  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 325.2k Views 52 Watching
  • Sergio RiusS Sergio Rius
    @AWI
    While that would be a logical approach, the the dimmer control in Domoticz it's complex and sometimes requires more than one click to activate. In other interfaces (Android, etc) that could be worse, and should change in the future.
    @dbemowsk
    I did not use S_INFO in my sketch, but I managed to use an array for valves configuration and may be pretty interesting if we mix the two of them.
    Note that this is a version 2.0 sketch, and that I removed all the remote management stuff. Due to the flow change in v2, the display menu was so difficult to do.
    Perhaps you can adapt it back and get back to the original idea.
    ///// Mysensors options /////
    //#define MY_DEBUG
    #define MY_NODE_ID 1 // Having some problems with auto Id on my installation.
    #include <Time.h>
    #include <Wire.h>
    #define SKETCH_NAME "GardenController"
    #define SKETCH_VERSION "1.0"
    /////// Display output options /////
    //#define USING_DISPLAY
    //boolean showTime = true;
    //#ifdef USING_DISPLAY
    //	LiquidCrystal_I2C lcd(0x27, 16, 2);
    //	//#define LCDINIT (DEBUG_PRINTLN("Setting up LCD..."); lcd.init(); lcd.clear(); lcd.backlight();)
    //#else
    //	#define LCDINIT
    //#endif
    const int latchPin = 8;
    const int clockPin = 4;
    const int dataPin = 7;
    unsigned char bitStatus;
    #define ACTIVE_LOW // comment out this line if your relays are active high
    #ifdef ACTIVE_LOW
    	#define ALL_ELEMENTS_OFF 0xFFFF
    	#define myShiftOut (shiftOut(dataPin, clockPin, MSBFIRST, ~bitStatus))
    #else
    	#define ALL_ELEMENTS_OFF 0U
    	#define myShiftOut (shiftOut(dataPin, clockPin, MSBFIRST, bitStatus))
    boolean clockSetup = false;
    ///// Serial interface options /////
    #define DEBUG_ON   // comment out to supress serial monitor output
    #ifdef DEBUG_ON
    	#define DEBUG_PRINT(x)   Serial.print(x)
    	#define SERIAL_START(x)  Serial.begin(x)
    #else
    ///// Control elements /////
    class myElement {
    public:
    	myElement(char* name, int runningTime, unsigned long Started);
    	char* Name;
    	int RunningTime;
    	unsigned long Started;
    myElement::myElement(char* Name, int RunningTime, unsigned long Started = 0)
    	this->Name = Name;
    	this->RunningTime = RunningTime;
    	this->Started = Started;
    myElement myElements[] =
    	{ "Irrigation Zone 1", 1 },
    	{ "Irrigation Zone 2", 1 },
    	{ "Pond Pump", 0 },
    	{ "Pond Lights", 0 },
    	{ "Front way lights", 0 },
    	{ "Acc1", 0 },
    	{ "Acc2", 0 },
    	{ "Acc3", 0 },
    int NUMBER_OF_ELEMENTS = sizeof(myElements) / sizeof(*myElements);
    MyMessage msg1valve(0, V_STATUS);
    	SERIAL_START(9600);
    	DEBUG_PRINTLN("Initialising...");
    	pinMode(latchPin, OUTPUT);
    	pinMode(clockPin, OUTPUT);
    	pinMode(dataPin, OUTPUT);
    	//LCDINIT;
    	//DEBUG_PRINTLN("Setting up LCD..."); lcd.init(); lcd.clear(); lcd.backlight();
    	//DEBUG_PRINTLN("Requesting time from Gateway");
    	//requestTime();
    	//DEBUG_PRINTLN("Ready!");
    	for (int i = 0; i < NUMBER_OF_ELEMENTS; i++) {
    		myElement Elm = myElements[i];
    		present(i, S_BINARY, Elm.Name);
    		wait(50);
    		DEBUG_PRINT("Presented element (id/name/preset time): "); DEBUG_PRINT(i); DEBUG_PRINT("/");  DEBUG_PRINT(Elm.Name); DEBUG_PRINT("/"); DEBUG_PRINTLN(Elm.RunningTime);
    		request(i, V_STATUS);
    		wait(50);
    	//Check if there are some timer lights to shutdown
    		//DEBUG_PRINT(myElements[i].Name); DEBUG_PRINT("/"); DEBUG_PRINT(myElements[i].RunningTime); DEBUG_PRINT("/"); DEBUG_PRINTLN(myElements[i].Started);
    		if (myElements[i].Started > 0) {
    			DEBUG_PRINT("Running element ("); DEBUG_PRINT(i); DEBUG_PRINTLN(")");
    			if ((millis() - myElements[i].Started) >= (myElements[i].RunningTime * 60000)){
    				DEBUG_PRINT("ELEMENT TIMEOUT! ("); DEBUG_PRINT(i); DEBUG_PRINTLN(")");
    				updateRelay(i, 0);
    				send(msg1valve.setSensor(i).set(false), false);
    		wait(500);
    //void receiveTime(time_t newTime)
    //	DEBUG_PRINTLN("Received time value, updating...");
    //	int lastSecond = second();
    //	int lastMinute = minute();
    //	int lastHour = hour();
    //	setTime(newTime);
    //	if (((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour)) )|| showTime)
    //		DEBUG_PRINT("Node's time currently set to: ");
    //		DEBUG_PRINT(day());
    //		DEBUG_PRINT("/");
    //		DEBUG_PRINT(month());
    //		DEBUG_PRINT(F("/"));
    //		DEBUG_PRINT(year());
    //		DEBUG_PRINT(hour() < 10 ? F(" 0") : F(" "));
    //		DEBUG_PRINT(hour());
    //		DEBUG_PRINT(minute() < 10 ? F(":0") : F(":"));
    //		DEBUG_PRINTLN(minute());
    //		showTime = false;
    //	else
    //		DEBUG_PRINTLN("Node's time did NOT need adjustment greater than 1 second.");
    //	clockSetup = true;
    	switch (message.type)
    	case V_STATUS:
    		DEBUG_PRINT("Received: Position "); DEBUG_PRINT(message.sensor); DEBUG_PRINT(" Value "); DEBUG_PRINTLN(message.getBool());
    		//DEBUG_PRINT("Before status: "); DEBUG_PRINTLN(bitStatus);
    		updateRelay(message.sensor, message.getBool());
    		break;
    	default:
    		break;
    //void RESET() {
    //	digitalWrite(latchPin, LOW);
    //	shiftOut(dataPin, clockPin, MSBFIRST, ALL_ELEMENTS_OFF);
    //	digitalWrite(latchPin, HIGH);
    void updateRelay(int whichPin, byte whichState) {
    	if (myElements[whichPin].RunningTime > 0){
    		if (whichState == 1){
    			myElements[whichPin].Started = millis();
    			DEBUG_PRINT("Stored start time ("); DEBUG_PRINT(myElements[whichPin].Started); DEBUG_PRINT(") for "); DEBUG_PRINTLN(whichPin);
    		else
    			myElements[whichPin].Started = 0;
    			DEBUG_PRINT("Reset start time for "); DEBUG_PRINTLN(whichPin);
    	bitWrite(bitStatus, whichPin, whichState);
    	//DEBUG_PRINT("updateRelay: bitStatus -> "); DEBUG_PRINTLN(bitStatus);
    	myShiftOut;
    As you may noticed, it can control up to 32 valves and you only have to populate the array. It'll be nice to request this data to domoticz and after a timer or received it, store in eeprom and populate the sub-nodes. Then in subsequent starts, boot with the info on eeprom and ask for changes.
    The sensor shuts itself the "valves" and if time is set to zero runs them without limit.
    That's not my irrigation controller, but my whole garden controller. (thaks the op for the idea)
    dbemowskD
    dbemowskD
    @Sergio-Rius Just a few things. I am assuming that the array you are talking about is "myElement". I am fairly new to MySensors and Domoticz. How do you use this array with Domoticz to send the zone times to the controller? It looks like you are setting the valve names and times within the sketch as if they are permanently set on the controller. I am a little confused about the presentation of the S_BINARY, Elm.Name:
    My understanding is that S_BINARY is just for on/off which I am guessing is the on/off control for the zone. What does the Elm.Name do though? Do yoy have a way to set valve times from within Domoticz?
    I also noticed that you removed the time sync with the receiveTime() function. This tells me that you are not sending the current time to the controller. Any reason for this?
    As for my sketch, I am thinking of another route to go with this where I can send the valve times and names using a single S_INFO sensor. I plan to use some of the information from this forum post: Splitting a string. The idea is to use a separator character such as ":" or "|" to create a pseudo array using a single string. Doing this will eliminate 2 S_INFO sensors for each zone, and also make it easier to configure. I am going to work on this tonight and see where I get with it.
    Sergio RiusS 1 Reply Last reply
    • AWIA AWI
      @dbemowsk I would suggest to take @PierreSt advice and go for a V_PERCENTAGE device. From my perspective you wil mostly deal with "a scale of fixed values' for more or less intensive irrigation. As you are working with Domoticz you can use a "Selector switch" to select the diiferent options.
      I am currently using this for selecting patterns in my Wall mounted mood light and it works like a charm.
      If anyone is intrested I will publish a "how-to" (in the Domoticz section)
      dbemowskD
      dbemowskD
      @AWI I am still not a big fan of the V_PERCENTAGE route. I like the flexibility of the all zones time as well as the individual zone times. I suppose from a scripting sense it wouldn't matter too much, but I still think it's easier and more flexible the other way.
      AWIA 1 Reply Last reply
      • dbemowskD
        dbemowskD
        #223
        OK, so I've modified my sketch making the change to only use a single S_INFO sensor. The idea is to send a pipe delimited string of all the config data for a zone in the following format:
        {all zone time}|{individual time}|{zone name}
        45|60|Garden/pond
        So all zones call uses 45 minutes, individual zone time is 60 minutes, and the zone name is "Garden/pond"
        Well without further adieu, here is the sketch.
        MySprinkler for MySensors
        Arduino Multi-Zone Sprinkler Control
        May 31, 2015
        *** Version 2.0
        *** Upgraded to http://MySensors.org version 1.4.1
        *** Expanded for up to 16 Valves
        *** Setup for active low relay board or comment out #define ACTIVE_LOW to switch to active high
        *** Switch to bitshift method vs byte arrays
        *** Changed RUN_ALL_ZONES Vera device to 0 (was highest valve)
        *** Added optional LCD display featuring remaining time, date last ran & current time
        *** Features 'raindrop' and 'clock' icons which indicate sensor is updating valve data and clock respectively
        *** Added single pushbutton menu to manually select which program to run (All Zones or a Single Zone)
        *** Added option of naming your Zones programmatically or with Vera (V_VAR3 used to store names)
        Utilizing your Vera home automation controller and the MySensors.org gateway you can
        control up to a sixteen zone irrigation system with only three digital pins.  This sketch
        will create NUMBER_OF_VALVES + 1 devices on your Vera controller
        This sketch features the following:
        * Allows you to cycle through All zones (RUN_ALL_ZONES) or individual zone (RUN_SINGLE_ZONE) control.
        * Use the 0th controller to activate RUN_ALL_ZONES (each zone in numeric sequence 1 to n)
          using Variable1 as the "ON" time in minutes in each of the vera devices created.
        * Use the individual zone controller to activate a single zone.  This feature uses
          Variable2 as the "ON" time for each individual device/zone.
        * Connect according to pinout below and uses Shift Registers as to allow the MySensors
          standard radio configuration and still leave available digital pins
        * Turning on any zone will stop the current process and begin that particular process.
        * Turning off any zone will stop the current process and turn off all zones.
        * To push your new time intervals for your zones, simply change the variable on your Vera and
          your arduino will call to Vera once a minute and update accordingly.  Variables will also be
          requested when the device is first powered on.
        * Pushbutton activation to RUN_ALL_ZONES, RUN_SINGLE_ZONE or halt the current program
        * LED status indicator
        PARTS LIST:
        Available from the MySensors store - http://www.mysensors.org/store/
        * Relays (8 channel)
        * Female Pin Header Connector Strip
        * Prototype Universal Printed Circuit Boards (PCB)
        * NRF24L01 Radio
        * Arduino (I used a Pro Mini)
        * FTDI USB to TTL Serial Adapter
        * Capacitors (10uf and .1uf)
        * 3.3v voltage regulator
        * Resistors (270 & 10K)
        * Female Dupont Cables
        * 1602 LCD (with I2C Interface)
        * LED
        * Push button
        * Shift Register (SN74HC595)
        * 2 Pole 5mm Pitch PCB Mount Screw Terminal Block
        * 3 Pole 5mm Pitch PCB Mount Screw Terminal Block
        * 22-24 gauge wire or similar (I used Cat5/Cat6 cable)
        * 18 gauge wire (for relay)
        * Irrigation Power Supply (24-Volt/750 mA Transformer)
        INSTRUCTIONS:
        * A step-by-step setup video is available here: http://youtu.be/l4GPRTsuHkI
        * After assembling your arduino, radio, decoupling capacitors, shift register(s), status LED, pushbutton LCD (I2C connected to
          A4 and A5) and relays, and load the sketch.
        * Following the instructions at https://MySensors.org include the device to your MySensors Gateway.
        * Verify that each new device has a Variable1, Variable2 and Variable3. Populate data accordingly with whole minutes for
          the RUN_ALL_ZONES routine (Variable1) and the RUN_SINGLE_ZONE routines (Variable 2).  The values entered for times may be zero and
          you may use the defaulet zone names by leaving Variable3 blank.
        * Once you have entered values for each zone and each variable, save the settings by pressing the red save button on your Vera.
        * Restart your arduino; verify the settings are loaded into your arduino with the serial monitor; the array will be printed
          on the serial monitor.
        * Your arduino should slow-flash, indicating that it is in ready mode.
        * There are multiple debug serial prints that can be monitored to assure that it is operating properly.
        * ***THIS SHOULD NO LONGER BE NEEDED*** The standard MySensors library now works. https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
        Contributed by Jim (BulldogLowell@gmail.com) with much contribution from Pete (pete.will@mysensors.org) and is released to the public domain
        #include <Wire.h>
        #include <Time.h>
        #include <LiquidCrystal.h>
        #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
        #define VALVE_RESET_TIME 7500UL   // Change this (in milliseconds) for the time you need your valves to hydraulically reset and change state
        #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
        #define SKETCH_NAME "MySprinkler"
        #define SKETCH_VERSION "2.0"
        #define CHILD_ID_SPRINKLER 0
        #define CHILD_ID_SPRINKLER_ALL 1
        #define CHILD_ID_SPRINKLER_IND 2
        #ifdef ACTIVE_LOW
        #define BITSHIFT_VALVE_NUMBER ~(1U << (valveNumber-1))
        #define ALL_VALVES_OFF 0xFFFF
        #else
        #define BITSHIFT_VALVE_NUMBER (1U << (valveNumber-1))
        #define ALL_VALVES_OFF 0U
        #ifdef DEBUG_ON
        #else
        // new V_TEXT variable type (development 20150905)
        const int V_TEXT = 47;
        // new S_INFO sensor type (development 20150905)
        const int S_INFO = 36 ;
        typedef enum {
          STAND_BY_ALL_OFF, RUN_SINGLE_ZONE, RUN_ALL_ZONES, CYCLE_COMPLETE, ZONE_SELECT_MENU
        SprinklerStates;
        SprinklerStates state = STAND_BY_ALL_OFF;
        SprinklerStates lastState;
        byte menuState = 0;
        unsigned long menuTimer;
        byte countDownTime = 10;
        int allZoneTime [NUMBER_OF_VALVES + 1];
        int valveSoloTime [NUMBER_OF_VALVES + 1];
        int valveNumber;
        int lastValve;
        unsigned long startMillis;
        const int ledPin = 5;
        const int waterButtonPin = 3;
        boolean buttonPushed = false;
        boolean clockUpdating = false;
        boolean recentUpdate = true;
        const char *dayOfWeek[] = {
          "Null", "Sunday ", "Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "
        // Name your Zones here or use Vera to edit them by adding a name in Variable3...
        String valveNickName[17] = {
          "All Zones", "Zone 1", "Zone 2", "Zone 3", "Zone 4", "Zone 5", "Zone 6", "Zone 7", "Zone 8", "Zone 9", "Zone 10", "Zone 11", "Zone 12", "Zone 13", "Zone 14", "Zone 15", "Zone 16"
        time_t lastTimeRun = 0;
        //Setup Shift Register...
        byte clock[8] = {0x0, 0xe, 0x15, 0x17, 0x11, 0xe, 0x0}; // fetching time indicator
        byte raindrop[8] = {0x4, 0x4, 0xA, 0xA, 0x11, 0xE, 0x0,}; // fetching Valve Data indicator
        // Set the pins on the I2C chip used for LCD connections:
        //                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
        LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
        MyMessage msg1valve(CHILD_ID_SPRINKLER, V_LIGHT);
        MyMessage var1valve(CHILD_ID_SPRINKLER_ALL, V_TEXT);
        MyMessage var2valve(CHILD_ID_SPRINKLER_IND, V_TEXT);
        bool receivedInitialValue = false;
          SERIAL_START(115200);
          DEBUG_PRINTLN(F("Initialising..."));
          pinMode(ledPin, OUTPUT);
          pinMode(waterButtonPin, INPUT_PULLUP);
          //pinMode(waterButtonPin, INPUT);
          attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
          digitalWrite (ledPin, HIGH);
          DEBUG_PRINTLN(F("Turning All Valves Off..."));
          updateRelays(ALL_VALVES_OFF);
          //delay(5000);
          lcd.begin(16, 2); //(16 characters and 2 line display)
          lcd.clear();
          lcd.backlight();
          lcd.createChar(0, clock);
          lcd.createChar(1, raindrop);
          //check for saved date in EEPROM
          //DEBUG_PRINTLN(F("Checking EEPROM for stored date:"));
          delay(500);
          if (gw.loadState(0) == 0xFF); // EEPROM flag
            //``DEBUG_PRINTLN(F("Retreiving last run time from EEPROM..."));
            for (int i = 0; i < 4 ; i++)
              lastTimeRun = lastTimeRun << 8;
              lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
          gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
          gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
          for (byte i = 0; i <= NUMBER_OF_VALVES; i++)
            gw.present((i * 2), S_LIGHT);
            gw.present(((i * 2) + 1), S_INFO);
            delay(100);
          DEBUG_PRINTLN(F("Presentation Complete"));
          digitalWrite (ledPin, LOW);
          DEBUG_PRINTLN(F("Ready..."));
          lcd.setCursor(0, 0);
          lcd.print(F(" Syncing Time  "));
          lcd.setCursor(15, 0);
          lcd.write(byte(0));
          lcd.setCursor(0, 1);
          int clockCounter = 0;
          while (timeStatus() == timeNotSet && clockCounter < 21)
            gw.process();
            gw.requestTime(receiveTime);
            DEBUG_PRINTLN(F("Requesting time:"));
            delay(1000);
            lcd.print(".");
            clockCounter++;
            if (clockCounter > 16)
              DEBUG_PRINTLN(F("Failed synchronization!"));
              lcd.clear();
              lcd.print(F("  Failed Clock  "));
              lcd.print(F(" Syncronization "));
              delay(2000);
              break;
          lcd.clear();
          //Update valve data when first powered on
            lcd.print(F(" Updating  "));
            lcd.print(F(" Valve Data: "));
            lcd.print(i);
            boolean flashIcon = false;
            DEBUG_PRINT(F("Calling for Valve "));
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(F(" Data..."));
            while (gw.process() == false)
              flashIcon = !flashIcon;
              flashIcon ? lcd.write(byte(1)) : lcd.print(F(" "));
              gw.request((i * 2) + 1, V_TEXT);
              delay(100);
          lcd.clear();
          gw.process();
          updateClock();
          updateDisplay();
          goGetValveTimes();
          if (buttonPushed)
            menuTimer = millis();
            DEBUG_PRINTLN(F("Button Pressed"));
            if (state == STAND_BY_ALL_OFF)
              state = ZONE_SELECT_MENU;
              menuState = 0;
            else if (state == ZONE_SELECT_MENU)
              menuState++;
              if (menuState > NUMBER_OF_VALVES)
                menuState = 0;
            else
            slowToggleLED ();
            if (state != lastState)
              DEBUG_PRINTLN(F("State all Zones off"));
                delay(50);
                gw.send(msg1valve.setSensor(i * 2).set(false), false);
              lcd.clear();
              lcd.setCursor(0,0);
              lcd.print(F("** Irrigation **"));
              lcd.setCursor(0,1);
              lcd.print(F("**   Halted   **"));
              delay(2000);
              lastValve = -1;
          else if (state == RUN_ALL_ZONES)
            if (lastValve != valveNumber)
                if (i == 0 || i == valveNumber)
                  gw.send(msg1valve.setSensor(i * 2).set(true), false);
                else
            lastValve = valveNumber;
            fastToggleLed();
              valveNumber = 1;
              DEBUG_PRINTLN(F("State Changed, Running All Zones..."));
            unsigned long nowMillis = millis();
            if (nowMillis - startMillis < VALVE_RESET_TIME)
            else if (nowMillis - startMillis < (allZoneTime[valveNumber] * 60000UL))
              updateRelays(BITSHIFT_VALVE_NUMBER);
            else
              DEBUG_PRINTLN(F("Changing Valves..."));
              startMillis = millis();
              valveNumber++;
              if (valveNumber > NUMBER_OF_VALVES)
                state = CYCLE_COMPLETE;
                lastValve = -1;
                lastTimeRun = now();
                saveDateToEEPROM(lastTimeRun);
                DEBUG_PRINT(F("State = "));
                DEBUG_PRINTLN(state);
          else if (state == RUN_SINGLE_ZONE)
            fastToggleLed();
                else
              DEBUG_PRINTLN(F("State Changed, Single Zone Running..."));
              DEBUG_PRINT(F("Zone: "));
              DEBUG_PRINTLN(valveNumber);
            else if (nowMillis - startMillis < (valveSoloTime [valveNumber] * 60000UL))
            else
          else if (state == CYCLE_COMPLETE)
            if (millis() - startMillis < 30000UL)
              fastToggleLed();
            else
          else if (state = ZONE_SELECT_MENU)
            displayMenu();
          lastState = state;
        void displayMenu(void)
          static byte lastMenuState = -1;
          static int lastSecond;
          if (menuState != lastMenuState)
            lcd.clear();
            lcd.print(valveNickName[menuState]);
            lcd.print(F("Starting"));
            DEBUG_PRINT(valveNickName[menuState]);
            Serial.print(F(" Starting Shortly"));
          int thisSecond = (millis() - menuTimer) / 1000UL;
          if (thisSecond != lastSecond && thisSecond < 8)
            lcd.print(F("."));
            Serial.print(".");
          lastSecond = thisSecond;
          if (millis() - menuTimer > 10000UL)
            if (menuState == 0)
              valveNumber = 1;
              state = RUN_ALL_ZONES;
            else
              valveNumber = menuState;
              state = RUN_SINGLE_ZONE;
          else
          lastMenuState = menuState;
        void updateRelays(int value)
          shiftOut(dataPin, clockPin, MSBFIRST, highByte(value));
          shiftOut(dataPin, clockPin, MSBFIRST, lowByte(value));
        void PushButton() //interrupt with debounce
          static unsigned long last_interrupt_time = 0;
          unsigned long interrupt_time = millis();
          if (interrupt_time - last_interrupt_time > 200)
            buttonPushed = true;
          last_interrupt_time = interrupt_time;
        void fastToggleLed()
          static unsigned long fastLedTimer;
          if (millis() - fastLedTimer >= 100UL)
            digitalWrite(ledPin, !digitalRead(ledPin));
            fastLedTimer = millis ();
        void slowToggleLED ()
          static unsigned long slowLedTimer;
          if (millis() - slowLedTimer >= 1250UL)
            slowLedTimer = millis ();
        //void getVariables(const MyMessage &message)
          boolean zoneTimeUpdate = false;
          if (message.isAck())
            DEBUG_PRINTLN(F("This is an ack from gateway"));
            if (message.sensor == (i * 2))
              if (message.type == V_LIGHT)
                int switchState = atoi(message.data);
                if (switchState == 0)
                  DEBUG_PRINTLN(F("Recieved Instruction to Cancel..."));
                else
                  if (i == 0)
                    valveNumber = 1;
                    DEBUG_PRINTLN(F("Recieved Instruction to Run All Zones..."));
                  else
                    valveNumber = i;
                    DEBUG_PRINT(F("Recieved Instruction to Activate Zone: "));
                    DEBUG_PRINTLN(i);
            if (message.sensor == ((i * 2) + 1))
              if (message.type == V_TEXT)
                String valveMessage = String(message.data);
                char* valveData = &valveMessage[0]; //.c_str();
                DEBUG_PRINT(F("Recieved valve data:"));
                DEBUG_PRINT(i);
                DEBUG_PRINT(F(" = "));
                DEBUG_PRINTLN(valveMessage);
                char* var = strtok(valveData, "|");
                int variable1 = atoi(var); // RUN_ALL_ZONES time
                if (variable1 != allZoneTime[i])
                  allZoneTime[i] = variable1;
                  zoneTimeUpdate = true;
                var = strtok(NULL, "|");
                int variable2 = atoi(var);// RUN_SINGLE_ZONE time
                if (variable2 != valveSoloTime[i])
                  valveSoloTime[i] = variable2;
                String newMessage = String(var);
                if (newMessage.length() == 0)
                  DEBUG_PRINT(F("No Name for "));
                  DEBUG_PRINTLN(i);
                  break;
                if (newMessage.length() > 16)
                  newMessage.substring(0, 16);
                valveNickName[i] = "";
                valveNickName[i] += newMessage;
                DEBUG_PRINT(F("Recieved name "));
                DEBUG_PRINT(i);
                DEBUG_PRINT(F(" called: "));
                DEBUG_PRINTLN(valveNickName[i]);
              receivedInitialValue = true;
          if (zoneTimeUpdate)
            DEBUG_PRINTLN(F("New Zone Times..."));
              if (i != 0)
                DEBUG_PRINT(F("Zone "));
                DEBUG_PRINT(i);
                DEBUG_PRINT(F(" individual time: "));
                DEBUG_PRINT(valveSoloTime[i]);
                DEBUG_PRINT(F(" group time: "));
                DEBUG_PRINTLN(allZoneTime[i]);
          else
            recentUpdate = false;
        void updateDisplay()
          static unsigned long lastUpdateTime;
          static boolean displayToggle = false;
          //static byte toggleCounter = 0;
          static SprinklerStates lastDisplayState;
          if (state != lastDisplayState || millis() - lastUpdateTime >= 3000UL)
            displayToggle = !displayToggle;
            switch (state) {
              case STAND_BY_ALL_OFF:
                fastClear();
                if (displayToggle)
                  lcd.print(F("  System Ready "));
                  if (clockUpdating)
                    lcd.write(byte(0));
                  lcd.print(hourFormat12() < 10 ? F(" ") : F(""));
                  lcd.print(hourFormat12());
                  lcd.print(minute() < 10 ? F(":0") : F(":"));
                  lcd.print(minute());
                  lcd.print(isAM() ? F("am") : F("pm"));
                  lcd.print(month() < 10 ? F(" 0") : F(" "));
                  lcd.print(month());
                  lcd.print(day() < 10 ? F("/0") : F("/"));
                  lcd.print(day());
                  lcd.print(F("/"));
                  lcd.print(year() % 100);
                else
                  lcd.print(F("  Last Watered "));
                  if (clockUpdating)
                    lcd.write(byte(0));
                  lcd.print(dayOfWeek[weekday(lastTimeRun)]);
                  lcd.setCursor(11, 1);
                  lcd.print(month(lastTimeRun) < 10 ? F(" ") : F(""));
                  lcd.print(month(lastTimeRun));
                  lcd.print(day(lastTimeRun) < 10 ? F("/0") : F("/"));
                  lcd.print(day(lastTimeRun));
                break;
              case RUN_SINGLE_ZONE:
                fastClear();
                if (displayToggle)
                  lcd.print(F("Single Zone Mode"));
                  lcd.print(F(" Zone:"));
                  if (valveNumber < 10) lcd.print(F("0"));
                  lcd.print(valveNumber);
                  lcd.print(F(" Active"));
                else
                  lcd.print(F(" Time Remaining "));
                  if (valveSoloTime[valveNumber] == 0)
                    lcd.print(F(" No Valve Time "));
                  else
                    unsigned long timeRemaining = (valveSoloTime[valveNumber] * 60) - ((millis() - startMillis) / 1000);
                    lcd.print(timeRemaining / 60 < 10 ? "   0" : "   ");
                    lcd.print(timeRemaining / 60);
                    lcd.print("min");
                    lcd.print(timeRemaining % 60 < 10 ? " 0" : " ");
                    lcd.print(timeRemaining % 60);
                    lcd.print("sec  ");
                break;
              case RUN_ALL_ZONES:
                fastClear();
                if (displayToggle)
                  lcd.print(F(" All-Zone  Mode "));
                  lcd.print(F(" Active "));
                else
                  int timeRemaining = (allZoneTime[valveNumber] * 60) - ((millis() - startMillis) / 1000);
                  lcd.print((timeRemaining / 60) < 10 ? "   0" : "   ");
                  lcd.print("min");
                  lcd.print("sec  ");
                break;
              case CYCLE_COMPLETE:
                if (displayToggle)
                  lcd.print(F(" Watering Cycle "));
                  lcd.print(F("    Complete    "));
                else
                  int totalTimeRan = 0;
                  for (int i = 1; i <= NUMBER_OF_VALVES + 1; i++)
                    totalTimeRan += allZoneTime[i];
                  lcd.print(F(" Total Time Run "));
                  lcd.print(totalTimeRan < 10 ? "   0" : "   ");
                  lcd.print(totalTimeRan);
                  lcd.print(" Minutes   ");
            lastUpdateTime = millis();
          lastDisplayState = state;
          DEBUG_PRINTLN(F("Time value received and updated..."));
          setTime(newTime);
          if (((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour)) || showTime)
            DEBUG_PRINTLN(F("Clock updated...."));
            DEBUG_PRINT(F("Sensor's time currently set to:"));
            DEBUG_PRINT(hourFormat12() < 10 ? F(" 0") : F(" "));
            DEBUG_PRINT(hourFormat12());
            DEBUG_PRINT(minute());
            DEBUG_PRINTLN(isAM() ? F("am") : F("pm"));
            DEBUG_PRINT(day());
            DEBUG_PRINTLN(year());
            DEBUG_PRINTLN(dayOfWeek[weekday()]);
            showTime = false;
          else
            DEBUG_PRINTLN(F("Sensor's time did NOT need adjustment greater than 1 second."));
        void fastClear()
          lcd.print(F("                "));
          lcd.print(F("                "));
        void updateClock()
          static unsigned long lastVeraGetTime;
          if (millis() - lastVeraGetTime >= 3600000UL) // updates clock time and gets zone times from vera once every hour
            DEBUG_PRINTLN(F("Requesting time and valve data from Gateway..."));
            lcd.write(byte(0));
            clockUpdating = true;
            lastVeraGetTime = millis();
        void saveDateToEEPROM(unsigned long theDate)
          DEBUG_PRINTLN(F("Saving Last Run date"));
          if (gw.loadState(0) != 0xFF)
            gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
          for (int i = 1; i < 5; i++)
            gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
        void goGetValveTimes()
          static unsigned long valveUpdateTime;
          static byte valveIndex = 1;
          if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
            DEBUG_PRINTLN(F("Calling for Valve Data..."));
            lcd.write(byte(1)); //lcd.write(1);
            gw.request((valveIndex * 4) + 1, V_TEXT);
            gw.request((valveIndex * 4) + 2, V_TEXT);
            gw.request((valveIndex * 4) + 3, V_TEXT);
            valveUpdateTime = millis();
            valveIndex++;
            if (valveIndex > NUMBER_OF_VALVES + 1)
              valveIndex = 1;
          @AWI
          @dbemowsk
          //#define MY_DEBUG
          #include <Time.h>
          #include <Wire.h>
          //#else
          //	#define LCDINIT
          //#endif
          #ifdef ACTIVE_LOW
          #else
          #ifdef DEBUG_ON
          #else
          class myElement {
          public:
          	char* Name;
          	int RunningTime;
          	this->Name = Name;
          	{ "Pond Pump", 0 },
          	{ "Acc1", 0 },
          	{ "Acc2", 0 },
          	{ "Acc3", 0 },
          	SERIAL_START(9600);
          	//LCDINIT;
          	//requestTime();
          		wait(50);
          		wait(50);
          				updateRelay(i, 0);
          		wait(500);
          //	else
          	case V_STATUS:
          		break;
          	default:
          		break;
          //void RESET() {
          		else
          	myShiftOut;
          AWIA
          AWIA
          AWI
          Can you elaborate on this? In my setup the Dimmer is as reliable as any other control. Main limitation is that the standard dimmer can only assume 16 "states"/ values.
          • dbemowskD dbemowsk
            AWIA
            AWIA
            AWI
            While introducing the V_TEXT/S_INFO type we were aware that this would be a would open up the route to many "non standard" applications. I personally try to keep everything in the standard types or to have a standard defined for it. (like in the V_ORIENTATION suggestion in the Orientation actuator ).
            Sometimes the choice is limited as with the V_PERCENTAGE/ DIMMER implementation in Domoticz as there is no "generic" type to represent just a value (int/float) or date/time (y/m/d h:m:s).
              Sergio RiusS
              Sergio RiusS
              Sergio Rius
              Yes, that was the part where we supposedly had to join our sketches. Just getting all the array contents from an S_INFO. Perhaps using some Json to array conversion. Should be some library for conversions there.
              Elm.Name assigns a name to the valve. And presents to Domoticz. Still doesn't exists a way to get from domoticz.
              Again, still doesn't....
              Yes. as I said it was so complicated for me to integrate the "stand-alone functions" that use loop cycles for running the menu. I planned to make dedicated functions for it, but didn't have time.
              And why not using this approach on a single S_INFO, that could feed the array I have in my sketch?
              dbemowskD 1 Reply Last reply
              • AWIA AWI
                Sergio RiusS
                Sergio RiusS
                Sergio Rius
                wrote on last edited by Sergio Rius
                #227
                The dimmer is reliable. I was talking of interface widget being complex. In Domoticz, to activate one zone you would have to first click, and when the popup appears, click again on the blue (sphere?) for it to start.
                In Imperihome, you would have up to 32 rgb dial indicators on your page and still don't get the current set value, and when you set it on, most of times it doesn't respect the current intensity value.
                And that doesn't solve the double timing setup nor the naming.
                I always like to apply the KISS rule to my developments and avoid to depend on other systems. Specially if they don't walk in the same direction. Imagine that in the future the dimmer system changes, for example, into a hue pallete.
                And it's true that mysensors and domoticz is lacking a sensors configuration system.
                  AWIA
                  AWIA
                  AWI
                  @Sergio-Rius Think I understand ;) and keep my systems as autonomous and simple as possible.
                  The route with S_INFO/V_TEXT won't bring you any luck, regarding the customization to be done in Domoticz to get values in V_TEXT (LUA / JSON).
                  btw. Like your sketch :thumbsup:
                  • AWIA AWI
                    Sergio RiusS
                    Sergio RiusS
                    Sergio Rius
                    @AWI
                    You'r right, that's not the best route. But until we have sensors configuration routines... ;)
                    Will we have? :grimacing:
                      @AWI
                      AWIA
                      AWIA
                      AWI
                      @Sergio-Rius Don't expect too much in either MySensors/ Domoticz unless you know of a "industry standard" approach which can be implemented with reasonable efforts by the community..
                      • AWIA AWI
                        dbemowskD
                        dbemowskD
                        Are you saying that Domoticz primary focus is to follow existing industry standards? Some times you need to shift away from the standards. Giving users more options will only increase the software's user base. If it were me, I'd rather become the standard than chase it.
                          dbemowskD
                          dbemowskD
                          The main part of my new approach is this bit here:
                                  DEBUG_PRINT(i);
                                    DEBUG_PRINTLN(i);
                                    break;
                                  DEBUG_PRINT(i);
                          The key is using strtok() to split the incoming string into it's parts. The code that I posted from my tests seems to work, at least from what I have tested so far. It uses one S_INFO sensor for each zone to carry the 3 parts that would be the V_VAR1 - V_VAR3 info in the original sketch. Granted it is only for 1.5, but if you can use anything from my 1.5 sketch in your 2.0 sketch, feel free.
                          • impertusI
                            impertusI
                            impertus
                            Hi first Great projekt. All the things is Just ordred from eBay. But i Wonder what the yellow component is.
                            And mayby a tuturial have to make a complete HA kontroller. And have to set i Up. Rigtig now i have a raspberry pi with calaos. But i Dont know have to the it Up with the system.
                            Hope there is some help in here :)
                            impertusI 1 Reply Last reply
                              I put together an extension of the multi-Relay controller for use as a controller for your irrigation project if you have more zones than available pins on your Arduino.
                              • Allows you to cycle through All zones or individual zone control.
                              • Use the (n+1)th device to activate each zone in numeric sequence (zero to n) using
                              • Use the individual zone controller to activate a single zone. This feature uses
                              • Connect according to pinout in the sketch and uses an 74HC595 (or equiv) Shift Register as to
                                allow the MySensors standard radio configuration and still leave available digital pins
                              • Compiles to ~12,000 Bytes, so will run on any Arduino
                              • Turning on any zone will stop the current process and begin that particular process.
                              • Turning off any zone will stop the current process and turn off all zones.
                              • Sketch must collect your desired intervals so it takes several minutes to startup.
                              • If you change your desired time intervals for your zones, simply restart your arduino
                                and it will self update to reflect those changes.
                              Example, I am using with 8 relays:
                              This will create 9 devices. Zero through 7 are the individual relays. Eight is the Sequencer, so to speak (refer to attachment).
                              Once you create this and add it using the gateway, go to each of zero through 7 and edit Variable1 and Variable2 for what time you want to use for the Sequencer or Zone respectively. Then save the settings. Then, restart your arduino; your arduino will extract these settings and save them to an array.
                              When you turn on device 8 (aka the Sequencer) the relays will actuate in order from zero to seven, each one staying on for the period entered in the Variable1 field. There is a 5 second delay at the start of a new zone to allow for the valves to hydraulically reset.
                              When you turn on any of devices zero through 7, it will run that zone only for the period of time entered in Variable2.
                              Selecting any new zone (0-8) will stop the current process and start as per above.
                              Hope you have a use for it. If you see any opportunity to improve, or find a bug, let me know.
                              Jim
                              modified. Attached wrong file, whoops!
                              Sprinkler.ino
                              wasamW
                              wasamW
                              wasam
                              @BulldogLowell
                              I love your programming skills, it is superb. Haven gone through your video, l was happy and l needed a modification to your setup. I want to use the arduino to power my irrigation with the following function.
                              Arduino with soil moisture sensor check. once the soil is dry, arduino to switch on the electric 1horse power pumping machine and at the same time open the solenoid valve to irrigate at a specified timing.
                              As per powering the pumping machine, arduino should check if there is public electricity supply before switching on the pump and if there is no public power supply then it should switch on the power generating set to power the pumping machine and solenoid valve.
                              After the sensor has confirmed that the soil is wet and moist, then arduino stops the pumping machine and then closes the electric 220v solenoid valve.
                              Second task.
                              Overhead Mist Sprayer (uses a different AC 1horse power pump)
                              A sensor to check when the sun temperature is 35 or 40 degrees or any programmed temperature and switch on the pumping machine to power the sprayer for a specified timing. Also arduino should should check if there is public electricity supply before switching on the pump and if there is no public power supply then it should switch on the power generating set to power the pumping machine.
                              Also irrigation records of time and dates and other function will be added up in the setup.
                              I like to know the hardwares l will need for this project, a guide and codes. I appreciate this .
                              • wasamW wasam
                                @BulldogLowell
                                Second task.
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                @wasam
                                There are several examples out there (either here or in the Arduino forum) of how to combine sketches for added functionality. Fortunately, you are starting with my code that is already non-blocking and uses little in the way of system resources so it should be straightforward from here.
                                The community here (including me) can assist in giving you what you want.
                                first thing is the hardware... assuming your using metric means you are 220VAC... you need a person familiar with mains switching to help you out there!
                                • impertusI impertus
                                  impertusI
                                  impertusI
                                  impertus
                                  @BulldogLowell
                                  petewillP 1 Reply Last reply
                                    @BulldogLowell
                                    petewillP
                                    petewillP
                                    petewill
                                    Where are you seeing the yellow component? Maybe it's the LED? Can you post a picture?
                                    • petewillP petewill
                                      impertusI
                                      impertusI
                                      impertus
                                        petewillP
                                        petewillP
                                        petewill
                                        @impertus Ah, ok. That is a .1uf capacitor.
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          @petewill
                                          which can be easily substituted by a flux capacitor.
                                          :wink:
