  3. Over the air (OTA) bootloading update tutorial?
97 Posts 19 Posters 72.8k Views 22 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    @tekka, please add OTA Serial monitor into the Santa Klaus list ;-)
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    • AnticimexA Anticimex
      @tekka that sounds good. For signing, exactly how are you planning to solve that?
      tekkaT
      tekkaT
      tekka
      @Anticimex I'm testing different scenarios, one using a signed checksum to initiate the OTA - this would be compatible with the current framework. The challenges are obviously size limitations and the lack of a RNG...
      • tekkaT tekka
        AnticimexA
        AnticimexA
        Anticimex
        @tekka yes if you plan to have a signer/verifier implemented in the bootloader size will definitely a challenge. About rng, yes well there is the arduino pseudo rng in SW. The atsha204 provide one in hw.
        • tekkaT tekka
          AnticimexA
          AnticimexA
          Anticimex
          @tekka a signed initiation I believe would come for free unless the initiation message is explicitly ignored when deciding to sign a message in the library. It is if/when the bootloader has to do signing or verification things get tricky. A signed initiation could be hacked though. An attacker could detect am initiated OTA transfer (target reboots in bootloader/OTA mode) and then (if the bootloader is unable to process signed messages) anyone could feed anything to it. If the bootloader could verify messages though, there would be no issue of course. The payload could be sent unsigned (for efficiency) and last a checksum is sent signed (which is validated both for signature and checksum on received payload) before bootloader marks flashed software as valid.
          tekkaT 1 Reply Last reply
            tekkaT
            tekkaT
            tekka
            @Anticimex the bootloader will only go to update mode if the initiation msg is signed and valid. The initiation msg is nothing but a signed crc+type+version fw_config message. This message is validated against the current fw crc and the type/version settings stored in the eeprom. If the message is invalid, the bootloader will proceed with the normal startup procedure (=validate fw crc against eeprom settings and start if ok).
            Now, an attacker could indeed interfere with unsigned fw payload blocks - but at the end, the crc from the newly transmitted fw will not match, and thus, the eeprom settings are not updated. At this point you are left with a non-functional node and a bootloader which requests a new (valid) fw.
            AnticimexA 1 Reply Last reply
            • tekkaT tekka
              AnticimexA
              AnticimexA
              Anticimex
              @tekka that sounds good. But this initiation message, it is sent during "normal" MySensors operation, right? If so, then you won't need to dabble with signing support in the bootloader. If the initiation message contain a crc of the "pending" FW, and this crc is protected by signature, the node will fully validate it, identify it as a OTA startup, store the crc in eeprom and reboot into FW upgrade mode. The bootloader just does it normal thing, receiving the new FW, and matching the calculated FW crc against the eeprom crc and reject the image if crc does not match. That's perfectly adequate for signed OTA.
              • AnticimexA
                AnticimexA
                Anticimex
                I should add that this signing goes right under the "normal" signing configuration. The receiving node has to be configured to require signed messages (and be able to process them) , and the GW has to be able to calculate signatures.
                • A
                  A
                  alfredocdmiranda
                  Hey guys,
                  So, I am new to MySensors community and I am very interested in OTA. I've read this thread and I am wondering if there is some tutorial teaching how we can transfer from controller/gateway to the nodes the sketch.
                  • NeverDieN
                    NeverDieN
                    This post is deleted!
                    • OitzuO
                      OitzuO
                      Oitzu
                      @KaaIoT What is the webinar exactly about? I spend the last 2-3 evenings rebuilding the OTA functionallity in a custom controller and compiling the bootloader for my 8mhz 3.3v nodes.
                      Maybe i can learn something to improve it?
                      NeverDieN 1 Reply Last reply
                      • A
                        A
                        alfredocdmiranda
                        @Oitzu could you share how you are building the messages and other things to send the new hex?
                        • OitzuO
                          OitzuO
                          Oitzu
                          As examples i recommend the nodejs controller: https://github.com/mysensors/Arduino/blob/development/NodeJsController/NodeJsController.js
                          Also the bootloader source:
                          https://github.com/mysensors/Arduino/tree/master/Bootloader
                          • OitzuO Oitzu
                            NeverDieN
                            NeverDieN
                            #33
                            I think maybe it was spam or something. The post is gone.
                            hekH 1 Reply Last reply
                            • NeverDieN NeverDie
                              Yes, it was classified as spam by the moderators.
                              • petewillP
                                petewillP
                                petewill
                                I am starting to play with OTA updates and I'm interested in testing the DualOptiBoot method. I have been searching the forum but I haven't been able to find a recommendation for what external flash memory to get. Does anyone have any suggestions? An eBay link would be fantastic if possible.
                                • AnticimexA
                                  AnticimexA
                                  Anticimex
                                  I have a mouser link to a memory that should work: http://eu.mouser.com/Search/m_ProductDetail.aspx?R=AT25DF512C-SSHN-Bvirtualkey58070000virtualkey988-AT25DF512CSSHN-B
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    #37
                                    @petewill
                                    please note that these external flashes are typically only rated for 3.3V.. (I can't remember if I have seen a 5V external flash actually).
                                    • petewillP
                                      petewillP
                                      petewill
                                      @Anticimex Thanks! Maybe I'll just order from Mouser or Digi-Key. I need to get the ATSHA204A also and I can't find much on eBay.
                                      @tbowmo Good to know, thanks! I'm sure I'll have more questions on wiring when I finally get to that point... :)
                                        Does a signed crc really provide sufficient security? Modifying a firmware in a way that results in the same crc should be fairly easy, since crc is very predictable.
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @mfalkvidd if so, the choice of crc algorithm is bad. And a hash should be used instead.
