  2. Announcements
  3. MySensors 1.5 Released
34 Posts 21 Posters 25.0k Views 9 Watching
  • epierreE
    epierreE
    epierre
    @hek seems there is something to correct http://forum.mysensors.org/topic/1729/updated-support-to-serial-version-1-5
    z-wave - Vera -> Domoticz
    hekH 1 Reply Last reply
    • epierreE epierre
      @epierre
      Already talked to @John. Will update documentation more clearly that V_DIMMER and V_LIGHT has been deprecated for the more general wording V_PERCENTAGE and V_STATUS.
      The old sketches will still work fine as I've introduced an alias.
      • JohnJ
        JohnJ
        John
        @hek, @epierre
        I think i was too fast with committing my updates which creates new downloads automatically (sorry if it was too quick), so I had to do a post just in case of some "eager to update" user i have.
        • S
          sebas
          Very nice. How do I find out how the new sensor types work? Specifically the RGB and RGBW sensors.
          I've browsed through the source code but haven't found it yet. What file should I be looking into?
          • G
            G
            gbfromhb
            Very cool. The timing was perfect. I was just about to jump into the deep end and start deploying the development branch. Thanks everyone for the hard work.
            • S sebas
              @sebas
              Guess I'll have to toss an RGB example together some day. But basically the payload should be a ascii hex string describing the color components. I.e "FF0000" for red.
              • SweebeeS
                SweebeeS
                Sweebee
                I'm trying to burn the gateway but i get this:
                /Users/Wiebe/Documents/Arduino/libraries/MySensors/MyGateway.cpp:13:30: fatal error: utility/MsTimer2.h: No such file or directory
                 #include "utility/MsTimer2.h"
                compilation terminated.
                  @diggs
                  I haven't made sketch-examples for all new sensor types yet. The community needs to help me with that. :)
                  D
                  D
                  diggs
                  @hek
                  No worries, thanks for clarifying
                  • BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @hek
                    I have to say, the documentation for the update to 1.5 was done very well... thanks to you and whomever else assisted.
                    nice work!
                    :thumbsup:
                      Thanks, but still room for improvements. :)
                      @Anticimex is currently deploying a jenkins build-server to automate builds of the examples for different platforms when things get pushed to github. Makes it much easier to keep up the quality.
                      This will also allow automatic doxygen documentation and perhaps a bit of a rearrangement of the repository layout which isn't optimal (except when downloading/installing).
                        msebbe
                        wrote on last edited by msebbe
                        #31
                        @hek I have updated my gateway but should the vera say plugin version 1.5? Or is the plugin version still 1.4? Im confused
                        • rvendrameR
                          rvendrameR
                          rvendrame
                          Mine says
                          Plugin Version:1.4
                          Lib Version: 1.5
                          So I guess the 'plugin' refers to the lua/xml/json files in Vera.
                          The oficial page points to Github. If dates are correct there, it seems nothing was changed recently (except by the HVAC device).
                          ESP8266 GW + mySensors 2.3.2
                          Alexa / Google Home
                          M 1 Reply Last reply
                          • rvendrameR rvendrame
                            Mine says
                            Plugin Version:1.4
                            Lib Version: 1.5
                            msebbe
                            @rvendrame
                            I got it working now, thank you
                              Haven't bumped plugin version. No major things changed over there.
