  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 398.0k Views 39 Watching
    Ok! Mis-read this line---
    After the last update to beta version....
    Thought you were talking about the development branch. Sorry.
    • YhtY
      YhtY
      Yht
      Hi all,
      First, I have to say this is awsome what @Yveaux did, thank you!
      Sorry if this question takes you back in time. I don't know what channel and id to use for the nodes,I tried channel 97 and id from 1-5 but it is not working..
      are you using mesh lib?
      YveauxY 1 Reply Last reply
      • YhtY Yht
        Hi all,
        YveauxY
        YveauxY
        Just leave the default channel untouched for both sensors and gateway. It should be fine.
        The gateway will automatically be assigned ID 0, the nodes can have any fixed ID.
        Dynamic ID assignment requires some extra software, as the gateway does not support it.
        • G
          G
          georgep56
          I'm also seeing my ESP8266 gateway crash when the controller requests its version.
          I had not seen this thread so I started a new topic here: http://forum.mysensors.org/topic/2493/esp8266-wifi-gateway-crashes-and-reboots-when-controller-connects
          • scalzS
            scalzS
            hi,
            maybe you have already seen it...but you can get cheap and smaller nodemcu. crazy price! I have ordered some, and waiting for them...
            http://fr.aliexpress.com/item/D1-mini-Mini-NodeMcu-4M-bytes-Lua-WIFI-Internet-of-Things-development-board-based-ESP8266/32529101036.html?spm=2114.06010108.3.1.04LsjX&ws_ab_test=searchweb201556_2_79_78_77_80,searchweb201644_0,searchweb201560_9
            • scalzS scalz
              hi,
              YveauxY
              YveauxY
              @scalz Nice! Thanks for the link!
              • D
                D
                drock1985
                Just wanted to chime in and say thank you for this gateway script @Yveaux
                I originally had an ethernet gateway for the longest time. But when I changed over to an OnHub router, it stopped working because it doesn't like to handle static IP, and the current branch sketch is too large to enable DHCP. This worked wonderfully with the OnHub out of the box (ver 7390.62.2) and shows up with a hostname of ESP_DA7D8B.
                Thanks again!
                My Projects
                2 Door Chime Sensor
                Washing Machine Monitor
                  mbj
                  When testing the ESP8266MQTTClient (downloaded latest version of the library today) and compiled with the NodeMCU 1.0 ...... option I get an odd result. The message at startup is (please disregard the "Radio init fail" - the radio was not yet connected. I just wanted to check the WiFi ):
                  2dO,4`lLMØl 8ðÿ0;0;3;0;9;Starting gateway (RNNGE-, 1.6.0-beta)
                  0;0;3;0;9;Radio init failed. Check wiring.
                  scandone
                  state: 0 -> 2 (b0)
                  state: 2 -> 3 (0)
                  state: 3 -> 5 (10)
                  add 0
                  aid 2
                  pm open phy_2,type:2 0 0
                  cnt
                  connected with XXXyyy, channel 1
                  dhcp client start...
                  ip:192.168.1.167,mask:255.255.255.0,gw:192.168.1.1
                  I can see from the router that the connection to 192.168.1.167 is successful but the oddity is that I have set the gateway to use a static address and also connect to a SSID which is not XXXyyy. The defines are:
                  #define MY_IP_ADDRESS 192,168,1,22
                  #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
                  So the ESP8266 uses dhcp when it should have a static address and connects to a SSID which is not given but may have been previously used at earlier tests.
                  I have looked at the code and tried a few changes to defines but none resulted in the override of dhcp.
                  Anyone have a clue?
                  • B
                    B
                    bp_968
                    I have the exact hardware in this setup but can't even get to the point where the hardware is a problem! I'm having compile errors during verify that make no sense and that I can't seem to find in the forums using search:
                    In file included from Esp8266Gateway.ino:69:0:
                    C:\Users\xxxxx\Documents\Arduino\libraries\SPI/SPI.h:982:8: error: 'SPIClass' does not name a type
                    extern SPIClass SPI;
                    Any suggestions? I'm running windows 10 and Arduino 1.6.5 with the most current esp8266 board files through board manager.
                    Apparently me and anything arduino related are like oil and water, yet I keep buying the stuff.
                    B 1 Reply Last reply
                    • B bp_968
                      B
                      B
                      bp_968
                      I tried this on my laptop and it worked fine (the compile verify did anyway) so I'll be reinstalling the IDE and trying again and hopefully that resolves my issues!
                      • T
                        tjay4x4
                        Yesterday I have successfully installed the ESP8266 module and it works fine, but the Vera3 show something strange now.
                        Has anyone experienced this?
                        • T tjay4x4
                          YveauxY
                          YveauxY
                          @tjay4x4 Seems like to be an issue again when going from 8-bit to 32-bit architecture.
                          Can you connect the ESP to your PC and capture the serial output when connecting to your lights and controlling them?
                          T 1 Reply Last reply
                          • YveauxY Yveaux
                            tjay4x4
                            wrote on last edited by tjay4x4
                            #213
                            @Yveaux Thank you for reply. Here is the serial monitor.When I put 100% light it shows Ok. But 70% and others, shows some digitals. But all working fine! :)
                            Insert Code Here
                            .................Connected!
                            0;0;3;0;9;read: 1-8-0 s=0,c=1,t=0,pt=7,l=5,sg=0:33.1
                            1;0;1;0;0;33.1
                            0;0;3;0;9;read: 1-8-0 s=1,c=1,t=0,pt=7,l=5,sg=0:44.2
                            1;1;1;0;0;44.2
                            0;0;3;0;9;read: 1-8-0 s=2,c=1,t=0,pt=7,l=5,sg=0:32.2
                            1;2;1;0;0;32.2
                            0;0;3;0;9;read: 1-8-0 s=1,c=1,t=0,pt=7,l=5,sg=0:44.3
                            1;1;1;0;0;44.3
                            Client 0 connected
                            Client 0 disconnected
                            0;0;3;0;9;read: 9-8-0 s=4,c=1,t=0,pt=7,l=5,sg=0:27.0
                            9;4;1;0;0;27.0
                            0;0;3;0;9;read: 9-8-0 s=3,c=1,t=1,pt=7,l=5,sg=0:21.0
                            9;3;1;0;1;21.0
                            Client 0 connected
                            Client 0: 0;0;3;0;2;Get Version
                            0;0;3;0;2;1.5.1
                            Client 0: 11;0;1;1;3;1090519100
                            0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=10,sg=0,st=ok:1090519100
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=10,sg=0:1090519100
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:805306369
                            11;0;1;0;2;805306369
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:805306428
                            11;0;1;0;3;805306428
                            Client 0: 11;0;1;1;3;0
                            0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=1,sg=0,st=ok:0
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=1,sg=0:0
                            11;0;1;1;3;0
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:805306368
                            11;0;1;0;2;805306368
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:805306368
                            11;0;1;0;3;805306368
                            Client 0: 11;0;1;1;3;100
                            0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=3,sg=0,st=ok:100
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=3,sg=0:100
                            11;0;1;1;3;100
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:1
                            11;0;1;0;2;1
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:100
                            11;0;1;0;3;100
                            Client 0: 11;0;1;1;3;80
                            0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:80
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:80
                            11;0;1;1;3;80
                            11;0;1;0;2;1
                            11;0;1;0;3;80
                            0;0;3;0;9;read: 1-8-0 s=2,c=1,t=0,pt=7,l=5,sg=0:32.3
                            1;2;1;0;0;32.3
                            Client 0: 11;0;1;1;3;70
                            0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:70
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:70
                            11;0;1;1;3;70
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:1107296257
                            11;0;1;0;2;1107296257
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:1107296326
                            11;0;1;0;3;1107296326
                            Client 0: 11;0;1;1;3;1107296326
                            0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=10,sg=0,st=ok:1107296326
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=10,sg=0:1107296326
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:922746881
                            11;0;1;0;2;922746881
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:922746950
                            11;0;1;0;3;922746950
                            0;0;3;0;9;read: 9-8-0 s=3,c=1,t=1,pt=7,l=5,sg=0:20.0
                            9;3;1;0;1;20.0
                            Client 0: 11;0;1;1;3;922746950
                            0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=9,sg=0,st=ok:922746950
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=9,sg=0:922746950
                            11;0;1;1;3;0
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:922746880
                            11;0;1;0;2;922746880
                            0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:922746880
                            11;0;1;0;3;922746880
                            11;0;1;1;3;100
                            11;0;1;0;2;1
                            11;0;1;0;3;100
                            • YveauxY
                              YveauxY
                              @tjay4x4 which version of MySensors are you running?
                              T 2 Replies Last reply
                              • YveauxY Yveaux
                                tjay4x4
                                @Yveaux I use https://github.com/mysensors/Arduino/archive/master.zip
                                Just reupload library
                                Some additionl information.
                                100%-90%-80%70%-60%-50%- OK 40%-bug :)
                                10%-20%-30%-40% -OK 50%-bug
                                ESP8266 MySensors Gateway
                                Connecting to 1111
                                IP: 192.168.1.44
                                9;3;1;0;1;20.0
                                0;0;3;0;9;read: 1-8-0 s=1,c=1,t=0,pt=7,l=5,sg=0:44.5
                                1;1;1;0;0;44.5
                                Client 0 connected
                                0;0;3;0;2;1.5.1
                                11;0;1;1;3;0
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:536870912
                                11;0;1;0;2;536870912
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:536870912
                                11;0;1;0;3;536870912
                                11;0;1;1;3;100
                                11;0;1;0;2;1
                                11;0;1;0;3;100
                                11;0;1;1;3;80
                                11;0;1;0;2;1
                                11;0;1;0;3;80
                                11;0;1;1;3;70
                                11;0;1;0;2;1
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:70
                                11;0;1;0;3;70
                                Client 0: 11;0;1;1;3;60
                                0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:60
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:60
                                11;0;1;1;3;60
                                11;0;1;0;2;1
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:60
                                11;0;1;0;3;60
                                0;0;3;0;9;read: 1-8-0 s=1,c=1,t=0,pt=7,l=5,sg=0:44.6
                                1;1;1;0;0;44.6
                                Client 0: 11;0;1;1;3;50
                                0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:50
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:50
                                11;0;1;1;3;50
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:1107296306
                                11;0;1;0;3;1107296306
                                0;0;3;0;9;read: 7-5-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.7
                                7;0;1;0;0;30.7
                                0;0;3;0;9;read: 3-2-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.2
                                3;0;1;0;0;30.2
                                0;0;3;0;9;read: 7-5-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.6
                                7;0;1;0;0;30.6
                                0;0;3;0;9;read: 3-2-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.1
                                3;0;1;0;0;30.1
                                1;1;1;0;0;44.5
                                11;0;1;1;3;0
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:1107296256
                                11;0;1;0;2;1107296256
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:1107296256
                                11;0;1;0;3;1107296256
                                11;0;1;1;3;100
                                11;0;1;0;2;1
                                11;0;1;0;3;100
                                11;0;1;1;3;0
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:0
                                11;0;1;0;2;0
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:0
                                11;0;1;0;3;0
                                0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:10
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:10
                                11;0;1;1;3;10
                                11;0;1;0;2;1
                                11;0;1;0;3;10
                                Client 0: 11;0;1;1;3;20
                                0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:20
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:20
                                11;0;1;1;3;20
                                11;0;1;0;2;1
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:20
                                11;0;1;0;3;20
                                Client 0: 11;0;1;1;3;30
                                0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:30
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:30
                                11;0;1;1;3;30
                                11;0;1;0;2;1
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:30
                                11;0;1;0;3;30
                                1;1;1;0;0;44.6
                                Client 0: 11;0;1;1;3;40
                                0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:40
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:40
                                11;0;1;1;3;40
                                0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:1107296296
                                11;0;1;0;3;1107296296
                                11;0;1;1;3;100
                                11;0;1;0;2;1
                                11;0;1;0;3;100
                                11;0;1;1;3;0
                                11;0;1;0;2;0
                                11;0;1;0;3;0
                                7;0;1;0;0;30.7
                                1;1;1;0;0;44.5
                                9;3;1;0;1;21.0
                                3;0;1;0;0;30.2
                                0;0;3;0;9;read: 1-8-0 s=0,c=1,t=0,pt=7,l=5,sg=0:33.4
                                1;0;1;0;0;33.4
                                9;3;1;0;1;20.0
                                • YveauxY Yveaux
                                  tjay4x4
                                  @Yveaux Now everything working! I reinstall all "Arduino-master" to Arduino 1.6 folder and now ALL Ok. Sorry for disturb. Thank you!!!
                                  • YveauxY
                                    YveauxY
                                    @tjay4x4 try development version of MySensors. This thread discussions a similar issue:
                                    http://forum.mysensors.org/topic/2118/esp8266-wifi-gateway-issue/2
                                    • YveauxY
                                      YveauxY
                                      @tjay4x4 Just crossed my reply! Great it's working now!
                                      • R
                                        R
                                        robosensor
                                        wrote on last edited by robosensor
                                        #219
                                        Yesterday I switched gateway hardware from serial gateway based on arduino pro mini 3.3V and nrf24l01+ (connected directly to uart port of my mikrotik router) to esp8266 nodemcu and nrf24l01+ (exactly as at this page: http://www.mysensors.org/build/esp8266_gateway, using GatewayESP8266 sketch from 1.6 branch, revision https://github.com/mysensors/Arduino/tree/1035f84a431a8f591d31100c3e73e99a8245e345).
                                        I have 4 nodes with ~27 sensors total, half of sensors sending data every 10 seconds, another sensors send data only if environment changed.
                                        After switching to esp8266 my gateway started loosing packets (messages) from my sensor nodes:
                                        Left side of graphs is esp8266, right side is old pro mini serial gateway, sensors sending data every 10 seconds. Distance between gateways is about 5-10 centimeters. Both nrf24l01+ boards oriented in the same direction.
                                        nrf24l01+ board isn't changed at all (I'm using old board from pro mini serial gateway).
                                        Also, I have tried different nrf24l01+ boards (different PCBs and different chip revisions, but seems like all of them are fake china chips). I have tried soldering 220 uF electrolytic and 0.1 uF ceramic capacitors directly to nrf24l01+ power pins. But nothing changed. Esp8266 gateway is losing messages.
                                        Switching back to pro mini serial gateway is completely solves issue (as shown in graph above).
                                        What else can I try to fix this? Could it be interference between wifi chip and nrf24? Or, maybe, this is software problem? Maybe non-interrupt driven polling of nrf24l01 causes loosing messages coming too often?
                                          @robosensor
                                          Interesting graph... But I have no immediate answer to you.
