  3. Problems with new GW
3 Posts 2 Posters 416 Views 2 Watching
    Misna
    Hi!
    I just migrated my Home Assistant from RPi to VMware vsphere virtual appliance. I didn't get the current Arduino Uno serial gateway to work via passing through the device in VMware (Zigbee stick works great this way).
    So I did a ESP8266 gateway since I had a board available. I got it flashed and I think the ESP talks with radio and HA talks with the gateway but my nodes won't work. I tried to remove the .json file, no help (just removed the entities from HA).
    All I get in serial monitor of the gateway is this (over and over):
    gwt:rfc:c=0,msg=0;255;3;0;2;
    What should I try next? All my nodes have statically assigned node ID's. I'm not 100% sure what the version of mysensors they have but I think it is 2.2.something
    skywatchS 1 Reply Last reply
    • M Misna
      Hi!
      skywatchS
      skywatchS
      skywatch
      @Misna The first thing I would od in your situation is to make sure that all gateways and nodes are on the latest version of mysensors and try again.
      2.3.2 is the latest stable version I believe.
        Misna
        Thanks, at least one of the nodes started working!
        Will try to update another one today.
