  3. 💬 EFEKTA Two channel Pulse Counter | nRF52
9 Posts 3 Posters 1.9k Views 2 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/658/EFEKTA-Two-channel-Pulse-Counter-or-nRF52
    • magpernM
      magpernM
      magpern
      wrote on last edited by magpern
      @berkseo I am interested in this one. I uploaded the gerber files to a fab-house I usually use. The normally charge 5 usd for 5-10 pcbs, but for this one (and your e-paper device), they want over 50 usd. They say it uses minimum hole size is 0.2, which makes it expensive to produce.
      Is this correct? If so, what pcb manufacturer do you recommend?
      berkseoB 1 Reply Last reply
      • magpernM
        magpernM
        magpern
        I checked your drill files. You do have 0.2mm drills for vias, and it looks they could be changed to 0.3mm without impacting anything. I suggest you change that, it would make it easier to produce.
        • magpernM
          magpernM
          magpern
          Me again, I just realized it is a "work in progress", but anyway, I ordered some pcbs, could you, despite it beeing a work in progress, upload the BOM and a "what goes where" description?
          • magpernM magpern
            berkseoB
            berkseoB
            berkseo
            @magpern said in 💬 EFEKTA Two channel Pulse Counter | nRF52:
            https://jlcpcb.com/
            More loyal policy :) in this project it is possible to increase the holes, in the project temperature sensor with the display is not. I just have the program default to 0.2 mm vnutrennee hole and I have no problems with the price of this service https://jlcpcb.com/
            • magpernM magpern
              berkseoB
              berkseoB
              berkseo
              @magpern
              I’ll download everything, but I don’t know when. In the queue updating the documentation for other popular projects
              magpernM 1 Reply Last reply
              • berkseoB berkseo
                @magpern
                magpernM
                magpernM
                magpern
                @berkseo said in 💬 EFEKTA Two channel Pulse Counter | nRF52:
                @magpern
                OK, thanks. Hope it is soon! In the mean time, I was hoping to order most of the components. Could you help me identify these?
                • magpernM magpern
                  @magpern
                  berkseoB
                  berkseoB
                  berkseo
                  wrote on last edited by hek
                  @magpern
                  1 - trimmer resistor 10K like these - https://ru.aliexpress.com/item/20-RM063-RM-063-100-200-500-1-2-5-10-20-50-100-200/32949941406.html
                  3 - ceramic capacitor 10uF 25V - https://ru.aliexpress.com/item/10uF-106-10-25V-1206-SMD-Chip-Multilayer-Ceramic-Capacitor-20pcs/32340271954.html
                  4 - ceramic capacitor ~100uF 6v/10v
                  2 - inductance 4.7UH - https://ru.aliexpress.com/item/100-SMD-1210-4-7uH-5-NLV32T-4R7J-PF/32853632579.html
                  5 - tlv3691 - https://www.elitan.ru/price/item10739559
                  • berkseoB berkseo
                    @magpern
                    magpernM
                    magpernM
                    magpern
                    @berkseo I'm trying to reverse engineer the BOM of this board, but I am quite unsuccessful. Could you please upload a BOM with (R1 = xxx k) or something similar, or Upload high-res closeups of the board so one can read the resistor values? Capacitors are a little harder, maybe you could share those values?
                    I have started on a BOM list, if you could help me fill it out, that would be much appreciated. I want to start soldering!!
                    Front
                    • YJ-16048 ----------- NRF52
                    • RGB LED ------------ RGB led with common cathod
                    • R11 ------------------------------------------------------------------- ???
                    • R12 ------------------------------------------------------------------- ???
                    • L1 --------- 4.7uH inductor
                    • C1 -------------------------------------------------------------------- ???
                    • TPS62XX ----------- TPS62745
                    • C3 -------10uF 25V 1206
                    • POWER ----- Vertical 7-pin switch
                    • U1, U3 ------- Battery holder 1/2 AA
                    • U5, U7 ------ 2 pin Screw connector
                    • Unmarked ------ Trimmer resistor 10K
                    • MODE, RESET --------- push button 3-pin vertical
                    • SWD -------- 6-pin female header 1.27 mm
                    Back
                    • R15 --------------------------------------------------------- ???
                    • R14 --------------------------------------------------------- ???
                    • R13 --------------------------------------------------------- ???
                    • R17 --------------------------------------------------------- ???
                    • R16 --------------------------------------------------------- ???
                    • R18 --------------------------------------------------------- ???
                    • R19 --------------------------------------------------------- ???
                    • C13 ----- 100uF 6v/10V
                    • C14 -------------------------------------------------------- ???
                    • R1 ---------------------------------------------------------- ???
                    • R2 ---------------------------------------------------------- ???
                    • U6, U8 ----- tlv3691
                    • R7, R10 -------------------------------------------------- ???
                    • R9 ---------------------------------------------------------- ???
                    • R8 ---------------------------------------------------------- ???
                    • R6 ---------------------------------------------------------- ???
                    • R4 ---------------------------------------------------------- ???
                    • R3 ---------------------------------------------------------- ???
                    • R5 ---------------------------------------------------------- ???
