  2. Feature Requests
  3. Magnetic field detection
5 Posts 2 Posters 4.5k Views 3 Watching
  • michlb1982M
    michlb1982M
    michlb1982
    Hello everyone...
    i try to build a Anemometer with an AS5040-Chip.... so it would be great to use mysensors with an Anemometer...
    does anyone have a similar project? maybe there are wiring-plans for the as5040 and arduinos?
    thanks for help..
    SparkmanS 1 Reply Last reply
    • michlb1982M michlb1982
      Hello everyone...
      thanks for help..
      SparkmanS
      SparkmanS
      Sparkman
      @michlb1982 This site shows how to connect an AS5040 to an Arduino and has a sample sketch: http://reprap.org/wiki/Magnetic_Rotary_Encoder_1.0. The section is towards the bottom called Digital SSI Output. None of the pins used conflict with NRF24 radio usage so it should be relatively simple to MySensor it.
      Cheers
      Al
      • michlb1982M
        michlb1982M
        michlb1982
        Hello
        thanks for the input...
        well i did it...
        i was able to build an Wind-direction-MYSENSOR... well i'm sure, its a little bit
        awkward and much to complicated but it works quite OK...
        the next step is to build a windspeed - sensor.. with the AS5040..
        here the Arduino nano Code...:
        const int ledPin = 13; //LED connected to digital pin 13
        const int clockPin = 5; //output to clock
        const int CSnPin = 4; //output to chip select
        const int inputPin = 6; //read AS5040
        int inputstream = 0; //one bit read from pin
        long packeddata = 0; //two bytes concatenated from inputstream
        long angle = 0; //holds processed angle value
        long anglemask = 65472; //0x1111111111000000: mask to obtain first 10 digits with position info
        long statusmask = 63; //0x000000000111111; mask to obtain last 6 digits containing status info
        long statusbits; //holds status/error information
        int DECn; //bit holding decreasing magnet field error data
        int INCn; //bit holding increasing magnet field error data
        int OCF; //bit holding startup-valid bit
        int COF; //bit holding cordic DSP processing error data
        int LIN; //bit holding magnet field displacement error data
        int debug = 0; //SET THIS TO 0 TO DISABLE PRINTING OF ERROR CODES
        int shortdelay = 1000; // this is the microseconds of delay in the data clock
        int longdelay =1000; // this is the milliseconds between readings
        #define CHILD_ID_DIR 0
        //#define INTERRUPT inputPin
        MyMessage msgDIR(CHILD_ID_DIR, V_DIRECTION);
          gw.begin(NULL, AUTO, true, AUTO);
          Serial.begin(250000);
          pinMode(ledPin, OUTPUT); // visual signal of I/O to chip
          pinMode(clockPin, OUTPUT); // SCK
          pinMode(CSnPin, OUTPUT); // CSn -- has to toggle high and low to signal chip to start data transfer
          pinMode(inputPin, INPUT); // SDA
          gw.sendSketchInfo("Winddirection", "1.0");
          gw.present(CHILD_ID_DIR, S_WIND);
        // CSn needs to cycle from high to low to initiate transfer. Then clock cycles. As it goes high
        // again, data will appear on sda
          digitalWrite(CSnPin, HIGH); // CSn high
          digitalWrite(clockPin, HIGH); // CLK high
          delay(longdelay);// time between readings
          digitalWrite(ledPin, HIGH); // signal start of transfer with LED
          digitalWrite(CSnPin, LOW); // CSn low: start of transfer
          delayMicroseconds(shortdelay); // delay for chip initialization
          digitalWrite(clockPin, LOW); // CLK goes low: start clocking
          delayMicroseconds(shortdelay); // hold low
          for (int x=0; x <16; x++) // clock signal, 16 transitions, output to clock pin
            digitalWrite(clockPin, HIGH); //clock goes high
            inputstream =digitalRead(inputPin); // read one bit of data from pin
        //Serial.print(inputstream, DEC);
            packeddata = ((packeddata << 1) + inputstream);// left-shift summing variable, add pin value
            delayMicroseconds(shortdelay); // end of one clock cycle
        // end of entire clock cycle
        //Serial.println(" ");
          digitalWrite(ledPin, LOW); // signal end of transmission
        // lots of diagnostics for verifying bitwise operations
        //Serial.print("packed:");
        //Serial.println(packeddata,DEC);
        //Serial.print("pack bin: ");
        //Serial.println(packeddata,BIN);
          angle = packeddata & anglemask; // mask rightmost 6 digits of packeddata to zero, into angle.
        //Serial.print("mask: ");
        //Serial.println(anglemask, BIN);
        //Serial.print("bin angle:");
        //Serial.println(angle, BIN);
        //Serial.print("angle: ");
        //Serial.println(angle, DEC);
          angle = (angle >> 6); // shift 16-digit angle right 6 digits to form 10-digit value
        //Serial.print("angleshft:");
        //Serial.print("angledec: ");
          angle = angle * 0.3515; // angle * (360/1024) == actual degrees
          Serial.print("angle: "); // and, finally, print it.
        //Serial.println("--------------------");
        //Serial.print("raw: "); // this was the prefix for the bit-by-bit diag output inside the loop.
          if (debug)
            statusbits = packeddata & statusmask;
            DECn = statusbits & 2; // goes high if magnet moved away from IC
            INCn = statusbits & 4; // goes high if magnet moved towards IC
            LIN = statusbits & 8; // goes high for linearity alarm
            COF = statusbits & 16; // goes high for cordic overflow: data invalid
            OCF = statusbits & 32; // this is 1 when the chip startup is finished.
            if (DECn && INCn) { Serial.println("magnet moved out of range"); }
            else
              if (DECn) { Serial.println("magnet moved away from chip"); }
              if (INCn) { Serial.println("magnet moved towards chip"); }
            if (LIN) { Serial.println("linearity alarm: magnet misaligned? Data questionable."); }
            if (COF) { Serial.println("cordic overflow: magnet misaligned? Data invalid."); }
          float V_DIRECTION = angle;
          gw.send(msgDIR.set(V_DIRECTION, DEC));
          packeddata = 0; // reset both variables to zero so they don't just accumulate
          angle = 0;
          gw.process();
          //gw.sleep(INTERRUPT,CHANGE);
          gw.sleep(longdelay);
        the code for FHEM:
        define MYSENSOR_111 MYSENSORS_DEVICE 111
        attr MYSENSOR_111 IODev SerialGate
        attr MYSENSOR_111 alias Windrichtung
        attr MYSENSOR_111 group Sensoren
        attr MYSENSOR_111 mapReading_direction 0 direction
        attr MYSENSOR_111 mapReading_gust 0 gust
        attr MYSENSOR_111 mapReading_wind 0 wind
        attr MYSENSOR_111 mode repeater
        attr MYSENSOR_111 room 03_Umwelt
        attr MYSENSOR_111 stateFormat {sprintf("%.0f",ReadingsVal("MYSENSOR_111","direction",0))."°"}
        a curcuit will follow in the next days...
        greets..
        Mike
        • michlb1982M
          michlb1982M
          michlb1982
          here some pics
          Foto 06.12.15, 13 06 18.jpg Foto 06.12.15, 13 06 27.jpg Foto 06.12.15, 13 06 08.jpg Foto 06.12.15, 13 06 00.jpg
          • michlb1982M
            michlb1982M
            michlb1982
            well, the promised curcuit...Windrichtung-AS5040-Mysensor.pdf Windrichtung_Steckplatine.jpg Windrichtung.fzz
