716 Posts 111 Posters 705.7k Views 93 Watching
    Thanks for reporting @dakipro. It seems to have been a caching issue in the service. Should not appear again.
    • D
      dany8075
      Me too i still have a bunch of rev 9. Where can i have all the old informations for this rev? I need to see the old webpage with instructions. Thank you !
      • D
        dakipro
        Thanks @hek it is certainly helpful. However the most powerful information is actually in the description page, about how to use the board, how to wire it up for different use cases etc. I suppose a previous version of the information tab is not available?
        If it could be archived (maybe even linked somewhere) it would be really helpful!
          The documentation at the time of the created revision is actually included in the zip as README.md (markdown).
          You should be able to view the file properly formatted in an md-editor or online using I.e.. https://dillinger.io/
          Uploaded images was never included in the revision dumps unfortunately.
          • D
            dakipro
            Ooops, my bad then :( I was pretty sure I checked readme.md file, but apparently I got confused.
            Thanks a million!
            • A
              APL2017
              I am also looking for documentation for Rev. 9 that I purchased. The link with revisions that was provided: https://www.openhardware.io/view/4/EasyNewbie-PCB-for-MySensors#tabs-revisions
              lists revisions 1-7, but not 9. All I need is readable schematic and PCB layout in PDF. Thanks.
              • A APL2017
                @apl2017 I don't know where the revision numbering comes from, but I believe the rev9 you are talking about is called rev5 on the revisions tab.
                Rev 10 was created 2018-06-04. That date matches with rev6 on the revisions tab.
                Perhaps @sundberg84 knows why there are two sets of revision numbers?
                • A
                  APL2017
                  What software was used to develop this board? My latest KiCad does not read schematic from Rev. 5 ZIP file. All I need is a simple PDF...
                  • A APL2017
                    sundberg84S
                    sundberg84S
                    #625
                    @apl2017 - Rev 10 = Kicad, but all below is Eagles.
                    This is Rev 9, Nrf24l01+
                    @mfalkvidd - the rev tab in openhardware is the revision for the manufacturer. This doesnt match, because it starts at 0 and ticks up. If you have a board with rev 1 but make a small change without updating the revision number but still wants to upgrade it to the pcb manufacturer you need a new revision for them... so thats causes the confusion. But i think @hek named it M.Rev (Manufacturer revision) to try to keep them apart.
                    • A
                      APL2017
                      Sorry to bother you again (3rd time), still waiting for readable PDF of Rev. 9 schematic and board layout. Thank you
                      • A APL2017
                        sundberg84S
                        sundberg84S
                        #627
                        @apl2017 - why pdf? The image above is just as good? It wont present any other info?
                        The reason why I ask is that I dont have eagles installed anymore... so its a bit of hassle for me.
                        • A
                          APL2017
                          sundberg84 Don't bother, I went through the hassle, downloaded Eagle and created readable PDF
                          D 1 Reply Last reply
                          • A APL2017
                            dakipro
                            @apl2017 care to share? :)
                            • E
                              E
                              ElCheekytico
                              Hey, @sundberg84 , I am trying to order the rfm69 version from ITEAD and their M.Rev1 file I downloaded looks to be your v9. Can you upload the v10 to them so I may place an order?
                              • P
                                P
                                Pierre1410
                                Hello, i have built my first sensor based on your PCB. I am of course in learning mode so it refuses to work so far. it is motion detector. I suspect a problem on the radio nrf24 but does not know how to monitor the node with Arduino IDE serial monitor. If i connect the board to the USB the radio is not powered (built the node on battery). and if i connect the battery i have no access to serial monitor. I am afraid to connect both the USB and the batteries and burn the all thing...
                                so far i know radio receives power/ PIR receives 3.3 Volts (have configured the PIR to 3.3)/ arduino mini pro led comes on with battery connected.
                                Any advice would be really welcome.
                                  Stephen205
                                  wrote on last edited by Stephen205
                                  #632
                                  The radio is only powered by the battery, the battery must be connected to test. Connect both the usb (set to 3.3v) and the battery, no damage will be caused by this.
                                  • P
                                    P
                                    Pierre1410
                                    Thanks Stephen. connected both and i can now see what is going on :-)
                                    • E ElCheekytico
                                      sundberg84S
                                      sundberg84S
                                      @ElCheekytico - I dont know why they wont update to rev 10. I have uploaded the new revision to openhardware... nothing else I can do, sorry.
                                      • P Pierre1410
                                        sundberg84S
                                        sundberg84S
                                        @pierre1410 - I would suggest you connect the battery, and then the usb/ftdi cable, but only GND, TX and RX fro the usb connection. This will have the node running on the batteries VCC and get you closer to the real deal. Using VCC from the usb adapter might be higher VCC than the batteries, and in worst case scenario it works great with that connected but not when you deploy and only use battery power.
                                        P 1 Reply Last reply
                                        • sundberg84S sundberg84
                                          P
                                          P
                                          Pierre1410
                                          @sundberg84 that is exactly what i experienced. thanks for the tip. struggling in fact to have my PIR sensor running on 3.3V. when i connect to the pin on the right of the board (3rd from top).. Arduino IDE serial terminal does not outcome any coherent information.
