  3. Round water tank level sensor
55 Posts 14 Posters 32.5k Views 19 Watching
  • Huw ThomasH Huw Thomas
    Yes I realise that , I just wasn't sure at first where I needed to change things in the sketch. I think I've worked it out. I have zero experience in reading programming code so couldn't at first find the PiR^2h equation to change it, but now I've found it.
    Boots33B
    Boots33B
    Boots33
    @Huw-Thomas Sounds like you are heading in the right direction.
    The water percent available calculation should work unaltered for a rectangular tank and you have already found
    waterAvail = PI* pow(tankRad,2)*(((fullHeight-outletHeight)+sensHeight)-pingHeight)/1000;    // calculate water available in litres
    That is the line that will need the change with the suggestions from above.
    • Lawrence HelmL
      Lawrence HelmL
      Lawrence Helm
      @Boots33 Have you thought about sending the days available. i.e. calculate daily usage and divide that by the water that is still available? would have to roll the numbers i.e. say take the last two weeks of how much the water dropped in a day averaged out... if that makes sense. :)
      Boots33B 1 Reply Last reply
      • Lawrence HelmL Lawrence Helm
        Boots33B
        Boots33B
        Boots33
        @lawrence-helm The tank that I am monitoring is used primarily for garden watering and topping up the pool, so it does not really have a regular sort of use. We also live in an area of frequent rainfall so the tank can stay at 100% for weeks on end.
        I can see that your idea would be a good addition to the sketch if the tank was to be used for general house duties where more frequent use would likely give a more meaningful result.
        • R
          R
          Ritesh T
          Banned
          #47
          Sorry for bumping up an old question but I’m in the same boat of requirement.
          And to my surprise there are quite a few new sensors in town:
          This one has 2 transducers instead of 1 therefore has less minimum detection distance as compared to JSN SR04T. It is also completely sealed and waterproof.
          Ebay spam link removed by moderator
          Before finalizing on this I had bought another one which was a waterproof modified version of HC-SR04 from here
          The 1st one is much more rugged and waterproof as compared to the latter one.
          Boots33B zboblamontZ 2 Replies Last reply
          • R Ritesh T
            Boots33B
            Boots33B
            Boots33
            @ritesh-t If you have not already found it you may also benefit from the thread by @zboblamont which can be found here. It addresses some issues of unstable readings that were occurring when the water in the tank was at a lower level.
            • Boots33B Boots33
              zboblamontZ
              zboblamontZ
              zboblamont
              @boots33 To be fair that was specific to the SR04-2.0, the technology has moved on a bit since non-waterproof twin head devices were the standard, but I confess having discovered the error it verifies with the Class-D quality water meter on the house-side. I may have to recalibrate the Litres/mm but the tank shape is not uniform cross section.
              @Ritesh-T All you can do is try the version you bought, but the original suffered badly inside a sealed tank where moisture was very high indeed, and housing it to protect the board may prove tricky. That was my reasoning for going with the parking sensor button type with remote board, plus the sensor is a snug fit in the end of 3/4" pipe/socket. The only recurring problem is condensation below -10c, perhaps your environment is different or have better luck with yours.
              • CrankyCoderC
                CrankyCoderC
                CrankyCoder
                I made a sensor like this myself. i took a non-water proof one and drilled holes to match the sensor in some plexiglass. and sealed around it with silicone. This worked until florida tried to drowned me out and flooded my entire sensor housing lol
                Home Automation Tinkerer
                www.CrankyCoder.net
                Gateway: MQTTClientGateway
                MySensors: 2.3
                • CrankyCoderC CrankyCoder
                  zboblamontZ
                  zboblamontZ
                  zboblamont
                  @crankycoder
                  Bad luck on the storm, presumably a weatherproof box lid/side drilled out per your plexiglass original was the next version?
                  CrankyCoderC 1 Reply Last reply
                  • R Ritesh T
                    zboblamontZ
                    zboblamontZ
                    zboblamont
                    @ritesh-t I presume you are aware the device you bought is 5v?
                    Not so sure of their claim that the reduced blind-spot of 2cm is down to dual diaphragms, the original dual from memory had the same 20cm blind-spot as the remote and also was 5v only.
                    • zboblamontZ zboblamont
                      @crankycoder
                      CrankyCoderC
                      CrankyCoderC
                      CrankyCoder
                      @zboblamont actually it was more of a "not completed" type of thing. i didn't finish the connection between the bottom part that houses the sensor and the top cap. so it got knocked over and water soaked in. so i will be redoing it and will just complete it this time :)
                      www.CrankyCoder.net
                      MySensors: 2.3
                      • Christian WC
                        Christian WC
                        Christian W
                        I have problems with the same sensor, the minimum or shortest measurement is 40 cm, and yet in its technical characteristics it says that the minimum is 20 cm.
                        Will we have to calibrate something?
                        Thank you
                        • greyy greyyG
                          greyy greyyG
                          greyy greyy
                          interesting, i will buy same sensor too
                          12.5k
