  3. nRF5 action!
nRF5 action!
  • T Toyman
    @neverdie what are potential advantages of micropython?
    @toyman OTA updates.
      Toyman
      @neverdie I am afraid it still relies on Softdevice
      monteM NeverDieN 2 Replies Last reply
      • T Toyman
        monteM
        monteM
        monte
        @toyman no, if your code is in python. So the deal is "just" to port mysensors to python.
        • T Toyman
          #1736
          @toyman Micropython on the BBC micro:bit (which uses the nRF51822) has a Radio library that uses Nordic's proprietary radio modes and doesn't involve Bluetooth. I suppose the question is: what would be involved in getting it to run on the nRF52832 or the nRF52840. Seems like it would be substantially the same.
          Faiing that, if I can directly manipulate the radio registers from miropython as I can from C, then it shouldn't be too hard to get at least minimal radio capability up and running from within micropython.
          If I can get rudimentary radio communications working in micropython, then from there it should be easy to do OTA updates via REPL. I did some proof of concept to that effect on the micro:bit, but quickly ran out of memory--the micro:bit has only a total of 16K of RAM, so there's very little headroom to begin with. On the nRF52840, lack of RAM shouldn't be an issue.
          U 1 Reply Last reply
            @scalz hinted at it previously, but it looks like MyNewt OS might offer yet another way to do OTA updates. According to their posted information, it offers:
            A open-source Bluetooth 5.0 stack (both Host & Controller), NimBLE, that completely replaces the proprietary SoftDevice on Nordic chipsets. (https://github.com/apache/mynewt-core/blob/master/README.md)
            Apparentlly it runs on both the nRF52832 and the nRF52840.
            S 1 Reply Last reply
              speechsupply
              @neverdie
              1737 posts and counting
              Spend hours reading this. Amazing journey so far.
                U
                U
                Uhrheber
                @neverdie There are three ways to manipulate registers directly from Micropython:
                1. Use machine.mem16
                2. Use the decorator @micropython_viper
                  The Viper code emitter implements integer types and pointers, allowing to access memory and registers directly.
                3. Use the decorator @micropython.asm_thumb
                  Write your code in ARM assembler.
                Problem: I don't know whether any of this is already implemented and works reliably in Micropython for nRF.
                • S speechsupply
                  @neverdie
                  Toyman
                  @speechsupply this thread is golden. I was so empowered that was able to easily switch to nRF SDK and to start producing (semi) commercial BLE-ANT device
                  • T Toyman
                    speechsupply
                    @toyman
                    Yea, On monday I'll order a couple of nRF52840 EVAL boards. Any suggestion regarding what to get?
                    Looked at both the BMD-340-EVAL and ofcourse the NRF52840-DK
                    • U Uhrheber
                      #1742
                      @uhrheber said in nRF5 action!:
                      Thanks! We finally nailed it all the way down on this thread here: https://forum.micropython.org/viewtopic.php?f=12&t=5377
                      :smiley:
                      • O
                        O
                        Omemanti
                        wrote on last edited by Omemanti
                        #1743
                        I see somewhat strange behaviour when using millis() for intervals.
                        I'm not sure it's my mistake, but one thing is that it seems that the millis rollover is around; 131.068.570 (36 hours)
                        When the rollover happens, it looks like it interrupts my sleep. Does that make sense?
                        sleep(digitalPinToInterrupt(PIR_Pin), CHANGE, LongSleep);
                        Debug lines => (Temp / RH - Millis)
                        21.44 / 61.15 - 130977952
                        21.43 / 61.16 - 131008158
                        21.42 / 61.15 - 131038364
                        21.44 / 61.14 - 131068570
                        I woke up because I saw movement at: 26576
                        Sleep Duration : -131042000  Im going back to sleep for 150000
                        21.43 / 61.16 - 176822
                        20-10-2018 => its been ±36 hours laters, and he woke up again at the same moment.
                        18.57 / 56.88 - 131007553
                        18.56 / 56.86 - 131037759
                        18.58 / 56.85 - 131067965
                        I woke up because I saw movement at: 25971
                        Sleep duration : -131042000 => Rollover??
                        18.55 / 56.89 - 206423
                        18.53 / 56.89 - 236628
                        18.54 / 56.90 - 266834
                        18.55 / 56.89 - 297040
                        18.54 / 56.90 - 327246
                        • M maciekczwa
                          I have the same problem with brand news ebyte modeules.
                          Here are my openocd logs:
                          Open On-Chip Debugger 0.10.0-dev-gdc53227 (2016-04-09-13:45)
                          Licensed under GNU GPL v2
                          For bug reports, read
                          debug_level: 2
                          0x4000
                          adapter speed: 10000 kHz
                          Info : clock speed 4000 kHz
                          Info : using stlink api v2
                          in procedure 'program'
                          in procedure 'reset' called at file "embedded:startup.tcl", line 478
                          in procedure 'ocd_bouncer'
                          embedded:startup.tcl:454: Error: ** Unable to reset target **
                          in procedure 'program_error' called at file "embedded:startup.tcl", line 479
                          wybrany port szeregowy at file "embedded:startup.tcl", line 454
                          nie istnieje albo Twoja płytka nie jest podłączona
                          O
                          O
                          Omemanti
                          #1744
                          @maciekczwa said in nRF5 action!:
                          debug_level: 2
                          0x4000
                          **embedded:startup.tcl:454: Error: ** Unable to reset target ****
                          maybe someone else already found the solution, but it took me a while to figure it out for myself.
                          So for documentation sake:
                          Just had the exact same things with new Ebyte NRF52832 modules, ST-Link v2 couldn't erase it. (the old once did erase without a single problem )
                          After some digging, I found the following:
                          (I'm using my NRF52832-DK for it, maybe other devices work as well, just tested this one)
                          DK => Ebyte module
                          GND(detect) => GND
                          SWDIO => SWDIO
                          SWDCLK => SWCLK
                          VTG => 3,3V
                          3,3V => 3,3V
                          GND =>GND
                          you can erase the protection using nRFgo Studio
                          1. On the left, you can find a header named Segger, click on that.
                          2. then it shows that it is locked, and you can click recover.
                          3. after that you can erase it
                          4. upload a new sketch using an ST-link V2 or the DK while you are still at it.
                          • alowhumA alowhum
                            This looks like an Arduino-nano/pro-mini style device with an NRF51:
                            https://www.aliexpress.com/item/Nrf51822-LIS3DH-Bluetooth-Module-CJMCU-8223-Bluetooth-acceleration-module/32821873481.html
                            alowhumA
                            alowhumA
                            alowhum
                            @alowhum said in nRF5 action!:
                            I tried uploading a simple blink sketch today. I found some code on github which suggested pin 23 and 24 are LED pins.
                            I got an error uploading via STM32 though.
                            debug_level: 2
                            0x4000
                            Info : Target voltage: 3.233552
                            Warn : UNEXPECTED idcode: 0x0bb11477
                            Error: expected 1 of 1: 0x2ba01477
                            in procedure 'init' called at file "embedded:startup.tcl", line 473
                            ** OpenOCD init failed **
                            shutdown command invoked
                            • O Omemanti
                              debug_level: 2
                              0x4000
                              DK => Ebyte module
                              GND(detect) => GND
                              SWDIO => SWDIO
                              SWDCLK => SWCLK
                              VTG => 3,3V
                              3,3V => 3,3V
                              GND =>GND
                              Toyman
                              @omemanti actually, all you need is to issue the following command:
                              nrfjprog.exe --recover
                              O mr_redM 2 Replies Last reply
                              • T Toyman
                                O
                                O
                                Omemanti
                                #1747
                                @toyman yup, I tried that one, but all it kept saying was something like; can't find programmer.. and this method, which has a GUI, worked without incident :)
                                • O Omemanti
                                  Toyman
                                  @omemanti that's strange, I use the methos regularly and it worls fine.
                                  Oh! Actually, sandeep's installation messes up Jlink drivers so they require reinstall for the method to work.
                                  That's why I am using arduino nrf5 with BMP to completely separate Arduino from Jlink
                                    #1749
                                    FYI, I'm switching from uPython over to uLisp. It already worked on the BBC:microbit, and I just now got uLisp working on the nRF52832. Because uLisp relies on Sandeep's library, it doesn't yet support the nRF52840. However, if/when Sandeep's library does support the nRF52840, the uLisp upgrade will be fairly easy.
                                    http://www.ulisp.com/
                                    Nca78N 1 Reply Last reply
                                      What is the reason for this switch ?
                                      • Nca78N Nca78
                                        #1751
                                        @nca78
                                        1. uPython seemed to require an intimate understanding of a rather complicated build process. I kept running into build-related snags. Maybe in the future they will simplify it.
                                        2. Its garbage collector can't handle heap fragmentation, and it appears that it never will.
                                        3. Adding c-extensions is a rather arcane process.
                                        In contrast, the uLisp build process is far simpler, and uLisp appears to have a proper garbage collector. Adding c-extensions is relatively easy.
                                          For anyone interested, I posted a simple nRF52 Tx and Rx demo program written in Forth: https://github.com/rabbithat/nRF52_SimpleTxRxDemo
                                          This code is a good starting point for beginners, because it is already working. You can easily modify the code to do whatever transmitting and receiving you want.
