  3. difference between encryption with personalization and simple password
17 Posts 6 Posters 2.3k Views 5 Watching
  • AndurilA
    AndurilA
    Anduril
    Hey there,
    is there any significant difference between the two options for encryption? Does the simple one consumes more flash? Is it safe to use with OTA updates (should be, as all communication is encrypted)? Why should you bother with personalization in the first place or is it only the 'old grown' method?
    Thanks for any contribution in advance,
    Anduril
    mfalkviddM AnticimexA 2 Replies Last reply
    • TRS-80T
      TRS-80T
      TRS-80
      I see you have been here quite longer than me (2015) so perhaps you are well beyond what I am about to mention, but I could not help but notice you mentioned encryption and not signing, and my understanding is the project have decided that signing is probably more important than encryption?
      Further, I have yet to implement any of that myself (although I am sure I will get to it "one day") so again I could really just be not fully understanding the implications of your question due to lack of knowledge.
      • AndurilA Anduril
        Hey there,
        Anduril
        @Anduril could you expand on what 2 options you are referring to?
        • AndurilA Anduril
          Hey there,
          Anduril
          AnticimexA
          AnticimexA
          Anticimex
          @Anduril for encryption, the difference is not significant. With personalization, the key is stored in flash/eeprom and without it is defined in your sketch. So, if you personalize, you can publish your sketch without worrying about being compromised. And encryption works transparently with the OTA solution, IF the software that implement OTA is aware of the encryption scheme. That is, the software that configures the radio (in some solutions that is the bootloader) need to configure the appropriate key to the radio hw or driver (depending on radio).
          For bootloader based OTA that require personalization unless you recompile the bootloader with the encryption key and make it configure the radio accordingly.
          • AndurilA
            AndurilA
            Anduril
            @mfalkvidd I mean the two options #define MY_ENCRYPTION_SIMPLE_PASSWD and #define MY_RFM69_ENABLE_ENCRYPTION (with personalization before)
            @Anticimex thank you for your answer. In my case I want to implement OTA with the online version with DualOptibootloader. This way, the node will be able to decrypt and store the new firmware in external flash. With the MYS Bootloader that would not be possible as far as I understood the thing...
            @TRS-80 signing will also be added. But I want to be able to send messages unseen from the 'public' to my nodes... some of them are text-based and I don't want to be sniffed...
            • TRS-80T
              TRS-80T
              TRS-80
              ^ Well, there is the man, right there (Anticimex). ^ :)
              You are in much better hands now, I will go back to trying to follow along and learn, as most of that reply still went over my head. :D
              AnticimexA 1 Reply Last reply
              • TRS-80T TRS-80
                AnticimexA
                AnticimexA
                Anticimex
                @TRS-80 well thanks :) the condensed answer is, use personalization if you can, as that is more private than the simple password flag. And if you plan to use OTA, dualoptiboot is the safest approach to leverage mysensors library features such as signing and encryption.
                • AndurilA
                  AndurilA
                  Anduril
                  @Anticimex is there a way to use both methods in one network? So to personalize nodes with the AES key (0x12; 0x34; 0x56; 0x00;...) and use SIMPLE_PASSWD "123456" (or some other derivativ)?
                  • AndurilA Anduril
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @Anduril yes that should be possible. Just make sure that the nodes that are personalized are configured with the same settings the simple flag enable "under the hood".
                    • AndurilA
                      AndurilA
                      Anduril
                      wow... to be honest I didn't expected it to be so easy... what flags are those "under the hood" settings?
                      • AndurilA Anduril
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @Anduril I don't remember actually but just greping on the define should reveal that.
                        • SuperNinjaS
                          SuperNinjaS
                          SuperNinja
                          @Anduril said in difference between encryption with personalization and simple password:
                          @Anticimex
                          Interesting, I'm going to make a remote control for my gate with an RFM69HCW, obviously I don't want the signal to be sniffed and copied.
                          I am new to MySensors, Is :
                          #define MY_SECURITY_SIMPLE_PASSWD "testpass"
                          is simply enough?
                          What to add if not secure enough?
                          • SuperNinjaS SuperNinja
                            @Anticimex
                            is simply enough?
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @SuperNinja if memory serves me, you only need the simple flag. You can read more in the doxygen site: https://www.mysensors.org/apidocs/group__SecuritySettingGrpPub.html
                            • AndurilA
                              AndurilA
                              Anduril
                              wrote on last edited by Anduril
                              @SuperNinja you only need #define MY_SECURITY_SIMPLE_PASSWD "testpass". The other one would be needed for encryption wih personalization (so keys saved in eeprom or atsha-chip)
                              @Anticimex is there a way to give the SIMPLE_PASSWD in hex? As far as I understand the AES key in the personalizer sketch is a hex and the password in sketch would be ASCII. Therefor even if looking identical they would not match. Or do I have to create a password first and convert that to hex to be used in personalization...
                              • AndurilA Anduril
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @Anduril I do not thing there is a limitation as long as the value of the define is in legal c code initializer format. The preprocessor will "paste" your define where it is mentioned so you can search the code for it to see where it is used. I do not recall there being any logic that assume ascii in the define.
                                • E
                                  E
                                  evb
                                  In the past, I did several tests about signing and encryption.
                                  The results and my thoughts, you can find them here: https://forum.mysensors.org/topic/10382/security-signing-messages-and-encryption-of-messages-a-guide-or-more-a-summary-of-my-tests?_=1604220215583
                                  Maybe it can help :-)
                                  SuperNinjaS 1 Reply Last reply
                                  • E evb
                                    SuperNinjaS
                                    SuperNinjaS
                                    SuperNinja
                                    @Anticimex , @Anduril Thanks for this response
                                    @evb great job, here is an easy to understand summary for beginners like me. Thanks
