  3. EasyPcb BH1750 Batterie sketch
13 Posts 3 Posters 2.4k Views 2 Watching
  • T
    The-Holgi
    i´m using the EasyPcb with 2AA Batteries and a BH1750 Sensor.
    In fhem the Batterie state is at 150 to 153%, here is my sketch, Maybe somebody can look at this:
    #include <BH1750.h>
    #include <Wire.h>
    #define CHILD_ID_LIGHT 0
    BH1750 lightSensor;
    // V_LIGHT_LEVEL should only be used for uncalibrated light level 0-100%.
    // If your controller supports the new V_LEVEL variable, use this instead for
    // transmitting LUX light level.
    // MyMessage msg(CHILD_ID_LIGHT, V_LEVEL);
    uint16_t lastlux;
    // BATTERY VOLTAGE DIVIDER SETUP
    #define VBAT_PER_BITS 0.003363075
    #define VMIN 1.9                                  //  Vmin (radio Min Volt)=1.9V (564v)
    #define VMAX 3.0                                  //  Vmax = (2xAA bat)=3.0V (892v)
    int batteryPcnt = 0;                              // Calc value for battery %
    int batLoop = 0;                                  // Loop to help calc average
    int batArray[3];                                  // Array to store value for average calc.
    int BATTERY_SENSE_PIN = A0;                       // select the input pin for the battery sense point
      lightSensor.begin();
    void presentation()  {
      sendSketchInfo("Light Lux Sensor", "1.0");
      uint16_t lux = lightSensor.readLightLevel();// Get Lux value
      Serial.println(lux);
      if (lux != lastlux) {
          send(msg.set(lux));
          lastlux = lux;
       batM();
      sleep(SLEEP_TIME); //sleep a bit
    void batM() //The battery calculations
       delay(500);
       // Battery monitoring reading
       delay(500);
       // Calculate the battery in %
       float Vbat  = sensorValue * VBAT_PER_BITS;
       int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
       Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
       // Add it to array so we get an average of 3 (3x20min)
       batArray[batLoop] = batteryPcnt;
       if (batLoop > 2) {
         batteryPcnt = (batArray[0] + batArray[1] + batArray[2] + batArray[3]);
         batteryPcnt = batteryPcnt / 3;
       if (batteryPcnt > 100) {
         batteryPcnt=100;
         Serial.print("Battery Average (Send): "); Serial.print(batteryPcnt); Serial.println(" %");
           batLoop = 0;
         else
         batLoop++;
      sleep(SLEEP_TIME);
    • T The-Holgi
      #include <BH1750.h>
      #include <Wire.h>
      BH1750 lightSensor;
      uint16_t lastlux;
            send(msg.set(lux));
            lastlux = lux;
         batM();
         delay(500);
         delay(500);
         if (batLoop > 2) {
           batteryPcnt=100;
             batLoop = 0;
           else
           batLoop++;
        sleep(SLEEP_TIME);
      Welcome to the MySensors forum @the-holgi
      The sketch will never report higher than 100% so the problem is probably some setting in fhem. I don't have experience with fhem but hopefully someone else can help, in case you can't find it yourself.
      • T
        The-Holgi
        thank you for quick reply.
        Here is the output of serial output:
        Battery percent: -81 %
        Battery Average (Send): -105 %
        794046 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:151
        794054 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
        794060 TSF:TDI:TSL```
        It sends 151 to fhem.
        Best regards Holger
        • T The-Holgi
          Best regards Holger
          @the-holgi it seems very wrong it is measuring a negative value. Could be the calculation gets messed up because of that? Start checking why you have a negative value? Connection issue ?
          • T
            The-Holgi
            there was a mistake in the code. The negative value in serial console now fixed, but the output is to high.
            Now i have change the value of #define VMAX 3.0 to #define VMAX 3.5, at 2,9V batt output
            in fhem is the output now 91%.
            But i´l think this is the wrong way.
            By the way, thanks for quick sending the PCB
            Here is the code:
            #include <BH1750.h>
            #include <Wire.h>
            BH1750 lightSensor;
            uint16_t lastlux;
            #define VMAX 3.5                                  //  Vmax = (2xAA bat)=3.0V (892v)
              analogReference(INTERNAL);             // For battery sensing
              delay(500); // Allow time for radio if power used as reset
                  send(msg.set(lux));
                  lastlux = lux;
               batM();
               delay(500);
               delay(500);
               if (batLoop > 2) {
                 batteryPcnt=100;
                   batLoop = 0;
                 else
                 batLoop++;
            • T
              The-Holgi
              Here the output in the console:
              51789 TSF:MSG:SEND,101-101-0-0,s=0,c=1,t=23,pt=3,l=2,sg=0,ft=0,st=OK:3
              Battery percent: 68 %
              Battery Average (Send): 91 %
              52801 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:91
              52809 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
              52815 TSF:TDI:TSL
              52817 MCO:SLP:WUP=-1
              52819 TSF:TRI:TSB```
              sundberg84S 2 Replies Last reply
              • T The-Holgi
                52815 TSF:TDI:TSL
                @the-holgi what kind of batteries are you using ? 2xAA ?
                • sundberg84S sundberg84
                  @sundberg84 first post says so :)
                  • T The-Holgi
                    52815 TSF:TDI:TSL
                    @the-holgi @mfalkvidd - oh, sorry missed that.
                    The code seems to be coming from my example and it works fine, so Im thinking it should be something with the voltage hense my question. But the next question would be if you can measure the voltage on A0?
                    • T
                      The-Holgi
                      on A0 are 0,8V. Batterie voltage is 2,6V.
                      • T The-Holgi
                        @the-holgi - hi! Sounds about right :)
                        This is an extended version: https://github.com/sundberg84/HomeAutomation/blob/master/BatteryMeasurer/BatteryMeasurer.ino
                        If you use this in the "//Battery inital calc" you will get a detailed debug which can help you measure. Can you use this code to test.
                        I btw notised in your first post you forgot analogreference() and this might cause the issue - but you have that in your second code. Maybe you could try to remove everything except the battery code and try. You can exclude the loop function in my code above and just do setup() and den reset the node if you need to read again.
                        • T
                          The-Holgi
                          the extended code works with right value . Every second the node sends the Batterie value and voltage to Controller.
                          Thanks vor the code.
                            In case anyone finds this thread: an error was found in the battery measurement code. See https://forum.mysensors.org/post/97409 for details. Sundberg84 has updated the code on github with a fix.
