  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 325.2k Views 52 Watching
    @petewill
    which can be easily substituted by a flux capacitor.
    :wink:
    impertusI
    impertusI
    impertus
    @BulldogLowell Thx :)
    Is this the rigth setup.
    Irrigationcontroller <-----> Radio + ethernet (Gateaway) ------> Router + Wifi ------> RaspB with (Calaos HA controller)
    Wifi -----> Calaos Mobile app
    How does the HA controller detects the signal from the irrigation controller? some mystisk setup :) or plug an play..
    What HA will you use (Opensouce)(With mobil function)
    petewillP 1 Reply Last reply
    • impertusI impertus
      petewillP
      petewillP
      petewill
      @BulldogLowell Ha! Unfortunately I'm fresh out of those...
      @impertus Both @BulldogLowell and I use Vera as our home automation controller (not open source). My setup looks like: Irrigation Controller <> Ethernet Gateway <> Vera <> Vera Mobile App (usually AutHomationHD). I haven't tested any other controllers with this device but reading up a little in this forum post it appears that some people have got it to work with Domoticz.
      impertusI 1 Reply Last reply
      • petewillP petewill
        impertusI
        impertusI
        impertus
        @petewill yeahh i did a little bit of surfing on the forum. And felt over Domoticz. I see that also can run on RaspBerryPi. So think i will give that at try. It will be nice with a newbie guide how to setup my sensors to Domo. step by step..
        now im waiting for the mailman with all my components :)
        • HuczasH
          HuczasH
          Huczas
          Hi, I've done recently this setup - it works greate with domoticz and Raspberry Pi 0.
          After some tests I findout that when I plug in power - sometimes all, sometimes 3 or 4 relays are turning ON for 1second.
          If that happend my 24V power adapter will be in trash. How to prevent that? Do I need to add something in code (I'm not a programmer)?
          • HuczasH Huczas
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @Huczas
            try adding a delay in various places in setup() start with 5 or even 10 seconds.
            • HuczasH
              HuczasH
              Huczas
              wrote on last edited by Huczas
              #246
              ok, I just get back from Hackerspace. Some people fix this issue:
              SN74HC595 - 13 pin (OE from datascheet) - remove GND and then add pull up 1k resistor and wire it to Arduino pin 6
              and software, added three lines in code:
                const int outputEnablePin = 6;
                pinMode(outputEnablePin, OUTPUT);
                digitalWrite (outputEnablePin, LOW);
              put them after 190 line https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/IrrigationController/IrrigationController.ino
              should be like that:
              <some code>
               //Setup Shift Register...
              const int latchPin = 8;
              const int clockPin = 4;
              const int dataPin  = 7;
              byte clock[8] = {0x0, 0xe, 0x15, 0x17, 0x11, 0xe, 0x0}; // fetching time indicator
              byte raindrop[8] = {0x4, 0x4, 0xA, 0xA, 0x11, 0xE, 0x0,}; // fetching Valve Data indicator
              // Set the pins on the I2C chip used for LCD connections:
              //                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
              LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
              MyMessage msg1valve(CHILD_ID_SPRINKLER, V_LIGHT);
              MyMessage var1valve(CHILD_ID_SPRINKLER, V_VAR1);
              MyMessage var2valve(CHILD_ID_SPRINKLER, V_VAR2);
                SERIAL_START(115200);
                DEBUG_PRINTLN(F("Initialising..."));
                pinMode(latchPin, OUTPUT);
                pinMode(clockPin, OUTPUT);
                pinMode(dataPin, OUTPUT);
                pinMode(ledPin, OUTPUT);
                pinMode(waterButtonPin, INPUT_PULLUP);
                //pinMode(waterButtonPin, INPUT);
                attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
                digitalWrite (ledPin, HIGH);
                DEBUG_PRINTLN(F("Turning All Valves Off..."));
                updateRelays(ALL_VALVES_OFF);
              <some code>
              If somebody can update this project in github and that fritzling draw - would be super nice.
              • HuczasH Huczas
                <some code>
                <some code>
                petewillP
                petewillP
                petewill
                @Huczas Great, thanks! Have you tested these updates? Also, can you post a link the info on hackerspace?
                HuczasH 1 Reply Last reply
                  HuczasH
                  HuczasH
                  Huczas
                  @petewill
                  Yes, I've tested this and it's working well!
                  Link to the hackerspace - HackerSpace Warsaw, they are on irc - where I talk with them, #hackerspace-pl at freenode servers.
                  petewillP 2 Replies Last reply
                  • HuczasH Huczas
                    @petewill
                    petewillP
                    petewillP
                    petewill
                    @Huczas Oh, ok. I thought it was a forum post. Thanks for the update. I will work to get this updated.
                    • HuczasH Huczas
                      @petewill
                      petewillP
                      petewillP
                      petewill
                      @Huczas the code has been updated in the 2.0 GitHub branch. The wiring diagram has also been updated. Thanks for the fix!
                        HuczasH
                        HuczasH
                        Huczas
                        @petewill as I sad before - pull up 1k resistor and wire it to Arduino pin 6 - I mean
                        pull up - connect to power,
                        so should be 1k resistor connected with power source(that make sence with pull up) and also with pin 6. Like below:
                        • HuczasH Huczas
                          petewillP
                          petewillP
                          petewill
                          @Huczas Ah, missed that. I fixed it.
                          • B
                            B
                            bsivley
                            I just finished building this but when I go to upload the code to my arduino i get this error
                            'byte clock [8]' redeclared as different kind of symbol
                            what does this mean ?
                            thanks
                            • B bsivley
                              thanks
                              petewillP
                              petewillP
                              petewill
                              @bsivley Are you using the libraries from the MySensors github page (https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries)? I just compiled it without any errors. What version of the Arduino IDE are you using? What version of MySensors are you using?
                              Andrej_ABA 1 Reply Last reply
                                Andrej_ABA
                                Andrej_ABA
                                Andrej_AB
                                @petewill Hi, Please can you advise what version Arduino IDE you are using for this sketch?
                                rechin304R 1 Reply Last reply
                                • Andrej_ABA Andrej_AB
                                  rechin304R
                                  rechin304R
                                  rechin304
                                  This post is deleted!
                                  • Andrej_ABA
                                    Andrej_ABA
                                    Andrej_AB
                                    Hi, Maybe somebody can help me with this issue? Managed to upload code for irrigation controller with Arduino IDE 1.6.12 but can't pair with Vera controller.
                                      petewillP
                                      petewillP
                                      petewill
                                      @Andrej_AB I'm using 1.6.12 but I haven't changed my node to 2.0 yet.
                                      What is the issue you are having with pairing? Do you see the presentation messages on your gateway? Do you have other nodes successfully paired with your Vera?
                                        Andrej_ABA
                                        Andrej_ABA
                                        Andrej_AB
                                        @petewill Hi, All my other nodes have successfully paired with Vera, but irrigation controller node can't pair with Vera, I have started inclusion mode on Vera, one minute passed 0 devices found.
                                        Please see attached picture.
                                          petewillP
                                          petewillP
                                          petewill
                                          @Andrej_AB It looks like it's communicating ok because it's getting the time. Have you ever had a mysenors node #5 in your Vera previously and deleted it? Could it be that the Vera thinks it's already there? What happens if you clear your eeprom on your irrigation controller then manually assign a different ID and then try to pair it again?
