  3. Home Assistant
  4. Can a gateway talk to itself?
6 Posts 4 Posters 894 Views 4 Watching
  • Danielo RodríguezD
    Danielo RodríguezD
    Danielo Rodríguez
    Recently I updated my gateway to add 3 status leds to it. They are working great and they allowed me to notice a singular pattern. Yesterday was the first day with the three leds and my hassio wasn't working very well. From time to time, I was seeing the green led turning on. Normal, it is looking for devices, I told myself. But today that I restarted my hassio after fixing some networking problems, I am noticing a much more frequent led blinking and not only the send one, but also the receiving one. This is what I see on the logs:
    2020-07-29 09:57:15 DEBUG (MainThread) [mysensors] Sending 0;255;3;0;2;
    2020-07-29 09:57:15 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;2;2.3.1
    2020-07-29 09:57:25 DEBUG (MainThread) [mysensors] Sending 0;255;3;0;2;
    2020-07-29 09:57:25 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;2;2.3.1
    2020-07-29 09:57:35 DEBUG (MainThread) [mysensors] Sending 0;255;3;0;2;
    2020-07-29 09:57:35 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;2;2.3.1
    I only have two nodes, and the other node is battery powered and turned off, so, who is my gateway talking to? Is it sending packets to itself?
    • BearWithBeardB
      BearWithBeardB
      BearWithBeard
      This is the controller (Home Assistant) pinging the gateway, to see if it's still running. It does this every 10 seconds by requesting the GW's sketch version (an internal command of type I_VERSION). The GW responds with 2.3.1. If the GW wouldn't reply, HA would disconnect from the GW and try to establish a new connection.
      See Serial Protocol - 2.x to make sense out of the string in the log.
      If you want to get rid of those ping-pong messages (and the constant blinking of the LEDs), you can switch to an MQTT gateway (per Ethernet or WiFi, doesn't matter).
      Danielo RodríguezD 1 Reply Last reply
      • BearWithBeardB BearWithBeard
        Danielo RodríguezD
        Danielo RodríguezD
        Danielo Rodríguez
        @BearWithBeard thanks for your response.
        Yesterday it was way less common to see this blinking, probably due to my networking problems and probably longer disconnected periods.
        It is not annoying me at all, it is just that I didn't expected the RX and TX leds to blink with communication that is not about the radio and the nodes, but it probably makes sense.
        • Danielo RodríguezD Danielo Rodríguez
          @Danielo-Rodríguez it is possible to use MY_INDICATION_HANDLER to see the reason for the blink. I am not sure, but maybe it is possible to also redefine which actions cause a blink. See https://github.com/mysensors/MySensors/blob/master/core/MyIndication.h#L23 and https://forum.mysensors.org/search?term=My_indication_handler&in=titlesposts&matchWords=all&sortBy=relevance&sortDirection=desc&showAs=posts
            Danielo RodríguezD
            Danielo Rodríguez
            Wow, that is very nice @mfalkvidd
            So I can override the indication function and it will be called on the same events that are now handled automatically right? So if I define this function I have to handle all the enum options right?
            YveauxY 1 Reply Last reply
              YveauxY
              YveauxY
              @Danielo-Rodríguez yes, that is correct
