  3. Send secured command to the gateway
15 Posts 4 Posters 2.7k Views 5 Watching
  • SnyfirS
    SnyfirS
    Snyfir
    i build a keypad node which send a message to the gateway to activate or deactivate the alarm. To avoid somebody to send the message whithout the keypad device i use signing message described here : https://www.mysensors.org/apidocs-beta/group__MySigninggrpPub.html
    in the keypad node i have:
    #define MY_SIGNING_ATSHA204
    and in the gateway i have:
    but if i understand well, only messages send from gateway to keypad node are signed. If i want signed messages send from keypad node to gateway i nead to put in the gateway:
    but when i do that all my nodes nead to sign here message but i want only the keypad node. I can used MY_SIGNING_WEAK_SECURITY but if the keypad node send non signed message, the message will be taking. and the security from my keypad node and the gateway is compromised.
    How can i force the gateway to accept only signed message from keypad node but accept non signed message from other node ?
    thank you for your help
    AnticimexA 1 Reply Last reply
    • SnyfirS Snyfir
      AnticimexA
      AnticimexA
      Anticimex
      @snyfir
      Hi!
      The gateway will require signatures from the keypad since the keypad also require it also with the weak security setting. However, with that setting, a rogue device could spoof and pretend to be your keypad, and then transmit a message to the gw that it no longer require signatures and therefore make the GW relax its requirement from that device until it again indicate it require signatures.
      You could add encryption to obfuscate your communication a bit which makes it harder for an attacker to spoof your keypad but that also require you to deploy encryption to the entire network.
      You could also hack your gw code so that it makes that particular node irreversibly require signatures from your keypad node but there is currently no "official" way of doing that.
      Another hack you could make which is less "hard core" is to adjust the behavior of the weak security flag to never allow "nerfing" security settings for a node.
      That is, even with the weak flag set, a gw will never allow a node to stop requiring signed messages.
      Or more to the point: the GW will allow a node to set the bit in gw eeprom to indicate that it require the node to send signed messages, but it will never clear it.
      The consequence of doing this is that if you at some point want to disable requirement for signatures for a node, you have to manually reset the eeprom flag in the GW.
      I don't remember exactly but I think this is the behaviour if you do not set the weak flag because the message to configure signing requirement is in itself not signed. Therefore the default is to accept going to a more secure state but not going back.
      Hope this makes things a bit more clear :)
      skywatchS SnyfirS 2 Replies Last reply
      • AnticimexA Anticimex
        @snyfir
        Hi!
        skywatchS
        skywatchS
        skywatch
        @anticimex Is it possible to have one gateway with HW signing and encryption for security related items on one RF channel and another gateway with just signing on another RF channel? - I have thought of doing this recently and this seems like a good time to ask. ;)
        • skywatchS skywatch
          AnticimexA
          AnticimexA
          Anticimex
          @skywatch yes, that is a perfectly viable option. As they are two separate independent networks they can have distinct configurations and requirements. This also applies to the security.
          Much like WLANs.
          skywatchS 1 Reply Last reply
            @snyfir
            Hi!
            SnyfirS
            SnyfirS
            Snyfir
            Thank you for your answer @Anticimex
            @anticimex said in Send secured command to the gateway:
            That exactly what i want to do. But it seams not implemented like this in MySensors V2.3.1
            Do you have an idea how to hack MySensors V2.3.1 to do this ?
            • SnyfirS Snyfir
              AnticimexA
              AnticimexA
              Anticimex
              @snyfir Yes, have a look at https://github.com/mysensors/MySensors/blob/master/core/MySigning.cpp#L414
              Commenting out that line (and https://github.com/mysensors/MySensors/blob/master/core/MySigning.cpp#L431 if you also use whitelisting) will prevent the GW when configured with MY_SIGNING_WEAK_SECURITY to "downgrade" security settings. Thus, a node that has registered in that it require signatures, will not be able to "undo" that by remote command in the GW.
              That should make your lock co-exist securely in your network even when the GW is not requiering signatures from other nodes.
              But please note that you still use the weak security flag, so all other GW logic still behaves as before (signed messages will only be required by nodes that require messages themselves and so on).
              I have intentianlly left out the option of selecting this operation mode because the security configuration is complex enough as it is and users unfamiliar with the inner workings of the signing backend might end up locking themselves out and having problems getting things working again (resetting EEPROM in your GW will make it loose routing tables and ID assignments as well so it is not something to make a habit out of doing :-) ).
              SnyfirS 1 Reply Last reply
                SnyfirS
                SnyfirS
                Snyfir
                Thank you @anticimex i will do that :+1:
                Maybe a proper way to avoid resetting EEPROM GW i can change the line https://github.com/mysensors/MySensors/blob/master/core/MySigning.cpp#L277 :
                from
                if (msg.destination == getNodeId()) {
                to
                if (msg.destination == getNodeId() && msg.sender >= 100) {
                in that way i don't nead to use MY_SIGNING_WEAK_SECURITY to "downgrade" security and if i nead a node transmission from node to gateway to be secure i just assign it an id > 100
                what do you think ?
                • SnyfirS Snyfir
                  from
                  to
                  what do you think ?
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @snyfir It might work, but watch out so that you do ensure that nobody can spoof the device ID or somehow trick your GW to reassign the ID to a level where it will not verify the message.
                    SnyfirS
                    SnyfirS
                    Snyfir
                    if in the controller i verify the couple message / id of the node, it will be ok no ?
                    it's possible to trick the GW to reassign the ID ?
                    • SnyfirS Snyfir
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @snyfir Sorry, my comment was incorrect. The GW does not assign IDs. Your controller does. So it comes down to how your controller reacts to what the GW reports.
                        Much like WLANs.
                        skywatchS
                        skywatchS
                        skywatch
                        @anticimex Thank you!
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @skywatch always happy to help a fellow "signer" :)
                            skywatchS
                            skywatchS
                            skywatch
                            @anticimex You may regret that statement when I finally get time to try it! :)
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @skywatch just read the docs and you'll be fine ;)
                              • alowhumA
                                alowhumA
                                alowhum
                                @Anticimex That sounds like a good idea for a new official feature to me? Especially if it's just one line that needs to be commented out?
