  3. implementing multiple sensors
83 Posts 28 Posters 98.0k Views 15 Watching
  • B
    B
    Bandra
    I'm coming close to finalising my multisensor sketch. I'll post code once I clean it up a little. I have a newborn at home, so if I forget to put code here then somebody please remind me in a little while :)
    • W waynehead99
      Nobody wants to take a crack at this? I figured this to be a common combo and would really like to get it to work properly.
      mikeones
      @waynehead99 Here is a sketch I run with DHT and motion support.
      #include <Sleep_n0m1.h>
      #include <EEPROM.h>
      #include <RF24.h>
      #include <Sensor.h>
      #include <DHT.h>
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      #define HUMIDITY_SENSOR_DIGITAL_PIN 4
      Sensor gw;
      DHT dht;
      Sleep sleep;
      float lastTemp;
      float lastHum;
      boolean lastValue = false;
      boolean metric = false;
      #define CHILD_ID 2   // Id of the sensor child
      long previousMillis_T = 0;     // will store last time temp data sent
      unsigned long startTime_T;
      unsigned long sensorInterval = 30000; // change this to desired sensor read interval in milliseconds
        gw.begin();
        gw.sendSketchInfo("Motion Sensor and DHT", "1.0");
        gw.sendSensorPresentation(CHILD_ID, S_MOTION);
        gw.sendSensorPresentation(CHILD_ID_HUM, S_HUM);
        gw.sendSensorPresentation(CHILD_ID_TEMP, S_TEMP);
        metric = gw.isMetricSystem();
        startTime_T = millis();
        Serial.println("Setup complete");
        // Read digital motion value
        if (lastValue != tripped) {
      	gw.sendVariable(CHILD_ID, V_TRIPPED, tripped?"1":"0");  // Send tripped value to gw
      	lastValue=tripped;
      	//Serial.println(tripped);
        if (millis() - startTime_T >= sensorInterval) {
      	if (isnan(temperature)) {
      	} else if (temperature) {
      	  lastTemp = temperature;
      	  if (!metric) {
      	  gw.sendVariable(CHILD_ID_TEMP, V_TEMP, temperature, 1);
      		Serial.print("T: ");
      		Serial.println(temperature);
      	//delay(dht.getMinimumSamplingPeriod());
      	if (isnan(humidity)) {
      	} else if (humidity) {
      		lastHum = humidity;
      		gw.sendVariable(CHILD_ID_HUM, V_HUM, humidity, 1);
      		Serial.print("H: ");
      		Serial.println(humidity);
        // Power down the radio.  Note that the radio will get powered back up
        // on the next write() call.
        delay(1000); //delay to allow serial to fully print before sleep
      • W
        W
        waynehead99
        Thanks that worked... and for my understanding... looks like your not really using interrupts at all? Looking at the code makes complete sense to me, and proves I was over thinking things on mine.
        Thanks again.
          mikeones
          The sensor is not running on battery power so I did not spend much time with the interrupt/sleep options.
          • T
            Tibus
            is it the same process with the new 1.4 library version?
            Could you please give us a exemple here or on github to have multiple sensor type on the same arduino with the new 1.4 library?
            if it's the same implementation, we could write multiple "gw.present(ID, XXXX);" and send a message for each child ID type?
            Thank's very much.
            • T
              Tibus
              Sorry, I found the new implementation in the "DallasTemperatureSensor" Example
              • mountainmanM
                mountainmanM
                mountainman
                wrote on last edited by mountainman
                #47
                Here is a version I'm currently using that makes use of interrupts so might be more suitable for a battery driven DHT/Motion multi sensor. It also includes the battery monitoring. Any feedback or improvements would be appreciated.
                #include <DHT.h>
                #define CHILD_ID_MOTION 2   // Id of the sensor child
                unsigned long SLEEP_TIME = F; // Sleep time between reports (in milliseconds)
                int oldValue=-1;
                DHT dht;
                float lastTemp;
                float lastHum;
                int oldBatteryPcnt = 0;
                int battLoop =0;
                // Initialize motion message
                MyMessage msg(CHILD_ID_MOTION, V_TRIPPED);
                boolean pinTriggered=0;//waitTime is number of seconds to hol in while loop
                long lastDebounceTime = 0;  // the last time the output pin was toggled
                long debounceDelay = 50;    // the debounce time; increase if the output flickers
                  analogReference(INTERNAL);
                  gw.begin();
                  gw.sendSketchInfo("Motion Humidity w/ Batt", "1.0");
                  gw.present(CHILD_ID_MOTION, S_MOTION);
                  pinMode(DIGITAL_INPUT_SENSOR,INPUT);      // sets the motion sensor digital pin as input
                  digitalWrite(DIGITAL_INPUT_SENSOR,HIGH);   // Activate internal pull-up
                  check_batt();
                  if (pinTriggered)
                	Serial.println(millis()-lastDebounceTime);
                	boolean value = digitalRead(DIGITAL_INPUT_SENSOR);
                	// If the switch changed, due to noise or pressing
                	if (value != oldValue) {
                		lastDebounceTime = millis();
                		// Send in the new value
                		gw.send(msg.set(value==HIGH ? 1 : 0));
                		battLoop++;
                		oldValue = value;
                		Serial.print("Mot: ");
                		Serial.println(value);
                	pinTriggered=0;
                  else
                	else if (temperature != lastTemp)
                	  if (!metric)
                	  battLoop++;
                	else if (humidity != lastHum)
                	  lastHum = humidity;
                	  battLoop++;
                	if (battLoop > 10)
                	  check_batt();
                	  battLoop=0;
                  pinTriggered = gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
                void check_batt()
                  // get the battery Voltage
                  Serial.println(sensorValue);
                  float batteryV  = sensorValue * 0.003363075;
                  Serial.print(batteryV);
                  Serial.println(" V");
                  Serial.print(batteryPcnt);
                  Serial.println(" %");
                	// Power up radio after sleep
                	oldBatteryPcnt = batteryPcnt;
                T C 2 Replies Last reply
                • W
                  W
                  waynehead99
                  How did you get 3 options for the sleep interrupt? Whenever I would try and add the sleep_time option it would give me compile errors.
                  • mountainmanM mountainman
                    #include <DHT.h>
                    int oldValue=-1;
                    DHT dht;
                    float lastTemp;
                    float lastHum;
                    int battLoop =0;
                      gw.begin();
                      check_batt();
                      if (pinTriggered)
                    		battLoop++;
                    		oldValue = value;
                    	pinTriggered=0;
                      else
                    	  if (!metric)
                    	  battLoop++;
                    	  lastHum = humidity;
                    	  battLoop++;
                    	if (battLoop > 10)
                    	  check_batt();
                    	  battLoop=0;
                    void check_batt()
                    Tibus
                    wrote on last edited by Tibus
                    #49
                    @mountainman
                    Thank you verry much, exactly what i need!
                    For child's id, if you have two sensor you have to change the ID in the second?
                    Sensor 1 :
                    Sensor 2:
                    #define CHILD_ID_HUM 3
                    #define CHILD_ID_TEMP 4
                    #define CHILD_ID_MOTION 5
                    • mountainmanM
                      mountainmanM
                      mountainman
                      @waynehead99 Are you using the new 1.4 Lib?
                      • E egbertje
                        Somebody has good result in a working multisensor and wants to share his code?
                        NuubiN
                        NuubiN
                        Nuubi
                        wrote on last edited by Nuubi
                        #51
                        @egbertje Good Question :-) It would be nice to learn from existing working sketches..
                        • AnticimexA
                          AnticimexA
                          Anticimex
                          @waynehead99 you most likely need 1.4 Lib for the new sleep constructor. I have not used sleep on 1.3 so I do not remember what arguments you had available there.
                          I have also extended sleep with an additional constructor which @hek has pulled into the release branch of 1.4 that permits you to use two external interrupts with independent triggers for sleep in addition to a timeout. Great for nodes with multiple sensors that still run on battery.
                          • E
                            E
                            egbertje
                            wrote on last edited by egbertje
                            #53
                            @Mountainman ;
                            Im trying your code and its almost what im looking for.
                            I have two questions about it:
                            1 : Is it possible that the battery info has is own child id?
                            2 : Why dont you implement a light sensor like an LDR?
                            I think that including LDR/light then you have the ideal multisensor ; light + temp/hum + motion + batt monitoring !
                            But for now im playing with your code and try to implement light.
                              #include <DHT.h>
                              int oldValue=-1;
                              DHT dht;
                              float lastTemp;
                              float lastHum;
                              int battLoop =0;
                                gw.begin();
                                check_batt();
                                if (pinTriggered)
                              		battLoop++;
                              		oldValue = value;
                              	pinTriggered=0;
                                else
                              	  if (!metric)
                              	  battLoop++;
                              	  lastHum = humidity;
                              	  battLoop++;
                              	if (battLoop > 10)
                              	  check_batt();
                              	  battLoop=0;
                              void check_batt()
                              C
                              C
                              codenea
                              @mountainman Is there any instructions on how to wire/setup the hardware to work with your code?
                              • mountainmanM
                                mountainmanM
                                mountainman
                                @egbertje;
                                The battery percentage is associated with the parent Arduino Node in the vera UI.
                                I have some LDRs ordered from Ebay so that is the next step. I had previously used the BH1750 I2C sensor in a multi sensor with the 1.3 lib but I want to debug on its own as it seemed to be giving unexpected readings.
                                @codenea The instructions are pretty much from the main page although if I get a chance I try to draw it up and post some pics. My setup not very pretty yet with perf board and jumper wires. A dedicated PCB would be nice.
                                • epierreE
                                  epierreE
                                  epierre
                                  Here is my combo to make a Home Monitoring solution:
                                  https://github.com/empierre/arduino/blob/master/MQv01dgi_1_4.ino
                                  It includes (currently on a Mega):
                                  • Barometer : BMP085
                                  • Temperature + Humidity DHT11
                                  • Particle sensor
                                  • Gas sensors MQ2 MQ6 MQ131 MQ135 TGS2600 2SH12
                                  To be added when stabilized:
                                  • Sound level in DB
                                  Could be added:
                                  • Light sensor
                                  • Vibration sensor
                                  • PIR
                                  z-wave - Vera -> Domoticz
                                  • pgoP
                                    pgoP
                                    pgo
                                    wrote on last edited by pgo
                                    #57
                                    Hi guys,
                                    this is a one node with publishing DS temperatures and listening for relay commands I finished and tested yesterday>
                                    https://github.com/pgo-sk/mysensors/blob/master/arduino/DS_and_Relay.ino
                                    feel free to comment/use/publish...
                                    I combined the Dalas and Relay examples together - you have to deactivate the sleep for the relays to listen 100% of time.
                                    MQTT identification on openHAB:
                                    MyMQTT/20/0/V_TEMP - DS sensor(s)
                                    MyMQTT/20/1/V_LIGHT - relay 1
                                    MyMQTT/20/2/V_LIGHT - relay 2
                                    If somebody is interested I can post the maps/items files for openHAB
                                    Regards,
                                    Pego
                                    PS I am working on an home automation system with solar hot air panels control/solar hot water panels and all the common stuff like lights/temperatures/weather etc.. More here: https://github.com/pgo-sk/mysensors/wiki/Home-automation-using-mysensors-and-openHAB
                                    • I
                                      I
                                      integlikewhoa
                                      I'm also following along interested in the Temp, Humidity, and motion sensor.
                                      T 1 Reply Last reply
                                      • I integlikewhoa
                                        Tibus
                                        @integlikewhoa check this :
                                        http://forum.mysensors.org/topic/404/3-in-1-humidity-temp-and-motion
                                        • pgoP
                                          pgoP
                                          pgo
                                          #60
                                          https://github.com/pgo-sk/mysensors/blob/master/arduino/DS_Light_Relay
                                          • DS18B20 (up to 16 like in original temp sketch)
                                          • TEMT6000 reporting LUX light values
                                          • 2x Relays
                                            running and tested
                                            Sensor <-> MQTT gateway <-> openHAB/PC
                                          When interested can post the openHAB items/sitemap(s) settings
                                          Screenshots - over teamviewer, sorry for the quality.
                                          Here the TEMT6000 output - in a quite dark room and changing weather today>
                                          upload-42ac73c1-61cf-4b90-9ec5-14a994a3b50a
                                          Here the temperature and relays:
                                          upload-86825c33-2cc2-4018-9e08-2020007af3a9
                                          Menu:
                                          upload-adf5c382-2803-49b9-a461-eb25beb572c0
                                          aquaproA 1 Reply Last reply
