  3. Air Conditioning state monitoring sensor
16 Posts 7 Posters 7.2k Views 5 Watching
  • Moshe LivneM
    Moshe LivneM
    Moshe Livne
    First, special thanks to @Chester for thinking the way to do that and @Sparkman, my hero, for correcting my silly mistake.
    These sensors are for checking if the kids (or me, just hypothetically :-) ) left the air conditioning running in their rooms. What makes it work is that the flaps move in a particular way when you turn the air conditioning off in my wall unit and they "close down" to a position that is impossible while its running.
    This is the sensor (looks almost professional!):
    I have since added also battery monitoring although I have to tweak it a bit as it shows 66%.
    The reed sensor sense the presence of a magnet on the flap.
    This is the sensor in position. Couldn't find my kids blue tack so had to use blue tape.
    I have carefully measure everything to fit into one of the super cheap aliexpress project boxes. what I didn't take into account was that the battery adds extra 4mm to the height. Darn.
    Here you can see the magnet:upload_-1 (6).jpg
    and this is the sketch:
    #define REED_PIN 3
    #define INTERRUPT REED_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    #define CHILD_ID 1
    #define SLEEP_TIME 28800000
    MyMessage msg(CHILD_ID, V_LIGHT);
      analogReference(INTERNAL);
      pinMode(REED_PIN, INPUT);
      digitalWrite(REED_PIN, HIGH); //internal pullup
    //  pinMode(A0, INPUT);
      Serial.begin(115200);
      gw.begin();
      gw.sendSketchInfo("AirCon Sensor", "1.0");
      gw.present(CHILD_ID, S_LIGHT);
    int old_value = -1;
    int oldBatteryPcnt = 0;
    	int value;
    	int bValue;
      // Listen for any knock at all.
    ///  gw.process(); // Process incomming messages
    //  	t = analogRead(A0);
      	value = digitalRead(REED_PIN);
    	Serial.println(value);
      	delay(500); //debounce
      	if (value != old_value){
      		old_value = value;
      		gw.send(msg.set(value));
    	//Battery
    	bValue = analogRead(BATTERY_SENSE_PIN);
        int batteryPcnt = bValue / 10;
        Serial.print("Battery : ");
    	Serial.print(batteryPcnt);
    	Serial.println("%");
        	oldBatteryPcnt = batteryPcnt;
    	gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    • C
      C
      Chester
      Great to see it working! Sometimes its definitely a case of going back to the simplest design idea to get the best result. Congratulations on getting the right solution :)
      • Moshe LivneM Moshe Livne
        #define REED_PIN 3
        #define CHILD_ID 1
          gw.begin();
        int old_value = -1;
        	int value;
        	int bValue;
          		old_value = value;
        	//Battery
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @Moshe-Livne
        props for the use of blue tape!
        all kidding aside, this is a great project!
          @Moshe-Livne
          Moshe LivneM
          Moshe LivneM
          Moshe Livne
          @BulldogLowell It does add a little 60`s look to the whole project, isn't it? I'll make these some pretty wood boxes. My problem is that temps here are now consistently under 10 degrees. white glue turns to cheese when its that cold. Have an idea for this as well... will post when it's ready.
          • C Chester
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @Chester That is why having a forum is so great! I don't think I would have thought about this myself - I tend to oversolve problems.
            • DidiD
              DidiD
              Didi
              you make yourself always down
              if (knowledge == 0) { use BRAIN; use GOOGLE;use SEARCH; } else {make POST;}
              • DidiD
                DidiD
                Didi
                you gave me more solutions i think about before you here
                • DidiD Didi
                  Moshe LivneM
                  Moshe LivneM
                  Moshe Livne
                  @Didi Thanks! Still, I tend to oversolve. I know that and try to fight it but whenever I see a problem my first instinct is an RPI with 1/2 TB storage, a few motors and sensors. Simple!
                  • T
                    ThinkPad
                    Nice! Although i would probably have opened the unit and see if i could tap into the signal of one of those 'operation' LED's.
                    That way the whole MySensors node would be invisible ;)
                    • Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      And here they are, mounted properly:
                      SparkmanS 1 Reply Last reply
                      • T
                        ThinkPad
                        Looking neat!
                          SparkmanS
                          SparkmanS
                          Sparkman
                          @Moshe-Livne Looks great, but I kind of miss the blue tape :stuck_out_tongue:
                          Cheers
                          Al
                          • SparkmanS Sparkman
                            Cheers
                            Al
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @Sparkman I cater for the community members needs:
                              SparkmanS
                              SparkmanS
                              Sparkman
                              @Moshe-Livne :laughing: :satisfied:
                              • DidiD
                                DidiD
                                Didi
                                :laughing:
                                • Ivan ZI
                                  Ivan ZI
                                  Ivan Z
                                  Good idea. Append IR control
