  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.8k Views 35 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @nivoc
    Have you tried to "bake" your sensebenders, in case they have been exposed to high humidity for a longer time?
    They are, as far as I know, produced in a part of China, which are known to have very high humidity. (been traveling there a lot some years ago)
    • HeinzH
      HeinzH
      Heinz
      wrote on last edited by Heinz
      #362
      @nivoc
      I can confirm your results: I am running two different sensors in the same room next to each other. The sensebender is always above the dht-22. Right now it is
      52% to 47.8% rel. humidity, while the temperature is 17.8 to 17.9 (which is nearly equal).
      • nivocN
        nivocN
        nivoc
        @tbowmo No I haven't baked yet. I will try that but not in the next two weeks. But I will report back.
        • nivocN
          nivocN
          nivoc
          But I tested tonight with distilled water - so should be exactly 100%. And again (I didn't know that thats possible) I got 104 and 107% so slightly above (still increasing). Thats great b/c that means all values are about 7-8% too high.
          At 33% the reading was about 40%
          At 75% the reading was about 83%
          At 100% the reading was about 106%
          So reading minus 8% gives a pretty accurate result. In the next few days i will test 3 more sensbender.
          Distilled Water (100% expected):
          upload-c0364fcd-876d-4701-a3ec-b0c55efc04a6
          • bjacobseB
            bjacobseB
            bjacobse
            wrote on last edited by bjacobse
            #365
            Read the spec for the humidity sensor used in the sensebender (Si7021 integrated humidity / temperature sensor.)
            Precision Relative Humidity Sensor: ± 3% RH (max), 0–80% RH
            To my reading this is actually 6% wrong reading to one of the sides - so when you are measuring yours to be 8% off, is caused that you are using the device outside of humidity range 100% and max is 80%
            Link to spec:
            https://www.silabs.com/Support Documents/TechnicalDocs/Si7021-A20.pdf
            What I want you to know, if your device is reading within 6 % of the value - it's still reading correct. and when you compare ex DHT22 that device also have some reading variation error. Do not expect to get 100% perfect value for 2 devices...
            • nivocN
              nivocN
              nivoc
              wrote on last edited by nivoc
              #366
              @bjacobse Yes and no :-)
              Yes 100% is outside of the spec.
              And no. 33% with Magnesium Chloride Hexahydrate is inside the spec and I get 40% instead of 33-34%.
              Max off should be 3% above or? Means 37% - but fair enough. Should be ok for household use.
              M bjacobseB 2 Replies Last reply
              • nivocN nivoc
                mvader
                I hope the Temp measurements are not off by that much.
                i don't need .00001 accuracy or anything. but i feel a big difference between 70 and 72 in my house.
                bjacobseB nivocN 2 Replies Last reply
                • M mvader
                  bjacobseB
                  bjacobseB
                  bjacobse
                  @mvader
                  Spec is: High Accuracy Temperature Sensor ±0.4 °C (max), –10 to 85 °C
                  So the temp accuracy is quite good
                  • nivocN nivoc
                    bjacobseB
                    bjacobseB
                    bjacobse
                    @nivoc
                    Yes you are right, +-3 from your humidity solution on 33%, then the reading could be in the interval 33-3=30% or up to 33+3=36% and should not show 40%
                    did you get same false readings from other sensebender humidity sensors?
                    nivocN 1 Reply Last reply
                    • bjacobseB bjacobse
                      @nivoc
                      nivocN
                      nivocN
                      nivoc
                      @bjacobse Yes I have 3 sensbener running from 2 different orders. All 3 are very near by each other. So at 33% they all read something near to 40%.
                      I have 4 more sensbenders to build. However I continue to test tonight with a Boveda-Pack that claims to bring the hum in a containter to exactly 69%. I did 4 test's so far and also used different technics. So i get more and more confident.
                      But the very good thing is - it looks every reproducible. So the value may be off but reproducable accurate off by about 8%. When I completed my test it will be very easy to correct it within the software.
                      • M mvader
                        nivocN
                        nivocN
                        nivoc
                        @mvader I haven't made any very accurate temp testings. But the readings are exactly the same than other non-sensbender devices in my home. I started researching the humidity b/c I had different readings between different devices.
                        Temp looks fine to me.
                        • T
                          tcontrada
                          What is the current consumption of the Sensebender during sleep and active modes?
                          Thanks,
                          Tony
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @tcontrada
                            there are some measurements in the old design thread here http://forum.mysensors.org/topic/510/minimal-design-thoughts
                            • N
                              N
                              nikos1671
                              Hi. What case you all using for the sensebender ?Any good idea.
                              • F
                                F
                                filipq
                                3_1456326631089_IMG_20160224_150344.jpg 2_1456326631089_IMG_20160224_150314.jpg 1_1456326631089_IMG_20160224_150303.jpg 0_1456326631088_IMG_20160224_150237.jpg
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @filipq
                                  Where did you find that box?
                                  • F
                                    F
                                    filipq
                                    @tbowmo
                                    Got it from http://cpc.farnell.com/1/1/57932-evatron-pp42m-case-sensor-ivory-71x71x27mm.html.
                                    Not the cheapest, but definitely worth the money as it is very good quality. There are other colours available (white and black) https://www.jprelec.co.uk/store.asp/c=552/Gas-Sensor-Case
                                    • scalzS
                                      scalzS
                                      @tbowmo: I have some of these too, it's nice box. i got these from tme. cheaper :)
                                      http://www.tme.eu/fr/details/box-sens-white/boitiers-dappar-dalarme-et-de-capt/supertronic/
                                      • ahmedadelhosniA
                                        ahmedadelhosniA
                                        ahmedadelhosni
                                        Hello @tbowmo
                                        Doesn't the atmega328 has only 2 pins which are D2 and D3 from external interrupts ?
                                        I am wondering why do we waste the usage of D2 since the IRQ pin is not used in the library ?
                                        AnticimexA 1 Reply Last reply
                                        • ahmedadelhosniA ahmedadelhosni
                                          Hello @tbowmo
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @ahmedadelhosni because it is not in use by the library <yet>. Would be a shame if the library some day gets updated with support for a radio that can enter low power sleep and still wake when needed.
                                          ahmedadelhosniA 1 Reply Last reply
