  3. What Happens to messages from Gateway when Node is not connected.
6 Posts 2 Posters 3.1k Views 1 Watching
    mainali
    When I publish a message, GW takes care of sending it to the appropriate node. what if the node is not available, will the messages be sent later whenever the node gets reconnected.
    Trying to understand if there is a support for QoS 1/ QoS2 as specified in MQTT documentation, is there a provision to make sure the message is delivered to the Nodes exactly once and receive ACK for the same. Message may be for nodes which may be far away and need multiple hops to reach, similarly the ACK has to be propagated to the client who issued the message.
    I am kinda lost here, someone point me in right direction, has someone implemented or tried something which I am looking to do.
    • ferpandoF
      ferpandoF
      ferpando
      From my experience, messages are lost if a node is not available when the message is sent.
      I'm working on a way to give the system a queue for messages. I use Vera as the controller.
      In my case, it is for messages that are sent too fast for the nodes to process, so messages are sent a few times until ack is received.
      I have it to retry a few times before it gives up, which is good enough for my needs at the moment, but I guess it wouldn't be difficult to implement somehting a bit more complex that keeps messages stored until the node becomes abailable.
      You can read about it here
      http://forum.mysensors.org/topic/131/scene-too-fast-for-gateway/52
        mainali
        @ferpando
        I am following your post, but given the size of gateway code maintaining a queue will have space constraints. Just wondering implementing this on controller end will solve the problem or it has to be both ways.
        I am writing my own controller after trying to use openHAB. Unfortunately for ruby there is just one library which is still in development and does not support Quality of Service beyond 0. Need to work on that to achieve messages are delivered exactly once.
        ferpandoF 1 Reply Last reply
        • M mainali
          @ferpando
          ferpandoF
          ferpandoF
          ferpando
          @mainali
          Messages are stored on the controller (Vera plugin in this case)
          If messages are generated directly by the gw then it could potentially be a problem if you store too many messages.
          My code deletes the message once it is ack'd, so it won't be sent again.
          If you need to store messages in the gw, maybe you could implement an external eeprom to store the messages until they are sent
            mainali
            What gateway are you using ? Vera uses mqtt protocol to send messages to gateway ?
            • ferpandoF
              ferpandoF
              ferpando
              My gateway is an arduino, and I don't think Vera uses mqqt protocol.
