  3. Home Assistant
  4. How to repeat presentation when using home-assistant with persistance false
3 Posts 3 Posters 1.3k Views 3 Watching
  • L
    L
    leonard
    I'am using home-assistant for a while and build some temperature sensors with mysensors.
    With the default settings, home-assistant is caching the presentation and sensor values in a pickle file. This has the following downsides:
    • when restarting home-assistant, old sensor values are beeing shown as new (just received)
    • when changing a sketch, some added information does not update (or partly).
    So I decided to turn off the persistence. Now I do have the problem, that nodes have to repeat their presentation when restarting home-assistant. I haven't got this working properly. Resetting the nodes fixes this issue, but that is not an solution.
    I see two solutions
    • repeat presentation (if necessary, nodes are battery powered)
    • tweak home-assistant to do a more clever persistence
    The more clever persistance would involve:
    • discard old sensor values (or do not show them as new values...)
    • allow sketch updates without limitations (details would have to be investigated)
    • Allow to remove nodes that are not present any more (pickle file can not be edited easily).
    Has anyone suggestions to solve this issues?
    Regards
    Leonard
    • simboS
      simboS
      simbo
      A related thread: https://forum.mysensors.org/topic/6843/re-request-presentation
      How can we send a I_PRESENT or I_REBOOT command using the HA / MySensors API? If there's a way, then an automation be be hard-coded to request each node to reboot.
      • J
        J
        jmg138
        is someone find a way to send a I_PRESENT or I_REBOOT command using HA? or an other workaround to force node presentation when the persistant file is desactivated? (usefull after a HA reboot for instance)
