  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 325.2k Views 52 Watching
  • dbemowskD
    dbemowskD
    I am trying to use this controller with Domoticz and I am wondering how to set the valve times. Is there anyone that is using this controller with Domoticz that can help?
    • HuczasH
      HuczasH
      Huczas
      Hi, in original code is written to work with Vera - this is similar to Domoticz. But I same like you have Domoticz on my RPi0. Some time ago I changed some lines in this code that it is working now with Domoticz.
      MySprinkler for MySensors
      Arduino Multi-Zone Sprinkler Control
      May 31, 2015
      *** Version 2.0
      *** Upgraded to http://MySensors.org version 1.4.1
      *** Expanded for up to 16 Valves
      *** Setup for active low relay board or comment out #define ACTIVE_LOW to switch to active high
      *** Switch to bitshift method vs byte arrays
      *** Changed RUN_ALL_ZONES Vera device to 0 (was highest valve)
      *** Added optional LCD display featuring remaining time, date last ran & current time
      *** Features 'raindrop' and 'clock' icons which indicate sensor is updating valve data and clock respectively
      *** Added single pushbutton menu to manually select which program to run (All Zones or a Single Zone)
      *** Added option of naming your Zones programmatically or with Vera (V_VAR3 used to store names)
      Utilizing your Vera home automation controller and the MySensors.org gateway you can
      control up to a sixteen zone irrigation system with only three digital pins.  This sketch
      will create NUMBER_OF_VALVES + 1 devices on your Vera controller
      This sketch features the following:
      * Allows you to cycle through All zones (RUN_ALL_ZONES) or individual zone (RUN_SINGLE_ZONE) control.
      * Use the 0th controller to activate RUN_ALL_ZONES (each zone in numeric sequence 1 to n)
        using Variable1 as the "ON" time in minutes in each of the vera devices created.
      * Use the individual zone controller to activate a single zone.  This feature uses
        Variable2 as the "ON" time for each individual device/zone.
      * Connect according to pinout below and uses Shift Registers as to allow the MySensors
        standard radio configuration and still leave available digital pins
      * Turning on any zone will stop the current process and begin that particular process.
      * Turning off any zone will stop the current process and turn off all zones.
      * To push your new time intervals for your zones, simply change the variable on your Vera and
        your arduino will call to Vera once a minute and update accordingly.  Variables will also be
        requested when the device is first powered on.
      * Pushbutton activation to RUN_ALL_ZONES, RUN_SINGLE_ZONE or halt the current program
      * LED status indicator
      PARTS LIST:
      Available from the MySensors store - http://www.mysensors.org/store/
      * Relays (8 channel)
      * Female Pin Header Connector Strip
      * Prototype Universal Printed Circuit Boards (PCB)
      * NRF24L01 Radio
      * Arduino (I used a Pro Mini)
      * FTDI USB to TTL Serial Adapter
      * Capacitors (10uf and .1uf)
      * 3.3v voltage regulator
      * Resistors (270 & 10K)
      * Female Dupont Cables
      * 1602 LCD (with I2C Interface)
      * LED
      * Push button
      * Shift Register (SN74HC595)
      * 2 Pole 5mm Pitch PCB Mount Screw Terminal Block
      * 3 Pole 5mm Pitch PCB Mount Screw Terminal Block
      * 22-24 gauge wire or similar (I used Cat5/Cat6 cable)
      * 18 gauge wire (for relay)
      * Irrigation Power Supply (24-Volt/750 mA Transformer)
      INSTRUCTIONS:
      * A step-by-step setup video is available here: http://youtu.be/l4GPRTsuHkI
      * After assembling your arduino, radio, decoupling capacitors, shift register(s), status LED, pushbutton LCD (I2C connected to
        A4 and A5) and relays, and load the sketch.
      * Following the instructions at https://MySensors.org include the device to your MySensors Gateway.
      * Verify that each new device has a Variable1, Variable2 and Variable3. Populate data accordingly with whole minutes for
        the RUN_ALL_ZONES routine (Variable1) and the RUN_SINGLE_ZONE routines (Variable 2).  The values entered for times may be zero and
        you may use the defaulet zone names by leaving Variable3 blank.
      * Once you have entered values for each zone and each variable, save the settings by pressing the red save button on your Vera.
      * Restart your arduino; verify the settings are loaded into your arduino with the serial monitor; the array will be printed
        on the serial monitor.
      * Your arduino should slow-flash, indicating that it is in ready mode.
      * There are multiple debug serial prints that can be monitored to assure that it is operating properly.
      * ***THIS SHOULD NO LONGER BE NEEDED*** The standard MySensors library now works. https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
      Contributed by Jim (BulldogLowell@gmail.com) with much contribution from Pete (pete.will@mysensors.org) and is released to the public domain
      #include <Wire.h>
      #include <Time.h>
      #include <LiquidCrystal.h>
      #define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
      #define VALVE_RESET_TIME 7500UL   // Change this (in milliseconds) for the time you need your valves to hydraulically reset and change state
      #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
      #define SKETCH_NAME "MySprinkler"
      #define SKETCH_VERSION "2.0"
      #define CHILD_ID_SPRINKLER 0
      #define ACTIVE_LOW // comment out this line if your relays are active high
      #define DEBUG_ON   // comment out to supress serial monitor output
      #ifdef ACTIVE_LOW
      #define BITSHIFT_VALVE_NUMBER ~(1U << (valveNumber-1))
      #define ALL_VALVES_OFF 0xFFFF
      #else
      #define BITSHIFT_VALVE_NUMBER (1U << (valveNumber-1))
      #define ALL_VALVES_OFF 0U
      #ifdef DEBUG_ON
      #define DEBUG_PRINT(x)   Serial.print(x)
      #define SERIAL_START(x)  Serial.begin(x)
      #else
      typedef enum {
        STAND_BY_ALL_OFF, RUN_SINGLE_ZONE, RUN_ALL_ZONES, CYCLE_COMPLETE, ZONE_SELECT_MENU
      SprinklerStates;
      SprinklerStates state = STAND_BY_ALL_OFF;
      SprinklerStates lastState;
      byte menuState = 0;
      unsigned long menuTimer;
      byte countDownTime = 10;
      int allZoneTime [NUMBER_OF_VALVES + 1];
      int valveSoloTime [NUMBER_OF_VALVES + 1];
      int valveNumber;
      int lastValve;
      unsigned long startMillis;
      const int ledPin = 5;
      const int waterButtonPin = 3;
      boolean buttonPushed = false;
      boolean showTime = true;
      boolean clockUpdating = false;
      boolean recentUpdate = true;
      const char *dayOfWeek[] = {
        "Null", "Sunday ", "Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "
      // Name your Zones here or use Vera to edit them by adding a name in Variable3...
      String valveNickName[17] = {
        "All Zones", "Zone 1", "Podlewanie 1", "Podlewanie 2", "Podlewanie 3", "Podlewanie 4", "Zone 6", "Zone 7", "Zone 8", "Zone 9", "Zone 10", "Zone 11", "Zone 12", "Zone 13", "Zone 14", "Zone 15", "Zone 16"
      time_t lastTimeRun = 0;
      //Setup Shift Register...
      const int latchPin = 8;
      const int clockPin = 4;
      const int dataPin  = 7;
      byte clock[8] = {0x0, 0xe, 0x15, 0x17, 0x11, 0xe, 0x0}; // fetching time indicator
      byte raindrop[8] = {0x4, 0x4, 0xA, 0xA, 0x11, 0xE, 0x0,}; // fetching Valve Data indicator
      // Set the pins on the I2C chip used for LCD connections:
      //                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
      LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
      MyMessage msg1valve(CHILD_ID_SPRINKLER, V_LIGHT);
      MyMessage var1valve(CHILD_ID_SPRINKLER, V_VAR1);
      MyMessage var2valve(CHILD_ID_SPRINKLER, V_VAR2);
        SERIAL_START(115200);
        DEBUG_PRINTLN(F("Initialising..."));
        pinMode(latchPin, OUTPUT);
        pinMode(clockPin, OUTPUT);
        pinMode(dataPin, OUTPUT);
        pinMode(ledPin, OUTPUT);
        pinMode(waterButtonPin, INPUT_PULLUP);
        //pinMode(waterButtonPin, INPUT);
        attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
        digitalWrite (ledPin, HIGH);
        DEBUG_PRINTLN(F("Turning All Valves Off..."));
        updateRelays(ALL_VALVES_OFF);
        //delay(5000);
        lcd.begin(16, 2); //(16 characters and 2 line display)
        lcd.clear();
        lcd.backlight();
        lcd.createChar(0, clock);
        lcd.createChar(1, raindrop);
        //check for saved date in EEPROM
        DEBUG_PRINTLN(F("Checking EEPROM for stored date:"));
        delay(500);
        if (gw.loadState(0) == 0xFF); // EEPROM flag
          DEBUG_PRINTLN(F("Retreiving last run time from EEPROM..."));
          for (int i = 0; i < 4 ; i++)
            lastTimeRun = lastTimeRun << 8;
            lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
        gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
        gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
        for (byte i = 0; i <= NUMBER_OF_VALVES; i++)
          gw.present(i, S_LIGHT);
        DEBUG_PRINTLN(F("Sensor Presentation Complete"));
        digitalWrite (ledPin, LOW);
        DEBUG_PRINTLN(F("Ready..."));
        lcd.setCursor(0, 0);
        lcd.print(F(" Syncing Time  "));
        lcd.setCursor(15, 0);
        lcd.write(byte(0));
        lcd.setCursor(0, 1);
        int clockCounter = 0;
        while (timeStatus() == timeNotSet && clockCounter < 21)
          gw.process();
          gw.requestTime(receiveTime);
          DEBUG_PRINTLN(F("Requesting time from Gateway:"));
          delay(1000);
          lcd.print(".");
          clockCounter++;
          if (clockCounter > 16)
            DEBUG_PRINTLN(F("Failed initial clock synchronization!"));
            lcd.clear();
            lcd.print(F("  Failed Clock  "));
            lcd.print(F(" Syncronization "));
            delay(2000);
            break;
        lcd.clear();
        //Update valve data when first powered on
          lcd.print(F(" Updating  "));
          lcd.print(F(" Valve Data: "));
          lcd.print(i);
          boolean flashIcon = false;
          DEBUG_PRINT(F("Calling for Valve "));
          DEBUG_PRINT(i);
          DEBUG_PRINTLN(F(" Data..."));
          while (gw.process() == false)
            flashIcon = !flashIcon;
            flashIcon ? lcd.write(byte(1)) : lcd.print(F(" "));
            gw.request(i, V_VAR1);
            delay(100);
            gw.request(i, V_VAR2);
            delay(100);
            gw.request(i, V_VAR3);
            delay(100);
        lcd.clear();
        gw.process();
        updateClock();
        updateDisplay();
        goGetValveTimes();
        if (buttonPushed)
          menuTimer = millis();
          DEBUG_PRINTLN(F("Button Pressed"));
          if (state == STAND_BY_ALL_OFF)
            state = ZONE_SELECT_MENU;
            menuState = 0;
          else if (state == ZONE_SELECT_MENU)
            menuState++;
            if (menuState > NUMBER_OF_VALVES)
              menuState = 0;
          else
          slowToggleLED ();
          if (state != lastState)
            DEBUG_PRINTLN(F("State Changed... all Zones off"));
              delay(50);
              gw.send(msg1valve.setSensor(i).set(false), false);
            lcd.clear();
            lcd.setCursor(0,0);
            lcd.print(F("** Irrigation **"));
            lcd.setCursor(0,1);
            lcd.print(F("**   Halted   **"));
            delay(2000);
            lastValve = -1;
        else if (state == RUN_ALL_ZONES)
          if (lastValve != valveNumber)
              if (i == 0 || i == valveNumber)
                gw.send(msg1valve.setSensor(i).set(true), false);
              else
          lastValve = valveNumber;
          fastToggleLed();
            valveNumber = 1;
            DEBUG_PRINTLN(F("State Changed, Running All Zones..."));
          unsigned long nowMillis = millis();
          if (nowMillis - startMillis < VALVE_RESET_TIME)
          else if (nowMillis - startMillis < (allZoneTime[valveNumber] * 60000UL))
            updateRelays(BITSHIFT_VALVE_NUMBER);
          else
            DEBUG_PRINTLN(F("Changing Valves..."));
            startMillis = millis();
            valveNumber++;
            if (valveNumber > NUMBER_OF_VALVES)
              state = CYCLE_COMPLETE;
              lastValve = -1;
              lastTimeRun = now();
              saveDateToEEPROM(lastTimeRun);
              DEBUG_PRINT(F("State = "));
              DEBUG_PRINTLN(state);
        else if (state == RUN_SINGLE_ZONE)
          fastToggleLed();
              else
            DEBUG_PRINTLN(F("State Changed, Single Zone Running..."));
            DEBUG_PRINT(F("Zone: "));
            DEBUG_PRINTLN(valveNumber);
          else if (nowMillis - startMillis < (valveSoloTime [valveNumber] * 60000UL))
          else
        else if (state == CYCLE_COMPLETE)
          if (millis() - startMillis < 30000UL)
            fastToggleLed();
          else
        else if (state = ZONE_SELECT_MENU)
          displayMenu();
        lastState = state;
      void displayMenu(void)
        static byte lastMenuState = -1;
        static int lastSecond;
        if (menuState != lastMenuState)
          lcd.clear();
          lcd.print(valveNickName[menuState]);
          lcd.print(F("Starting"));
          DEBUG_PRINT(valveNickName[menuState]);
          Serial.print(F(" Starting Shortly"));
        int thisSecond = (millis() - menuTimer) / 1000UL;
        if (thisSecond != lastSecond && thisSecond < 8)
          lcd.print(F("."));
          Serial.print(".");
        lastSecond = thisSecond;
        if (millis() - menuTimer > 10000UL)
          if (menuState == 0)
            valveNumber = 1;
            state = RUN_ALL_ZONES;
          else
            valveNumber = menuState;
            state = RUN_SINGLE_ZONE;
        else
        lastMenuState = menuState;
      void updateRelays(int value)
        digitalWrite(latchPin, LOW);
        shiftOut(dataPin, clockPin, MSBFIRST, highByte(value));
        shiftOut(dataPin, clockPin, MSBFIRST, lowByte(value));
        digitalWrite(latchPin, HIGH);
      void PushButton() //interrupt with debounce
        static unsigned long last_interrupt_time = 0;
        unsigned long interrupt_time = millis();
        if (interrupt_time - last_interrupt_time > 200)
          buttonPushed = true;
        last_interrupt_time = interrupt_time;
      void fastToggleLed()
        static unsigned long fastLedTimer;
        if (millis() - fastLedTimer >= 100UL)
          digitalWrite(ledPin, !digitalRead(ledPin));
          fastLedTimer = millis ();
      void slowToggleLED ()
        static unsigned long slowLedTimer;
        if (millis() - slowLedTimer >= 1250UL)
          slowLedTimer = millis ();
      void getVariables(const MyMessage &message)
        boolean zoneTimeUpdate = false;
        if (message.isAck())
          DEBUG_PRINTLN(F("This is an ack from gateway"));
          if (message.sensor == i)
            if (message.type == V_LIGHT)
              int switchState = atoi(message.data);
              if (switchState == 0)
                DEBUG_PRINTLN(F("Recieved Instruction to Cancel..."));
              else
                if (i == 0)
                  valveNumber = 1;
                  DEBUG_PRINTLN(F("Recieved Instruction to Run All Zones..."));
                else
                  valveNumber = i;
                  DEBUG_PRINT(F("Recieved Instruction to Activate Zone: "));
                  DEBUG_PRINTLN(i);
            else if (message.type == V_VAR1)
              int variable1 = 15; // atoi(message.data);// RUN_ALL_ZONES time
              DEBUG_PRINT(F("Recieved variable1 valve:"));
              DEBUG_PRINT(i);
              DEBUG_PRINT(F(" = "));
              DEBUG_PRINTLN(variable1);
              if (variable1 != allZoneTime[i])
                allZoneTime[i] = variable1;
                zoneTimeUpdate = true;
            else if (message.type == V_VAR2)
              int variable2 = 10; //atoi(message.data);// RUN_SINGLE_ZONE time
              DEBUG_PRINT(F("Recieved variable2 valve:"));
              DEBUG_PRINT(i);
              DEBUG_PRINTLN(variable2);
              if (variable2 != valveSoloTime[i])
                valveSoloTime[i] = variable2;
            else if (message.type == V_VAR3)
              String newMessage = String(message.data);
              if (newMessage.length() == 0)
                DEBUG_PRINT(F("No Name Recieved for zone "));
                DEBUG_PRINTLN(i);
                break;
              if (newMessage.length() > 16)
                newMessage.substring(0, 16);
              valveNickName[i] = "";
              valveNickName[i] += newMessage;
              DEBUG_PRINT(F("Recieved new name for zone "));
              DEBUG_PRINT(i);
              DEBUG_PRINT(F(" and it is now called: "));
              DEBUG_PRINTLN(valveNickName[i]);
        if (zoneTimeUpdate)
          DEBUG_PRINTLN(F("New Zone Times Recieved..."));
            if (i != 0)
              DEBUG_PRINT(F("Zone "));
              DEBUG_PRINT(i);
              DEBUG_PRINT(F(" individual time: "));
              DEBUG_PRINT(valveSoloTime[i]);
              DEBUG_PRINT(F(" group time: "));
              DEBUG_PRINTLN(allZoneTime[i]);
        else
          recentUpdate = false;
      void updateDisplay()
        static unsigned long lastUpdateTime;
        static boolean displayToggle = false;
        //static byte toggleCounter = 0;
        static SprinklerStates lastDisplayState;
        if (state != lastDisplayState || millis() - lastUpdateTime >= 3000UL)
          displayToggle = !displayToggle;
          switch (state) {
            case STAND_BY_ALL_OFF:
              fastClear();
              if (displayToggle)
                lcd.print(F("  System Ready "));
                if (clockUpdating)
                  lcd.write(byte(0));
                lcd.print(hour() < 10 ? F(" ") : F(""));
                lcd.print(hour());
                lcd.print(minute() < 10 ? F(":0") : F(":"));
                lcd.print(minute());
                //lcd.print(isAM() ? F("am") : F("pm"));
                lcd.setCursor(7, 1);
                lcd.print(day() < 10 ? F(" 0") : F(" "));
                lcd.print(day());
                lcd.print(month() < 10 ? F("/0") : F("/"));
                lcd.print(month());
                lcd.print(F("/"));
                lcd.print(year() % 100);
              else
                lcd.print(F("  Last Watered "));
                if (clockUpdating)
                  lcd.write(byte(0));
                lcd.print(dayOfWeek[weekday(lastTimeRun)]);
                lcd.setCursor(10, 1);
                lcd.print(day(lastTimeRun) < 10 ? F(" 0") : F(""));
                lcd.print(day(lastTimeRun));
                lcd.print(month(lastTimeRun) < 10 ? F("/0") : F("/"));
                lcd.print(month(lastTimeRun));
              break;
            case RUN_SINGLE_ZONE:
              fastClear();
              if (displayToggle)
                lcd.print(F("Single Zone Mode"));
                lcd.print(F(" Zone:"));
                if (valveNumber < 10) lcd.print(F("0"));
                lcd.print(valveNumber);
                lcd.print(F(" Active"));
              else
                lcd.print(F(" Time Remaining "));
                if (valveSoloTime[valveNumber] == 0)
                  lcd.print(F(" No Valve Time "));
                else
                  unsigned long timeRemaining = (valveSoloTime[valveNumber] * 60) - ((millis() - startMillis) / 1000);
                  lcd.print(timeRemaining / 60 < 10 ? "   0" : "   ");
                  lcd.print(timeRemaining / 60);
                  lcd.print("min");
                  lcd.print(timeRemaining % 60 < 10 ? " 0" : " ");
                  lcd.print(timeRemaining % 60);
                  lcd.print("sec  ");
              break;
            case RUN_ALL_ZONES:
              fastClear();
              if (displayToggle)
                lcd.print(F(" All-Zone  Mode "));
                lcd.print(F(" Active "));
              else
                int timeRemaining = (allZoneTime[valveNumber] * 60) - ((millis() - startMillis) / 1000);
                lcd.print((timeRemaining / 60) < 10 ? "   0" : "   ");
                lcd.print("min");
                lcd.print("sec  ");
              break;
            case CYCLE_COMPLETE:
              if (displayToggle)
                lcd.print(F(" Watering Cycle "));
                lcd.print(F("    Complete    "));
              else
                int totalTimeRan = 0;
                for (int i = 1; i < NUMBER_OF_VALVES + 1; i++)
                  totalTimeRan += allZoneTime[i];
                lcd.print(F(" Total Time Run "));
                lcd.print(totalTimeRan < 10 ? "   0" : "   ");
                lcd.print(totalTimeRan);
                lcd.print(" Minutes   ");
          lastUpdateTime = millis();
        lastDisplayState = state;
      void receiveTime(time_t newTime)
        DEBUG_PRINTLN(F("Time value received and updated..."));
        int lastSecond = second();
        int lastMinute = minute();
        int lastHour = hour();
        setTime(newTime);
        if (((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour)) || showTime)
          DEBUG_PRINTLN(F("Clock updated...."));
          DEBUG_PRINT(F("Sensor's time currently set to:"));
          DEBUG_PRINT(hourFormat12() < 10 ? F(" 0") : F(" "));
          DEBUG_PRINT(hourFormat12());
          DEBUG_PRINT(minute() < 10 ? F(":0") : F(":"));
          DEBUG_PRINT(minute());
          DEBUG_PRINTLN(isAM() ? F("am") : F("pm"));
          DEBUG_PRINT(month());
          DEBUG_PRINT(F("/"));
          DEBUG_PRINT(day());
          DEBUG_PRINTLN(year());
          DEBUG_PRINTLN(dayOfWeek[weekday()]);
          showTime = false;
        else
          DEBUG_PRINTLN(F("Sensor's time did NOT need adjustment greater than 1 second."));
      void fastClear()
        lcd.print(F("                "));
        lcd.print(F("                "));
      void updateClock()
        static unsigned long lastVeraGetTime;
        if (millis() - lastVeraGetTime >= 3600000UL) // updates clock time and gets zone times from vera once every hour
          DEBUG_PRINTLN(F("Requesting time and valve data from Gateway..."));
          lcd.write(byte(0));
          clockUpdating = true;
          lastVeraGetTime = millis();
      void saveDateToEEPROM(unsigned long theDate)
        DEBUG_PRINTLN(F("Saving Last Run date"));
        if (gw.loadState(0) != 0xFF)
          gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
        for (int i = 1; i < 5; i++)
          gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
      void goGetValveTimes()
        static unsigned long valveUpdateTime;
        static byte valveIndex = 1;
        if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
          DEBUG_PRINTLN(F("Calling for Valve Data..."));
          lcd.write(byte(1)); //lcd.write(1);
          gw.request(valveIndex, V_VAR1);
          gw.request(valveIndex, V_VAR2);
          gw.request(valveIndex, V_VAR3);
          valveUpdateTime = millis();
          valveIndex++;
          if (valveIndex > NUMBER_OF_VALVES + 1)
            valveIndex = 1;
      Ok, originally time - how long relay is triggered was downloaded from Vera, I commented out this two lines and specify time there. When you power on arduino - program is trying to connect to Vera and download all data but it obviously fail at it. After a while it's just get date and time from Domoticz. So no names of zones or how long water them. All is hard coded in Arduino.
      Now there is 15 minutes if you trigger all zones and 10 minutes if you choose specific single zone.
      If you want change it you need burn it again on Arduino - so it is not the best solution, but it works :) And it is about 1 week with testing all with laptop and FTDI connected to this controller. After that - you can leave it forever.
      PS, also I changed date and time - it is 24h and DD/MM/YY - so more European friendly :)
      dbemowskD 1 Reply Last reply
      • HuczasH Huczas
        May 31, 2015
        *** Version 2.0
        PARTS LIST:
        * NRF24L01 Radio
        * LED
        * Push button
        INSTRUCTIONS:
        #include <Wire.h>
        #include <Time.h>
        #ifdef ACTIVE_LOW
        #else
        #ifdef DEBUG_ON
        #else
        typedef enum {
        SprinklerStates;
        byte menuState = 0;
        int valveNumber;
        int lastValve;
          //delay(5000);
          lcd.clear();
          lcd.backlight();
          delay(500);
          lcd.write(byte(0));
            gw.process();
            delay(1000);
            lcd.print(".");
            clockCounter++;
              lcd.clear();
              delay(2000);
              break;
          lcd.clear();
            lcd.print(i);
            DEBUG_PRINT(i);
              delay(100);
              delay(100);
              delay(100);
          lcd.clear();
          gw.process();
          updateClock();
          updateDisplay();
          goGetValveTimes();
          if (buttonPushed)
              menuState = 0;
              menuState++;
                menuState = 0;
            else
            slowToggleLED ();
                delay(50);
              lcd.clear();
              lcd.setCursor(0,0);
              lcd.setCursor(0,1);
              delay(2000);
              lastValve = -1;
                else
            fastToggleLed();
              valveNumber = 1;
            else
              valveNumber++;
                lastValve = -1;
            fastToggleLed();
                else
            else
              fastToggleLed();
            else
            displayMenu();
          lastState = state;
            lcd.clear();
            lcd.print(F("."));
            Serial.print(".");
            if (menuState == 0)
              valveNumber = 1;
            else
          else
                else
                  if (i == 0)
                    valveNumber = 1;
                  else
                    valveNumber = i;
                    DEBUG_PRINTLN(i);
                DEBUG_PRINT(i);
                DEBUG_PRINT(i);
                  DEBUG_PRINTLN(i);
                  break;
                DEBUG_PRINT(i);
          if (zoneTimeUpdate)
              if (i != 0)
                DEBUG_PRINT(i);
          else
            switch (state) {
                fastClear();
                if (displayToggle)
                  if (clockUpdating)
                    lcd.write(byte(0));
                  lcd.print(hour());
                  lcd.print(day());
                  lcd.print(month());
                  lcd.print(F("/"));
                else
                  if (clockUpdating)
                    lcd.write(byte(0));
                break;
                fastClear();
                if (displayToggle)
                else
                  else
                    lcd.print("min");
                    lcd.print("sec  ");
                break;
              case RUN_ALL_ZONES:
                fastClear();
                if (displayToggle)
                else
                  lcd.print("min");
                  lcd.print("sec  ");
                break;
                if (displayToggle)
                else
          setTime(newTime);
            DEBUG_PRINT(day());
            showTime = false;
          else
        void fastClear()
          lcd.print(F("                "));
          lcd.print(F("                "));
        void updateClock()
            lcd.write(byte(0));
            valveIndex++;
              valveIndex = 1;
        dbemowskD
        dbemowskD
        @Huczas One of the main things I wanted with this project was the ability to change the watering times in the automation software using a script. If I have to reprogram the arduino every time I want to change a time it seems pointless . I am looking into a few ideas with this to make it work in Domoticz. If I come up with something, it is most likely going to be a hack workaround.
        I have a post also in the Domoticz forum on a more generalized solution that would cover this situation. Seems though that this is something that the Domoticz team will need to implement. Hopefully I can figure out some kind of workaround to get this going for now.
        HuczasH 1 Reply Last reply
        • dbemowskD dbemowsk
          HuczasH
          HuczasH
          Huczas
          @dbemowsk Hmm if you set 1 hour or more and start watering in Domoticz, then you can manually (or by script) turn off wathering during that time - this is my simple solution to your problem :)
          But remember - RPi isn't that reliable for me, it can freeze and then you get swamp instead of nice grass.
          • HuczasH Huczas
            dbemowskD
            dbemowskD
            @Huczas That is all the more reason to have it on the sprinkler controller node. I am trying what I think might be a workable solution. I need to do more testing with it tonight to see if it's going to work, but I think it will. Once I test it I will post my code.
            Sergio RiusS 1 Reply Last reply
              Sergio RiusS
              Sergio RiusS
              Sergio Rius
              @dbemowsk
              While domoticz devs implement a way of better managing variables, perhaps you can implement a text sensor in the sketch and use it like a "times array". You could then populate it from Domoticz and send to the node as it was some text to show on a display.
              I was porting this sketch to mysensors v2 but the changes on this version are so deep that I discarded it.
              • Sergio RiusS Sergio Rius
                @dbemowsk
                dbemowskD
                dbemowskD
                @Sergio-Rius That is the exact thing I am working on. In Domoticz it shows up as devices, but I can live with that for now until they can do something.
                • Mark JeffordM
                  Mark JeffordM
                  Mark Jefford
                  domoticz i don't think have plans to support this, they took out the ability to use free text variables.
                  I plan on doing 1 minute cycles for irrigation and using a moisture sensor to evaluate how much longer the cycles need to run for.
                  Sergio RiusS petewillP dbemowskD 3 Replies Last reply
                  • Mark JeffordM Mark Jefford
                    Sergio RiusS
                    Sergio RiusS
                    Sergio Rius
                    @Mark-Jefford
                    DOH! :weary:
                      petewillP
                      petewillP
                      petewill
                      :( that's unfortunate. Do they have any other way to store and retrieve variables? Has anyone reached out to them with this need?
                        dbemowskD
                        dbemowskD
                        Can you elaborate a little more? What do you mean when you say free text variables?
                        • Sergio RiusS
                          Sergio RiusS
                          Sergio Rius
                          Now that I read it twice... Just see that I writed "text sensor" not text or custom variables. That was what I first thought as a solution when I read about the the custom variable sending was dropped.
                          And yes, it's so unfortunate that Domoticz doesn't foresees the need to have "intelligent" nodes. That's so limiting. I would like to build, for example, a garage door opener or a central heating controller. Those things must continue working even if domoticz loses connection. And they must have standalone routines that must be preconfigured without being a programmer.
                          What if someone wants to sell an easy to use kit? In my language we say this is "andar con burreras", walking the path with those flaps horses and donkeys wear so they can't see sidewise.
                            dbemowskD
                            dbemowskD
                            I agree. That's a big part of automation.
                            • dbemowskD
                              dbemowskD
                              I am very close to having this working. The hardest part so far is sorting out all the text devices in Domoticz. I needed to use JSON calls to set the data for each of the text devices, but once they are set I shouldn't have to change them. But being JSON calls I should be able to easily change them with a script if needed.
                              So I have the node present S_INFO devices for each of the 3 variables (all zones time, individual zone time, and zone name). I have 4 zones, so that presents 12 new devices to Domoticz. I have set zone names and they display correctly on the irrigation controller, I just need to figure out some of the zone time variables and what devices they are attached to.
                              I should have this working in the next couple days and once I get it I will post the code with some notes on configuring it all.
                              • PierreStP
                                PierreStP
                                PierreSt
                                Just an idea I was considering for my project, but haven't got around implementing yet so I don't know how viable it is.
                                Wouldn't it be possible to use a S_Dimmer type of device instead of an S_Light?
                                That way you can set the "dimmer" value in the UI between 0-100, and use this as the minutes in the sketch (I doubt I will water any part of my garden more than 100 mn). Granted it does not allow to have 2 different settings for manual and automatic, but I don't see this as a real limitation (actually, S_Dimmer also has a V_Watt variable, so theoretically you could also use that one).
                                • dbemowskD
                                  dbemowskD
                                  So I think I have this figured out.One of the things that I had to contend with was running out of memory on my 5V Pro Mini 328. To fix this I had to comment out and shorten some of the DEBUG PRINTLN statements which didn't impede functionality.
                                  The key to making this work is presenting 3 new sensors for each zone. The sensors are S_INFO sensors that use V_TEXT variables. Because these are new to 2.0 and our sketch is for 1.5, we need to define them to be able to use them.
                                  const int V_TEXT = 47;
                                  // new S_INFO sensor type (development 20150905)
                                  const int S_INFO = 36 ;
                                  Here is how I present the new sensors. The S_LIGHT sensor is the valve control. The next 3 S_INFO sensors are the replacements for V_VAR1 - V_VAR3. They are defined as follows;
                                  All zones time
                                  Individual zone time
                                  Zone display name
                                      gw.present((i * 4), S_LIGHT);
                                      gw.present(((i * 4) + 1), S_INFO);
                                      gw.present(((i * 4) + 2), S_INFO);
                                      gw.present(((i * 4) + 3), S_INFO);
                                  The hardest part in this was figuring out the V_TEXT values on the Domoticz side. What I found was the easiest was to set each to a numeric value from 1 to whatever number of sensors are presented. To set the values type this into the address bar of your web browser:
                                  http://{your_domoticz_ip_address}:8080/json.htm?type=command&param=udevice&idx=41&nvalue=0&svalue=1
                                  Replace the 41 in idx=41 wit the idx value in the setup>devices list, and change the 1 in svalue=1 to the number next number. Once those are set, start all zones using the button on the controller. You will see one of the numbers on the display. Match that number with it's index (idx) value and re-run the above json command changing the idx to the matched index, and the svalue to the name of the zone:
                                  http://{your_domoticz_ip_address}:8080/json.htm?type=command&param=udevice&idx=36&nvalue=0&svalue=Run all zones
                                  Repeat this for all zone names. Then repeat the process by letting a zone start and matching a zone time to it's index. That is the reason for setting each V_TEXT variable to a unique number. When testing each zone on an "All Zones" run, it is best to find the first zone and set the time to 1 minute. Then run "All Zones" again and let the first zone run its 1 minute to hit the zone 2 time. Continue this through all zones changing the Domoticz names and values for each to identify them all.
                                  I have not been able to fully test this as my controller is set up slightly different than the one presented. I have done the steps above and have all of that set, but my zone 1 is my master valve, and zones 2 through 5 are my zones 1 through 4. Because of this I need to figure out the changes in my sketch. If someone can test this as I have it so far, that would help. Once I know this works, I will make my needed changes.
                                  Here is the complete modified sketch:
                                  May 31, 2015
                                  *** Version 2.0
                                  PARTS LIST:
                                  * NRF24L01 Radio
                                  * LED
                                  * Push button
                                  INSTRUCTIONS:
                                  #include <Wire.h>
                                  #include <Time.h>
                                  #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
                                  #define CHILD_ID_SPRINKLER_ALL 1
                                  #define CHILD_ID_SPRINKLER_IND 2
                                  #ifdef ACTIVE_LOW
                                  #else
                                  #ifdef DEBUG_ON
                                  #else
                                  // new V_TEXT variable type (development 20150905)
                                  typedef enum {
                                  SprinklerStates;
                                  byte menuState = 0;
                                  int valveNumber;
                                  int lastValve;
                                    "All Zones", "Zone 1", "Zone 2", "Zone 3", "Zone 4", "Zone 5", "Zone 6", "Zone 7", "Zone 8", "Zone 9", "Zone 10", "Zone 11", "Zone 12", "Zone 13", "Zone 14", "Zone 15", "Zone 16"
                                  LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                                  MyMessage var1valve(CHILD_ID_SPRINKLER_ALL, V_TEXT);
                                  MyMessage var2valve(CHILD_ID_SPRINKLER_IND, V_TEXT);
                                  bool receivedInitialValue = false;
                                    //delay(5000);
                                    lcd.clear();
                                    lcd.backlight();
                                    //DEBUG_PRINTLN(F("Checking EEPROM for stored date:"));
                                    delay(500);
                                      //``DEBUG_PRINTLN(F("Retreiving last run time from EEPROM..."));
                                    DEBUG_PRINTLN(F("Presentation Complete"));
                                    lcd.write(byte(0));
                                      gw.process();
                                      DEBUG_PRINTLN(F("Requesting time:"));
                                      delay(1000);
                                      lcd.print(".");
                                      clockCounter++;
                                        DEBUG_PRINTLN(F("Failed synchronization!"));
                                        lcd.clear();
                                        delay(2000);
                                        break;
                                    lcd.clear();
                                      lcd.print(i);
                                      DEBUG_PRINT(i);
                                        gw.request((i * 4) + 1, V_TEXT);
                                        delay(100);
                                        gw.request((i * 4) + 2, V_TEXT);
                                        delay(100);
                                        gw.request((i * 4) + 3, V_TEXT);
                                        delay(100);
                                    lcd.clear();
                                    gw.process();
                                    updateClock();
                                    updateDisplay();
                                    goGetValveTimes();
                                    if (buttonPushed)
                                        menuState = 0;
                                        menuState++;
                                          menuState = 0;
                                      else
                                      slowToggleLED ();
                                        DEBUG_PRINTLN(F("State all Zones off"));
                                          delay(50);
                                          gw.send(msg1valve.setSensor(i * 4).set(false), false);
                                        lcd.clear();
                                        lcd.setCursor(0,0);
                                        lcd.setCursor(0,1);
                                        delay(2000);
                                        lastValve = -1;
                                            gw.send(msg1valve.setSensor(i * 4).set(true), false);
                                          else
                                      fastToggleLed();
                                        valveNumber = 1;
                                      else
                                        valveNumber++;
                                          lastValve = -1;
                                      fastToggleLed();
                                          else
                                      else
                                        fastToggleLed();
                                      else
                                      displayMenu();
                                    lastState = state;
                                      lcd.clear();
                                      lcd.print(F("."));
                                      Serial.print(".");
                                      if (menuState == 0)
                                        valveNumber = 1;
                                      else
                                    else
                                      if (message.sensor == (i * 4))
                                          else
                                            if (i == 0)
                                              valveNumber = 1;
                                            else
                                              valveNumber = i;
                                              DEBUG_PRINTLN(i);
                                      if (message.sensor == ((i * 4) + 1))
                                        if (message.type == V_TEXT)
                                          int variable1 = atoi(message.data);// RUN_ALL_ZONES time
                                          DEBUG_PRINT(i);
                                      if (message.sensor == ((i * 4) + 2))
                                          int variable2 = atoi(message.data);// RUN_SINGLE_ZONE time
                                          DEBUG_PRINT(i);
                                      if (message.sensor == ((i * 4) + 3))
                                            DEBUG_PRINT(F("No Name for "));
                                            DEBUG_PRINTLN(i);
                                            break;
                                          DEBUG_PRINT(F("Recieved name "));
                                          DEBUG_PRINT(i);
                                          DEBUG_PRINT(F(" called: "));
                                        receivedInitialValue = true;
                                    if (zoneTimeUpdate)
                                      DEBUG_PRINTLN(F("New Zone Times..."));
                                        if (i != 0)
                                          DEBUG_PRINT(i);
                                    else
                                      switch (state) {
                                          fastClear();
                                          if (displayToggle)
                                            if (clockUpdating)
                                              lcd.write(byte(0));
                                            lcd.print(hourFormat12() < 10 ? F(" ") : F(""));
                                            lcd.print(hourFormat12());
                                            lcd.print(month() < 10 ? F(" 0") : F(" "));
                                            lcd.print(month());
                                            lcd.print(day() < 10 ? F("/0") : F("/"));
                                            lcd.print(day());
                                            lcd.print(F("/"));
                                          else
                                            if (clockUpdating)
                                              lcd.write(byte(0));
                                            lcd.setCursor(11, 1);
                                            lcd.print(month(lastTimeRun) < 10 ? F(" ") : F(""));
                                            lcd.print(day(lastTimeRun) < 10 ? F("/0") : F("/"));
                                          break;
                                          fastClear();
                                          if (displayToggle)
                                          else
                                            else
                                              lcd.print("min");
                                              lcd.print("sec  ");
                                          break;
                                        case RUN_ALL_ZONES:
                                          fastClear();
                                          if (displayToggle)
                                          else
                                            lcd.print("min");
                                            lcd.print("sec  ");
                                          break;
                                          if (displayToggle)
                                          else
                                            for (int i = 1; i <= NUMBER_OF_VALVES + 1; i++)
                                    setTime(newTime);
                                      DEBUG_PRINT(day());
                                      showTime = false;
                                    else
                                  void fastClear()
                                    lcd.print(F("                "));
                                    lcd.print(F("                "));
                                  void updateClock()
                                      lcd.write(byte(0));
                                      gw.request((valveIndex * 4) + 1, V_TEXT);
                                      gw.request((valveIndex * 4) + 2, V_TEXT);
                                      gw.request((valveIndex * 4) + 3, V_TEXT);
                                      valveIndex++;
                                        valveIndex = 1;
                                  Curious to see how this works for people.
                                  Sergio RiusS AWIA 2 Replies Last reply
                                    All zones time
                                    Zone display name
                                    May 31, 2015
                                    *** Version 2.0
                                    PARTS LIST:
                                    * NRF24L01 Radio
                                    * LED
                                    * Push button
                                    INSTRUCTIONS:
                                    #include <Wire.h>
                                    #include <Time.h>
                                    #ifdef ACTIVE_LOW
                                    #else
                                    #ifdef DEBUG_ON
                                    #else
                                    typedef enum {
                                    SprinklerStates;
                                    byte menuState = 0;
                                    int valveNumber;
                                    int lastValve;
                                      //delay(5000);
                                      lcd.clear();
                                      lcd.backlight();
                                      delay(500);
                                      lcd.write(byte(0));
                                        gw.process();
                                        delay(1000);
                                        lcd.print(".");
                                        clockCounter++;
                                          lcd.clear();
                                          delay(2000);
                                          break;
                                      lcd.clear();
                                        lcd.print(i);
                                        DEBUG_PRINT(i);
                                          delay(100);
                                          delay(100);
                                          delay(100);
                                      lcd.clear();
                                      gw.process();
                                      updateClock();
                                      updateDisplay();
                                      goGetValveTimes();
                                      if (buttonPushed)
                                          menuState = 0;
                                          menuState++;
                                            menuState = 0;
                                        else
                                        slowToggleLED ();
                                            delay(50);
                                          lcd.clear();
                                          lcd.setCursor(0,0);
                                          lcd.setCursor(0,1);
                                          delay(2000);
                                          lastValve = -1;
                                            else
                                        fastToggleLed();
                                          valveNumber = 1;
                                        else
                                          valveNumber++;
                                            lastValve = -1;
                                        fastToggleLed();
                                            else
                                        else
                                          fastToggleLed();
                                        else
                                        displayMenu();
                                      lastState = state;
                                        lcd.clear();
                                        lcd.print(F("."));
                                        Serial.print(".");
                                        if (menuState == 0)
                                          valveNumber = 1;
                                        else
                                      else
                                            else
                                              if (i == 0)
                                                valveNumber = 1;
                                              else
                                                valveNumber = i;
                                                DEBUG_PRINTLN(i);
                                            DEBUG_PRINT(i);
                                            DEBUG_PRINT(i);
                                              DEBUG_PRINTLN(i);
                                              break;
                                            DEBUG_PRINT(i);
                                      if (zoneTimeUpdate)
                                          if (i != 0)
                                            DEBUG_PRINT(i);
                                      else
                                        switch (state) {
                                            fastClear();
                                            if (displayToggle)
                                              if (clockUpdating)
                                                lcd.write(byte(0));
                                              lcd.print(month());
                                              lcd.print(day());
                                              lcd.print(F("/"));
                                            else
                                              if (clockUpdating)
                                                lcd.write(byte(0));
                                            break;
                                            fastClear();
                                            if (displayToggle)
                                            else
                                              else
                                                lcd.print("min");
                                                lcd.print("sec  ");
                                            break;
                                          case RUN_ALL_ZONES:
                                            fastClear();
                                            if (displayToggle)
                                            else
                                              lcd.print("min");
                                              lcd.print("sec  ");
                                            break;
                                            if (displayToggle)
                                            else
                                      setTime(newTime);
                                        DEBUG_PRINT(day());
                                        showTime = false;
                                      else
                                    void fastClear()
                                      lcd.print(F("                "));
                                      lcd.print(F("                "));
                                    void updateClock()
                                        lcd.write(byte(0));
                                        valveIndex++;
                                          valveIndex = 1;
                                    Sergio RiusS
                                    Sergio RiusS
                                    Sergio Rius
                                    @dbemowsk
                                    Just a hint on memory: Why creating three sensors for each valve? Why not creating a unique sensor with array contents for all valves? ;)
                                      @dbemowsk
                                      dbemowskD
                                      dbemowskD
                                      @Sergio-Rius I hadn't thought of the array. I've never dealt with a S_INFO/V_TEXT as an array. Do you have an example of this? It does sound like an easier approach.
                                        All zones time
                                        Zone display name
                                        May 31, 2015
                                        *** Version 2.0
                                        PARTS LIST:
                                        * NRF24L01 Radio
                                        * LED
                                        * Push button
                                        INSTRUCTIONS:
                                        #include <Wire.h>
                                        #include <Time.h>
                                        #ifdef ACTIVE_LOW
                                        #else
                                        #ifdef DEBUG_ON
                                        #else
                                        typedef enum {
                                        SprinklerStates;
                                        byte menuState = 0;
                                        int valveNumber;
                                        int lastValve;
                                          //delay(5000);
                                          lcd.clear();
                                          lcd.backlight();
                                          delay(500);
                                          lcd.write(byte(0));
                                            gw.process();
                                            delay(1000);
                                            lcd.print(".");
                                            clockCounter++;
                                              lcd.clear();
                                              delay(2000);
                                              break;
                                          lcd.clear();
                                            lcd.print(i);
                                            DEBUG_PRINT(i);
                                              delay(100);
                                              delay(100);
                                              delay(100);
                                          lcd.clear();
                                          gw.process();
                                          updateClock();
                                          updateDisplay();
                                          goGetValveTimes();
                                          if (buttonPushed)
                                              menuState = 0;
                                              menuState++;
                                                menuState = 0;
                                            else
                                            slowToggleLED ();
                                                delay(50);
                                              lcd.clear();
                                              lcd.setCursor(0,0);
                                              lcd.setCursor(0,1);
                                              delay(2000);
                                              lastValve = -1;
                                                else
                                            fastToggleLed();
                                              valveNumber = 1;
                                            else
                                              valveNumber++;
                                                lastValve = -1;
                                            fastToggleLed();
                                                else
                                            else
                                              fastToggleLed();
                                            else
                                            displayMenu();
                                          lastState = state;
                                            lcd.clear();
                                            lcd.print(F("."));
                                            Serial.print(".");
                                            if (menuState == 0)
                                              valveNumber = 1;
                                            else
                                          else
                                                else
                                                  if (i == 0)
                                                    valveNumber = 1;
                                                  else
                                                    valveNumber = i;
                                                    DEBUG_PRINTLN(i);
                                                DEBUG_PRINT(i);
                                                DEBUG_PRINT(i);
                                                  DEBUG_PRINTLN(i);
                                                  break;
                                                DEBUG_PRINT(i);
                                          if (zoneTimeUpdate)
                                              if (i != 0)
                                                DEBUG_PRINT(i);
                                          else
                                            switch (state) {
                                                fastClear();
                                                if (displayToggle)
                                                  if (clockUpdating)
                                                    lcd.write(byte(0));
                                                  lcd.print(month());
                                                  lcd.print(day());
                                                  lcd.print(F("/"));
                                                else
                                                  if (clockUpdating)
                                                    lcd.write(byte(0));
                                                break;
                                                fastClear();
                                                if (displayToggle)
                                                else
                                                  else
                                                    lcd.print("min");
                                                    lcd.print("sec  ");
                                                break;
                                              case RUN_ALL_ZONES:
                                                fastClear();
                                                if (displayToggle)
                                                else
                                                  lcd.print("min");
                                                  lcd.print("sec  ");
                                                break;
                                                if (displayToggle)
                                                else
                                          setTime(newTime);
                                            DEBUG_PRINT(day());
                                            showTime = false;
                                          else
                                        void fastClear()
                                          lcd.print(F("                "));
                                          lcd.print(F("                "));
                                        void updateClock()
                                            lcd.write(byte(0));
                                            valveIndex++;
                                              valveIndex = 1;
                                        AWIA
                                        AWIA
                                        AWI
                                        @dbemowsk I would suggest to take @PierreSt advice and go for a V_PERCENTAGE device. From my perspective you wil mostly deal with "a scale of fixed values' for more or less intensive irrigation. As you are working with Domoticz you can use a "Selector switch" to select the diiferent options.
                                        I am currently using this for selecting patterns in my Wall mounted mood light and it works like a charm.
                                        If anyone is intrested I will publish a "how-to" (in the Domoticz section)
                                        Sergio RiusS dbemowskD 2 Replies Last reply
                                        • AWIA AWI
                                          Sergio RiusS
                                          Sergio RiusS
                                          Sergio Rius
                                          wrote on last edited by Sergio Rius
                                          #220
                                          @AWI
                                          While that would be a logical approach, the the dimmer control in Domoticz it's complex and sometimes requires more than one click to activate. In other interfaces (Android, etc) that could be worse, and should change in the future.
                                          @dbemowsk
                                          I did not use S_INFO in my sketch, but I managed to use an array for valves configuration and may be pretty interesting if we mix the two of them.
                                          Note that this is a version 2.0 sketch, and that I removed all the remote management stuff. Due to the flow change in v2, the display menu was so difficult to do.
                                          Perhaps you can adapt it back and get back to the original idea.
                                          ///// Mysensors options /////
                                          //#define MY_DEBUG
                                          #define MY_NODE_ID 1 // Having some problems with auto Id on my installation.
                                          #include <Time.h>
                                          #include <Wire.h>
                                          #define SKETCH_NAME "GardenController"
                                          #define SKETCH_VERSION "1.0"
                                          /////// Display output options /////
                                          //#define USING_DISPLAY
                                          //boolean showTime = true;
                                          //#ifdef USING_DISPLAY
                                          //	LiquidCrystal_I2C lcd(0x27, 16, 2);
                                          //	//#define LCDINIT (DEBUG_PRINTLN("Setting up LCD..."); lcd.init(); lcd.clear(); lcd.backlight();)
                                          //#else
                                          //	#define LCDINIT
                                          //#endif
                                          unsigned char bitStatus;
                                          #ifdef ACTIVE_LOW
                                          	#define ALL_ELEMENTS_OFF 0xFFFF
                                          	#define myShiftOut (shiftOut(dataPin, clockPin, MSBFIRST, ~bitStatus))
                                          #else
                                          	#define ALL_ELEMENTS_OFF 0U
                                          	#define myShiftOut (shiftOut(dataPin, clockPin, MSBFIRST, bitStatus))
                                          boolean clockSetup = false;
                                          ///// Serial interface options /////
                                          #ifdef DEBUG_ON
                                          #else
                                          ///// Control elements /////
                                          class myElement {
                                          public:
                                          	myElement(char* name, int runningTime, unsigned long Started);
                                          	char* Name;
                                          	int RunningTime;
                                          	unsigned long Started;
                                          myElement::myElement(char* Name, int RunningTime, unsigned long Started = 0)
                                          	this->Name = Name;
                                          	this->RunningTime = RunningTime;
                                          	this->Started = Started;
                                          myElement myElements[] =
                                          	{ "Irrigation Zone 1", 1 },
                                          	{ "Irrigation Zone 2", 1 },
                                          	{ "Pond Pump", 0 },
                                          	{ "Pond Lights", 0 },
                                          	{ "Front way lights", 0 },
                                          	{ "Acc1", 0 },
                                          	{ "Acc2", 0 },
                                          	{ "Acc3", 0 },
                                          int NUMBER_OF_ELEMENTS = sizeof(myElements) / sizeof(*myElements);
                                          MyMessage msg1valve(0, V_STATUS);
                                          	SERIAL_START(9600);
                                          	DEBUG_PRINTLN("Initialising...");
                                          	//LCDINIT;
                                          	//DEBUG_PRINTLN("Setting up LCD..."); lcd.init(); lcd.clear(); lcd.backlight();
                                          	//DEBUG_PRINTLN("Requesting time from Gateway");
                                          	//requestTime();
                                          	//DEBUG_PRINTLN("Ready!");
                                          	for (int i = 0; i < NUMBER_OF_ELEMENTS; i++) {
                                          		myElement Elm = myElements[i];
                                          		present(i, S_BINARY, Elm.Name);
                                          		wait(50);
                                          		DEBUG_PRINT("Presented element (id/name/preset time): "); DEBUG_PRINT(i); DEBUG_PRINT("/");  DEBUG_PRINT(Elm.Name); DEBUG_PRINT("/"); DEBUG_PRINTLN(Elm.RunningTime);
                                          		request(i, V_STATUS);
                                          		wait(50);
                                          	//Check if there are some timer lights to shutdown
                                          		//DEBUG_PRINT(myElements[i].Name); DEBUG_PRINT("/"); DEBUG_PRINT(myElements[i].RunningTime); DEBUG_PRINT("/"); DEBUG_PRINTLN(myElements[i].Started);
                                          		if (myElements[i].Started > 0) {
                                          			DEBUG_PRINT("Running element ("); DEBUG_PRINT(i); DEBUG_PRINTLN(")");
                                          			if ((millis() - myElements[i].Started) >= (myElements[i].RunningTime * 60000)){
                                          				DEBUG_PRINT("ELEMENT TIMEOUT! ("); DEBUG_PRINT(i); DEBUG_PRINTLN(")");
                                          				updateRelay(i, 0);
                                          		wait(500);
                                          //void receiveTime(time_t newTime)
                                          //	DEBUG_PRINTLN("Received time value, updating...");
                                          //	int lastSecond = second();
                                          //	int lastMinute = minute();
                                          //	int lastHour = hour();
                                          //	setTime(newTime);
                                          //	if (((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour)) )|| showTime)
                                          //		DEBUG_PRINT("Node's time currently set to: ");
                                          //		DEBUG_PRINT(day());
                                          //		DEBUG_PRINT("/");
                                          //		DEBUG_PRINT(month());
                                          //		DEBUG_PRINT(F("/"));
                                          //		DEBUG_PRINT(year());
                                          //		DEBUG_PRINT(hour() < 10 ? F(" 0") : F(" "));
                                          //		DEBUG_PRINT(hour());
                                          //		DEBUG_PRINT(minute() < 10 ? F(":0") : F(":"));
                                          //		DEBUG_PRINTLN(minute());
                                          //		showTime = false;
                                          //	else
                                          //		DEBUG_PRINTLN("Node's time did NOT need adjustment greater than 1 second.");
                                          //	clockSetup = true;
                                          	switch (message.type)
                                          	case V_STATUS:
                                          		DEBUG_PRINT("Received: Position "); DEBUG_PRINT(message.sensor); DEBUG_PRINT(" Value "); DEBUG_PRINTLN(message.getBool());
                                          		//DEBUG_PRINT("Before status: "); DEBUG_PRINTLN(bitStatus);
                                          		updateRelay(message.sensor, message.getBool());
                                          		break;
                                          	default:
                                          		break;
                                          //void RESET() {
                                          //	digitalWrite(latchPin, LOW);
                                          //	shiftOut(dataPin, clockPin, MSBFIRST, ALL_ELEMENTS_OFF);
                                          //	digitalWrite(latchPin, HIGH);
                                          void updateRelay(int whichPin, byte whichState) {
                                          	if (myElements[whichPin].RunningTime > 0){
                                          		if (whichState == 1){
                                          			myElements[whichPin].Started = millis();
                                          			DEBUG_PRINT("Stored start time ("); DEBUG_PRINT(myElements[whichPin].Started); DEBUG_PRINT(") for "); DEBUG_PRINTLN(whichPin);
                                          		else
                                          			myElements[whichPin].Started = 0;
                                          			DEBUG_PRINT("Reset start time for "); DEBUG_PRINTLN(whichPin);
                                          	bitWrite(bitStatus, whichPin, whichState);
                                          	//DEBUG_PRINT("updateRelay: bitStatus -> "); DEBUG_PRINTLN(bitStatus);
                                          	myShiftOut;
                                          As you may noticed, it can control up to 32 valves and you only have to populate the array. It'll be nice to request this data to domoticz and after a timer or received it, store in eeprom and populate the sub-nodes. Then in subsequent starts, boot with the info on eeprom and ask for changes.
                                          The sensor shuts itself the "valves" and if time is set to zero runs them without limit.
                                          That's not my irrigation controller, but my whole garden controller. (thaks the op for the idea)
                                          dbemowskD AWIA 2 Replies Last reply
