  3. Domoticz
  4. States Relay
States Relay
1 Posts 1 Posters 541 Views 1 Watching
  • J
    J
    JeeLet
    translate French--> Anglais
    Hello
    a request on the Eternal "status feedback" of a command.
    did the command activate my request?
    a can like an existential, to be or not to be
    My test model diagram
    Domoticz ----> Arduino output ----> Relay
    Domoticz <----- Arduino Input <----- °--°
    the scheme
    a skit tampering
     * compilation de
     *  RelayActuator.ino et BinarySwitchSensor.ino
     * LA DESCRIPTION
     * utilisation d'un contact auxilaire du relais pour retour d'etat d'une commande,
    //----------------------- Library Configuration ---------------------
     #define MY_DEBUG                          // uncomment to enable debug prints to serial monitor
     #define MY_NODE_ID 22                   /*Node en ID static*/
     #define MY_TRANSPORT_WAIT_READY_MS 3000 /*Tempo d'attente de mis en Com, des millisecondes*/
     #define  MY_SPLASH_SCREEN_DISABLED /*désactive écran de démarrage MySensors (économie 120oct. en flash)*/
    //-------------------------------Bus RS485--------------------------------
     #define MY_RS485
     #define MY_RS485_DE_PIN 2
     #define MY_RS485_BAUD_RATE22 9600  /* débit du bus rs485*/
     // #define MY_RS485_HWSERIAL Serial1    /*pour Mega2560,Serial 1-2- ou 3 ? */
    #include <Bounce2.h>  /*anti rebond*/
    #define CHILD_ID 3 // contact enfant
    //--------------- contact-----------------------
    #define BUTTON_PIN  7   // Broche Arduino Digital I / O pour bouton / interrupteur reed
    //------------------ relay------------------------------
    #define RELAY_PIN 3  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    //----------------- contact
    //Bounce debouncer = Bounce();
    //int oldValue=-1;
    int oldValue=0;
    bool state;
    // -----------------contact--------------------
    MyMessage msg(CHILD_ID,V_TRIPPED);  // V_LIGHT si vous utilisez S_LIGHT
    //MyMessage msg(CHILD_ID,V_LIGHT);
    //-------------------- Relay--------------------------------
    //void before()
    //    for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
    //        pinMode(pin, OUTPUT);  // Then set relay pins in output mode
            //digitalWrite(pin, loadState(sensor)?RELAY_ON:RELAY_OFF);
      // Configurer le bouton
      pinMode(BUTTON_PIN,INPUT_PULLUP);
      // configure le bouton et debounce
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
     // Assurez-vous que les relais sont désactivés au démarrage
      // Réglez ensuite les broches de relais en mode sortie
      pinMode(RELAY_PIN, OUTPUT);
     //------------------ contact-----------------
      // pouvez utiliser S_DOOR, S_MOTION ou S_LIGHT,  Si S_LIGHT est utilisé,
      //n'oubliez pas de mettre à jour le type de variable que vous envoyez. Voir "msg" ci-dessus.
     // present(CHILD_ID, S_DOOR);
    present(CHILD_ID, S_LIGHT);
      //-------------------- relay ---------------------------------------
          sendSketchInfo("Relay et State", "2.0");
         present(sensor, S_BINARY);  // Register et  created as child devices
    //      --------------- contact--------------
      debouncer.update(); // control Etat contact
      int value = debouncer.read(); // Récupère la valeur de mise à jour
      if (value != oldValue && value==0) {
          send(msg.set(state?false:true), true); // Envoyer un nouvel état et demander un accusé de réception
      oldValue = value;
    //  if (value != oldValue)  // Envoyer la nouvelle valeur
    //     send(msg.set(value==HIGH ? 1 : 0));
    //     oldValue = value;
    // -------------------- Relay-----------------------
    if (message.isAck()) {
       // if (message.getType()==V_STATUS) {
            // Change relay state
                 // digitalWrite(message.getSensor()-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
    //-----------------cmd local----------------
         state = message.getBool();
            // Write some debug info
            Serial.print("    Incoming change for sensor:");
            Serial.println(message.getSensor());
            Serial.print("   New status: ");
            Serial.print(" etat contact ");
            Serial.println(oldValue);
    // ----------------- fin Pgm -----------------
    already made a request on
    but no answer. https://easydomoticz.com/forum/viewtopic.php?f=20&t=10601
    so how to activate the relay state in Domoticz
    Thank you
