1.1k Posts 105 Posters 796.0k Views 98 Watching
  • monteM monte
    @sundberg84 you can also use smd crystal. They are cheaply available on aliexpress. Are you using 0603 caps and resistors?
    sundberg84S
    sundberg84S
    @monte - 0805 res/caps, (for me easy to solder, while 0603 is possible but start to get hard).
    I was thinking about SMD crystal but left it since i couldnt find a common size. Do you know a good size for SMD crystal (with multiple brands?) like 0805 or a good searchword? I found HC-49S but they are the same size as the ones with pins.
    monteM 1 Reply Last reply
    • sundberg84S sundberg84
      @tbowmo - Thanks!! :) 42mm diameter (round, but the 3d view doesnt show that).
      The track - well, it seems like I can only get KiCad to make 45dgr tracks... need to investigate it its possible to make other tracks...
      O
      O
      Omemanti
      wrote on last edited by Omemanti
      #639
      @sundberg84 "well, it seems like I can only get KiCad to make 45dgr tracks"
      References => General Settings => Limit graphics lines to 45 degrees
      • bjacobseB
        bjacobseB
        bjacobse
        I recently hacked my Assa Abloy/Yale smart lock as it could only turn +-90° created a new washer ring, so it now can turn infinitely so it is usable to use a lock
        The needed 3D stl file or Freecad drawing is to be found here:
        https://www.thingiverse.com/thing:3155286
          @Yveaux - Yes, as long as you don't tell her ;)
          N
          N
          Nina Baines
          What an inspiring thread!
            monteM
            monteM
            monte
            @sundberg84 I've bought these 5032 crystals: https://www.aliexpress.com/item/Free-shipping-20pcs-16-000MHZ-16mhz-20pF-2Pin-5032-smd-quartz-resonator-Crystal/32821974003.html but there are plentiful other offers on aliexspress and/or ebay. This 5032 package seems to be the most common. There is another package with the same size but with 4 pins 2 of which are not connected, I bought them from my local distributor, while was waiting a package from aliexpress. But those with 4 pins are harder to solder (obviously) and I don't see any pros of using them.
            The most suitable for hand soldering and easiest to find are these: 0_1540201979487_2014022559267404.jpg
            According to this image the ones I have are TX5 and TG5.
            • sundberg84S
              sundberg84S
              Im getting so tired of soldering extra wires and stuff so today im doing a "MysX to All common sensors breakout board"...
              Dont know if this will work... but worth a shot.
              • alowhumA
                alowhumA
                alowhum
                #644
                @sundberg84 If I'm honest some of those sensors seem 'old' to me.
                • I usually go for the BEM280 instead of the BMP085 and DHT22. It's so cheap now.
                • I never use pulse soil sensors, only the capacitive kind, as they last much longer and don't pollute the soil.
                In fact, I always make all my sensors with the Nano Wireless Expansion Board, which is about $2. You can simply plug in the NRF24 into it.
                https://www.aliexpress.com/item/Free-shipping-Nano-328P-IO-wireless-sensor-expansion-board-for-XBEE-and-NRF24L01-Socket-for-arduino/32264665470.html
                sundberg84S Nca78N 2 Replies Last reply
                • alowhumA alowhum
                  sundberg84S
                  sundberg84S
                  @alowhum thanks for the reply!
                  I used the sensor in MySensors build section, i somehow believe that is whats used the most. But that does not stop me from adding your suggestion for BEM280. That Wireless board looks great, but Im working with the MysX connector so thats why im making this board.
                  • alowhumA alowhum
                    wrote on last edited by Nca78
                    #646
                    @alowhum said in What did you build today (Pictures) ?:
                    Unfortunately most of the cheap breakout boards found on AliExpress use clones with much worse specs than the original version
                    But you can't really make battery-powered sensors with those ? The regulators are AMS1117 with 5mA typical quiescent current.
                    • Nca78N Nca78
                      monteM
                      monteM
                      monte
                      @nca78 said in What did you build today (Pictures) ?:
                      Could you be more specific? How exactly worth specs does they have. Was going to buy a bunch of them. Maybe there is some comparison or tests?
                      • alowhumA
                        alowhumA
                        alowhum
                        #648
                        @sundberg84 yes, sorry about that, I realised too late that it's an expansion board.
                        @Nca78 Thanks! That 5ma leak current was exactly the kind of info I needed about the board. I was wondering it if could be useful for battery powered things. None of my sensors are. Well, one - I used the BBC Micro:bit as a battery powered motion sensor.
                        I guess not having a regulator on board is what makes the Arduino Pro Micro so good at being battery powered.
                        Out of curiosity: if I attached the board to a Usb powerbank (say 10.000 Mah) to operate as an electricity led pulse sensor.. what would be an estimate for how long it would run?
                        mfalkviddM gohanG 2 Replies Last reply
                        • alowhumA alowhum
                          @alowhum rough calculation: 10,000/5 = 2,000h = 83 days. Lower if other componens also consume power.
                          • monteM monte
                            @monte clones use different components, so it depends on which clone.
                            • alowhumA alowhum
                              actually the better solution is the pro mini at 3.3v with regulator and led removed, and you can use an LDO regulator to power it with a LiPo cell or no regulator at all if you use a LiFePO4 battery. Using the arduino at 3.3v allows you to use all radio modules and all the low power sensors.
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                This is my new PSU - 3D printed enclosure and a few components
                                It is very precise.
                                YveauxY bjacobseB sundberg84S 3 Replies Last reply
                                • alexsh1A alexsh1
                                  It is very precise.
                                  @alexsh1 nice! Why do you have 4 banana sockets and what's the color coding?
                                  alexsh1A 1 Reply Last reply
                                  • alexsh1A alexsh1
                                    It is very precise.
                                    bjacobseB
                                    bjacobseB
                                    bjacobse
                                    @alexsh1 Looks awesome
                                      #655
                                      Something nice about those power supplies is that for very little extra money (maybe $1-3 extra) you can buy versions with UART and/or even bluetooth data output that you can send to a logger. I'd have to check, but it might even be controllable that way also.
                                        Yes, in fact I bought the DPS5015 with its metal box and BT/USB interface and I can control it from the computer. Data logging of course is limited to the values on the screen
                                        • YveauxY Yveaux
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @yveaux This is simple. The Aliexpress seller sent me these instead of black and red ones. So I have been creative - black and blue is negative and yellow and green is positive. Did not bothered waiting for a few weeks for replacement.
