG:GWL OK
                      	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20199 TSF:CKU:OK
                      	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20196 TSF:PNG:SEND,TO=0
                      	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20193 TSF:MSG:FPAR REQ,ID=6
                      	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20190 TSF:MSG:BC
                      	Aug 14, 2018 13:47:58	Notice	Node	 Serial   0	Received	Internal	[Log message] 20184 TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                      	Aug 14, 2018 13:47:55	Notice	Node	 Serial   0	Received	Internal	[Log message] 17587 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                      	Aug 14, 2018 13:47:55	Notice	Gateway	 Serial	Sent	Internal	[Discover]
                      	Aug 14, 2018 13:47:48	Info	Sensor variable	 Serial   7:TestBoard BMP180   1:38654387 TSF:MSG:READ,7-7-0,s=1,c=0,t=8,pt=0,l=0,sg=0:  Pressure	Received	Set	[Pressure] 1017
                      	Aug 14, 2018 13:47:48	Notice	Node	 Serial   0	Received	Internal	[Log message] 11030 TSF:MSG:READ,7-7-0,s=1,c=1,t=4,pt=7,l=5,sg=0:1017
                      	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 34 MCO:BGN:INIT OK,TSP=1
                      	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 28 MCO:BGN:STP
                      	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Presentation	[Repeater node] 2.3.0
                      	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[GatewayTable ready] Gateway startup complete.
                      	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 23 MCO:REG:NOT NEEDED
                      	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 17 TSM:INIT:GW MODE
                      	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 20 TSM:READY:ID=0,PAR=0,DIS=0
                      	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 14 TSM:INIT:TSP OK
                      	Aug 14, 2018 13:47:37	Notice	Node	 Serial   0	Received	Internal	[Log message] 6 TSF:WUR:MS=0
                      unfortunately somehow makes no difference
                      I think I let the fun with FOTA first and reburn the stock arduino bootloader. The normal sensor transmission works so apparently without problems
                      tekkaT 1 Reply Last reply
                        Try using nrf24 normal module, not PA, on gateway and see if you get better results
                        • H Harrdy
                          tekkaT
                          tekkaT
                          tekka
                          @harrdy Maybe node & GW are too close - try moving them further away. Also, what RF24_PA_LEVEL setting are you using on your GW?
                          • H
                            H
                            Harrdy
                            wrote on last edited by Harrdy
                            i also try different distances, from few cm to a few meters. All nodes were flashed with RF24_PA_LEVEL HIGH. On the gw i try LOW and HIGH
                            My idea was still to get the Sensebender Gateway to exclude the gateway as a source of error. But I'm not sure if the Sensebender gw supports the nrf24l01+pa. Or i buy another finish builded gateway based on esp8266 (like MDMSGate) or something else ...
                              Try low power on both radio and put them 3 meters away. Those unshielded pa modules are a pain with higher power settings
                              • H
                                H
                                Harrdy
                                Your right, it was a power supply issue. I made few changes.
                                • first step, change back from uno to nano.
                                • second step, move from nano shield to breadboard
                                • third step, add a powersupply breadboard shield
                                • fourth step, add 0.1uF & 100uF cap between gnd and 3.3v
                                after this, all red flashes are gone (PA LEVEL High). all "NACK" messages have disappeared and never come back until now.
                                edit: ok, too happy ... wrong wired leds, connected to 3-5 instead of 4-6. red flashes are still alive and my arrest because of the disappeared nack messages? a filter in mycontroller ... :/
                                i also tried both radios @low with 3 meters distance. same result.
                                  Try a normal radio on gateway instead of the PA lna
