  3. Lux sensor (BH1750) sending battery level (V)
12 Posts 6 Posters 1.8k Views 5 Watching
  • F Offline
    F Offline
    FrankVK
    wrote on last edited by FrankVK
    I really enjoy using MySensors!
    Got a small general question though: I'm using a BH1750 light sensor, powered by a 3V battery and I'd like to keep an eye on the battery status.
    I have added a line to the existing BH1750 scetch:
    #define CHILD_ID_VCC = 1
    MyMessage msgVcc(CHILD_ID_VCC, V_VOLTAGE);
    void Presentation() {
      sendSketchInfo("Light Lux Sensor", "1.1");
      present(CHILD_ID_VCC, S_MULTIMETER);
    Loop() {
    uint16_t lux = lightSensor.readLightLevel();
    float Vcc = ReadVcc();
    send(msgLux.set(Lux));
    send(msgVcc.set(Vcc));
    Domoticz recieves the data now, but the Voltage is reading 2968V because readVcc delivers mV
    If I change the code to:
    float Vcc = readVcc()/1000;
    I get an error message "call of overloaded 'set(float&)'is ambiguous"
    How can I send decimal values to the Domoticz controller from MySensors?
    Regards, Frank
    zboblamontZ mfalkviddM 2 Replies Last reply
    • F FrankVK
      Loop() {
      Regards, Frank
      zboblamontZ Offline
      zboblamontZ Offline
      zboblamont
      @frankvk No programming skills, but is it correct trying to calculate in a procedure call rather than insert an intermediate step?
      If the ReadVcc() procedure call returns millivolts, suggest preceding the "float Vcc = ReadVcc();" with "int Voltage= ReadVcc();" and change the "float Vcc = ReadVcc();" to "float Vcc = Voltage/1000;", it should then do as you want.
      • F Offline
        F Offline
        FrankVK
        Hi Zboblamont,
        Thanks for your response, but the error occurs in the line, obviously because Vcc is of the type 'float'
        • F FrankVK
          Hi Zboblamont,
          zboblamontZ Offline
          zboblamontZ Offline
          zboblamont
          wrote on last edited by zboblamont
          @frankvk I'm no expert on this, but do know all my nodes send battery as a float for the last 2 years, excerpt as follows:
          // Call for battery reading, send in every 12th RTC call?
             if(halfday==12){
             digitalWrite(BatteryOn, HIGH);
             voltread = analogRead(BatteryIn);
             float voltage = (7.272 * voltread) / 1024;
             sleep(5);
             digitalWrite(BatteryOn, LOW);
             send(msg3.set(voltage,2));
             sleep(50);
             voltread=0;
             sleep(50);
             halfday=0;//Reset for 12 hourly cycle
             halfday++;//Increment hourly cycle
          That is based on the internal value defined without any complications, but note that the message is sent to 2 decimal places, whether that truncation is essential for the MySensors environment I do not know, it was all I required.
          • electrikE Offline
            electrikE Offline
            electrik
            Is there a typo in your message or in your code?
            First you used ReadVcc(), then readVcc()
            • F FrankVK
              Loop() {
              Regards, Frank
              @frankvk could you post the entire sketch, including where readVcc comes from? Seeing the code will make it much easier to help you.
              • B Offline
                B Offline
                bgunnarb
                The line
                should be:
                float Vcc = readVcc()/1000.;
                to start with. Note the decimal point! If read Vcc() returns a float, you cannot divide by an integer.
                I have never been so busy since I retired!
                K 1 Reply Last reply
                • B bgunnarb
                  The line
                  should be:
                  K Offline
                  K Offline
                  kimot
                  @bgunnarb
                  But readVcc returns long
                  long readVcc() {
                    long result;
                    ADCSRA |= _BV(ADSC); // Convert
                    while (bit_is_set(ADCSRA,ADSC));
                    result = ADCL;
                    result |= ADCH<<8;
                    result = 1126400L / result; // Back-calculate AVcc in mV
                    return result;
                  • K kimot
                    @bgunnarb
                    long readVcc() {
                      long result;
                      result = ADCL;
                      result |= ADCH<<8;
                      return result;
                    A float can be divided by an integer. The result will be a float.
                    A long can be divided by an integer or a float. The result will differ though.
                    2968/1000 will give the integer 2
                    2968/1000.0 will give the float 2.968
                    See "Integer and floating point division" at https://www.learncpp.com/cpp-tutorial/32-arithmetic-operators/
                    zboblamontZ F B 3 Replies Last reply
                      zboblamontZ Offline
                      zboblamontZ Offline
                      zboblamont
                      @mfalkvidd @bgunnarb Something new learned from that, hadn't realised a procedure call could be mathematically manipulated like that, nor the subtle differences in the outputs...
                        F Offline
                        F Offline
                        FrankVK
                        Actually, I needed to change 2 things: first one was dividing by 1000.0 rather than 1000 and the other one was calling send(msgVcc.set(Vcc, 2)); rather than send(msgVcc.set(Vcc)); Now the log reads 2.95V.
                        Thanks Mikael (@mfalkvidd) & everyone! Happy coding!
                          B Offline
                          B Offline
                          bgunnarb
                          @mfalkvidd
                          Yep, this is a great way of introducing errors that will be nearly impossible to find!:grinning:
                          12.1k
