1.1k Posts 105 Posters 796.0k Views 98 Watching
  • sundberg84S
    sundberg84S
    Im getting so tired of soldering extra wires and stuff so today im doing a "MysX to All common sensors breakout board"...
    Dont know if this will work... but worth a shot.
    • alowhumA
      alowhumA
      alowhum
      #644
      @sundberg84 If I'm honest some of those sensors seem 'old' to me.
      • I usually go for the BEM280 instead of the BMP085 and DHT22. It's so cheap now.
      • I never use pulse soil sensors, only the capacitive kind, as they last much longer and don't pollute the soil.
      In fact, I always make all my sensors with the Nano Wireless Expansion Board, which is about $2. You can simply plug in the NRF24 into it.
      https://www.aliexpress.com/item/Free-shipping-Nano-328P-IO-wireless-sensor-expansion-board-for-XBEE-and-NRF24L01-Socket-for-arduino/32264665470.html
      sundberg84S Nca78N 2 Replies Last reply
      • alowhumA alowhum
        sundberg84S
        sundberg84S
        @alowhum thanks for the reply!
        I used the sensor in MySensors build section, i somehow believe that is whats used the most. But that does not stop me from adding your suggestion for BEM280. That Wireless board looks great, but Im working with the MysX connector so thats why im making this board.
        • alowhumA alowhum
          wrote on last edited by Nca78
          #646
          @alowhum said in What did you build today (Pictures) ?:
          Unfortunately most of the cheap breakout boards found on AliExpress use clones with much worse specs than the original version
          But you can't really make battery-powered sensors with those ? The regulators are AMS1117 with 5mA typical quiescent current.
          monteM 1 Reply Last reply
          • Nca78N Nca78
            monteM
            monteM
            monte
            @nca78 said in What did you build today (Pictures) ?:
            Could you be more specific? How exactly worth specs does they have. Was going to buy a bunch of them. Maybe there is some comparison or tests?
            • alowhumA
              alowhumA
              alowhum
              #648
              @sundberg84 yes, sorry about that, I realised too late that it's an expansion board.
              @Nca78 Thanks! That 5ma leak current was exactly the kind of info I needed about the board. I was wondering it if could be useful for battery powered things. None of my sensors are. Well, one - I used the BBC Micro:bit as a battery powered motion sensor.
              I guess not having a regulator on board is what makes the Arduino Pro Micro so good at being battery powered.
              Out of curiosity: if I attached the board to a Usb powerbank (say 10.000 Mah) to operate as an electricity led pulse sensor.. what would be an estimate for how long it would run?
              mfalkviddM gohanG 2 Replies Last reply
              • alowhumA alowhum
                @alowhum rough calculation: 10,000/5 = 2,000h = 83 days. Lower if other componens also consume power.
                • monteM monte
                  @monte clones use different components, so it depends on which clone.
                  • alowhumA alowhum
                    actually the better solution is the pro mini at 3.3v with regulator and led removed, and you can use an LDO regulator to power it with a LiPo cell or no regulator at all if you use a LiFePO4 battery. Using the arduino at 3.3v allows you to use all radio modules and all the low power sensors.
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      This is my new PSU - 3D printed enclosure and a few components
                      It is very precise.
                      YveauxY bjacobseB sundberg84S 3 Replies Last reply
                      • alexsh1A alexsh1
                        It is very precise.
                        @alexsh1 nice! Why do you have 4 banana sockets and what's the color coding?
                        alexsh1A 1 Reply Last reply
                        • alexsh1A alexsh1
                          It is very precise.
                          bjacobseB
                          bjacobseB
                          bjacobse
                          @alexsh1 Looks awesome
                            #655
                            Something nice about those power supplies is that for very little extra money (maybe $1-3 extra) you can buy versions with UART and/or even bluetooth data output that you can send to a logger. I'd have to check, but it might even be controllable that way also.
                              Yes, in fact I bought the DPS5015 with its metal box and BT/USB interface and I can control it from the computer. Data logging of course is limited to the values on the screen
                              • YveauxY Yveaux
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @yveaux This is simple. The Aliexpress seller sent me these instead of black and red ones. So I have been creative - black and blue is negative and yellow and green is positive. Did not bothered waiting for a few weeks for replacement.
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  #658
                                  @neverdie It is purely for logging and control. I did not require either so did not order it. If you add all extras, it does become considerably more expensive.
                                  • alexsh1A alexsh1
                                    It is very precise.
                                    sundberg84S
                                    sundberg84S
                                    @alexsh1 very nice! Is the 3d-drawing online to be downloaded? I think I want one as well.
                                    • D
                                      dakipro
                                      wrote on last edited by dakipro
                                      #660
                                      Saw that all other kids cool kids have one, so I installed one kitchen-pc as well.
                                      It is Flytech K757 15'' POS terminal, windows 10 pro, touch screen, 300gb (soon to be ssd) 8gb ram dual core 2,2ghz. Purchased from local "ebay" for around 140 eur.
                                      Now I can make that awesome dinner, once in a full moon, without having to carry and unlock my phone all the time...
                                      • axillentA
                                        axillentA
                                        axillent
                                        esp8266 based thermostat for heating system
                                        1_1541182358775_Фото 02.11.2018, 21 10 39.jpg 0_1541182358775_Фото 02.11.2018, 21 07 09.jpg
                                        sense and drive
                                        • axillentA
                                          axillentA
                                          axillent
                                          bridge from single wire (my w3p manchester based) to UART. will be used to bridge single wire network with Ethernet throuth ESP8266 or STM32 + Wiznet
                                          second photo - development stand with w3p bus
                                          sense and drive
