  3. Relay / Motion Multisensor
motionrelaymultisensor
14 Posts 9 Posters 20.2k Views 4 Watching
  • D
    Dalhoj
    wrote on last edited by Dalhoj
    Hi, I thought I would share my newest project with you Guys.
    This project is a multisensory, containing a relay and a motion sensor.
    The project is powered by 230V and has a small 5V power supply in the box as well.
    What I used:
    HC-SR501 PIR
    1 channel relay
    Arduino Pro Mini 5V
    NRF24L01+
    AMS1117 5V-3.3V Step Down Module
    1A 5V Power Supply from Ebay
    Code:
    MultiSensor_Relay_Motion.ino
    Pictures:
    The Multisensor is used in my basement room, and turns on the light if there is motion, when I enter the room.
    The logic is made by PLEG on a Vera3
    • SalmoidesS
      SalmoidesS
      Salmoides
      Very nice.
      Sal
        Nice! But you should probably isolate the high voltage parts a bit. We wouldn't want a MySensors related fire started.
        RJ_MakeR 1 Reply Last reply
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          +1 on that one!
          RJ_Make
          D 1 Reply Last reply
          • RJ_MakeR RJ_Make
            +1 on that one!
            Dalhoj
            @ServiceXp @hek Here just a little update
            I have now glued all parts to the box, and added a plastic cover over the part with 230V
            so now nothing should be able to touch and it looks a bit nicer.
              madmax
              Hello
              i want to make a similar project but i want to add a dht22 with this sketch
              have you a sketch with a dht because i have a problem with mine
              thanks
              • M madmax
                Hello
                thanks
                Dalhoj
                @madmax good idea I have some DHT22 lying around. But I have not tried making a multi sensor with them.
                Have You tried the skech from the site, I tried it and it work on mine?
                • D Dalhoj
                  madmax
                  @Dalhoj i use this and it's working fine
                  i want to include another relay and it's ok for me
                  #include <SimpleTimer.h>
                  #define CHILD_ID_HUM 1
                  #define CHILD_ID_TEMP 2
                  #define CHILD_ID_MOTION 3
                  #define CHILD_ID_RELAY 4
                  #define HUMIDITY_SENSOR_DIGITAL_PIN 19
                  #define MOTION_SENSOR_DIGITAL_PIN 3
                  #define INTERRUPT MOTION_SENSOR_DIGITAL_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
                  #define RELAY  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                  unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds) - 10mins
                  DHT dht;
                  SimpleTimer timer;
                  float lastTemp;
                  float lastHum;
                  boolean lastTripped;
                  boolean metric = true;
                  MyMessage msg(CHILD_ID_MOTION, V_TRIPPED);
                    gw.sendSketchInfo("HumTempRelayMotion", "1.0");
                    gw.present(CHILD_ID_MOTION, S_MOTION);
                    gw.present(CHILD_ID_RELAY, S_LIGHT);
                    pinMode(RELAY, OUTPUT);
                    digitalWrite(RELAY, gw.loadState(RELAY)?RELAY_OFF:RELAY_ON);
                    //Serial.begin(9600);
                    timer.setInterval(30000, getMeasure);
                    timer.run();
                    boolean tripped = digitalRead(MOTION_SENSOR_DIGITAL_PIN) == HIGH;
                    if (tripped != lastTripped) {
                      lastTripped = tripped;
                      Serial.print("M: ");
                      Serial.println(tripped);
                      gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
                    if (message.type==V_LIGHT) {
                       // Change relay state
                       digitalWrite(message.sensor-CHILD_ID_RELAY+RELAY, message.getBool()?RELAY_ON:RELAY_OFF);
                       // Store state in eeprom
                  void getMeasure() {
                    if (isnan(temperature)) {
                      lastTemp = temperature;
                      if (!metric) {
                      Serial.print("T: ");
                    if (isnan(humidity)) {
                        lastHum = humidity;
                        Serial.print("H: ");
                        Serial.println(humidity);
                  • Ashley SavageA
                    Ashley SavageA
                    Ashley Savage
                    hello, just looking to use this project to try and set up a motion triggered sprinkler to scare away some rabbits eating my plants and grass. Thinking of the relay triggering a 24v valve, my only problem is how do I extend the time the replay is closed, thinking I only need to spray water for 5-10secs... any tips would be greatly appreciated.
                    thanks
                    Ashley SavageA 1 Reply Last reply
                    • Tomasz PazioT
                      Tomasz PazioT
                      Tomasz Pazio
                      wrote on last edited by Tomasz Pazio
                      Guys, I would like to use this sketch with dht but on Uno and with 8 relays and use analog pins...
                      Should I Just change part:
                      #define RELAY 8
                      To
                      #define RELAY A0
                      • GertSandersG
                        GertSandersG
                        GertSanders
                        This project got me inspired, so I made this:
                        Same PIR, no relay on this board yet. To test the principle (and sketch) I used a red LED. The kicker is that I can send an SMS ("LED ON") to this board to switch on the LED, and another (... "LED OFF" tada !) to switch it back off. I can ask "STAT?" and it sends me an SMS with the status of all analog/digital ports. And when the PIR "fires" I get a prowl message via Domoticz. Call me a kid, blame the glas of wine I just had, but this is super fun !!!!!
                        • Ashley SavageA Ashley Savage
                          thanks
                          Ashley SavageA
                          Ashley SavageA
                          Ashley Savage
                          @Ashley-Savage
                          ah mis read the code... build circuit and sorted my timer via my vera with a timer to switch off relay after 5 secs...
                          • N
                            N
                            nihilo83
                            Has anyone the code for mysensors 2.1?
                            It doesnt work for me in 2.1 :/
                            Please help
                            N 1 Reply Last reply
                            • N nihilo83
                              Please help
                              N
                              N
                              nihilo83
                              I need your help pls :/
