716 Posts 111 Posters 704.0k Views 93 Watching
  • B
    B
    barrydou
    wrote on last edited by barrydou
    #642
    Hello
    I think there is a mistake in your code (on github) to mesure battery.
    The array have 4 values, but you divide by 3. So you get to high result.
    https://github.com/sundberg84/HomeAutomation/blob/master/BatteryMeasurer/BatteryMeasurer.ino
    On line 77
    Everything else is ok in my case :) the board works well with 2 battery AA, and 47uF cap (not with 4.7uF) .
    • B barrydou
      Hello
      On line 77
      Nice catch @barrydou
      The bat array is declared to hold 3 elements
      int batArray[3];
      but then 4 values are fetched
      batArray[3] is outside of the array, so the ram here could hold any value.
      The code should probably be changed to this
      batteryPcnt = (batArray[0] + batArray[1] + batArray[2]);
      • B
        B
        barrydou
        @mfalkvidd : I think you have to change the condition in if too :
        if (batLoop > 1) {
        With that, batLoop = 2 when entering in the if (so the 3 values of the array are filled : 0, 1, 2), calculating the average and reseting the batLoop to 0.
        If not modify, the array will be set with batArray[3] just before entering the
        if (batLoop > 2) {
        Other way is to set the batArray size to 4 values, and divide by 4 (I'm actually trying that).
        • B barrydou
          if (batLoop > 1) {
          if (batLoop > 2) {
          sundberg84S
          sundberg84S
          @barrydou @mfalkvidd - thanks.
          Wouldnt it be easiest to just "+ batArray[3]" so it is
          the declaration = 3 elements
          batterypct = 3 elements
          batloop > 2 should be correct (0,1 and 2)
          I dont think the code has made any faulty readings since the declaration is only for 3 elements, making batArray[3] never used? (Or always been 0). The batteryPcnt is then divived by 3.
          • sundberg84S sundberg84
            @sundberg84 batloop > 2 is incorrect, since that means batloop==3 and the code above has just written outside the array, corrupting whatever happened to be there.
            • sundberg84S
              sundberg84S
              We must be ordering EasyPCB alof from PCBway since they used it as an example board for this youtuber:
              https://www.youtube.com/watch?v=S6YxwxtinrY&t=28s
              Nca78N 1 Reply Last reply
                @sundberg84 haha gorgeous, I think they only sent open hardware boards, and ran some batches from boards available on openhardware, as except the perfboards they send as free gifts the other real PCBs are MySWeMosIRShield by @emc2 and the RollerShutterNode by @Scalz
                https://www.openhardware.io/view/385/MySWeMosIRShield-IR-blaster-shield-for-WeMos-D1
                https://www.openhardware.io/view/22/Roller-Shutter-Node
                • E
                  E
                  emc2
                  Looks nice in red ;)
                  • P
                    P
                    Pierre1410
                    hello, i have a stupid question... on the 3 rows below VCC and GD on your prototyping area; are the rows connected horizontally like a breadboard? thanks
                    • P Pierre1410
                      sundberg84S
                      sundberg84S
                      @pierre1410 - no stupid questions, simple answer though, no :)
                      • EmeE
                        EmeE
                        Eme
                        wrote on last edited by Eme
                        #652
                        Hello Sundberg84 et al,
                        I purchased Easy Newbie PCB (Rev 10) with the hope of jumping into the IoT rave... I tried to create the Gateway - and it works perfectly. I also found and created an advanced Water Sprinkler MyS project by Pete and Co!... that also worked perfectly.
                        However, I cant seem to get simpler beginner sketches to work with EasyNewbie. I have soldered the need components (the regulated version). I plan to connect to a 4 relay module, but for now, I am simulating the relay with a simple LED attached to D2. I have uploaded the following sketch which was originally written for version 1.0 MySensors - but have been corrected using guidelines I found for converting 1.0 - 2.0 version. but still no cheese - the controller (Domoticz) displays the Node, but not the complete child nodes, - the LED connected to pin D2 (or D3, D5..) on the Easy Newbie doesn't light up even when I toggle the switches and devices on controller. Don't know what I might be doing wrong, please help.
                        // Example sketch showing how to control physical relays.
                        // This example will remember relay state even after power failure.
                        // Enable debug prints
                        #define MY_NODE_ID 4  // Set this to fix your Radio ID or use AUTO or 1
                        #define MY_REGISTRATION_FEATURE // Forece registration
                        #define MY_REGISTRATION_RETRIES 5
                        #include <TimeLib.h>
                        #include <LCD.h>
                        #include <LiquidCrystal.h>
                        // For Debug
                        #ifdef DEBUG_ON
                        #define SERIAL_START(x)
                        //#define RELAY_1  2  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                        #define RELAY_PIN 3
                        #define SKETCH_NAME "Base Relay Node"
                        #define SKETCH_VERSION "0.1.2"
                        #define CHILD_ID 0
                        MyMessage msg(1,V_LIGHT);
                        //void before()
                          for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                            pinMode(pin, OUTPUT);
                          // Fetch relay status
                            //    present(sensor, S_BINARY);
                            present(sensor, S_LIGHT);
                            boolean savedState = loadState(sensor);
                            digitalWrite(pin, savedState?RELAY_ON:RELAY_OFF);
                            send(msg.set(savedState? 1 : 0));
                        //  sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                        //      update Relays;
                        send(msg.set(sensor).set(false), false);
                        wait(50);
                        void incomingMessage(const MyMessage &message)
                          if (msg.type==V_STATUS) {
                            // Change relay state
                            digitalWrite(msg.sensor-1+RELAY_PIN, msg.getBool()?RELAY_ON:RELAY_OFF);
                            // Store state in eeprom
                            saveState(msg.sensor, msg.getBool());
                            Serial.print(msg.sensor);
                            Serial.println(msg.getBool());
                        • EmeE Eme
                          #include <LCD.h>
                          // For Debug
                          #ifdef DEBUG_ON
                          #define RELAY_PIN 3
                          #define CHILD_ID 0
                          //void before()
                          //      update Relays;
                          wait(50);
                          sundberg84S
                          sundberg84S
                          @eme - hi!
                          Im very sorry, code is not my strong side.
                          Do you think its a problem with the hardware?
                          Do you have any logs?
                          EmeE 1 Reply Last reply
                            @eme - hi!
                            EmeE
                            EmeE
                            Eme
                            @sundberg84 I have the Domoticz log below. but just incase it doesn't reveal much, do you have a working sketch for EasyNewbie and a 4-relay module block?
                            2019-04-05 22:28:20.172 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:28:21.229 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:28:22.169 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:28:55.333 Status: MySensors: Node: 3, Sketch Name: Base Relay Node
                            2019-04-05 22:28:56.459 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:29:00.141 Status: LUA: All based event fired
                            2019-04-05 22:29:53.736 Status: User: Eme initiated a switch command (29/Light/On)
                            2019-04-05 22:29:54.297 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:29:57.701 Status: User: Eme initiated a switch command (29/Light/Off)
                            2019-04-05 22:29:58.206 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:30:00.533 Status: User: Eme initiated a switch command (28/Light/On)
                            2019-04-05 22:30:00.534 Status: LUA: All based event fired
                            2019-04-05 22:30:01.729 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:30:07.427 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:30:07.095 Status: User: Eme initiated a switch command (27/Light/On)
                            2019-04-05 22:30:13.674 Status: User: Eme initiated a switch command (29/Light/On)
                            2019-04-05 22:30:15.706 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:30:19.773 Status: User: Eme initiated a switch command (26/Light/On)
                            2019-04-05 22:30:20.138 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:30:55.858 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:30:55.427 Status: User: Eme initiated a switch command (26/Light/Off)
                            2019-04-05 22:30:59.611 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:30:59.256 Status: User: Eme initiated a switch command (29/Light/Off)
                            2019-04-05 22:31:00.280 Status: LUA: All based event fired
                            2019-04-05 22:31:02.813 Status: User: Eme initiated a switch command (27/Light/Off)
                            2019-04-05 22:31:03.242 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:31:06.944 Status: User: Eme initiated a switch command (28/Light/Off)
                            2019-04-05 22:31:07.393 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:31:22.892 (My Sensors Gateway) Light/Switch (Light)
                            2019-04-05 22:31:22.527 Status: User: Eme initiated a switch command (26/Light/On)
                            2019-04-05 22:32:00.351 Status: LUA: All based event fired ```
                            • EmeE Eme
                              sundberg84S
                              sundberg84S
                              @eme sorry I don't. The most common "issue" is that power is to weak for 4 relays or noice is introduced in the radio from the relay.
                              It's very hard to understand without real logs. Sorry
                              • EmeE
                                EmeE
                                Eme
                                I eventually got it to work. I am not using the EasyNewbie to power the load (its for 24volts swimming pool light). Couldn't get the 4th relay to work - not sure why its not responding to the controller. but I noticed some bug with my batch of 16 PCB -
                                Okay I think I have seen some bugs... my batch of EasyNewbie Rev 10 has some hardware issues - The provisions to attach sensors are not correctly marked. D6 doesn't actually connect to D6 pin on the Arduino (must have failed a via somewhere). I am not sure how many pins are used for the radio and other components, but if you intend to use this for a small project, I will avoid D8 - D13 as they appears to be taken. D1 and D2 are used for the TX & RX so you only have D2 - D6 to play with (more than enough pins for a newbie if you ask me).
                                • EmeE Eme
                                  sundberg84S
                                  sundberg84S
                                  @eme good you found the issue. First time I ever hear of a comfirmed PCB hardware bug, so its very rare. Very strange the silkscreen were moved or not aligned correctly as well. From where did you order the PCB?
                                  The documentation states which pins connect to what on the PCB, so make sure you check that out. D9-D13 are used by the radio as in all MySensors projects. D8 for the extra flash. You can find the MysX documentation here as well if you need to find out more about the pins.
                                  • EmeE
                                    EmeE
                                    Eme
                                    @Sunberg84 I bought them off Ebay via this very site... The Packing List reads Shipped by Abdera's Sundberg Ostra Gransgatan 2, Lonsboda, Sverige 28070, SE. I believe that's you.
                                    Well I am forced to solder directly to the Nano pins, and so far so good. I think you should help with a 4 relay sketch that works. My appears to be a hit and run, works in the morning and fails after a while. but I am learning as I go.
                                    • EmeE Eme
                                      sundberg84S
                                      sundberg84S
                                      @eme Thats me - ok, good to know then - but I guess you mean the Mini pins and not Nano since the PCB doesnt support the Nano?
                                        EmeE
                                        EmeE
                                        Eme
                                        #660
                                        @sundberg84 Yes you are right I meant to say ProMini not Nano - I have 18 of these PCB - not so happy I have to solder directly to the Arduino - that's exactly what I was avoiding in the first place. Do you have a good relay block sketch that works? Much appreciated if you can help.
                                        One last thing, I am trying to run a node off a 12Volts battery, can you explain this image below again?
                                        • Will this work for a 5V Promini?
                                        • What are the blue lines? and
                                        • what are the red lines?
                                        • EmeE Eme
                                          sundberg84S
                                          sundberg84S
                                          #661
                                          @eme - its is very strange - I have a big batch here with Rev 10 and i checked atleast 20 of them randomly and all have continutiy between D6/pro mini and D6/MysX. You must have had extreme bad luck and if you check the others it should be ok.
                                          Can you post a picture (close up) of the board not working please showing D6/Pro mini and D6/MysX.
                                          For 12v I would use the prototyping area with a 12 > 5v converter. If you want to use the internal voltage regulator on the pro mini you can connect to RAW but beware that clones will not handle this very good. The specs are 12v but I have seen many bad clones getting destroyed.
                                          I dont really remember this image and from which context this is from. I guess the lines represent different voltages. Adding 12V on reg and a 12>5v regulator on the TO92 footprint will convert and feed the board 5v, but kill the radio...
