  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 325.2k Views 52 Watching
  • petewillP petewill
    @Ngwpower Don't give up! It is a learning curve for sure but totally worth it when you finally get it. Try the irrigation controller sketch from the MySensors 1.5 library example. All the required stuff should be there.
    @Sergio-Rius I'm not sure what you're looking for. Do you need the 1.5 version?
    Sergio RiusS
    Sergio RiusS
    Sergio Rius
    @petewill
    The problem are the new libraries that come with newer arduino ide. My attempts fail about the wire.h library location or a wrong "positive" variable at liquiddisplay.
    I think it's not compatible with newer libraries.
    • ? A Former User
      Thanks, I envy you young people at 67 just opening the wide world of tech - do't have to do this sitting on a motor grader or Bull Dozer in the high desert. I have tried from 1.3 to 2.0 and thought I saw a flicker of LED in the string of switches, as in your example. Had my 5V on the wrong pin, so back to square one.
      I am having fun attempting to learn the terminology as well as the application!
      petewillP
      petewillP
      petewill
      wrote on last edited by petewill
      #182
      I was just thinking the other day I can't wait until I retire so I'll have more time to work on this stuff ;)
      I'm glad you're not giving up. It took me a while to get it too but eventually it all started to make a little sense. Unfortunately you're starting at a harder time because we are all still getting comfortable with 2.0
      @Sergio-Rius Ok, I haven't updated my libraries for a while so hopefully these will work for you. 0_1468884836658_Libraries.zip
      Sergio RiusS 1 Reply Last reply
        Sergio RiusS
        Sergio RiusS
        Sergio Rius
        wrote on last edited by Sergio Rius
        #183
        @petewill
        Thank you very much. Unfortunately those are not the libraries I've problems with. The problem are the built-in ones. The ones that come with the Arduino IDE.
        What version of the IDE are you running? I guess you use the Mysensors 1.4.2 libs.
        I installed Arduino IDE 1.6.9 and using your libraries, those are the errors shown:
        WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
        W:\Domotica\MySensors_Arduino\arduino-1.6.9\portable\sketchbook\libraries\LiquidCrystal\I2CIO.cpp:35:26: fatal error: ../Wire/Wire.h: No such file or directory
         #include <../Wire/Wire.h>
        compilation terminated.
        Multiple libraries were found for "Wire.h"
         Used: W:\Domotica\MySensors_Arduino\arduino-1.6.9\portable\sketchbook\libraries\Wire
         Not used: W:\Domotica\MySensors_Arduino\arduino-1.6.9\hardware\arduino\avr\libraries\Wire
        Multiple libraries were found for "LiquidCrystal.h"
         Used: W:\Domotica\MySensors_Arduino\arduino-1.6.9\portable\sketchbook\libraries\LiquidCrystal
         Not used: W:\Domotica\MySensors_Arduino\arduino-1.6.9\libraries\LiquidCrystal
        exit status 1
        Error compiling for board Arduino Nano.
        As you can appreciate, the Wire library is at the ../Wire path, so that error is meaningless.
        I told you that I hate java environments? I still haven't found one that works out of the developer computer without issues. X)
        EDIT: So the problem is that the Wire library has been updated, but we are still using an old version of the LiquidCrystal. This last one expects the .h files been on the root library folder but this has been changed in newer versions. Built-in libraries have their code in "src" subfolder.
        I moved it to parent folder and it compiles, but I don't know what will happen with other dependencies.
        Better would be updating the sketch.
        L AWIA 2 Replies Last reply
        • L Lars65
          @Ngwpower I use this one which is earlier in this thread, an it works with my domoticz.
          MySprinkler for MySensors
          Arduino Multi-Zone Sprinkler Control
          May 31, 2015
          *** Version 2.0
          *** Upgraded to http://MySensors.org version 1.4.1
          *** Expanded for up to 16 Valves
          *** Setup for active low relay board or comment out #define ACTIVE_LOW to switch to active high
          *** Switch to bitshift method vs byte arrays
          *** Changed RUN_ALL_ZONES Vera device to 0 (was highest valve)
          *** Added optional LCD display featuring remaining time, date last ran & current time
          *** Features 'raindrop' and 'clock' icons which indicate sensor is updating valve data and clock respectively
          *** Added single pushbutton menu to manually select which program to run (All Zones or a Single Zone)
          *** Added option of naming your Zones programmatically or with Vera (V_VAR3 used to store names)
          Utilizing your Vera home automation controller and the MySensors.org gateway you can
          control up to a sixteen zone irrigation system with only three digital pins.  This sketch
          will create NUMBER_OF_VALVES + 1 devices on your Vera controller
          This sketch features the following:
          * Allows you to cycle through All zones (RUN_ALL_ZONES) or individual zone (RUN_SINGLE_ZONE) control.
          * Use the 0th controller to activate RUN_ALL_ZONES (each zone in numeric sequence 1 to n)
            using Variable1 as the "ON" time in minutes in each of the vera devices created.
          * Use the individual zone controller to activate a single zone.  This feature uses
            Variable2 as the "ON" time for each individual device/zone.
          * Connect according to pinout below and uses Shift Registers as to allow the MySensors
            standard radio configuration and still leave available digital pins
          * Turning on any zone will stop the current process and begin that particular process.
          * Turning off any zone will stop the current process and turn off all zones.
          * To push your new time intervals for your zones, simply change the variable on your Vera and
            your arduino will call to Vera once a minute and update accordingly.  Variables will also be
            requested when the device is first powered on.
          * Pushbutton activation to RUN_ALL_ZONES, RUN_SINGLE_ZONE or halt the current program
          * LED status indicator
          PARTS LIST:
          Available from the MySensors store - http://www.mysensors.org/store/
          * Relays (8 channel)
          * Female Pin Header Connector Strip
          * Prototype Universal Printed Circuit Boards (PCB)
          * NRF24L01 Radio
          * Arduino (I used a Pro Mini)
          * FTDI USB to TTL Serial Adapter
          * Capacitors (10uf and .1uf)
          * 3.3v voltage regulator
          * Resistors (270 & 10K)
          * Female Dupont Cables
          * 1602 LCD (with I2C Interface)
          * LED
          * Push button
          * Shift Register (SN74HC595)
          * 2 Pole 5mm Pitch PCB Mount Screw Terminal Block
          * 3 Pole 5mm Pitch PCB Mount Screw Terminal Block
          * 22-24 gauge wire or similar (I used Cat5/Cat6 cable)
          * 18 gauge wire (for relay)
          * Irrigation Power Supply (24-Volt/750 mA Transformer)
          INSTRUCTIONS:
          * A step-by-step setup video is available here: http://youtu.be/l4GPRTsuHkI
          * After assembling your arduino, radio, decoupling capacitors, shift register(s), status LED, pushbutton LCD (I2C connected to
            A4 and A5) and relays, and load the sketch.
          * Following the instructions at https://MySensors.org include the device to your MySensors Gateway.
          * Verify that each new device has a Variable1, Variable2 and Variable3. Populate data accordingly with whole minutes for
            the RUN_ALL_ZONES routine (Variable1) and the RUN_SINGLE_ZONE routines (Variable 2).  The values entered for times may be zero and
            you may use the defaulet zone names by leaving Variable3 blank.
          * Once you have entered values for each zone and each variable, save the settings by pressing the red save button on your Vera.
          * Restart your arduino; verify the settings are loaded into your arduino with the serial monitor; the array will be printed
            on the serial monitor.
          * Your arduino should slow-flash, indicating that it is in ready mode.
          * There are multiple debug serial prints that can be monitored to assure that it is operating properly.
          * ***THIS SHOULD NO LONGER BE NEEDED*** The standard MySensors library now works. https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
          Contributed by Jim (BulldogLowell@gmail.com) with much contribution from Pete (pete.will@mysensors.org) and is released to the public domain
          #include <Wire.h>
          #include <Time.h>
          #include <LiquidCrystal.h>
          #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
          #define VALVE_RESET_TIME 7500UL   // Change this (in milliseconds) for the time you need your valves to hydraulically reset and change state
          #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
          #define SKETCH_NAME "MySprinkler Domoticz"
          #define SKETCH_VERSION "2.0"
          #define CHILD_ID_SPRINKLER 0
          //#define ACTIVE_LOW // comment out this line if your relays are active high
          #define DEBUG_ON   // comment out to supress serial monitor output
          #ifdef ACTIVE_LOW
          #define BITSHIFT_VALVE_NUMBER ~(1U << (valveNumber-1))
          #define ALL_VALVES_OFF 0xFFFF
          #else
          #define BITSHIFT_VALVE_NUMBER (1U << (valveNumber-1))
          #define ALL_VALVES_OFF 0U
          #ifdef DEBUG_ON
          #define DEBUG_PRINT(x)   Serial.print(x)
          #define SERIAL_START(x)  Serial.begin(x)
          #else
          typedef enum {
            STAND_BY_ALL_OFF, RUN_SINGLE_ZONE, RUN_ALL_ZONES, CYCLE_COMPLETE, ZONE_SELECT_MENU
          SprinklerStates;
          SprinklerStates state = STAND_BY_ALL_OFF;
          SprinklerStates lastState;
          byte menuState = 0;
          unsigned long menuTimer;
          byte countDownTime = 10;
          int allZoneTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};     // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
          int valveSoloTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};   // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
          int valveNumber;
          int lastValve;
          unsigned long startMillis;
          const int ledPin = 5;
          const int waterButtonPin = 3;
          boolean buttonPushed = false;
          boolean showTime = true;
          boolean clockUpdating = false;
          boolean recentUpdate = true;
          const char *dayOfWeek[] = {
            "Null", "Sunday ", "Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "
          // Name your Zones here or use Vera to edit them by adding a name in Variable3...
          String valveNickName[17] = {
            "All Zones", "Zone 1", "Zone 2", "Zone 3", "Zone 4", "Zone 5", "Zone 6", "Zone 7", "Zone 8", "Zone 9", "Zone 10", "Zone 11", "Zone 12", "Zone 13", "Zone 14", "Zone 15", "Zone 16"
          time_t lastTimeRun = 0;
          //Setup Shift Register...
          const int latchPin = 8;
          const int clockPin = 4;
          const int dataPin  = 7;
          byte clock[8] = {0x0, 0xe, 0x15, 0x17, 0x11, 0xe, 0x0}; // fetching time indicator
          byte raindrop[8] = {0x4, 0x4, 0xA, 0xA, 0x11, 0xE, 0x0,}; // fetching Valve Data indicator
          // Set the pins on the I2C chip used for LCD connections:
          //                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
          LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
          MyMessage msg1valve(CHILD_ID_SPRINKLER, V_LIGHT);
          MyMessage var1valve(CHILD_ID_SPRINKLER, V_VAR1);
          MyMessage var2valve(CHILD_ID_SPRINKLER, V_VAR2);
            SERIAL_START(115200);
            DEBUG_PRINTLN(F("Initialising..."));
            pinMode(latchPin, OUTPUT);
            pinMode(clockPin, OUTPUT);
            pinMode(dataPin, OUTPUT);
            pinMode(ledPin, OUTPUT);
            pinMode(waterButtonPin, INPUT_PULLUP);
            //pinMode(waterButtonPin, INPUT);
            attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
            digitalWrite (ledPin, HIGH);
            DEBUG_PRINTLN(F("Turning All Valves Off..."));
            updateRelays(ALL_VALVES_OFF);
            //delay(5000);
            lcd.begin(16, 2); //(16 characters and 2 line display)
            lcd.clear();
            lcd.backlight();
            lcd.createChar(0, clock);
            lcd.createChar(1, raindrop);
            //check for saved date in EEPROM
            DEBUG_PRINTLN(F("Checking EEPROM for stored date:"));
            delay(500);
            if (gw.loadState(0) == 0xFF); // EEPROM flag
              DEBUG_PRINTLN(F("Retreiving last run time from EEPROM..."));
              for (int i = 0; i < 4 ; i++)
                lastTimeRun = lastTimeRun << 8;
                lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
            gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
            gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
            for (byte i = 0; i <= NUMBER_OF_VALVES; i++)
              gw.present(i, S_LIGHT);
            DEBUG_PRINTLN(F("Sensor Presentation Complete"));
            digitalWrite (ledPin, LOW);
            DEBUG_PRINTLN(F("Ready..."));
            lcd.setCursor(0, 0);
            lcd.print(F(" Syncing Time  "));
            lcd.setCursor(15, 0);
            lcd.write(byte(0));
            lcd.setCursor(0, 1);
            int clockCounter = 0;
            while (timeStatus() == timeNotSet && clockCounter < 21)
              gw.process();
              gw.requestTime(receiveTime);
              DEBUG_PRINTLN(F("Requesting time from Gateway:"));
              delay(1000);
              lcd.print(".");
              clockCounter++;
              if (clockCounter > 16)
                DEBUG_PRINTLN(F("Failed initial clock synchronization!"));
                lcd.clear();
                lcd.print(F("  Failed Clock  "));
                lcd.print(F(" Syncronization "));
                delay(2000);
                break;
            lcd.clear();
            //Update valve data when first powered on
              lcd.print(F(" Updating  "));
              lcd.print(F(" Valve Data: "));
              lcd.print(i);
              boolean flashIcon = false;
              DEBUG_PRINT(F("Calling for Valve "));
              DEBUG_PRINT(i);
              DEBUG_PRINTLN(F(" Data..."));
              while (gw.process() == false)
                flashIcon = !flashIcon;
                flashIcon ? lcd.write(byte(1)) : lcd.print(F(" "));
                gw.request(i, V_VAR1);
                delay(100);
                gw.request(i, V_VAR2);
                delay(100);
                gw.request(i, V_VAR3);
                delay(100);
            lcd.clear();
            gw.process();
            updateClock();
            updateDisplay();
            //goGetValveTimes();
            if (buttonPushed)
              menuTimer = millis();
              DEBUG_PRINTLN(F("Button Pressed"));
              if (state == STAND_BY_ALL_OFF)
                state = ZONE_SELECT_MENU;
                menuState = 0;
              else if (state == ZONE_SELECT_MENU)
                menuState++;
                if (menuState > NUMBER_OF_VALVES)
                  menuState = 0;
              else
              slowToggleLED ();
              if (state != lastState)
                DEBUG_PRINTLN(F("State Changed... all Zones off"));
                  delay(50);
                  gw.send(msg1valve.setSensor(i).set(false), false);
                lcd.clear();
                lcd.setCursor(0,0);
                lcd.print(F("** Irrigation **"));
                lcd.setCursor(0,1);
                lcd.print(F("**   Halted   **"));
                delay(2000);
                lastValve = -1;
            else if (state == RUN_ALL_ZONES)
              if (lastValve != valveNumber)
                  if (i == 0 || i == valveNumber)
                    gw.send(msg1valve.setSensor(i).set(true), false);
                  else
              lastValve = valveNumber;
              fastToggleLed();
                valveNumber = 1;
                DEBUG_PRINTLN(F("State Changed, Running All Zones..."));
              unsigned long nowMillis = millis();
              if (nowMillis - startMillis < VALVE_RESET_TIME)
              else if (nowMillis - startMillis < (allZoneTime[valveNumber] * 60000UL))
                updateRelays(BITSHIFT_VALVE_NUMBER);
              else
                DEBUG_PRINTLN(F("Changing Valves..."));
                startMillis = millis();
                valveNumber++;
                if (valveNumber > NUMBER_OF_VALVES)
                  state = CYCLE_COMPLETE;
                  lastValve = -1;
                  lastTimeRun = now();
                  saveDateToEEPROM(lastTimeRun);
                  DEBUG_PRINT(F("State = "));
                  DEBUG_PRINTLN(state);
            else if (state == RUN_SINGLE_ZONE)
              fastToggleLed();
                  else
                DEBUG_PRINTLN(F("State Changed, Single Zone Running..."));
                DEBUG_PRINT(F("Zone: "));
                DEBUG_PRINTLN(valveNumber);
              else if (nowMillis - startMillis < (valveSoloTime [valveNumber] * 60000UL))
              else
            else if (state == CYCLE_COMPLETE)
              if (millis() - startMillis < 30000UL)
                fastToggleLed();
              else
            else if (state = ZONE_SELECT_MENU)
              displayMenu();
            lastState = state;
          void displayMenu(void)
            static byte lastMenuState = -1;
            static int lastSecond;
            if (menuState != lastMenuState)
              lcd.clear();
              lcd.print(valveNickName[menuState]);
              lcd.print(F("Starting"));
              DEBUG_PRINT(valveNickName[menuState]);
              Serial.print(F(" Starting Shortly"));
            int thisSecond = (millis() - menuTimer) / 1000UL;
            if (thisSecond != lastSecond && thisSecond < 8)
              lcd.print(F("."));
              Serial.print(".");
            lastSecond = thisSecond;
            if (millis() - menuTimer > 10000UL)
              if (menuState == 0)
                valveNumber = 1;
                state = RUN_ALL_ZONES;
              else
                valveNumber = menuState;
                state = RUN_SINGLE_ZONE;
            else
            lastMenuState = menuState;
          void updateRelays(int value)
            digitalWrite(latchPin, LOW);
            shiftOut(dataPin, clockPin, MSBFIRST, highByte(value));
            shiftOut(dataPin, clockPin, MSBFIRST, lowByte(value));
            digitalWrite(latchPin, HIGH);
          void PushButton() //interrupt with debounce
            static unsigned long last_interrupt_time = 0;
            unsigned long interrupt_time = millis();
            if (interrupt_time - last_interrupt_time > 200)
              buttonPushed = true;
            last_interrupt_time = interrupt_time;
          void fastToggleLed()
            static unsigned long fastLedTimer;
            if (millis() - fastLedTimer >= 100UL)
              digitalWrite(ledPin, !digitalRead(ledPin));
              fastLedTimer = millis ();
          void slowToggleLED ()
            static unsigned long slowLedTimer;
            if (millis() - slowLedTimer >= 1250UL)
              slowLedTimer = millis ();
          void getVariables(const MyMessage &message)
            boolean zoneTimeUpdate = false;
            if (message.isAck())
              DEBUG_PRINTLN(F("This is an ack from gateway"));
              if (message.sensor == i)
                if (message.type == V_LIGHT)
                  int switchState = atoi(message.data);
                  if (switchState == 0)
                    DEBUG_PRINTLN(F("Recieved Instruction to Cancel..."));
                  else
                    if (i == 0)
                      valveNumber = 1;
                      DEBUG_PRINTLN(F("Recieved Instruction to Run All Zones..."));
                    else
                      valveNumber = i;
                      DEBUG_PRINT(F("Recieved Instruction to Activate Zone: "));
                      DEBUG_PRINTLN(i);
                else if (message.type == V_VAR1)
                  int variable1 = atoi(message.data);// RUN_ALL_ZONES time
                  DEBUG_PRINT(F("Recieved variable1 valve:"));
                  DEBUG_PRINT(i);
                  DEBUG_PRINT(F(" = "));
                  DEBUG_PRINTLN(variable1);
                  if (variable1 != allZoneTime[i])
                    allZoneTime[i] = variable1;
                    zoneTimeUpdate = true;
                else if (message.type == V_VAR2)
                  int variable2 = atoi(message.data);// RUN_SINGLE_ZONE time
                  DEBUG_PRINT(F("Recieved variable2 valve:"));
                  DEBUG_PRINT(i);
                  DEBUG_PRINTLN(variable2);
                  if (variable2 != valveSoloTime[i])
                    valveSoloTime[i] = variable2;
                else if (message.type == V_VAR3)
                  String newMessage = String(message.data);
                  if (newMessage.length() == 0)
                    DEBUG_PRINT(F("No Name Recieved for zone "));
                    DEBUG_PRINTLN(i);
                    break;
                  if (newMessage.length() > 16)
                    newMessage.substring(0, 16);
                  valveNickName[i] = "";
                  valveNickName[i] += newMessage;
                  DEBUG_PRINT(F("Recieved new name for zone "));
                  DEBUG_PRINT(i);
                  DEBUG_PRINT(F(" and it is now called: "));
                  DEBUG_PRINTLN(valveNickName[i]);
            if (zoneTimeUpdate)
              DEBUG_PRINTLN(F("New Zone Times Recieved..."));
                if (i != 0)
                  DEBUG_PRINT(F("Zone "));
                  DEBUG_PRINT(i);
                  DEBUG_PRINT(F(" individual time: "));
                  DEBUG_PRINT(valveSoloTime[i]);
                  DEBUG_PRINT(F(" group time: "));
                  DEBUG_PRINTLN(allZoneTime[i]);
            else
              recentUpdate = false;
          void updateDisplay()
            static unsigned long lastUpdateTime;
            static boolean displayToggle = false;
            //static byte toggleCounter = 0;
            static SprinklerStates lastDisplayState;
            if (state != lastDisplayState || millis() - lastUpdateTime >= 3000UL)
              displayToggle = !displayToggle;
              switch (state) {
                case STAND_BY_ALL_OFF:
                  fastClear();
                  if (displayToggle)
                    lcd.print(F("  System Ready "));
                    if (clockUpdating)
                      lcd.write(byte(0));
                    lcd.print(hourFormat12() < 10 ? F(" ") : F(""));
                    lcd.print(hourFormat12());
                    lcd.print(minute() < 10 ? F(":0") : F(":"));
                    lcd.print(minute());
                    lcd.print(isAM() ? F("am") : F("pm"));
                    lcd.print(month() < 10 ? F(" 0") : F(" "));
                    lcd.print(month());
                    lcd.print(day() < 10 ? F("/0") : F("/"));
                    lcd.print(day());
                    lcd.print(F("/"));
                    lcd.print(year() % 100);
                  else
                    lcd.print(F("  Last Watered "));
                    if (clockUpdating)
                      lcd.write(byte(0));
                    lcd.print(dayOfWeek[weekday(lastTimeRun)]);
                    lcd.setCursor(11, 1);
                    lcd.print(month(lastTimeRun) < 10 ? F(" ") : F(""));
                    lcd.print(month(lastTimeRun));
                    lcd.print(day(lastTimeRun) < 10 ? F("/0") : F("/"));
                    lcd.print(day(lastTimeRun));
                  break;
                case RUN_SINGLE_ZONE:
                  fastClear();
                  if (displayToggle)
                    lcd.print(F("Single Zone Mode"));
                    lcd.print(F(" Zone:"));
                    if (valveNumber < 10) lcd.print(F("0"));
                    lcd.print(valveNumber);
                    lcd.print(F(" Active"));
                  else
                    lcd.print(F(" Time Remaining "));
                    if (valveSoloTime[valveNumber] == 0)
                      lcd.print(F(" No Valve Time "));
                    else
                      unsigned long timeRemaining = (valveSoloTime[valveNumber] * 60) - ((millis() - startMillis) / 1000);
                      lcd.print(timeRemaining / 60 < 10 ? "   0" : "   ");
                      lcd.print(timeRemaining / 60);
                      lcd.print("min");
                      lcd.print(timeRemaining % 60 < 10 ? " 0" : " ");
                      lcd.print(timeRemaining % 60);
                      lcd.print("sec  ");
                  break;
                case RUN_ALL_ZONES:
                  fastClear();
                  if (displayToggle)
                    lcd.print(F(" All-Zone  Mode "));
                    lcd.print(F(" Active "));
                  else
                    int timeRemaining = (allZoneTime[valveNumber] * 60) - ((millis() - startMillis) / 1000);
                    lcd.print((timeRemaining / 60) < 10 ? "   0" : "   ");
                    lcd.print("min");
                    lcd.print("sec  ");
                  break;
                case CYCLE_COMPLETE:
                  if (displayToggle)
                    lcd.print(F(" Watering Cycle "));
                    lcd.print(F("    Complete    "));
                  else
                    int totalTimeRan = 0;
                    for (int i = 1; i < NUMBER_OF_VALVES + 1; i++)
                      totalTimeRan += allZoneTime[i];
                    lcd.print(F(" Total Time Run "));
                    lcd.print(totalTimeRan < 10 ? "   0" : "   ");
                    lcd.print(totalTimeRan);
                    lcd.print(" Minutes   ");
              lastUpdateTime = millis();
            lastDisplayState = state;
          void receiveTime(time_t newTime)
            DEBUG_PRINTLN(F("Time value received and updated..."));
            int lastSecond = second();
            int lastMinute = minute();
            int lastHour = hour();
            setTime(newTime);
            if (((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour)) || showTime)
              DEBUG_PRINTLN(F("Clock updated...."));
              DEBUG_PRINT(F("Sensor's time currently set to:"));
              DEBUG_PRINT(hourFormat12() < 10 ? F(" 0") : F(" "));
              DEBUG_PRINT(hourFormat12());
              DEBUG_PRINT(minute() < 10 ? F(":0") : F(":"));
              DEBUG_PRINT(minute());
              DEBUG_PRINTLN(isAM() ? F("am") : F("pm"));
              DEBUG_PRINT(month());
              DEBUG_PRINT(F("/"));
              DEBUG_PRINT(day());
              DEBUG_PRINTLN(year());
              DEBUG_PRINTLN(dayOfWeek[weekday()]);
              showTime = false;
            else
              DEBUG_PRINTLN(F("Sensor's time did NOT need adjustment greater than 1 second."));
          void fastClear()
            lcd.print(F("                "));
            lcd.print(F("                "));
          void updateClock()
            static unsigned long lastVeraGetTime;
            if (millis() - lastVeraGetTime >= 3600000UL) // updates clock time and gets zone times from vera once every hour
              DEBUG_PRINTLN(F("Requesting time and valve data from Gateway..."));
              lcd.write(byte(0));
              clockUpdating = true;
              lastVeraGetTime = millis();
          void saveDateToEEPROM(unsigned long theDate)
            DEBUG_PRINTLN(F("Saving Last Run date"));
            if (gw.loadState(0) != 0xFF)
              gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
            for (int i = 1; i < 5; i++)
              gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
          void goGetValveTimes()
            static unsigned long valveUpdateTime;
            static byte valveIndex = 1;
            if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
              DEBUG_PRINTLN(F("Calling for Valve Data..."));
              lcd.write(byte(1)); //lcd.write(1);
              gw.request(valveIndex, V_VAR1);
              gw.request(valveIndex, V_VAR2);
              gw.request(valveIndex, V_VAR3);
              valveUpdateTime = millis();
              valveIndex++;
              if (valveIndex > NUMBER_OF_VALVES + 1)
                valveIndex = 1;
           Take away the three dots in the bottom.
          Sergio RiusS
          Sergio RiusS
          Sergio Rius
          @Lars65
          As you also use it from Domoticz, your controller notices the changes in valves? I mean, when the IC is cycling through zones, Domoticz correctly changes states or you must refresh the page for it to show?
          L 1 Reply Last reply
          • Sergio RiusS Sergio Rius
            @Lars65
            L
            L
            Lars65
            @Sergio-Rius yes, I can turn them on/off, and the switch is also shifting from on/off.
              @petewill
              exit status 1
              L
              L
              Lars65
              @Sergio-Rius Those can you download from internet. About Liquidcrystal is there a newer version called NewLiquidCrystal, that is also possible to download.
              That one worked for me.
              I deleted all my duplicates, it is anoying when you get those messeges in the arduino ide.
              Also the fatal error you get is ../wire/wire.h.
              seems like you have #include <../Wire/Wire.h
              What happens if you just write #include Wire.h
              • L Lars65
                Sergio RiusS
                Sergio RiusS
                Sergio Rius
                @Lars65
                Thanks. No, I finally made it work.
                I only have to find why my Domoticz don't update the switch status.
                  @petewill
                  exit status 1
                  AWIA
                  AWIA
                  AWI
                  @Sergio-Rius you can change the reference in the display library files. Just remove the path to the wire.h library.
                  • L Lars65
                    May 31, 2015
                    *** Version 2.0
                    PARTS LIST:
                    * NRF24L01 Radio
                    * LED
                    * Push button
                    INSTRUCTIONS:
                    #include <Wire.h>
                    #include <Time.h>
                    #ifdef ACTIVE_LOW
                    #else
                    #ifdef DEBUG_ON
                    #else
                    typedef enum {
                    SprinklerStates;
                    byte menuState = 0;
                    int valveNumber;
                    int lastValve;
                      //delay(5000);
                      lcd.clear();
                      lcd.backlight();
                      delay(500);
                      lcd.write(byte(0));
                        gw.process();
                        delay(1000);
                        lcd.print(".");
                        clockCounter++;
                          lcd.clear();
                          delay(2000);
                          break;
                      lcd.clear();
                        lcd.print(i);
                        DEBUG_PRINT(i);
                          delay(100);
                          delay(100);
                          delay(100);
                      lcd.clear();
                      gw.process();
                      updateClock();
                      updateDisplay();
                      if (buttonPushed)
                          menuState = 0;
                          menuState++;
                            menuState = 0;
                        else
                        slowToggleLED ();
                            delay(50);
                          lcd.clear();
                          lcd.setCursor(0,0);
                          lcd.setCursor(0,1);
                          delay(2000);
                          lastValve = -1;
                            else
                        fastToggleLed();
                          valveNumber = 1;
                        else
                          valveNumber++;
                            lastValve = -1;
                        fastToggleLed();
                            else
                        else
                          fastToggleLed();
                        else
                        displayMenu();
                      lastState = state;
                        lcd.clear();
                        lcd.print(F("."));
                        Serial.print(".");
                        if (menuState == 0)
                          valveNumber = 1;
                        else
                      else
                            else
                              if (i == 0)
                                valveNumber = 1;
                              else
                                valveNumber = i;
                                DEBUG_PRINTLN(i);
                            DEBUG_PRINT(i);
                            DEBUG_PRINT(i);
                              DEBUG_PRINTLN(i);
                              break;
                            DEBUG_PRINT(i);
                      if (zoneTimeUpdate)
                          if (i != 0)
                            DEBUG_PRINT(i);
                      else
                        switch (state) {
                            fastClear();
                            if (displayToggle)
                              if (clockUpdating)
                                lcd.write(byte(0));
                              lcd.print(month());
                              lcd.print(day());
                              lcd.print(F("/"));
                            else
                              if (clockUpdating)
                                lcd.write(byte(0));
                            break;
                            fastClear();
                            if (displayToggle)
                            else
                              else
                                lcd.print("min");
                                lcd.print("sec  ");
                            break;
                          case RUN_ALL_ZONES:
                            fastClear();
                            if (displayToggle)
                            else
                              lcd.print("min");
                              lcd.print("sec  ");
                            break;
                            if (displayToggle)
                            else
                      setTime(newTime);
                        DEBUG_PRINT(day());
                        showTime = false;
                      else
                    void fastClear()
                      lcd.print(F("                "));
                      lcd.print(F("                "));
                    void updateClock()
                        lcd.write(byte(0));
                        valveIndex++;
                          valveIndex = 1;
                    A Former User
                    @Lars65
                    Tried your sketch as well as a few of my own adjustments, still getting
                    Yard_Sprinklers_revised_7-20.ino:85:18: fatal error: Time.h: No such file or directory.
                    At a loss of where I missed this in the library!
                    Rather be riding my scooter! got to get it done!
                    • AWIA AWI
                      Sergio RiusS
                      Sergio RiusS
                      Sergio Rius
                      @AWI
                      I'll try it.
                      @Ngwpower
                      Don't drop the towel. Just install the library from the libraries manager.
                      ? 1 Reply Last reply
                        @AWI
                        I'll try it.
                        @Ngwpower
                        A Former User
                        @Sergio-Rius Really confused found these in AVR libraries on my computer. 0_1469044384924_upload-b0e77311-082b-4d33-9473-c59ef1302d37
                        Am I looking in the wrong place?
                        Thank You for the help!
                        • ? A Former User
                          Sergio RiusS
                          Sergio RiusS
                          Sergio Rius
                          #192
                          @Ngwpower
                          ArduinoIDE Menu->Program->Include Library->Library manager
                          0_1469044814353_upload-bdb3d59c-30bb-4c2e-8345-9aa060d3d67e
                          I'm currently looking at converting the sketch to v2.0
                            A Former User
                            This post is deleted!
                            • PaweMedP
                              PaweMedP
                              PaweMed
                              Hello, is there anyone who can explain to me step by step how to deal with these libraries ? I received this error when compiling :
                              "C:\Users\witkowski.med\Downloads\IrrigationController\IrrigationController\IrrigationController.ino:85:22: fatal error: MySensor.h: No such file or directory
                              exit status 1"
                              I have installed the various library and it doesnt help. My IDE version is 1.6.10.
                              • PaweMedP PaweMed
                                exit status 1"
                                Sergio RiusS
                                Sergio RiusS
                                Sergio Rius
                                @PaweMed
                                If you've done a new installation, perhaps you installed Mysensors libraries from the IDE lib manager. In that case you could have installed v2.0.
                                In the newer version the library has changed to Mysensors.h, please read the documentation carefully as this is not a minor upgrade:
                                https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
                                • PaweMedP
                                  PaweMedP
                                  PaweMed
                                  wrote on last edited by PaweMed
                                  #196
                                  • rechin304R rechin304
                                    Pictures of the case project and how is arranged inside. Not yet on the final location, still testing.
                                    5_1461396298101_IMG_3866.JPG 4_1461396298101_IMG_3865.JPG 3_1461396298101_IMG_3863.JPG 1_1461396298101_IMG_3861.JPG 0_1461396298101_IMG_3860.JPG
                                    k5mapK
                                    k5mapK
                                    k5map
                                    @rechin304 - that's a great case/box. Where did you purchase it?
                                    rechin304R 1 Reply Last reply
                                    • k5mapK k5map
                                      rechin304R
                                      rechin304R
                                      rechin304
                                      @k5map From here http://www.ebay.com/itm/2PCS-Waterproof-Plastic-Cover-Project-Electronic-Case-Enclosure-Box-125-80-32mm-/321803320255?hash=item4aecf8fbbf
                                      • dbemowskD
                                        dbemowskD
                                        I am in the process of building this controller and in reading the comments here where some were asking about a master valve and how to control it. This is the concept that I am going to try with my setup.
                                        I only have 4 zones to control, so with the 8 channel relay board that I have, I am going to use channel 8 as my pump start relay control. The idea is that when any one channel is on, the diodes will activate the master valve, but keep the signal from back-feeding into another relay channel.
                                        Hope that helps some people out there.
                                        • dbemowskD
                                          dbemowskD
                                          #200
                                          So I figured I would share my progress with my version of this project. The majority of the build was done to the schematic from the build section of the site. The only changes I am making are eliminating the use of Q0 on the shift register, and wiring in diodes like I mentioned in my previous post to control my pump start relay using relay channel 8 when any zone is turned on. I may even add a connection for one more digital line for a pump only startup, but will have to see about the code mods to do that.
                                          One of my hurdles that I wanted to overcome was what kind of case I would be building this in. I searched on ebay a bit, but couldn't find what I wanted. I was digging through some old stuff one day and found an old composite video A/V switcher that I no longer use.
                                          A/V switcher front
                                          A/V switcher back
                                          Rather than recycling it, I figured, why not up-cycle it. The case was the perfect size for the 8 channel relay board. I even kept the back portion of the original circuit board to re-use the old DC in jack and build my regulator circuit on using an AMS1117 3.3v regulator. The output of the power board is Ground (black), +5V (red) and +3.3V (yellow).
                                          relay/power boards
                                          AMS1117 regulator
                                          I cut a slot in the front of the case to allow access to the relay connections.
                                          front cutout
                                          The connections came out just enough to allow access to the screw terminals. You can also see the mouning of the LCD, push button and status LED.
                                          screw terminals
                                          main board
                                          I designed the circuit board so that it could plug directly on top of the 8 channel relay board. Notice the header connector strip between the pro mini and the shift register. There is just enough room above the blue 3 input power connector to attach the FTDI cable for programming the pro mini. The last thing I need to add to the board is the 8 diodes to control the pump start relay which will be channel 8 on the relay board. Currently the code uses outputs Q0 thru Q7 of the shift register to control relays 1 thru 8. I will need to make a slight change to the code to use Q1 thru Q7 as the first 7 relays as it was easier to connect it that way to the header connector. I am eliminating the use of Q0 in the circuit.
                                          I am having a few issues with compiling the code to upload to the pro mini. It is telling me that it can't find the LiquidCrystal.h file, and I have the library in my arduino library folder. The folder has both the LiquidCrystal.h and LiquidCrystal_I2C.h files, so I am not sure what is up there. I hope to have it figured out soon so I can test the assembly.
                                          Thanks for reviewing.
