  3. Vera
  4. button problem
button problem
16 Posts 4 Posters 6.8k Views 1 Watching
  • ferpandoF Offline
    ferpandoF Offline
    ferpando
    I have a couple of push buttons using the vlight in the sketch.
    The problem is that VERA restarts if I push a button too many times.
    I would like to limit the pushes the sensor is able to send to maybe 1 per second.
    It should send the first push immediately but if another push is detected then wait 1 second to send it.
    Would this too difficult to implement?
    Any clues on how to start?
    B 1 Reply Last reply
    • ferpandoF ferpando
      B Offline
      B Offline
      BulldogLowell
      @ferpando
      have you tried to change the debouncer interval to 1000ms?
      debouncer.interval(1000)
      • ferpandoF Offline
        ferpandoF Offline
        ferpando
        I tried to rise it above 20 but it just stops working.
          B Offline
          B Offline
          BulldogLowell
          wrote on last edited by BulldogLowell
          @ferpando
          you are using "Door/Window & Pushbutton" sketch?
          try this:
          PushbuttonWithLockout.ino
          • ferpandoF Offline
            ferpandoF Offline
            ferpando
            I'm using a multi binary sketch for 2 buttons.
            I'll take a look at yours.
            Could it be the vera plugin what's causing the restarts?
              B Offline
              B Offline
              BulldogLowell
              I would look at the vera log while you are doing a button push.
              The two button sketch should be no problem. If you need help, post it and I can try my best.
              • ferpandoF Offline
                ferpandoF Offline
                ferpando
                I'm having some problems with these buttons.
                They work but sometimes Vera just restarts.
                I'll try to loot at vera logs and see.
                Keep you posted.
                Thanks for the help
                • hekH Offline
                  hekH Offline
                  Which Vera version are you using? Vera 2?
                  I doubt the MySensors plugin makes Vera restart unless it is very low on memory or overloaded with other work.
                  ferpandoF 1 Reply Last reply
                    ferpandoF Offline
                    ferpandoF Offline
                    ferpando
                    @hek
                    I currently have a vera lite running.
                    It never restarts but when it does is after I push a button, no action is fired, then I push again maybe 2-3 times and then I find Vera is restarting.
                    I still have no proof but I'll try to find something in the logs.
                      @hek
                      B Offline
                      B Offline
                      BulldogLowell
                      @ferpando said:
                      @hek
                      did the lockout help?
                      I agree with Hek, it seems like there must be something up on the vera side.
                      • B BulldogLowell
                        @ferpando said:
                        @hek
                        ferpandoF Offline
                        ferpandoF Offline
                        ferpando
                        @BulldogLowell
                        Didn't have the chance to test it yet.
                        I also have an RFXcom device attached to vera. Maybe they don't like eachother? Anyone has one?
                        • K Offline
                          K Offline
                          korttoma
                          I do have both the mysensors gateway and a RFXtrx433 attachced to a veralite. My system is stable now but I have allso had issues with memory and have uninstalled everything I absolutely did not need and simplyfied everything I could. If your vera is acting strange I would check my memory status.
                          • Tomas
                          • K korttoma
                            ferpandoF Offline
                            ferpandoF Offline
                            ferpando
                            @korttoma
                            could you post your memory usage for comparison?
                            • K Offline
                              K Offline
                              korttoma
                              memoryTotal 62480
                              memoryFree 8360
                              memoryBuffers 5652
                              memoryCached 17336
                              memoryUsed 54120
                              memoryAvailable 25696
                              I began to have issues once memoryAvailable is less than 20000.
                              • Tomas
                              • K korttoma
                                memoryTotal 62480
                                memoryFree 8360
                                memoryBuffers 5652
                                memoryCached 17336
                                memoryUsed 54120
                                ferpandoF Offline
                                ferpandoF Offline
                                ferpando
                                wrote on last edited by ferpando
                                @korttoma
                                this is what I currently have on my vera lite:
                                                total         used         free       shared      buffers
                                    Mem:        62480        55376         7104            0         6304
                                   Swap:            0            0            0
                                  Total:        62480        55376         7104
                                how do you get the 'memoryAvailable'?
                                • K Offline
                                  K Offline
                                  korttoma
                                  I have the "System Monitor" plugin installed so I get it as a Variable in the advanced tab.
                                  • Tomas
