  3. Domoticz
  4. Roller shutter(s_cover) on Domoticz
8 Posts 6 Posters 2.6k Views 6 Watching
  • TmasterT
    TmasterT
    Tmaster
    wrote on last edited by Tmaster
    hello. I'm building and remake of Simple cover actuator from @dpressle (here), i call it a remake because my shutter have 2 relays ,one for UP and 1 for Down(not power and direction like original one)
    and i'm having problems to make it work like "blind percentage" switch type on Domoticz.
    i read that they were not supported 4 years ago but i think it was already corrected.Right?
    picture above its what i got on domoticz, up,down and stop works,but percentage its buggy ,not respond, and status its always closed,even when windows it' full open(full up).
    my edited code
    #define MY_RADIO_RFM69
    //#define MY_REPEATER_FEATURE
    #include <Bounce2.h>
    // uncomment if we want to manually assign an ID
    //#define MY_NODE_ID 1 /
    #define BUTTON_UP_PIN 5  // Arduino Digital I/O pin number for up button
    #define BUTTON_DOWN_PIN 6  // Arduino Digital I/O pin number for down button
    //#define BUTTON_STOP_PIN 7  // Arduino Digital I/O pin number for stop button
    #define RELAY_UP_PIN 3  // Arduino Digital I/O pin number for direction relay
    #define RELAY_DOWN_PIN 4  // Arduino Digital I/O pin number for power relay
    #define RELAY_ON 0
    #define RELAY_OFF 1
    //#define RELAY_DOWN 1
    //#define RELAY_UP 0
    #define DIRECTION_DOWN 1
    #define DIRECTION_UP 0
    #define SKETCH_NAME "Cover"
    #define SKETCH_VER "2.0"
    #define CHILD_ID_COVER 0   // sensor Id of the sensor child
    #define STATE_UP 100 // 100 is open - up
    #define STATE_DOWN 0 // 0 is closed - down
    //#define CHILD_ID_CALIBRATE 1   // sensor Id of the sensor child to calibrate
    #define CHILD_ID_SET 1   // sensor Id of the sensor child to init the roll time
    #define PRESENT_MESSAGE "shuttle for Livingroom"
    const int LEVELS = 100; //the number of levels
    float rollTime = 28.0; //the overall rolling time of the shutter
    const bool IS_ACK = false; //is to acknowlage
    static bool initial_state_sent = false;//for hass we need at list one state send at begining
    // debouncing parameters
    int value = 0;
    int oldValueUp = 0;
    int oldValueDown = 0;
    //int value1=0;int value2=0;
    int oldValueStop=0;
    int oldValueStop1=0;
    //static unsigned long last_interrupt_time_up = 0;
    //static unsigned long last_interrupt_time_down = 0;
    //static unsigned long debounce_time = 200;
    Bounce debouncerUp = Bounce();
    Bounce debouncerDown = Bounce();
    //Bounce debouncerStop = Bounce();
    // shutter position parameters
    float timeOneLevel = rollTime / LEVELS;
    int requestedShutterLevel = 0;
    int currentShutterLevel = 0;
    unsigned long lastLevelTime = 0;
    bool isMoving = false;
    int directionUpDown;
    enum CoverState {
      STOP,
     UP, // Window covering. Up.
      DOWN, // Window covering. Down.
    static int coverState = STOP;
    MyMessage msgUP(CHILD_ID_COVER, V_UP);
    MyMessage msgDown(CHILD_ID_COVER, V_DOWN);
    MyMessage msgStop(CHILD_ID_COVER, V_STOP);
    MyMessage msgPercentage(CHILD_ID_COVER, V_PERCENTAGE);
    //MyMessage msgCode(CHILD_ID_SET, V_IR_SEND);
    void sendState() {
      // Send current state and status to gateway.
      send(msgUP.set(coverState == UP));
      send(msgDown.set(coverState == DOWN));
      send(msgStop.set(coverState == STOP));
      send(msgPercentage.set(currentShutterLevel));
    void shuttersUp(void) {
    #ifdef MY_DEBUG
      Serial.println("Shutters going up");
      if (digitalRead(RELAY_DOWN_PIN) == RELAY_ON) {
          digitalWrite(RELAY_DOWN_PIN, RELAY_OFF);
          delay(20);
      digitalWrite(RELAY_UP_PIN, RELAY_ON);
      directionUpDown = DIRECTION_UP;
      isMoving = true;
      coverState = UP;
      sendState();
    void shuttersDown(void) {
    #ifdef MY_DEBUG
      Serial.println("Shutters going down");
      if (digitalRead(RELAY_UP_PIN) ==  RELAY_ON) {
         digitalWrite(RELAY_UP_PIN, RELAY_OFF);
         delay(20);
      digitalWrite(RELAY_DOWN_PIN, RELAY_ON);
      directionUpDown = DIRECTION_DOWN;
      isMoving = true;
      coverState = DOWN;
      sendState();
    void shuttersHalt(void) {
    #ifdef MY_DEBUG
      Serial.println("Shutters halted X");
     // Serial.println("2 BOTOES OFF");
       // if (digitalRead((RELAY_UP_PIN) || (RELAY_DOWN_PIN) )==  RELAY_ON) {
        delay(20);
      isMoving = false;
      requestedShutterLevel = currentShutterLevel;
    #ifdef MY_DEBUG
      Serial.println("saving state to: ");
      Serial.println(String(currentShutterLevel));
      saveState(CHILD_ID_COVER, currentShutterLevel);
      coverState = STOP;
      //sendState();
    void changeShuttersLevel(int level) {
      int dir = (level > currentShutterLevel) ? DIRECTION_UP : DIRECTION_DOWN;
      if (isMoving && dir != directionUpDown) {
        shuttersHalt();
      requestedShutterLevel = level;
    void initShutters() {
    #ifdef MY_DEBUG
      Serial.println("Init Cover");
      shuttersUp();
      delay((rollTime + timeOneLevel * LEVELS) * 1000);
      currentShutterLevel = STATE_UP;
    #ifdef MY_DEBUG
      Serial.println("recieved incomming message");
      Serial.println("Recieved message for sensor: ");
      Serial.println(String(message.sensor));
      Serial.println("Recieved message with type: ");
      Serial.println(String(message.type));
      if (message.sensor == CHILD_ID_COVER) {
        switch (message.type) {
          case V_UP:
            //Serial.println(", New status: V_UP");
            changeShuttersLevel(STATE_UP);
            //state = UP;
            //sendState();
            break;
          case V_DOWN:
            //Serial.println(", New status: V_DOWN");
            changeShuttersLevel(STATE_DOWN);
            //state = DOWN;
            //sendState();
            break;
          case V_STOP:
            //Serial.println(", New status: V_STOP");
            shuttersHalt();
            //state = IDLE;
            //sendState();
            break;
          case V_PERCENTAGE:
            //Serial.println(", New status: V_PERCENTAGE");
            //          if (!initial_state_sent) {
            //            #ifdef MY_DEBUG
            //            Serial.println("Receiving initial value from controller");
            //            #endif
            //            initial_state_sent = true;
            int per = message.getInt();
            if (per > STATE_UP) {
              per = STATE_UP;
            changeShuttersLevel(per);
            //InitShutters(message.getInt());//send value < 0 or > 100 to calibrate
            //sendState();
            break;
    else if (message.sensor ==  CHILD_ID_SET) {
        if (message.type == V_VAR1) {
          Serial.println(", New status: V_VAR1, with payload: ");
          String strRollTime = message.getString();
          rollTime = strRollTime.toFloat();
          Serial.println("rolltime value: ");
          Serial.println(String(rollTime));
          saveState(CHILD_ID_SET, rollTime);
    #ifdef MY_DEBUG
      Serial.println("exiting incoming message");
      return;
    void before() {
      // Setup the button
      pinMode(BUTTON_UP_PIN, INPUT_PULLUP);
      // Activate internal pull-up
      digitalWrite(BUTTON_UP_PIN, HIGH);
      //attachInterrupt(digitalPinToInterrupt(BUTTON_UP_PIN), upButtonPress, RISING);
      pinMode(BUTTON_DOWN_PIN, INPUT_PULLUP);
      digitalWrite(BUTTON_DOWN_PIN, HIGH);
     // attachInterrupt(digitalPinToInterrupt(BUTTON_DOWN_PIN), downButtonPress, RISING);
      //pinMode(BUTTON_STOP_PIN, INPUT_PULLUP);
      //digitalWrite(BUTTON_STOP_PIN, HIGH);
      debouncerUp.attach(BUTTON_UP_PIN);
      debouncerUp.interval(5);
      debouncerDown.attach(BUTTON_DOWN_PIN);
      debouncerDown.interval(5);
     // debouncerStop.attach(BUTTON_UP_PIN&&BUTTON_UP_PIN);
     // debouncerStop.interval(5);
      pinMode(RELAY_UP_PIN, OUTPUT);
      pinMode(RELAY_DOWN_PIN, OUTPUT);
    void presentation() {
      sendSketchInfo(SKETCH_NAME, SKETCH_VER);
      present(CHILD_ID_COVER, S_COVER, PRESENT_MESSAGE, IS_ACK);
      //present(CHILD_ID_SET, S_CUSTOM);
    void setup(void) {
      //set up roll time if the saved value is not 255
      Serial.println("getting rolltime from eeprom: ");
      float tmpRollTime = loadState(CHILD_ID_SET);
      if (tmpRollTime != 0xff) {
        rollTime = tmpRollTime;
      int state = loadState(CHILD_ID_COVER);
    #ifdef MY_DEBUG
      Serial.println("getting state from eeprom: ");
      Serial.println(String(state));
      if (state == 0xff) {
        initShutters();
      } else {
        changeShuttersLevel(state);
    void loop(void) {
    #ifdef MY_DEBUG
        sendState();
       // send(msgCode.set('20.0'));
        //    #ifdef MY_DEBUG
        //    Serial.println("Requesting initial value from controller");
        //    #endif
        //    request(CHILD_ID_COVER, V_PERCENTAGE);
        //    wait(2000, C_SET, V_PERCENTAGE);
      debouncerUp.update();
      value = debouncerUp.read();
      if (value == 0 && value != oldValueUp) {
        //state = UP;
        //sendState();
      oldValueUp = value;
      debouncerDown.update();
      value = debouncerDown.read();
      if (value == 0 && value != oldValueDown) {
        //state = DOWN;
        //sendState();
      oldValueDown = value;
     // debouncerStop.update();
      //value = debouncerStop.read();
      //if (value == 0 && value !=( oldValueUp||oldValueDown)) {
    // debouncerDown.update();
    // debouncerUp.update();
      value = debouncerUp.rose();
       if (value == 0 && value != oldValueStop){
       shuttersHalt();
       oldValueStop = value;
      value = debouncerDown.rose();
        if (value == 0 && value != oldValueStop1){
        shuttersHalt();
        oldValueStop1 = value;
      if (isMoving) {
        unsigned long _now = millis();
        if (_now - lastLevelTime >= timeOneLevel * 1000) {
          if (directionUpDown == DIRECTION_UP) {
            currentShutterLevel += 1;
          } else {
            currentShutterLevel -= 1;
    #ifdef MY_DEBUG
          //Serial.println(String(requestedShutterLevel));
          lastLevelTime = millis();
          //send(msgPercentage.set(currentShutterLevel));
        if (currentShutterLevel == requestedShutterLevel){
        //if ((currentShutterLevel == requestedShutterLevel) || (digitalRead(((RELAY_UP_PIN) ==1) &&(RELAY_DOWN_PIN) ==1))) {
          shuttersHalt();
      else if (requestedShutterLevel != currentShutterLevel) {
        if (requestedShutterLevel > currentShutterLevel) {
          shuttersUp();
        else {
          shuttersDown();
    what am i missing? thank you .
    i'm a arduino fan .Even sometimes don't undestanding how to use it :P
    • TmasterT Tmaster
      my edited code
      #define RELAY_ON 0
      #define RELAY_OFF 1
      int value = 0;
      int oldValueUp = 0;
      int oldValueStop=0;
      enum CoverState {
        STOP,
      void sendState() {
      #ifdef MY_DEBUG
            delay(20);
        isMoving = true;
        coverState = UP;
        sendState();
      #ifdef MY_DEBUG
           delay(20);
        isMoving = true;
        coverState = DOWN;
        sendState();
      #ifdef MY_DEBUG
          delay(20);
        isMoving = false;
      #ifdef MY_DEBUG
        coverState = STOP;
        //sendState();
          shuttersHalt();
      #ifdef MY_DEBUG
        shuttersUp();
      #ifdef MY_DEBUG
            case V_UP:
              //state = UP;
              //sendState();
              break;
            case V_DOWN:
              //state = DOWN;
              //sendState();
              break;
            case V_STOP:
              shuttersHalt();
              //state = IDLE;
              //sendState();
              break;
            case V_PERCENTAGE:
              //            #ifdef MY_DEBUG
              //            #endif
                per = STATE_UP;
              //sendState();
              break;
      #ifdef MY_DEBUG
        return;
      void before() {
        // Setup the button
      void setup(void) {
      #ifdef MY_DEBUG
          initShutters();
        } else {
      void loop(void) {
      #ifdef MY_DEBUG
          sendState();
          //    #ifdef MY_DEBUG
          //    #endif
          //state = UP;
          //sendState();
        oldValueUp = value;
          //state = DOWN;
          //sendState();
         shuttersHalt();
          shuttersHalt();
        if (isMoving) {
            } else {
      #ifdef MY_DEBUG
            shuttersHalt();
            shuttersUp();
          else {
            shuttersDown();
      @tmaster what does the debug log from the node say?
      • TmasterT
        TmasterT
        Tmaster
        thank you for reply @mfalkvidd
        Payload like 100 shoud be 100% on domoticz, right? how does domoticz "know" that a blindcover /or shutter is open or close? because it's not respondig to that...
         __  __       ____
                |___/                      2.3.1
        16 MCO:BGN:INIT NODE,CP=RRNNA---,REL=255,VER=2.3.1
        26 MCO:BGN:BFR
        28 TSM:INIT
        30 TSF:WUR:MS=0
        34 TSM:INIT:TSP OK
        34 TSF:SID:OK,ID=4
        36 TSM:FPAR
        1257 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        1423 TSF:MSG:READ,0-0-4,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        1429 TSF:MSG:FPAR OK,ID=0,D=1
        3264 TSM:FPAR:OK
        3264 TSM:ID
        3266 TSM:ID:OK
        3268 TSM:UPL
        3276 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        3315 TSF:MSG:READ,0-0-4,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        3321 TSF:MSG:PONG RECV,HP=1
        3325 TSM:UPL:OK
        3328 TSM:READY:ID=4,PAR=0,DIS=1
        3540 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        3567 TSF:MSG:READ,0-0-4,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        3786 TSF:MSG:SEND,4-4-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1
        4005 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        4046 TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=1,sg=0:M
        4263 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Cover
        4483 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
        4708 TSF:MSG:SEND,4-4-0-0,s=0,c=0,t=5,pt=0,l=22,sg=0,ft=0,st=OK:shuttle for Livingroom
        4716 MCO:REG:REQ
        4929 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        4956 TSF:MSG:READ,0-0-4,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        4962 MCO:PIM:NODE REG=1
        4964 MCO:BGN:STP
        28.00
        4968 MCO:BGN:INIT OK,TSP=1
        5185 TSF:MSG:SEND,4-4-0-0,s=0,c=1,t=29,pt=1,l=1,sg=0,ft=0,st=OK:0
        5402 TSF:MSG:SEND,4-4-0-0,s=0,c=1,t=30,pt=1,l=1,sg=0,ft=0,st=OK:0
        5619 TSF:MSG:SEND,4-4-0-0,s=0,c=1,t=31,pt=1,l=1,sg=0,ft=0,st=OK:1
        5838 TSF:MSG:SEND,4-4-0-0,s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:0
        after I give an order of CLOSE (DOWN) shutter (v_percentage=0)
        ------------     *(HERE WAS AT 100% AND I ORDER TO GO 0%(CLOSED)* -------------------
        Shutters going down
        612509 TSF:MSG:SEND,4-4-0-0,s=0,c=1,t=29,pt=1,l=1,sg=0,ft=0,st=OK:0
        612728 TSF:MSG:SEND,4-4-0-0,s=0,c=1,t=30,pt=1,l=1,sg=0,ft=0,st=OK:1
        612947 TSF:MSG:SEND,4-4-0-0,s=0,c=1,t=31,pt=1,l=1,sg=0,ft=0,st=OK:0
        613167 TSF:MSG:SEND,4-4-0-0,s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:100
        99
        98
        Shutters halted X
        saving state to:
        645519 TSF:MSG:SEND,4-4-0-0,s=0,c=1,t=29,pt=1,l=1,sg=0,ft=0,st=OK:0
        645738 TSF:MSG:SEND,4-4-0-0,s=0,c=1,t=30,pt=1,l=1,sg=0,ft=0,st=OK:0
        645957 TSF:MSG:SEND,4-4-0-0,s=0,c=1,t=31,pt=1,l=1,sg=0,ft=0,st=OK:1
        646176 TSF:MSG:SEND,4-4-0-0,s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:0
        ------------    *(HERE REACH 0%)* -------------------
        • TmasterT
          TmasterT
          Tmaster
          so, i assume that my question it's not obvious and because that domoticz still have this bug...
          i will leave it without percentage bar(just as blind) because its just to opena and close that shutter at night/morning
          nobody have an sensor with S_COVER presented on Domoticz working good?
          • F
            F
            feanor-anglin
            I have similar problem. Some time ago I even wrote a nice piece of code to update roller shutter position if changed from buttons. But domoticz just does not seem to understand values the sensor sends. So I confirm, blinds percentage is buggy.
            • MasMatM
              MasMatM
              MasMat
              Old thread, I know. Anybody know if this was ever fixed? I can get by with just open/close but percentage would be extra snazzy.
              I'm using a 12V dc motor and microswitches at limit points. The blind is just SO heavy/dragging that I had to get a beefy DC motor. The apparatus moves nicely. Just the control circuitry to do.
              • R
                R
                razdwa
                Bumping an old thread.
                It looks like domoticz is detecting two device types with the same unit ID - blinds and lights.
                V_PERCENTAGE values send from the device to domoticz updates the Light/Switch value. It also works the other way around - changing the light type device to dimmer and updating the dim value - sends V_PERCENTAGE command to mySensors which effectively targets the cover (as they have the same unit ID).
                • K
                  K
                  kamilb85
                  Someone know if it is problem with Domoticz or MySensors?
