  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 408.1k Views 39 Watching
  • YveauxY Yveaux
    @D_dude flush the serial output after each print.
    The ESP will output the serial data in the background while your programm continues and then it crashes.
    YhtY
    YhtY
    Yht
    I'm getting all the time this:
    ESP8266 MySensors Gateway
    Connecting to layla
    ......Connected!
    IP: 192.168.0.102
    Then it got stuck so I do reset and getting this in loop:
    Connecting to layla
    ..Connected!
    IP: 192.168.0.102
    0;0;3;0;9;radio init fail
    Soft WDT reset
    ctx: cont
    sp: 3ffefe70 end: 3fff00a0 offset: 01b0
    stack>>>
    3fff0020: 00000000 00000000 3ffeed74 40203665
    3fff0030: 0000007f 3ffef074 40205ba0 3ffef080
    3fff0040: 40202114 00000001 00000000 40205c10
    3fff0050: 6600a8c0 00ffffff 0100a8c0 3ffef074
    3fff0060: 3ffe84ac 3ffeee8c 3ffeefb0 4020256b
    3fff0070: 3ffe86b8 6600a8c0 00000000 00000000
    3fff0080: 3fffdc20 00000000 3ffef06d 40205bde
    3fff0090: 00000000 00000000 3ffef080 40100114
    <<<stack<<<
    ets Jan 8 2013,rst cause:2, boot mode:(3,6)
    tail 0
    chksum 0x42
    csum 0x42
    ~ld
    • YhtY Yht
      Connecting to layla
      ......Connected!
      IP: 192.168.0.102
      Connecting to layla
      ..Connected!
      IP: 192.168.0.102
      Soft WDT reset
      ctx: cont
      stack>>>
      <<<stack<<<
      tail 0
      chksum 0x42
      csum 0x42
      ~ld
      #197
      @Yht 0;0;3;0;9;radio init fail
      Means there's something wrong with your nRF communication. The WDT reset following this is normal.
      • C
        C
        ciprian
        i have been using wifi gateway with Domoticz controller without any problems until recentely. After the last update to beta version of the controller, the gateway crashes when the controller request gateway version:
        Gateway startup complete.
        Client 0: 0;0;3;0;2;
        Exception (28):
        epc1=0x4000bf80 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
        ctx: cont
        sp: 3ffebf60 end: 3ffec1f0 offset: 01a0
        I have tested with telnet client with the same request and it was ok. Then I saw that the request from controller was terminated with only <LF> and not with <CR><LF> and this is why it crashed. I have added the following to the sketch:
        •    if (inChar == '\n')
              if (inputString[i].string[inputString[i].idx-1] != '\r') { // if the last char is not CR then add it
              inputString[i].string[inputString[i].idx++]='\r';
              // a command was issued by the client
              // we will now try to send it to the actuator
        and now it seems to work.
        Is this the right way to go?
          @ciprian
          Are you talking abut this line of code?
          https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyGatewayTransportEthernet.cpp#L194
          C 1 Reply Last reply
            @ciprian
            C
            C
            ciprian
            @hek My code is from GatewayESP8266.ino example in Mysensors 1.5, line 234.
              Ok! Mis-read this line---
              After the last update to beta version....
              Thought you were talking about the development branch. Sorry.
              • YhtY
                YhtY
                Yht
                Hi all,
                First, I have to say this is awsome what @Yveaux did, thank you!
                Sorry if this question takes you back in time. I don't know what channel and id to use for the nodes,I tried channel 97 and id from 1-5 but it is not working..
                are you using mesh lib?
                • YhtY Yht
                  Hi all,
                  Just leave the default channel untouched for both sensors and gateway. It should be fine.
                  The gateway will automatically be assigned ID 0, the nodes can have any fixed ID.
                  Dynamic ID assignment requires some extra software, as the gateway does not support it.
                  • G
                    G
                    georgep56
                    I'm also seeing my ESP8266 gateway crash when the controller requests its version.
                    I had not seen this thread so I started a new topic here: http://forum.mysensors.org/topic/2493/esp8266-wifi-gateway-crashes-and-reboots-when-controller-connects
                      hi,
                      maybe you have already seen it...but you can get cheap and smaller nodemcu. crazy price! I have ordered some, and waiting for them...
                      http://fr.aliexpress.com/item/D1-mini-Mini-NodeMcu-4M-bytes-Lua-WIFI-Internet-of-Things-development-board-based-ESP8266/32529101036.html?spm=2114.06010108.3.1.04LsjX&ws_ab_test=searchweb201556_2_79_78_77_80,searchweb201644_0,searchweb201560_9
                      • scalzS scalz
                        hi,
                        @scalz Nice! Thanks for the link!
                        • D
                          drock1985
                          Just wanted to chime in and say thank you for this gateway script @Yveaux
                          I originally had an ethernet gateway for the longest time. But when I changed over to an OnHub router, it stopped working because it doesn't like to handle static IP, and the current branch sketch is too large to enable DHCP. This worked wonderfully with the OnHub out of the box (ver 7390.62.2) and shows up with a hostname of ESP_DA7D8B.
                          Thanks again!
                          My Projects
                          2 Door Chime Sensor
                          Washing Machine Monitor
                            mbj
                            When testing the ESP8266MQTTClient (downloaded latest version of the library today) and compiled with the NodeMCU 1.0 ...... option I get an odd result. The message at startup is (please disregard the "Radio init fail" - the radio was not yet connected. I just wanted to check the WiFi ):
                            2dO,4`lLMØl 8ðÿ0;0;3;0;9;Starting gateway (RNNGE-, 1.6.0-beta)
                            0;0;3;0;9;Radio init failed. Check wiring.
                            scandone
                            state: 0 -> 2 (b0)
                            state: 2 -> 3 (0)
                            state: 3 -> 5 (10)
                            add 0
                            aid 2
                            pm open phy_2,type:2 0 0
                            cnt
                            connected with XXXyyy, channel 1
                            dhcp client start...
                            ip:192.168.1.167,mask:255.255.255.0,gw:192.168.1.1
                            I can see from the router that the connection to 192.168.1.167 is successful but the oddity is that I have set the gateway to use a static address and also connect to a SSID which is not XXXyyy. The defines are:
                            #define MY_IP_ADDRESS 192,168,1,22
                            So the ESP8266 uses dhcp when it should have a static address and connects to a SSID which is not given but may have been previously used at earlier tests.
                            I have looked at the code and tried a few changes to defines but none resulted in the override of dhcp.
                            Anyone have a clue?
                            • B
                              B
                              bp_968
                              I have the exact hardware in this setup but can't even get to the point where the hardware is a problem! I'm having compile errors during verify that make no sense and that I can't seem to find in the forums using search:
                              In file included from Esp8266Gateway.ino:69:0:
                              C:\Users\xxxxx\Documents\Arduino\libraries\SPI/SPI.h:982:8: error: 'SPIClass' does not name a type
                              extern SPIClass SPI;
                              Any suggestions? I'm running windows 10 and Arduino 1.6.5 with the most current esp8266 board files through board manager.
                              Apparently me and anything arduino related are like oil and water, yet I keep buying the stuff.
                              B 1 Reply Last reply
                              • B bp_968
                                B
                                B
                                bp_968
                                I tried this on my laptop and it worked fine (the compile verify did anyway) so I'll be reinstalling the IDE and trying again and hopefully that resolves my issues!
                                • T
                                  tjay4x4
                                  Yesterday I have successfully installed the ESP8266 module and it works fine, but the Vera3 show something strange now.
                                  Has anyone experienced this?
                                  • T tjay4x4
                                    @tjay4x4 Seems like to be an issue again when going from 8-bit to 32-bit architecture.
                                    Can you connect the ESP to your PC and capture the serial output when connecting to your lights and controlling them?
                                    • YveauxY Yveaux
                                      tjay4x4
                                      wrote on last edited by tjay4x4
                                      #213
                                      @Yveaux Thank you for reply. Here is the serial monitor.When I put 100% light it shows Ok. But 70% and others, shows some digitals. But all working fine! :)
                                      Insert Code Here
                                      .................Connected!
                                      0;0;3;0;9;read: 1-8-0 s=0,c=1,t=0,pt=7,l=5,sg=0:33.1
                                      1;0;1;0;0;33.1
                                      0;0;3;0;9;read: 1-8-0 s=1,c=1,t=0,pt=7,l=5,sg=0:44.2
                                      1;1;1;0;0;44.2
                                      0;0;3;0;9;read: 1-8-0 s=2,c=1,t=0,pt=7,l=5,sg=0:32.2
                                      1;2;1;0;0;32.2
                                      0;0;3;0;9;read: 1-8-0 s=1,c=1,t=0,pt=7,l=5,sg=0:44.3
                                      1;1;1;0;0;44.3
                                      Client 0 connected
                                      Client 0 disconnected
                                      0;0;3;0;9;read: 9-8-0 s=4,c=1,t=0,pt=7,l=5,sg=0:27.0
                                      9;4;1;0;0;27.0
                                      0;0;3;0;9;read: 9-8-0 s=3,c=1,t=1,pt=7,l=5,sg=0:21.0
                                      9;3;1;0;1;21.0
                                      Client 0 connected
                                      Client 0: 0;0;3;0;2;Get Version
                                      0;0;3;0;2;1.5.1
                                      Client 0: 11;0;1;1;3;1090519100
                                      0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=10,sg=0,st=ok:1090519100
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=10,sg=0:1090519100
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:805306369
                                      11;0;1;0;2;805306369
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:805306428
                                      11;0;1;0;3;805306428
                                      Client 0: 11;0;1;1;3;0
                                      0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=1,sg=0,st=ok:0
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=1,sg=0:0
                                      11;0;1;1;3;0
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:805306368
                                      11;0;1;0;2;805306368
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:805306368
                                      11;0;1;0;3;805306368
                                      Client 0: 11;0;1;1;3;100
                                      0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=3,sg=0,st=ok:100
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=3,sg=0:100
                                      11;0;1;1;3;100
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:1
                                      11;0;1;0;2;1
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:100
                                      11;0;1;0;3;100
                                      Client 0: 11;0;1;1;3;80
                                      0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:80
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:80
                                      11;0;1;1;3;80
                                      11;0;1;0;2;1
                                      11;0;1;0;3;80
                                      0;0;3;0;9;read: 1-8-0 s=2,c=1,t=0,pt=7,l=5,sg=0:32.3
                                      1;2;1;0;0;32.3
                                      Client 0: 11;0;1;1;3;70
                                      0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:70
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:70
                                      11;0;1;1;3;70
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:1107296257
                                      11;0;1;0;2;1107296257
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:1107296326
                                      11;0;1;0;3;1107296326
                                      Client 0: 11;0;1;1;3;1107296326
                                      0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=10,sg=0,st=ok:1107296326
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=10,sg=0:1107296326
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:922746881
                                      11;0;1;0;2;922746881
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:922746950
                                      11;0;1;0;3;922746950
                                      0;0;3;0;9;read: 9-8-0 s=3,c=1,t=1,pt=7,l=5,sg=0:20.0
                                      9;3;1;0;1;20.0
                                      Client 0: 11;0;1;1;3;922746950
                                      0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=9,sg=0,st=ok:922746950
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=9,sg=0:922746950
                                      11;0;1;1;3;0
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:922746880
                                      11;0;1;0;2;922746880
                                      0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:922746880
                                      11;0;1;0;3;922746880
                                      11;0;1;1;3;100
                                      11;0;1;0;2;1
                                      11;0;1;0;3;100
                                      • YveauxY
                                        @tjay4x4 which version of MySensors are you running?
                                        T 2 Replies Last reply
                                        • YveauxY Yveaux
                                          tjay4x4
                                          @Yveaux I use https://github.com/mysensors/Arduino/archive/master.zip
                                          Just reupload library
                                          Some additionl information.
                                          100%-90%-80%70%-60%-50%- OK 40%-bug :)
                                          10%-20%-30%-40% -OK 50%-bug
                                          Connecting to 1111
                                          IP: 192.168.1.44
                                          9;3;1;0;1;20.0
                                          0;0;3;0;9;read: 1-8-0 s=1,c=1,t=0,pt=7,l=5,sg=0:44.5
                                          1;1;1;0;0;44.5
                                          Client 0 connected
                                          0;0;3;0;2;1.5.1
                                          11;0;1;1;3;0
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:536870912
                                          11;0;1;0;2;536870912
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:536870912
                                          11;0;1;0;3;536870912
                                          11;0;1;1;3;100
                                          11;0;1;0;2;1
                                          11;0;1;0;3;100
                                          11;0;1;1;3;80
                                          11;0;1;0;2;1
                                          11;0;1;0;3;80
                                          11;0;1;1;3;70
                                          11;0;1;0;2;1
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:70
                                          11;0;1;0;3;70
                                          Client 0: 11;0;1;1;3;60
                                          0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:60
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:60
                                          11;0;1;1;3;60
                                          11;0;1;0;2;1
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:60
                                          11;0;1;0;3;60
                                          0;0;3;0;9;read: 1-8-0 s=1,c=1,t=0,pt=7,l=5,sg=0:44.6
                                          1;1;1;0;0;44.6
                                          Client 0: 11;0;1;1;3;50
                                          0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:50
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:50
                                          11;0;1;1;3;50
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:1107296306
                                          11;0;1;0;3;1107296306
                                          0;0;3;0;9;read: 7-5-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.7
                                          7;0;1;0;0;30.7
                                          0;0;3;0;9;read: 3-2-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.2
                                          3;0;1;0;0;30.2
                                          0;0;3;0;9;read: 7-5-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.6
                                          7;0;1;0;0;30.6
                                          0;0;3;0;9;read: 3-2-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.1
                                          3;0;1;0;0;30.1
                                          1;1;1;0;0;44.5
                                          11;0;1;1;3;0
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:1107296256
                                          11;0;1;0;2;1107296256
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:1107296256
                                          11;0;1;0;3;1107296256
                                          11;0;1;1;3;100
                                          11;0;1;0;2;1
                                          11;0;1;0;3;100
                                          11;0;1;1;3;0
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2,sg=0:0
                                          11;0;1;0;2;0
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:0
                                          11;0;1;0;3;0
                                          0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:10
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:10
                                          11;0;1;1;3;10
                                          11;0;1;0;2;1
                                          11;0;1;0;3;10
                                          Client 0: 11;0;1;1;3;20
                                          0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:20
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:20
                                          11;0;1;1;3;20
                                          11;0;1;0;2;1
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:20
                                          11;0;1;0;3;20
                                          Client 0: 11;0;1;1;3;30
                                          0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:30
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:30
                                          11;0;1;1;3;30
                                          11;0;1;0;2;1
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:30
                                          11;0;1;0;3;30
                                          1;1;1;0;0;44.6
                                          Client 0: 11;0;1;1;3;40
                                          0;0;3;0;9;send: 0-0-11-11 s=0,c=1,t=3,pt=0,l=2,sg=0,st=ok:40
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=0,l=2,sg=0:40
                                          11;0;1;1;3;40
                                          0;0;3;0;9;read: 11-11-0 s=0,c=1,t=3,pt=2,l=2,sg=0:1107296296
                                          11;0;1;0;3;1107296296
                                          11;0;1;1;3;100
                                          11;0;1;0;2;1
                                          11;0;1;0;3;100
                                          11;0;1;1;3;0
                                          11;0;1;0;2;0
                                          11;0;1;0;3;0
                                          7;0;1;0;0;30.7
                                          1;1;1;0;0;44.5
                                          9;3;1;0;1;21.0
                                          3;0;1;0;0;30.2
                                          0;0;3;0;9;read: 1-8-0 s=0,c=1,t=0,pt=7,l=5,sg=0:33.4
                                          1;0;1;0;0;33.4
                                          9;3;1;0;1;20.0
                                          12.5k
