  3. nRF5 action!
nRF5 action!
    @scalz hinted at it previously, but it looks like MyNewt OS might offer yet another way to do OTA updates. According to their posted information, it offers:
    A open-source Bluetooth 5.0 stack (both Host & Controller), NimBLE, that completely replaces the proprietary SoftDevice on Nordic chipsets. (https://github.com/apache/mynewt-core/blob/master/README.md)
    Apparentlly it runs on both the nRF52832 and the nRF52840.
    S 1 Reply Last reply
      speechsupply
      @neverdie
      1737 posts and counting
      Spend hours reading this. Amazing journey so far.
        @toyman Micropython on the BBC micro:bit (which uses the nRF51822) has a Radio library that uses Nordic's proprietary radio modes and doesn't involve Bluetooth. I suppose the question is: what would be involved in getting it to run on the nRF52832 or the nRF52840. Seems like it would be substantially the same.
        Faiing that, if I can directly manipulate the radio registers from miropython as I can from C, then it shouldn't be too hard to get at least minimal radio capability up and running from within micropython.
        If I can get rudimentary radio communications working in micropython, then from there it should be easy to do OTA updates via REPL. I did some proof of concept to that effect on the micro:bit, but quickly ran out of memory--the micro:bit has only a total of 16K of RAM, so there's very little headroom to begin with. On the nRF52840, lack of RAM shouldn't be an issue.
        U
        U
        Uhrheber
        @neverdie There are three ways to manipulate registers directly from Micropython:
        1. Use machine.mem16
        2. Use the decorator @micropython_viper
          The Viper code emitter implements integer types and pointers, allowing to access memory and registers directly.
        3. Use the decorator @micropython.asm_thumb
          Write your code in ARM assembler.
        Problem: I don't know whether any of this is already implemented and works reliably in Micropython for nRF.
        • S speechsupply
          @neverdie
          Toyman
          @speechsupply this thread is golden. I was so empowered that was able to easily switch to nRF SDK and to start producing (semi) commercial BLE-ANT device
          • T Toyman
            speechsupply
            @toyman
            Yea, On monday I'll order a couple of nRF52840 EVAL boards. Any suggestion regarding what to get?
            Looked at both the BMD-340-EVAL and ofcourse the NRF52840-DK
            • U Uhrheber
              #1742
              @uhrheber said in nRF5 action!:
              Thanks! We finally nailed it all the way down on this thread here: https://forum.micropython.org/viewtopic.php?f=12&t=5377
              :smiley:
              • O
                O
                Omemanti
                wrote on last edited by Omemanti
                #1743
                I see somewhat strange behaviour when using millis() for intervals.
                I'm not sure it's my mistake, but one thing is that it seems that the millis rollover is around; 131.068.570 (36 hours)
                When the rollover happens, it looks like it interrupts my sleep. Does that make sense?
                sleep(digitalPinToInterrupt(PIR_Pin), CHANGE, LongSleep);
                Debug lines => (Temp / RH - Millis)
                21.44 / 61.15 - 130977952
                21.43 / 61.16 - 131008158
                21.42 / 61.15 - 131038364
                21.44 / 61.14 - 131068570
                I woke up because I saw movement at: 26576
                Sleep Duration : -131042000  Im going back to sleep for 150000
                21.43 / 61.16 - 176822
                20-10-2018 => its been ±36 hours laters, and he woke up again at the same moment.
                18.57 / 56.88 - 131007553
                18.56 / 56.86 - 131037759
                18.58 / 56.85 - 131067965
                I woke up because I saw movement at: 25971
                Sleep duration : -131042000 => Rollover??
                18.55 / 56.89 - 206423
                18.53 / 56.89 - 236628
                18.54 / 56.90 - 266834
                18.55 / 56.89 - 297040
                18.54 / 56.90 - 327246
                • M maciekczwa
                  I have the same problem with brand news ebyte modeules.
                  Here are my openocd logs:
                  Open On-Chip Debugger 0.10.0-dev-gdc53227 (2016-04-09-13:45)
                  Licensed under GNU GPL v2
                  For bug reports, read
                  debug_level: 2
                  0x4000
                  adapter speed: 10000 kHz
                  Info : clock speed 4000 kHz
                  Info : using stlink api v2
                  in procedure 'program'
                  in procedure 'reset' called at file "embedded:startup.tcl", line 478
                  in procedure 'ocd_bouncer'
                  embedded:startup.tcl:454: Error: ** Unable to reset target **
                  in procedure 'program_error' called at file "embedded:startup.tcl", line 479
                  wybrany port szeregowy at file "embedded:startup.tcl", line 454
                  nie istnieje albo Twoja płytka nie jest podłączona
                  O
                  O
                  Omemanti
                  #1744
                  @maciekczwa said in nRF5 action!:
                  debug_level: 2
                  0x4000
                  **embedded:startup.tcl:454: Error: ** Unable to reset target ****
                  maybe someone else already found the solution, but it took me a while to figure it out for myself.
                  So for documentation sake:
                  Just had the exact same things with new Ebyte NRF52832 modules, ST-Link v2 couldn't erase it. (the old once did erase without a single problem )
                  After some digging, I found the following:
                  (I'm using my NRF52832-DK for it, maybe other devices work as well, just tested this one)
                  DK => Ebyte module
                  GND(detect) => GND
                  SWDIO => SWDIO
                  SWDCLK => SWCLK
                  VTG => 3,3V
                  3,3V => 3,3V
                  GND =>GND
                  you can erase the protection using nRFgo Studio
                  1. On the left, you can find a header named Segger, click on that.
                  2. then it shows that it is locked, and you can click recover.
                  3. after that you can erase it
                  4. upload a new sketch using an ST-link V2 or the DK while you are still at it.
                  • alowhumA alowhum
                    This looks like an Arduino-nano/pro-mini style device with an NRF51:
                    https://www.aliexpress.com/item/Nrf51822-LIS3DH-Bluetooth-Module-CJMCU-8223-Bluetooth-acceleration-module/32821873481.html
                    alowhumA
                    alowhumA
                    alowhum
                    @alowhum said in nRF5 action!:
                    I tried uploading a simple blink sketch today. I found some code on github which suggested pin 23 and 24 are LED pins.
                    I got an error uploading via STM32 though.
                    debug_level: 2
                    0x4000
                    Info : Target voltage: 3.233552
                    Warn : UNEXPECTED idcode: 0x0bb11477
                    Error: expected 1 of 1: 0x2ba01477
                    in procedure 'init' called at file "embedded:startup.tcl", line 473
                    ** OpenOCD init failed **
                    shutdown command invoked
                    • O Omemanti
                      debug_level: 2
                      0x4000
                      DK => Ebyte module
                      GND(detect) => GND
                      SWDIO => SWDIO
                      SWDCLK => SWCLK
                      VTG => 3,3V
                      3,3V => 3,3V
                      GND =>GND
                      Toyman
                      @omemanti actually, all you need is to issue the following command:
                      nrfjprog.exe --recover
                      O mr_redM 2 Replies Last reply
                      • T Toyman
                        O
                        O
                        Omemanti
                        #1747
                        @toyman yup, I tried that one, but all it kept saying was something like; can't find programmer.. and this method, which has a GUI, worked without incident :)
                        • O Omemanti
                          Toyman
                          @omemanti that's strange, I use the methos regularly and it worls fine.
                          Oh! Actually, sandeep's installation messes up Jlink drivers so they require reinstall for the method to work.
                          That's why I am using arduino nrf5 with BMP to completely separate Arduino from Jlink
                            #1749
                            FYI, I'm switching from uPython over to uLisp. It already worked on the BBC:microbit, and I just now got uLisp working on the nRF52832. Because uLisp relies on Sandeep's library, it doesn't yet support the nRF52840. However, if/when Sandeep's library does support the nRF52840, the uLisp upgrade will be fairly easy.
                            http://www.ulisp.com/
                            Nca78N 1 Reply Last reply
                              What is the reason for this switch ?
                              • Nca78N Nca78
                                #1751
                                @nca78
                                1. uPython seemed to require an intimate understanding of a rather complicated build process. I kept running into build-related snags. Maybe in the future they will simplify it.
                                2. Its garbage collector can't handle heap fragmentation, and it appears that it never will.
                                3. Adding c-extensions is a rather arcane process.
                                In contrast, the uLisp build process is far simpler, and uLisp appears to have a proper garbage collector. Adding c-extensions is relatively easy.
                                  For anyone interested, I posted a simple nRF52 Tx and Rx demo program written in Forth: https://github.com/rabbithat/nRF52_SimpleTxRxDemo
                                  This code is a good starting point for beginners, because it is already working. You can easily modify the code to do whatever transmitting and receiving you want.
                                    #1753
                                    I just now posted a wireless Forth REPL for nRF52's on github:
                                    https://github.com/rabbithat/nRF52_wireless_Forth_REPL
                                    This allows you to wirelessly connect with a nRF52 remote node to update and/or interact with your code exactly the same as if the remote node was directly connected to your computer.
                                    :grinning: :grinning: :grinning:
                                      smilvert
                                      I have recently installed an Ebyte E73 as my gateway with a DHT22. The problem is that I need to restart the gateway every 2 days and I can't figure out why. Can someone help me?
                                         Copyright (C) 2013-2017 Sensnology AB
                                         REVISION HISTORY
                                      // Enable debug prints
                                      // Enable serial gateway
                                      #define MY_GATEWAY_SERIAL
                                      // Set blinking period
                                      //#define MY_RADIO_NRF24
                                      #define MY_RADIO_NRF5_ESB
                                      //#define MY_RADIO_RFM95
                                      #include "DHT.h"
                                      int switch_led = 1;
                                      #define ledPin 11
                                      #define DHT_DATA_PIN 02
                                      #define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
                                      // Set this offset if the sensor has a permanent small offset to the real temperatures.
                                      // In Celsius degrees (as measured by the device)
                                      #define SENSOR_TEMP_OFFSET 0
                                      static const uint64_t UPDATE_INTERVAL = 600000;
                                      #define CHILD_ID_HUM 1
                                      #define CHILD_ID_TEMP 0
                                      float lastTemp;
                                      float lastHum;
                                      uint8_t nNoUpdatesTemp;
                                      uint8_t nNoUpdatesHum;
                                      bool metric = true;
                                      DHT dht(DHT_DATA_PIN, DHTTYPE);
                                          pinMode(PIN_LED1, OUTPUT);
                                          digitalWrite(PIN_LED1, HIGH);
                                          dht.begin(); // set data pin of DHT sensor
                                          sendSketchInfo("Serial Gateway nrf52", "1.0");
                                          wait(500);
                                          present(CHILD_ID_HUM, S_HUM);
                                          // Reading temperature or humidity takes about 250 milliseconds!
                                          // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
                                          float h = dht.readHumidity();
                                          // Read temperature as Celsius (the default)
                                          float t = dht.readTemperature();
                                          // Read temperature as Fahrenheit (isFahrenheit = true)
                                          float f = dht.readTemperature(true);
                                          Serial.print("Test print");
                                          // Check if any reads failed and exit early (to try again).
                                          if (isnan(h) || isnan(t) || isnan(f)) {
                                          //Serial.println("Failed to read from DHT sensor!");
                                          return;
                                          send(msgHum.set(h, 1));
                                          send(msgTemp.set(t, 1));
                                          wait(UPDATE_INTERVAL);
                                      O 1 Reply Last reply
                                        magkudjee
                                        Hi every one. I'm very new in mysensors (I use bad English)
                                        in my sketch how to setup sleep,interrupt for 3 button (์NRF51822)
                                        thank you
                                        #define MY_NODE_ID 4
                                        #define CHILD_ID_SW1 1
                                        #define CHILD_ID_SW2 2
                                        #define CHILD_ID_SW3 3
                                        #define BUTTON1_PIN 3
                                        #define BUTTON2_PIN 4
                                        #define BUTTON3_PIN 5
                                        boolean sw1State;
                                        boolean lastState1;
                                        boolean tripped1 = HIGH;
                                        boolean sw2State;
                                        boolean lastState2;
                                        boolean tripped2 = HIGH;
                                        boolean sw3State;
                                        boolean lastState3;
                                        boolean tripped3 = HIGH;
                                        MyMessage msg1(CHILD_ID_SW1, V_TRIPPED);
                                        MyMessage msg2(CHILD_ID_SW2, V_TRIPPED);
                                        MyMessage msg3(CHILD_ID_SW3, V_TRIPPED);
                                          sendSketchInfo("Push Button 1", "1.0");
                                          present(CHILD_ID_SW1, S_DOOR);
                                          present(CHILD_ID_SW2, S_DOOR);
                                          present(CHILD_ID_SW3, S_DOOR);
                                          pinMode (BUTTON1_PIN,INPUT_PULLUP);
                                          pinMode (BUTTON2_PIN,INPUT_PULLUP);
                                          pinMode (BUTTON3_PIN,INPUT_PULLUP);
                                          sw1State = digitalRead(BUTTON1_PIN);
                                          if ( ( sw1State == LOW) && (lastState1 == HIGH) ) tripped1 = !tripped1;
                                          send(msg1.set(tripped1==HIGH ? "1" : "0"));
                                             lastState1 = sw1State;
                                          sw2State = digitalRead(BUTTON2_PIN);
                                          if ( ( sw2State == LOW) && (lastState2 == HIGH) ) tripped2 = !tripped2;
                                          send(msg2.set(tripped2==HIGH ? "1" : "0"));
                                             lastState2 = sw2State;
                                          sw3State = digitalRead(BUTTON3_PIN);
                                          if ( ( sw3State == LOW) && (lastState3 == HIGH) ) tripped3 = !tripped3;
                                          send(msg3.set(tripped3==HIGH ? "1" : "0"));
                                             lastState3 = sw3State;
                                          //sleep(digitalPinToInterrupt(BUTTON1_PIN), CHANGE, 0);
                                          //sleep(INTERRUPT, CHANGE, 0);
                                        nagelcN 1 Reply Last reply
                                        • S smilvert
                                             REVISION HISTORY
                                          #include "DHT.h"
                                          int switch_led = 1;
                                          #define ledPin 11
                                          float lastTemp;
                                          float lastHum;
                                          bool metric = true;
                                              wait(500);
                                              return;
                                          O
                                          O
                                          Omemanti
                                          @smilvert do you have some more information? like some serial output?
                                          I had some issues with statements that uses millis(), in about 1,5 up to 2 days (much shorter the normaly I suppose) it did its rollover back to 0. This messed some waiting times for me.
