  3. Suddenly a Sensor is Missing, not the whole Node. (RPI Eth Gateway, HA)
5 Posts 2 Posters 1.3k Views 2 Watching
  • S Offline
    se-O-matic
    i'm running a sensor network for a couple of years without problems. The setup is described below.
    Some days ago i build an other sensor node and now suddenly a random sensor is missing a view days after HomeAssistant restart.
    So, after a restart everything works perfect. But after a view days the temperature reading of one node, not always the same node, didnt work. The values for humidity and battery level still work from this node. After a restart of the Pi everything works again.
    One time I didnt restart for a couple of days, even more temperature sensors failed. And again the humidity readings still work. After a restart everything works again.
    My network:
    A Raspberry Pi 3 with 64 Bit Raspbian. Homeassistant running in Docker.
    A RFM69 rf module is connected to the GPIO of the RPI to run a ethernet gateway. I had to recompile it because of the 64 Bit structure.
    I have several sensors based of an arduino structure and the RFM69 modules:
    • 3 Temperature/Humidity PLUS ONE NEW Temp/Hum sensor
    • 1 Temp/Hum/Light sensor
    • 1 USB charger sensor (report two current values, if switched on)
    • 1 power meter sensor (actually offline to rewrite the code for an new power meter with different protocol)
    Additionally a couple of actuators and switches over zigbee (SonOff USB stick), like curtains and wall plugs.
    And one BTLE temp/hum sensor.
    Now I 'm a little helpless where to start the debugging. I think the problem occurs between the mysensors gateway and HomeAssistant.
    Is this a space problem for storing the data?
    Maybe I can switch to a more convenient setup, like an mysensors USB gateway and the HASS-OS from HomeAssistant instead of the "experimental" docker stuff?
    I hope someone has a good idea to help.
    Thanks!
    se-O-matic
    • E Offline
      E Offline
      eiten
      Hi @se-O-matic
      can you please post your source code of the node in question?
      You only restarted Home Assistant, not the nodes, correct?
      Thanks and regards, Edi
      • S Offline
        se-O-matic
        thanks for the reply.
        Yes, a restart of the raspberry is enough.
        This is the code of the temperatur sensors:
         * My Sensors Node for temperature and humidity
         * Hardware: MSN R00
         * BME280 (temp, hum) at I2C
         * Runs at 2 x AA batterys
        // RFM69CW at 433 MHz / Raspebrry Pi as ethernet gateway
        #define MY_RADIO_RFM69
        #define MY_RFM69_NEW_DRIVER
        #define MY_RFM69_FREQUENCY RFM69_433MHZ
        // BME280 library from Adafruit, need the Adafruit "Unified Sensor library", too
        #include <Adafruit_BME280.h>
        // Define child IDs and messages
        #define CHILD_ID_TEMP  0
        #define CHILD_ID_HUM   1
        // Define strings, which are send to the controller
        #define SKETCHSTR "Temp Humidity Sensor"
        #define SKETCHVER "1.0"
        // Sleep time for sensor
        uint32_t SLEEP_TIME = 300000;    // sleep time between reads (seconds * 1000 milliseconds)
        // Constructor for sensor
        Adafruit_BME280 bme;
        #define BME280_TEMP_OFFSET -1.0    // calibration ofsset for the temperature
        // Battery stuff
        #define EMPTY 536         // Brown Out ATMega   //536 equal to 1.8 V
        #define SCALE 0.2415      // (100/950-EMPTY)    //950 equal to 3.2 V
        int BATTERY_SENSE_PIN = A0;   // select the input pin for the battery sense point
        int batteryPcnt = 0, oldBatteryPcnt = 0;
        // Global variables for sensor values
        float temp = 25.0, hum = 50.0;
        float temp_last = 0.0, hum_last = 0.0;
        // Helper for calculate battery percentage
        int calc_pcnt(int value){
          int batteryPcnt = ((value - EMPTY) * SCALE);
          batteryPcnt = (batteryPcnt > 100) ? 100 : batteryPcnt;
          batteryPcnt = (batteryPcnt < 0) ? 0 : batteryPcnt;
          return batteryPcnt;
          analogReference(INTERNAL);
          //BME280 stuff
          bme.begin(0x77);
          bme.setSampling(Adafruit_BME280::MODE_FORCED,
                          Adafruit_BME280::SAMPLING_X1,   // temperature
                          Adafruit_BME280::SAMPLING_NONE, // pressure
                          Adafruit_BME280::SAMPLING_X1,   // humidity
                          Adafruit_BME280::FILTER_OFF );
          oldBatteryPcnt = calc_pcnt(analogRead(BATTERY_SENSE_PIN));
          sendSketchInfo(SKETCHSTR, SKETCHVER);
          present(CHILD_ID_TEMP, S_TEMP, "Temperature");
          present(CHILD_ID_HUM, S_HUM, "Humidity");
          //read temp and hum and lux
          bme.takeForcedMeasurement();
          temp = bme.readTemperature();
          temp = temp + BME280_TEMP_OFFSET;
          hum = bme.readHumidity();
          if(temp != temp_last){
            send(msgTemp.set(temp, 2));
            temp_last = temp;
          if(hum != hum_last){
            send(msgHum.set(hum, 2));
            hum_last = hum;
          // send the battery level
          batteryPcnt = calc_pcnt(analogRead(BATTERY_SENSE_PIN));
          if (batteryPcnt < oldBatteryPcnt) {
              oldBatteryPcnt = batteryPcnt;
          sleep(SLEEP_TIME);
        It's also hosted on github: https://github.com/se-o-matic/msn/blob/master/Software/msn_BME280/msn_BME280.ino
        Thanks!
        • E Offline
          E Offline
          eiten
          Sorry @se-O-matic , but I can't see any problem. Does the temperature recover with time? I only can imagine that you have a collision on air.
          • S Offline
            se-O-matic
            No, it does not recover.
            The Problem is not easy to debug. I now want to build a serial gateway. With that, I am more flexible to test. Maybe to run MySensors on a second raspberry pi with a standard Home Assistant HASS-Os image. Or I check the MySensors network with MyController.
            At this moment i run the whole system on 64 Bit raspbian, with HA in docker, which is a little bit experimental and i had to fix some lines in the ethernet gateway to compile it for 64 bit. So this is experimental, too.
            12.1k
