  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 450.5k Views 35 Watching
  • epierreE
    epierreE
    epierre
    and now ethanol/isopropylène (bike chain cleaning product):
    MQ2    :LPG   :247ppm   CO    :0ppm    SMOKE :1053ppm
    MQ6    :LPG   :3527ppm    CH4   :2160ppm
    MQ131  :CL2   :10ppm    O3    :12ppm
    TGS2600:H2    :7891ppm C2H5OH:14279ppm C4H10 :27751ppm
    MQ135  :CO2   :0ppm    CO    :0ppm     CH3   :0ppm    NH4    :0ppm
    Dust   :raw   : 206    Voltage: 1.01 - Dust Density: 71.00
    • epierreE
      epierreE
      epierre
      and now eveyone through aceton:
      MQ2    :LPG   :25ppm   CO    :0ppm    SMOKE :48ppm
      MQ6    :LPG   :19677ppm    CH4   :3010ppm
      MQ131  :CL2   :71ppm    O3    :51ppm
      TGS2600:H2    :8448ppm C2H5OH:15007ppm C4H10 :28738ppm
      MQ135  :CO2   :840ppm    CO    :0ppm     CH3   :400ppm    NH4    :1474ppm
      Dust   :raw   : 728    Voltage: 3.55 - Dust Density: 504.30
      remark that dust sensor goes up ! and TGS2600 goes down afterward:
      MQ2    :LPG   :8ppm   CO    :0ppm    SMOKE :11ppm
      MQ6    :LPG   :1264ppm    CH4   :1194ppm
      MQ131  :CL2   :27ppm    O3    :24ppm
      TGS2600:H2    :4966ppm C2H5OH:8407ppm C4H10 :16227ppm
      Dust   :raw   : 165    Voltage: 0.81 - Dust Density: 36.96
      • epierreE
        epierreE
        epierre
        wrote on last edited by epierre
        #23
        @hek I now have the netatmo CO2 xml and json, they are based on the generic sensor.
        But I don't have mysensors running on my vera...
        I would need from you:
        • the device and variable type
        • an icon, but maybe I can reuse the other one
        maybe
        CO2 = {22, "urn:schemas-micasaverde-com:device:CO2Sensor:1", "D_CO2Sensor.xml", "CO2 "}
        CO2 = {36, "urn:micasaverde-com:serviceId:CO2Sensor", "Concentration", "396" },
        S_CO2Sensor.json D_CO2Sensor.xml D_CO2Sensor.json
        P.S. there's the icon from Nest plugin too: http://cocu.la/vera/nest/nest_co.png
        • epierreE
          epierreE
          epierre
          About initial calibration, just a warning from this graph:
          you can see high levels around july 21 then dropping in august... the sensor has been restarted... that is what the call clean air...
          this automatic reading at the start should be stored in the sketch and not reclaculated at each reboot or you would loose all reference on your data...
          • epierreE
            epierreE
            epierre
            This post is deleted!
            • epierreE
              epierreE
              epierre
              YveauxY 1 Reply Last reply
              • epierreE epierre
                [[topic:post-is-deleted]]
                YveauxY
                YveauxY
                @epierre did you just post the same reply 3 times or is the forum software showing yet another bug?
                epierreE 1 Reply Last reply
                • YveauxY Yveaux
                  epierreE
                  epierreE
                  epierre
                  @Yveaux don't know, I did post once...
                  • korttomaK
                    korttomaK
                    korttoma
                    I wanted to get acquainted with the MQ2 AirQuality Sensor so I took a look at the sketch from github.
                    One thing I noticed was that there is some sleep-time defined, is this just to make the sensor report the value every 30 seconds?
                    I guess it is not for saving power so you can run it on batteries because my understanding is that it needs to be hot in order to function correctly and that will drain the battery fast.
                    Does not look like the calibration during setup takes in account the preheating time either, maybe it is a good idea to add a delay before the calibration so the sensor gets hot enough.
                    Please correct me if I'm wrong.
                    • Tomas
                    • epierreE
                      epierreE
                      epierre
                      #30
                      @hek Here is a first list from the most commons:
                      • Carbon Monoxide – CO
                      • Carbon Dioxide – CO2
                      • Oxygen – O2
                      • Methane – CH4
                      • Hydrogen – H2
                      • Ammonia – NH3
                      • Isobutane – C4H10
                      • Ethanol – CH3CH2OH (aka C2H5OH or C2H60)
                      • Toluene – C6H5CH3
                      • Hydrogen Sulfide – H2S
                      • Nitrogen Dioxide – NO2
                      • Ozone – O3
                      • Hydrocarbons – VOC
                      • Chlorine CL2
                      • Ammonium NH4
                      • Ethanol CO2H50H
                      • Methyl CH3
                      • Acetone CH3_2CO
                      • LPG (both C3H8 C4H10)
                      • korttomaK korttoma
                        epierreE
                        epierreE
                        epierre
                        #31
                        I see your point, but from experience I don't see a difference on heating... I should have a closer look. This one does not need a special pre-heating as some other (MQ-7).
                        Clearly this cannot run on battery on MQ/TGS/MICS series, so surely removing the sleep and adding a wait would do the trick the same way.
                        If you want to play and see something, the MQ135 is much better for it reacts to CO2, so having someone in a room or not you could see it easily changing.
                        A current weakness on the sketches is to take into accound humidity and temperature to correct the value, that will come too.
                        • epierreE
                          epierreE
                          epierre
                          I was looking for some other gas sensor, but these have no shield ready to connect to arduino :
                          Sensor	     Operating Voltage  	Heater Power
                          MiCS-2710 (NO2)	  2.5 V	           43 mW
                          MiCS-5525 (CO)	   5.0 V	           76 mW
                          do I need a dedicated 2.5 V linear regulator such as Microchip TC1071VCT713 ?
                          • epierreE
                            epierreE
                            epierre
                            • epierreE
                              epierreE
                              epierre
                              • epierreE
                                epierreE
                                epierre
                                @hek about initial calibration, how would I do check if there is a value in the eeprom or not, and if not run an initial calibration ?
                                hekH 1 Reply Last reply
                                • epierreE epierre
                                  @epierre
                                  Unwritten eeprom has the value 0xff.
                                  • O
                                    O
                                    Omemanti
                                    First of al I'm a novice in all of this. I can read some code but the whole arduino thing is new to me.
                                    I tried to get the MQ135 working on my uno with tearing apart the : https://github.com/empierre/arduino/blob/master/1.3/MQ135dgi.ino.
                                    I tried to pull out the bits and parts to get a accurate reading on my serial monitor.
                                    It sometimes read 1 or 2, but most of the time it is 0.
                                    Can it have something to do with it being mounted on its own PCB? (I ordered the one suggested in the store..)
                                    Can someone help me out?
                                    Groetjes Mark
                                    • O Omemanti
                                      Groetjes Mark
                                      epierreE
                                      epierreE
                                      epierre
                                      #38
                                      @Omemanti hello have you plugged it on the right pins, this is an analogic sensor to be plugged on A0, with 5V and GND pins. Don't wire the digital one, useless...
                                      My minimal value is 53.. so not 0 or 1 hwich looks more like the digital output ;-)
                                      • O
                                        O
                                        Omemanti
                                        should be alright right?
                                        • O Omemanti
                                          epierreE
                                          epierreE
                                          epierre
                                          @Omemanti cabling is correct
