  3. Help me build a RFM69 gateway using wemos d1 + keyestudio RFM69 shield
1 Posts 1 Posters 629 Views 1 Watching
  • A
    A
    airmedic79
    Hi!
    I am trying to build a RFM69 gateway with wemos d1 and keyestudio RFM69 shield. The code is compiled and uploaded but I see no serial log nor wifi connection. It just doesn't show anything. Can I set up the gateway? Thanks in advance.
    • arduino ide 2.3.2
    • mysensors 2.3.2
    • esp8266 board 2.7.4 (ver 3.1.2 won't upload the code)
    The RFM69 shield is from Keyestudio.
    https://wiki.keyestudio.com/KS0515_Keyestudio_FSK_Wireless_Shield_RFM69HCW_868mhz(Black_and_Eco-friendly)
    Here's the code.
    #define MY_BAUD_RATE 9600
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RFM69_868MHZ // Set your frequency here
    #define MY_IS_RFM69HW
    #define MY_GATEWAY_ESP8266
    #define MY_WIFI_SSID "**"
    #define MY_WIFI_PASSWORD "
    #define MY_HOSTNAME "WEMOSD1_GW"
    #define MY_IP_ADDRESS 192,168,0,146
    #define MY_IP_GATEWAY_ADDRESS 192,168,0,1
    #define MY_PORT 5003
    #define MY_GATEWAY_MAX_CLIENTS 20
