  3. 💬 Temperature and humidity sensor(ver.ATmega328)+E-Ink display
39 Posts 12 Posters 10.1k Views 10 Watching
  • H heinzv
    @mfalkvidd ;-) that is what I'm arguing since quite a while and my major concern with the 328p. It has a ridiculous small ram and flash if you want to do something with things like an e-paper display. An almost empty mysensors temp sensor sketch with just adding the GxEPF lib and declaring the minimum display object leads to 101% RAM and flash is also runnin out. TFT and OLED displays are energy killer and e-paper see to be a ram killer.
    So I'm trying to either to find a bare e-paper library (I've got some C code from Heltec) which I'll try or I have to give up to connect an e-paper to a 328p and really use a second MCU just for e-paper (as it was proposed), even if I don't like to have two MCU's, two sketches etc.
    I see that nearly nobody is building a battery powered sensor with a display.
    MCU's which can deal with all that (a lot of ram, flash, low energy modes) are the ESP MCU's but the sleep behavior seem to be an obstacle for the projects and nobody dares to deal with it - only the ESPeasy project is using and accepting the ESP deep sleep behavior with the warmstart concept.
    So I will furthe rinvestigate which project will be the base for my battery powered sensors with a nice display.
    @heinzv it's a great project and it will make me build some e-paper nodes.
    But I don't understand why you don't want to switch to NRF52 ? You would have way more power and memory than you need, and much lower consumption in sleep mode.
    H berkseoB 2 Replies Last reply
    • Nca78N Nca78
      H
      H
      heinzv
      @nca78 you're right, it has more RAM/Flash, low energy for battery usage and I have seen modules which are also around 4€.
      I'll rethink my MCU strategy again for the battery sensors as I have seen that nRF52 is full supported (with sleep, deep sleep) in mySensors right?
      Is this a board you can recommend and is there a PCB which can carry this barebone board? I would also like to use in in conjunction with an RFM95 (LoRa).
      https://www.aliexpress.com/item/nRF52832-2-4GHz-Wireless-rf-Module-CDSENET-E73-2G4M04S-SPI-SMD-rf-Receiver-transmitter-Bluetooth-Module/32819293925.html?spm=2114.search0104.3.1.154316a3exrCMu&ws_ab_test=searchweb0_0,searchweb201602_5_5724111_10065_10068_5724211_10547_5723812_10548_5724311_5723712_5890011_10696_5723212_5724011_10084_10083_10618_5722212_10304_5970011_10307_10820_5723412_10821_5723312_10302_5723612_5723112_5910011_5723912_5722312_10059_5722112_100031_5725111_10103_5725011_5722412_5723012_5990011_5980011_5724911,searchweb201603_1,ppcSwitch_3&algo_expid=a0777517-1560-4235-9f5e-6be74d13d07d-0&algo_pvid=a0777517-1560-4235-9f5e-6be74d13d07d&transAbTest=ae803_1&priceBeautifyAB=0
      berkseoB 1 Reply Last reply
      • mfalkviddM
        Neverdie has created a few, https://www.openhardware.io/view/436/nRF52832-Breakout-Board for example
        • Nca78N Nca78
          berkseoB
          berkseoB
          berkseo
          @nca78 said in 💬 Temperature and humidity sensor with 1.54 E-Paper display:
          Such a sensor will be, until everything suits in 328 (consumption, memory). I'm still studying the NRF52 chip. Of special interest is the awakening from an external request. The standard implementation in NRF24 compatibility mode is not impressive :(
          tekkaT 1 Reply Last reply
          • berkseoB berkseo
            tekkaT
            tekkaT
            tekka
            @berkseo Nice board and idea - would you mind posting your pcb layout files and testing sketch for the community?
            • tekkaT tekka
              berkseoB
              berkseoB
              berkseo
              @tekka
              I think that I will update the information from few days on openhardware.io. Waiting for new PCB with the changes (rev2), their photo was spread higher in this topic. It is necessary to check them, if everything is ok, I update the information.
              • berkseoB
                berkseoB
                berkseo
                #32
                maybe someone can tell me why my Gerber files don't work here?
                Latin letters?
                • berkseoB
                  berkseoB
                  berkseo
                  • berkseoB berkseo
                    Latin letters?
                    #34
                    @berkseo I have the same problem. This has been going on for some time now. @HEK needs to fix it, but hasn't. So, I end up posting images from OSHPARK, or else it looks like a mouse has gnawed away at my PCB. @HEK, how about fixing it?
                      wrote on last edited by hek
                      #35
                      Yeah, openhardware.io is dependent on the https://github.com/tracespace/gerber-to-svg / https://www.npmjs.com/package/pcb-stackup-core project. I use it to generate an svg which then is converted to png with alpha channel which is feed into some three.js magic hack on the frontend to "cut the holes" using alpha in the png.
                      Some gerbers seems to render a bit funny. I have tried tweaking it and have sent bug reports to the author a few times. But pcb-stackup is a slow progressing project. The outline have been disables due to even worse rendering in many occasions. Not sure what triggers faulty renderings. Kicad/Eagle gerbers seems to work better for some reason.
                      In this specific case I guess the problem is because you're using a none-standard naming of the gerber files. Check some other project on openhardware.io that renders fine to see the correct naming of the different layer-files.
                        @hek FWIW, in the past it seemed to work fine. Only in the last year or so has it stopped working correctly. So, maybe if you/they revert to an earlier version....
                        • H heinzv
                          berkseoB
                          berkseoB
                          berkseo
                          #37
                          @heinzv
                          I have not been able to run these modules, it seems they are problematic
                          ...but found as it seems to me the best
                          I know that with these modules can be more or less tolerable work in NRF DK. But I needed the modules that each user would be able to programming in Arduino IDE as simple as atmega328
                          • alowhumA
                            alowhumA
                            alowhum
                            I have been working with serial driven screens for a while. They work!
                            I just noticed there's also an e-paper version. Perhaps it's interesting?
                            https://www.waveshare.com/wiki/4.3inch_e-Paper_UART_Module
                            • berkseoB
                              berkseoB
                              berkseo
                              The project is closed. See the continuation of this development in the new project - https://www.openhardware.io/view/629/EFEKTA-TempandHum-sensorver-nRF52832-E-Ink-display
