  3. SSMSG - Single file SQL MySensors Gateway
8 Posts 4 Posters 3.9k Views 1 Watching
  • DammeD
    DammeD
    Damme
    Code Contributor
    wrote on last edited by Damme
    This is what I've been working on, Exact purpose is still unknown, Probobly full of bugs and lacks functionallity.
    https://github.com/Damme/SSMSG
    start with no parameters and it will be running in background.
    • Requires version 1.4b
    YveauxY 1 Reply Last reply
    • DammeD Damme
      YveauxY
      YveauxY
      So leave it to us to figure out ;-)
      I think you want to create some middleware to send to/receive from sensor nodes without using Vera, right?
      DammeD 1 Reply Last reply
      • YveauxY Yveaux
        DammeD
        DammeD
        Damme
        Code Contributor
        @Yveaux :) correct, I use a small php page for controlling some lights and stuff and a cron script that reads light value and calculate if it should turn on / off lights.
        the small scripts dont need any access to the usb device, only a DB connection.
        YveauxY ch3b7C 2 Replies Last reply
        • DammeD Damme
          YveauxY
          YveauxY
          @Damme You might be interested in my post at http://forum.mysensors.org/topic/175/open-source-home-automation-software/19
          I experimented with MySensors and MQTT, a publish/subscribe messaging system.
          It also acts as a database, but you don't have to actively request sensor data as you can subscribe to them from e.g. the sensor nodes or a logging task. Once subscribed you simply get the data pushed when an update arrives!
            Nice. Looking forward to see where it leads!
            • DammeD Damme
              ch3b7C
              ch3b7C
              ch3b7
              @Damme How the gateway recieve data and send to other sensor ? like "255;255;3;0;4;2\n" because if i send directly from arduino program work, but with other program connected to serial port not work.
              • ch3b7C ch3b7
                DammeD
                DammeD
                Damme
                Code Contributor
                @ch3b7 Uhm, Might misunderstood you. You'll have to configure the serial port correctly and then send \n , if using echo you need to use echo -e -n "1;1;1;1;1;1\n"
                • ch3b7C
                  ch3b7C
                  ch3b7
                  @Damme said:
                  1;1;1;1;1;1\n
                  sorry im from argentina and my english is very bad xD the problem is... i can send "255;255;3;0;4;2\n" from vb.net programm to arduino gateway in COM port and then the gateway send the same command to the sensor to change de ID
                  vb.net --> arduino gw ---> sensor
                  but i think the gw dont read the incoming data
                  at now im use your script and work fine
