716 Posts 111 Posters 705.7k Views 93 Watching
  • P
    P
    Pierre1410
    Hello, Is there a way to solder a DC-DC booster 3.3V to 5V directly onto the Easy PCB or should it be connected separately to power a PIR for instance? and would that really prevent using 2xAA batteries to power the all thing? have tried to step down the PIR to work at 3.3V but it was not conclusive. Thanks a lot.
    • P Pierre1410
      sundberg84S
      sundberg84S
      @pierre1410 - you can always use the prototyping area for a 3.3 to 5v booster but... booster + PIR might cause false triggers, so choose your booster wisely.
      • P
        P
        Pierre1410
        @sundberg84, had to migrate my gateway to Ethernet in the meantime but now I am on the PIR/ battery case. i have my booster to 5V in.. will post the results of it...
        gohanG 1 Reply Last reply
        • P Pierre1410
          wrote on last edited by gohan
          #641
          @pierre1410 why do you need 5v? There are pir sensors working at 3v and you can even modify the standard pir sensor to work at 3v
          • B
            B
            barrydou
            wrote on last edited by barrydou
            #642
            Hello
            I think there is a mistake in your code (on github) to mesure battery.
            The array have 4 values, but you divide by 3. So you get to high result.
            https://github.com/sundberg84/HomeAutomation/blob/master/BatteryMeasurer/BatteryMeasurer.ino
            On line 77
            Everything else is ok in my case :) the board works well with 2 battery AA, and 47uF cap (not with 4.7uF) .
            • B barrydou
              Hello
              On line 77
              Nice catch @barrydou
              The bat array is declared to hold 3 elements
              int batArray[3];
              but then 4 values are fetched
              batArray[3] is outside of the array, so the ram here could hold any value.
              The code should probably be changed to this
              batteryPcnt = (batArray[0] + batArray[1] + batArray[2]);
              • B
                B
                barrydou
                @mfalkvidd : I think you have to change the condition in if too :
                if (batLoop > 1) {
                With that, batLoop = 2 when entering in the if (so the 3 values of the array are filled : 0, 1, 2), calculating the average and reseting the batLoop to 0.
                If not modify, the array will be set with batArray[3] just before entering the
                if (batLoop > 2) {
                Other way is to set the batArray size to 4 values, and divide by 4 (I'm actually trying that).
                • B barrydou
                  if (batLoop > 1) {
                  if (batLoop > 2) {
                  sundberg84S
                  sundberg84S
                  @barrydou @mfalkvidd - thanks.
                  Wouldnt it be easiest to just "+ batArray[3]" so it is
                  the declaration = 3 elements
                  batterypct = 3 elements
                  batloop > 2 should be correct (0,1 and 2)
                  I dont think the code has made any faulty readings since the declaration is only for 3 elements, making batArray[3] never used? (Or always been 0). The batteryPcnt is then divived by 3.
                  • sundberg84S sundberg84
                    @sundberg84 batloop > 2 is incorrect, since that means batloop==3 and the code above has just written outside the array, corrupting whatever happened to be there.
                    • sundberg84S
                      sundberg84S
                      We must be ordering EasyPCB alof from PCBway since they used it as an example board for this youtuber:
                      https://www.youtube.com/watch?v=S6YxwxtinrY&t=28s
                      Nca78N 1 Reply Last reply
                        @sundberg84 haha gorgeous, I think they only sent open hardware boards, and ran some batches from boards available on openhardware, as except the perfboards they send as free gifts the other real PCBs are MySWeMosIRShield by @emc2 and the RollerShutterNode by @Scalz
                        https://www.openhardware.io/view/385/MySWeMosIRShield-IR-blaster-shield-for-WeMos-D1
                        https://www.openhardware.io/view/22/Roller-Shutter-Node
                        • E
                          E
                          emc2
                          Looks nice in red ;)
                          • P
                            P
                            Pierre1410
                            hello, i have a stupid question... on the 3 rows below VCC and GD on your prototyping area; are the rows connected horizontally like a breadboard? thanks
                            • P Pierre1410
                              sundberg84S
                              sundberg84S
                              @pierre1410 - no stupid questions, simple answer though, no :)
                              • EmeE
                                EmeE
                                Eme
                                wrote on last edited by Eme
                                #652
                                Hello Sundberg84 et al,
                                I purchased Easy Newbie PCB (Rev 10) with the hope of jumping into the IoT rave... I tried to create the Gateway - and it works perfectly. I also found and created an advanced Water Sprinkler MyS project by Pete and Co!... that also worked perfectly.
                                However, I cant seem to get simpler beginner sketches to work with EasyNewbie. I have soldered the need components (the regulated version). I plan to connect to a 4 relay module, but for now, I am simulating the relay with a simple LED attached to D2. I have uploaded the following sketch which was originally written for version 1.0 MySensors - but have been corrected using guidelines I found for converting 1.0 - 2.0 version. but still no cheese - the controller (Domoticz) displays the Node, but not the complete child nodes, - the LED connected to pin D2 (or D3, D5..) on the Easy Newbie doesn't light up even when I toggle the switches and devices on controller. Don't know what I might be doing wrong, please help.
                                // Example sketch showing how to control physical relays.
                                // This example will remember relay state even after power failure.
                                // Enable debug prints
                                #define MY_NODE_ID 4  // Set this to fix your Radio ID or use AUTO or 1
                                #define MY_REGISTRATION_FEATURE // Forece registration
                                #define MY_REGISTRATION_RETRIES 5
                                #include <TimeLib.h>
                                #include <LCD.h>
                                #include <LiquidCrystal.h>
                                // For Debug
                                #ifdef DEBUG_ON
                                #define SERIAL_START(x)
                                //#define RELAY_1  2  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                #define RELAY_PIN 3
                                #define SKETCH_NAME "Base Relay Node"
                                #define SKETCH_VERSION "0.1.2"
                                #define CHILD_ID 0
                                MyMessage msg(1,V_LIGHT);
                                //void before()
                                  for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                                    pinMode(pin, OUTPUT);
                                  // Fetch relay status
                                    //    present(sensor, S_BINARY);
                                    present(sensor, S_LIGHT);
                                    boolean savedState = loadState(sensor);
                                    digitalWrite(pin, savedState?RELAY_ON:RELAY_OFF);
                                    send(msg.set(savedState? 1 : 0));
                                //  sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                                //      update Relays;
                                send(msg.set(sensor).set(false), false);
                                wait(50);
                                void incomingMessage(const MyMessage &message)
                                  if (msg.type==V_STATUS) {
                                    // Change relay state
                                    digitalWrite(msg.sensor-1+RELAY_PIN, msg.getBool()?RELAY_ON:RELAY_OFF);
                                    // Store state in eeprom
                                    saveState(msg.sensor, msg.getBool());
                                    Serial.print(msg.sensor);
                                    Serial.println(msg.getBool());
                                • EmeE Eme
                                  #include <LCD.h>
                                  // For Debug
                                  #ifdef DEBUG_ON
                                  #define RELAY_PIN 3
                                  #define CHILD_ID 0
                                  //void before()
                                  //      update Relays;
                                  wait(50);
                                  sundberg84S
                                  sundberg84S
                                  @eme - hi!
                                  Im very sorry, code is not my strong side.
                                  Do you think its a problem with the hardware?
                                  Do you have any logs?
                                  EmeE 1 Reply Last reply
                                    @eme - hi!
                                    EmeE
                                    EmeE
                                    Eme
                                    @sundberg84 I have the Domoticz log below. but just incase it doesn't reveal much, do you have a working sketch for EasyNewbie and a 4-relay module block?
                                    2019-04-05 22:28:20.172 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:28:21.229 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:28:22.169 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:28:55.333 Status: MySensors: Node: 3, Sketch Name: Base Relay Node
                                    2019-04-05 22:28:56.459 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:29:00.141 Status: LUA: All based event fired
                                    2019-04-05 22:29:53.736 Status: User: Eme initiated a switch command (29/Light/On)
                                    2019-04-05 22:29:54.297 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:29:57.701 Status: User: Eme initiated a switch command (29/Light/Off)
                                    2019-04-05 22:29:58.206 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:30:00.533 Status: User: Eme initiated a switch command (28/Light/On)
                                    2019-04-05 22:30:00.534 Status: LUA: All based event fired
                                    2019-04-05 22:30:01.729 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:30:07.427 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:30:07.095 Status: User: Eme initiated a switch command (27/Light/On)
                                    2019-04-05 22:30:13.674 Status: User: Eme initiated a switch command (29/Light/On)
                                    2019-04-05 22:30:15.706 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:30:19.773 Status: User: Eme initiated a switch command (26/Light/On)
                                    2019-04-05 22:30:20.138 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:30:55.858 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:30:55.427 Status: User: Eme initiated a switch command (26/Light/Off)
                                    2019-04-05 22:30:59.611 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:30:59.256 Status: User: Eme initiated a switch command (29/Light/Off)
                                    2019-04-05 22:31:00.280 Status: LUA: All based event fired
                                    2019-04-05 22:31:02.813 Status: User: Eme initiated a switch command (27/Light/Off)
                                    2019-04-05 22:31:03.242 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:31:06.944 Status: User: Eme initiated a switch command (28/Light/Off)
                                    2019-04-05 22:31:07.393 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:31:22.892 (My Sensors Gateway) Light/Switch (Light)
                                    2019-04-05 22:31:22.527 Status: User: Eme initiated a switch command (26/Light/On)
                                    2019-04-05 22:32:00.351 Status: LUA: All based event fired ```
                                    • EmeE Eme
                                      sundberg84S
                                      sundberg84S
                                      @eme sorry I don't. The most common "issue" is that power is to weak for 4 relays or noice is introduced in the radio from the relay.
                                      It's very hard to understand without real logs. Sorry
                                      • EmeE
                                        EmeE
                                        Eme
                                        I eventually got it to work. I am not using the EasyNewbie to power the load (its for 24volts swimming pool light). Couldn't get the 4th relay to work - not sure why its not responding to the controller. but I noticed some bug with my batch of 16 PCB -
                                        Okay I think I have seen some bugs... my batch of EasyNewbie Rev 10 has some hardware issues - The provisions to attach sensors are not correctly marked. D6 doesn't actually connect to D6 pin on the Arduino (must have failed a via somewhere). I am not sure how many pins are used for the radio and other components, but if you intend to use this for a small project, I will avoid D8 - D13 as they appears to be taken. D1 and D2 are used for the TX & RX so you only have D2 - D6 to play with (more than enough pins for a newbie if you ask me).
                                        • EmeE Eme
                                          sundberg84S
                                          sundberg84S
                                          @eme good you found the issue. First time I ever hear of a comfirmed PCB hardware bug, so its very rare. Very strange the silkscreen were moved or not aligned correctly as well. From where did you order the PCB?
                                          The documentation states which pins connect to what on the PCB, so make sure you check that out. D9-D13 are used by the radio as in all MySensors projects. D8 for the extra flash. You can find the MysX documentation here as well if you need to find out more about the pins.
