  3. nRF5 action!
nRF5 action!
  • T Toyman
    @omemanti actually, all you need is to issue the following command:
    nrfjprog.exe --recover
    O
    O
    Omemanti
    wrote on last edited by Omemanti
    #1747
    @toyman yup, I tried that one, but all it kept saying was something like; can't find programmer.. and this method, which has a GUI, worked without incident :)
    • O Omemanti
      Toyman
      @omemanti that's strange, I use the methos regularly and it worls fine.
      Oh! Actually, sandeep's installation messes up Jlink drivers so they require reinstall for the method to work.
      That's why I am using arduino nrf5 with BMP to completely separate Arduino from Jlink
        #1749
        FYI, I'm switching from uPython over to uLisp. It already worked on the BBC:microbit, and I just now got uLisp working on the nRF52832. Because uLisp relies on Sandeep's library, it doesn't yet support the nRF52840. However, if/when Sandeep's library does support the nRF52840, the uLisp upgrade will be fairly easy.
        http://www.ulisp.com/
        Nca78N 1 Reply Last reply
          What is the reason for this switch ?
          • Nca78N Nca78
            #1751
            @nca78
            1. uPython seemed to require an intimate understanding of a rather complicated build process. I kept running into build-related snags. Maybe in the future they will simplify it.
            2. Its garbage collector can't handle heap fragmentation, and it appears that it never will.
            3. Adding c-extensions is a rather arcane process.
            In contrast, the uLisp build process is far simpler, and uLisp appears to have a proper garbage collector. Adding c-extensions is relatively easy.
              For anyone interested, I posted a simple nRF52 Tx and Rx demo program written in Forth: https://github.com/rabbithat/nRF52_SimpleTxRxDemo
              This code is a good starting point for beginners, because it is already working. You can easily modify the code to do whatever transmitting and receiving you want.
                #1753
                I just now posted a wireless Forth REPL for nRF52's on github:
                https://github.com/rabbithat/nRF52_wireless_Forth_REPL
                This allows you to wirelessly connect with a nRF52 remote node to update and/or interact with your code exactly the same as if the remote node was directly connected to your computer.
                :grinning: :grinning: :grinning:
                  smilvert
                  I have recently installed an Ebyte E73 as my gateway with a DHT22. The problem is that I need to restart the gateway every 2 days and I can't figure out why. Can someone help me?
                     Copyright (C) 2013-2017 Sensnology AB
                     REVISION HISTORY
                  // Enable debug prints
                  // Enable serial gateway
                  #define MY_GATEWAY_SERIAL
                  // Set blinking period
                  //#define MY_RADIO_NRF24
                  #define MY_RADIO_NRF5_ESB
                  //#define MY_RADIO_RFM95
                  #include "DHT.h"
                  int switch_led = 1;
                  #define ledPin 11
                  #define DHT_DATA_PIN 02
                  #define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
                  // Set this offset if the sensor has a permanent small offset to the real temperatures.
                  // In Celsius degrees (as measured by the device)
                  #define SENSOR_TEMP_OFFSET 0
                  static const uint64_t UPDATE_INTERVAL = 600000;
                  #define CHILD_ID_HUM 1
                  #define CHILD_ID_TEMP 0
                  float lastTemp;
                  float lastHum;
                  uint8_t nNoUpdatesTemp;
                  uint8_t nNoUpdatesHum;
                  bool metric = true;
                  DHT dht(DHT_DATA_PIN, DHTTYPE);
                      pinMode(PIN_LED1, OUTPUT);
                      digitalWrite(PIN_LED1, HIGH);
                      dht.begin(); // set data pin of DHT sensor
                      sendSketchInfo("Serial Gateway nrf52", "1.0");
                      wait(500);
                      present(CHILD_ID_HUM, S_HUM);
                      // Reading temperature or humidity takes about 250 milliseconds!
                      // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
                      float h = dht.readHumidity();
                      // Read temperature as Celsius (the default)
                      float t = dht.readTemperature();
                      // Read temperature as Fahrenheit (isFahrenheit = true)
                      float f = dht.readTemperature(true);
                      Serial.print("Test print");
                      // Check if any reads failed and exit early (to try again).
                      if (isnan(h) || isnan(t) || isnan(f)) {
                      //Serial.println("Failed to read from DHT sensor!");
                      return;
                      send(msgHum.set(h, 1));
                      send(msgTemp.set(t, 1));
                      wait(UPDATE_INTERVAL);
                  O 1 Reply Last reply
                    magkudjee
                    Hi every one. I'm very new in mysensors (I use bad English)
                    in my sketch how to setup sleep,interrupt for 3 button (์NRF51822)
                    thank you
                    #define MY_NODE_ID 4
                    #define CHILD_ID_SW1 1
                    #define CHILD_ID_SW2 2
                    #define CHILD_ID_SW3 3
                    #define BUTTON1_PIN 3
                    #define BUTTON2_PIN 4
                    #define BUTTON3_PIN 5
                    boolean sw1State;
                    boolean lastState1;
                    boolean tripped1 = HIGH;
                    boolean sw2State;
                    boolean lastState2;
                    boolean tripped2 = HIGH;
                    boolean sw3State;
                    boolean lastState3;
                    boolean tripped3 = HIGH;
                    MyMessage msg1(CHILD_ID_SW1, V_TRIPPED);
                    MyMessage msg2(CHILD_ID_SW2, V_TRIPPED);
                    MyMessage msg3(CHILD_ID_SW3, V_TRIPPED);
                      sendSketchInfo("Push Button 1", "1.0");
                      present(CHILD_ID_SW1, S_DOOR);
                      present(CHILD_ID_SW2, S_DOOR);
                      present(CHILD_ID_SW3, S_DOOR);
                      pinMode (BUTTON1_PIN,INPUT_PULLUP);
                      pinMode (BUTTON2_PIN,INPUT_PULLUP);
                      pinMode (BUTTON3_PIN,INPUT_PULLUP);
                      sw1State = digitalRead(BUTTON1_PIN);
                      if ( ( sw1State == LOW) && (lastState1 == HIGH) ) tripped1 = !tripped1;
                      send(msg1.set(tripped1==HIGH ? "1" : "0"));
                         lastState1 = sw1State;
                      sw2State = digitalRead(BUTTON2_PIN);
                      if ( ( sw2State == LOW) && (lastState2 == HIGH) ) tripped2 = !tripped2;
                      send(msg2.set(tripped2==HIGH ? "1" : "0"));
                         lastState2 = sw2State;
                      sw3State = digitalRead(BUTTON3_PIN);
                      if ( ( sw3State == LOW) && (lastState3 == HIGH) ) tripped3 = !tripped3;
                      send(msg3.set(tripped3==HIGH ? "1" : "0"));
                         lastState3 = sw3State;
                      //sleep(digitalPinToInterrupt(BUTTON1_PIN), CHANGE, 0);
                      //sleep(INTERRUPT, CHANGE, 0);
                    nagelcN 1 Reply Last reply
                    • S smilvert
                         REVISION HISTORY
                      #include "DHT.h"
                      int switch_led = 1;
                      #define ledPin 11
                      float lastTemp;
                      float lastHum;
                      bool metric = true;
                          wait(500);
                          return;
                      O
                      O
                      Omemanti
                      @smilvert do you have some more information? like some serial output?
                      I had some issues with statements that uses millis(), in about 1,5 up to 2 days (much shorter the normaly I suppose) it did its rollover back to 0. This messed some waiting times for me.
                      S 1 Reply Last reply
                      • M magkudjee
                        thank you
                        boolean sw1State;
                        boolean lastState1;
                        boolean sw2State;
                        boolean lastState2;
                        boolean sw3State;
                        boolean lastState3;
                        nagelcN
                        nagelcN
                        nagelc
                        @magkudjee
                        MySensors will support 2 interrupts using sleep. I do not think it will support 3.
                        Use this format for the sleep call:
                        sleep(interrupt1, mode1, interrupt2, mode2, ms=0);
                        In your case: sleep(BUTTON1_PIN, CHANGE, BUTTON2_PIN, CHANGE, 0);
                        I don't know how to handle the 3rd interrupt.
                        Check the MySensors API document here: https://www.mysensors.org/download/sensor_api_20#sleeping
                        • O Omemanti
                          smilvert
                          @omemanti Well it seems to start working now... Hopefully it works :) Havn't restart the gateway in 2 weeks now
                          • T Toyman
                            mr_redM
                            mr_redM
                            mr_red
                            @toyman @Omemanti
                            For Documentations sake:
                            I was having the same problems of the Ebyte E73 Module of being locked.
                            The ST_LinkV2 Clone Firmware are not able to recover the modules as the swd implementation is missing some direct register write capabilities.
                            The nfrjprog and nor openocd are working with the ST_LinkV2.
                            As suggested in this thread somewhere, I was able to get the modules unlocked with the Jlink clone and nrfjprog.
                            see also :
                            https://github.com/micooke/arduino-nRF5-smartwatches/blob/master/nrf52_disable_read_protection.txt
                            That (pirated) Firmware is working with swd and is able to recover the modules. Had to solve some dll-issues before, but got it working.
                            After the recovery with nrfjprog the stlink and the jlink are working as expected with openocd.
                            To find out if your wiring etc. is fine and it is really the locked devices you get this when starting your openocd interface.
                            The voltage is fine but the breakpoints are recognized.
                            Info : using stlink api v2
                            It should be
                            Info : nrf52.cpu: hardware has 6 breakpoints, 4 watchpoints
                            ileneken3I 1 Reply Last reply
                            • mr_redM mr_red
                              @toyman @Omemanti
                              see also :
                              It should be
                              ileneken3I
                              ileneken3I
                              ileneken3
                              @mr_red
                              I can add some of my own "documentation" on this issue. I only recently was able to program an Ebyte E73 module, and it was a long struggle. I used the NRF DK, and had help from a Nordic engineer.
                              • The recommended way to connect to the external device is:
                              Using the P20 and P1 headers, connect:
                              P20 VDD -> 3.3v on EBYTE 2G4M04S1B module
                              P20 SWDIO -> SWDIO on EBYTE 2G4M04S1B module
                              P20 SWDCLK -> SWDCLK on EBYTE 2G4M04S1B module
                              P20 VTG -> P1 VDD
                              P1 GND -> GND on EBYTE 2G4M04S1B module
                              To unlock the chip, execute:
                              nrfjprog -f nrf52 --recover
                              They also recommend using nrfjprog to program the device, because nRFgo Studio is deprecated. But I used the Studio and it worked fine. I gave Studio the .hex produced by the Arduino IDE using "Sketch" -> "Export compiled Binary".
                              As mentioned in the previous post, it is unlikely to unlock the board with anything but the NRF DK or a genuine J-Link. (Maybe a good fake J-Link).
                              Mistakes others may be able to learn from:
                              • Soldering the module onto a custom board can be hard. If you miss a little solder on SWDCLK or SWDIO, there is no hope. Check continuity on every pin you need!
                              • Make sure you don't order a NRF52810 module - only NRF52832 . You can program them, but Mysensors is not compatible. It's easy to hit the wrong link on AliExpress as they look identical.
                              • The NRF DK seems to deliver only 2.8V to the device. I first thought there was a problem, and tried to connect external power sources. But it seems to work powered from the DK.
                              mr_redM 1 Reply Last reply
                              • nagelcN nagelc
                                @magkudjee
                                magkudjee
                                @nagelc
                                thank you
                                • ileneken3I ileneken3
                                  @mr_red
                                  P20 VTG -> P1 VDD
                                  mr_redM
                                  mr_redM
                                  mr_red
                                  @ileneken3
                                  It is a struggle indeed. I wanted to stay "low cost" with clone stlink and clone jlink.
                                  As this is in preparation for a local hackspace workshop the entry level should be as low as possible.
                                  And I suceeded to get this running for under 10€. (only one Jlink needed to unlock the modules once)
                                  I am using platform.io and arduino, which use openocd internally. No need for nrfgo or an second programm and take the hex somewhere else.
                                  Highly recommend platform.io for this! Flashing & Serial output are superfast, nice IDE and my dev-cycle speed up by an order of magnitude.
                                  Question:
                                  I am using an second device for USB-Serial convertion to get some print-msg out of the nrf52832.
                                  Is there any way to do this over the programmer?
                                  You can define the RX/TX pins in the nrf52832 to the pins you want.
                                  Hardware Workaround by Neverdie: Connector Board -openhardware.io
                                  • mr_redM mr_red
                                    @ileneken3
                                    Question:
                                    Toyman
                                    @mr_red said in nRF5 action!:
                                    Not in Arduino. In KEIL you can use RTT (pretty cool stuff, debug via SWD)
                                    But if you just want to decrease a number of programmers, you can use Black Magic Probe, made from BluePill ($2 at Ali). It is 2-in-1 SWD and USB-UART converter on one PCB
                                    • alowhumA
                                      alowhumA
                                      alowhum
                                      @ileneken3 @mr_red Thanks for this! Glad to hear I wasn't going crazy, but that others have had the same issue.
                                      • O
                                        O
                                        Omemanti
                                        A quick Google pointed me to https://github.com/AndruPol/nrf52832-recover/blob/master/README.md
                                        I do have a STM32F103C8T6 laying around. But ATM no time to play with it.
                                        Maybe that's the €3 solution for unlocking.
                                        • O Omemanti
                                          Toyman
                                          @omemanti said in [nRF5 action!]Maybe that's the €3 solution for unlocking.
                                          BMP is enough to unlock. BluePill costs ca. €2 and it's easily convertable to BMP
