  3. 💬 Sensebender Micro
💬 Sensebender Micro
temperatureatmega328atsha204ahumidityflashmysensors
116 Posts 42 Posters 52.2k Views 38 Watching
  • F flybysun
    I'm using the mysensor lib for a while but I recently run into problems. I've some arduino pro minis running with dht22 sensors which send their data over nrf24 to an mqtt ethernet gateway.
    But maybe someone can help me with this one: I have build my own sensebender-micro modules. First of all I programmed the fuses of the mega328p as follows: lfuse: 0xE2, hfuse: 0xD2, efuse: 0xFE. Then I've programmed the DualOptiBoot Bootloader to them, everything worked fine so far, I can upoload sketches from the Arduino IDE via FTDI Programmer. The Problem: When I upload the official example sketch and watch the serial monitor I just see the MySensors splash screen. It seems, that the sketch does not even run into the setup routine. This starts to make me crazy, since I do not even know where to search. If I upload other sketches (basic blinking led, serial port examples or the passive node example from mysensors) it shows that my hardware in general seems to work. When I enable debug this is the output:
     __  __       ____
    16 MCO:BGN:INIT NODE,CP=RNONA---,VER=2.3.0
    26 TSM:INIT
    28 TSF:WUR:MS=0
    36 TSM:INIT:TSP OK
    38 TSF:SID:OK,ID=100
    40 TSM:FPAR
    75 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2084 !TSM:FPAR:NO REPLY
    2086 TSM:FPAR
    2121 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4130 !TSM:FPAR:NO REPLY
    4132 TSM:FPAR
    4167 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6176 !TSM:FPAR:NO REPLY
    6178 TSM:FPAR
    6213 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8222 !TSM:FPAR:FAIL
    8224 TSM:FAIL:CNT=1
    8226 TSM:FAIL:DIS
    8228 TSF:TDI:TSL
    18229 TSM:FAIL:RE-INIT
    18231 TSM:INIT
    18239 TSM:INIT:TSP OK
    18241 TSF:SID:OK,ID=100
    18243 TSM:FPAR
    18280 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20289 !TSM:FPAR:NO REPLY
    Even the NRF24 connection seems to work. This is the output of my mosquitto broker when running the passive node example:
    home/OpenMQTTGateway/LWT Online
    home/OpenMQTTGateway/version 0.7
    mygateway1-out/100/255/0/0/17 2.3.0
    mygateway1-out/100/255/3/0/6 255
    mygateway1-out/100/255/3/0/11 Passive node
    mygateway1-out/100/255/3/0/12 1.0
    mygateway1-out/100/0/0/0/6 (null)
    mygateway1-out/100/0/1/0/0 25.70
    mygateway1-out/100/0/1/0/0 26.90
    mygateway1-out/100/0/1/0/0 27.30
    mygateway1-out/100/0/1/0/0 25.80
    mygateway1-out/100/0/1/0/0 26.00
    I appreciate any help, thanks in advance!
    Hi @flybysun, welcome to the forum!
    !TSM:FPAR:NO REPLY
    means that the sensor node does not get a response from the gateway. What type of gateway are you using? Could you post the debug log from it?
    If you haven't already, check https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to troubleshoot them. (Hint: Power supply is the most common problem, the nrf24 is extremely picky)
    • F
      F
      flybysun
      Hi @mfalkvidd, thanks for the warm welcome!
      So, tonight I'll give it another try. I soldered 1000uF above VCC and GND on both the sender and the gateway RF Links (that's all I could find here for now). Still got issues. Here are the logs from my gateway, when it starts up and receives values from my working sensor I had before:
      0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.3.0
      3 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      12 TSM:INIT:GW MODE
      14 TSM:READY:ID=0,PAR=0,DIS=0
      17 MCO:REG:NOT NEEDED
      580 GWT:TPC:IP=192.168.0.222
      1583 MCO:BGN:STP
      1584 MCO:BGN:INIT OK,TSP=1
      1587 GWT:TPC:IP=192.168.0.222
      2589 GWT:RMQ:MQTT RECONNECT
      2797 GWT:RMQ:MQTT CONNECTED
      2800 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
      20587 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:32.5
      20592 GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/1,MSG SENT
      55353 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:27.3
      55358 GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/0,MSG SENT
      55364 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:32.6
      55369 GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/1,MSG SENT
      This looks okay I guess, now this happens when I activate my SenseBender Micro:
      139854 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      139859 TSF:MSG:BC
      139860 TSF:MSG:FPAR REQ,ID=3
      139864 TSF:PNG:SEND,TO=0
      139866 TSF:CKU:OK
      139868 TSF:MSG:GWL OK
      140512 !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      141940 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      141945 TSF:MSG:BC
      141947 TSF:MSG:FPAR REQ,ID=3
      141949 TSF:CKU:OK,FCTRL
      141952 TSF:MSG:GWL OK
      142632 !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      144021 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      144026 TSF:MSG:BC
      144028 TSF:MSG:FPAR REQ,ID=3
      144030 TSF:CKU:OK,FCTRL
      144033 TSF:MSG:GWL OK
      144746 !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      146101 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      146106 TSF:MSG:BC
      146108 TSF:MSG:FPAR REQ,ID=3
      146111 TSF:CKU:OK,FCTRL
      146113 TSF:MSG:GWL OK
      146857 !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      I filled this logs into the Log Parser and found out that the Gateway receives informations on the sensor node, but when it responses it does not get the ACK from the sensor node.
      May I have a faulty NRF24? I just received a new batch from AliExpress and this my first try with them.
      My gateway is an Arduino Uno Board with the Arduino Ethernet shield and on top of that equipped with the long range version of the NRF24 Board (the one with the antenna).
      The SenseBender is equipped with the "normal" smt version as suggested. The sensor nodes which are working right now were equipped with the smd version of the nrf-board.
      I also found out that the initialization of the sensor and the gateway has a different Core initialization, different capabilities (CP). I looked through the API, but didn't find what CP=RNNGA or CP=RNONA stands for.
      Any suggestions or ideas?
      • F flybysun
        3 TSM:INIT
        4 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        12 TSM:INIT:GW MODE
        1583 MCO:BGN:STP
        139859 TSF:MSG:BC
        139866 TSF:CKU:OK
        141945 TSF:MSG:BC
        144026 TSF:MSG:BC
        146106 TSF:MSG:BC
        @flybysun information on capabilites is available at https://forum.mysensors.org/topic/7718/mysensors-capabilities-deciphering and https://www.mysensors.org/apidocs/group__MyCapabilities.html
        • tbowmoT
          tbowmoT
          tbowmo
          @flybysun
          what is the "official" firmware that you upload to the atmega? If it's the sensebender micro fw, then please observe that this is meant to run with a Si7021 sensor, and not DHT22, so unless you modify things, it won't run without that sensor onboard..
          • F
            F
            flybysun
            wrote on last edited by flybysun
            #98
            @tbowmo
            I have a 1:1 build of the sensebender micro, including the Si7021. Something I definetly will try tonight is to change the the radio modules with one of these I had before (and are working). I've just discovered this here:
            https://forum.mysensors.org/topic/1153/we-are-mostly-using-fake-nrf24l01-s-but-worse-fakes-are-emerging
            With "official" firmware I mean the Arduino Sketch which is included on the hardware webpage:
            • F
              F
              flybysun
              @mfalkvidd @tbowmo
              So folks, I finally got it to work. It really seems to be a problem with my radio modules. When I change my PA module on the gateway against one of these I ordered for the SenseBender Micro, everything works fine. But I still don't understand why my pro mini with the smd radio was able to send the data to the pa module, while the sensebender connected to a smd version still didn't work.
              Is there anything special on the PA Version, that I've missed? I wonder if I can live with that now, I thought the PA Version has a bit more sensitivity and gain and would be better as the central gateway unit.
              • F flybysun
                @mfalkvidd @tbowmo
                @flybysun the PA version draws much more power than the non-PA version (5x more if I remember correctly). If the power supply can't deliver clean power (without ripples or sudden dips), the radio will malfunction.
                • djbonetD
                  djbonetD
                  djbonet
                  Hi team,
                  By curiosity running the Atmega328p at 8mhz down to 1.8v isn’t out of spec ?
                  Does it work reliable ?
                  Should we div8 clock speed than mesure vcc and set prescaler accordingly ?
                  Just by curiosity for further project I see a lot of info to not go above 4Mhz at 1.8mhz as the data sheet and other that it’s working stable even a 8mhz
                  Thanks all !
                  • djbonetD djbonet
                    Hi team,
                    Thanks all !
                    @djbonet yes, running the atmega328 at 8MHz and 1.8V is out of spec.
                    Yes, sometimes running out of spec doesn’t cause problems.
                    djbonetD 1 Reply Last reply
                      djbonetD
                      djbonetD
                      djbonet
                      @mfalkvidd
                      Thank you for your fast answer
                      • djbonetD djbonet
                        @mfalkvidd
                        @djbonet you’re welcome. If I remember correctly, the datasheet diagram shows the limit for 8MHz to be 2.4V
                          marnej
                          Hello
                          Can't compile skech .. .does anyone have updated ?
                            martim
                            Is there a way to order this board somewhere else. I have ordered now 3 times 2 boards. 2 times 1 board broken and it is very hard to communicate with them and almost never reply.
                            tbowmoT 1 Reply Last reply
                            • M martim
                              tbowmoT
                              tbowmoT
                              tbowmo
                              @martim
                              Unfortunately we do not have any other manufacturing partners, so all sensebender boards are produced by itead.
                              How did you confirm that the board where broken? Have you tried starting the self test in the standard firmware that the micro is delivered with?
                              The factory firmware is available at
                              https://github.com/mysensors/SensebenderMicro/blob/master/Arduino/SensebenderMicro/SensebenderMicro.ino
                              • SuperNinjaS
                                SuperNinjaS
                                SuperNinja
                                @tbowmo I am using Sensebender Micro on an ATMega328p Barebones with internal 8MHz and RFM69 working good. Since I don't have quartz connected on PB6 and PB7, I would like to use these ports. I tried from 14 to 21 but unable to flash my led (connected to PB6).
                                With Minicore: PB6 and PB7 are 20 and 21 respectively.
                                With Sensbender Micro, what are the ports? (if they exist)
                                • K
                                  K
                                  keithellis
                                  Hello, really interesting in getting a few of these Sensebender Micros, but it does not seem to be available any more. Will they be coming back into stock?
                                  • K keithellis
                                    tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @keithellis
                                    They should be available here https://itead.cc/product/mysensors-micro/
                                    K 1 Reply Last reply
                                    • tbowmoT tbowmo
                                      @keithellis
                                      K
                                      K
                                      keithellis
                                      @tbowmo Thats great, thank you. The URL seems to have changed.
                                      • K
                                        K
                                        keithellis
                                        Hi there,
                                        Just received a couple of Sensebender Micro's, really excited to get them up and running. I'm trying to compile the sample code, but I can't find a library for the sha204, I'm getting the following error:
                                        sha204_lib_return_codes.h: No such file or directory
                                        Any idea how I can solve this please.
                                        thank you.
                                        • K keithellis
                                          Hi there,
                                          thank you.
                                          @keithellis the file is in the same folder as the example sketch: https://github.com/mysensors/MySensors/tree/development/examples/SecurityPersonalizer
                                          How did you install MySensors? How did you open the SecurityPersonalizer sketch?
